I am having issues deploying our code from labview to the drivers station via wifi. When we use the usb, the code deploys no problem. I get this message when I try.
You can find some troubleshooting steps here: LabVIEW for FRC Shows Connection Failed to My roboRIO
Most importantly, I would ensure you have the correct IP address/hostname in your project:
172.22.11.2 is exclusive for USB. You will need the .local address for it to work in different networks (WiFi, Ethernet).
You da man Oscar. We fixed it. Thank you.
What is this and where can I find it in labview?
