My team is having problems with the robot loosing communication when connected through the wifi router. It runs fine when connect by USB. We have imaged the router and the roborio. We are using the stock project with no changes.
Has anyone else seen this problem. If so how did you fix it
thanks you very much for your fast responses. We just solved the issue. It seems like the computer we were using just need to be restarted and it worked fine. Not sure what went wrong but this seems to have fixed the problem
Other people on the forums have reported connection issues with an Autodesk updater running on their system. If you have Autodesk installed, you may want to look into that.
i just did some testing and it looks like that was the problem. When it was on i would lose packets every 10 seconds. When i turned it off the problem was fixed
