Robot shooting to set position on initialization (Not supposed to happen)
Hey, this is Mohamed from Team 5142. I have successfully implemented a ProfiledPIDController on my robot’s Arm Swivel, Telescope, and Elevator. However, as soon as I press enable for teleoperated mode, the robot shoots (And I mean shoots, the speed is crazy, it almost broke the arm) to the set position. I have to figure out how to slow it down as well as disable the autofiring on initialization (We want the set positions to correspond to buttons on a joystick, which I have written, but it doesn’t do so). All code pertaining to the problem is noted below; any help would be wholly appreciated.
The instantCommand that uses all three subsystems
public class GrabGround extends InstantCommand {
  private final Swivel swivel;
  private final Telescope telescope;
  private final Elevator elevator;
  private final double swivTargetPosition;
  private final double teleTargetPosition;
  private final double elevTargetPosition;
  public GrabGround(Swivel swivel, double swivTargetPosition, Telescope telescope, double teleTargetPosition, Elevator elevator, double elevTargetPosition) {
      this.swivel = swivel;
      this.swivTargetPosition = swivTargetPosition;
      this.telescope = telescope;
      this.teleTargetPosition = teleTargetPosition;
      this.elevator = elevator;
      this.elevTargetPosition = elevTargetPosition;
      addRequirements(swivel);
      addRequirements(telescope);
      addRequirements(elevator);
  @Override
  public void initialize() {
      swivel.setTargetPosition(swivTargetPosition);
      telescope.setTargetPosition(teleTargetPosition);
      elevator.setTargetPosition(elevTargetPosition);
The ArmSwivel Subsystem
public class Swivel extends SubsystemBase {
  /** Creates a new Swivel. */
  // All reference angles (For placement/collection)
  private double groundSwivelAngle = 30; // Swivel angle for ground collection
  private double singleSubSwivelAngle = 180; // Swivel angle for single substation collection
  private double straightSwivelAngle = 90; // Swivel angle for double substation collection
  // The TalonSRX motor controller that controls the swivel motion.
  private final CANSparkMax m_swivel;
  private final RelativeEncoder m_encoder;
  private final ProfiledPIDController m_controller;
  // Target position for the motor
  public double m_targetPosition;
  private static final double kP = 0.1;
  private static final double kI = 0;
  private static final double kD = 0;
  private static final double kMaxVelocity = (.01);
  private static final double kMaxAcceleration = (.01);
  public Swivel() {
    m_swivel = new CANSparkMax(7, MotorType.kBrushless); // Swivel Motor CAN ID
    m_encoder = m_swivel.getEncoder();
    m_swivel.setIdleMode(IdleMode.kBrake); // Initialize the motor as braked
    m_controller = new ProfiledPIDController(kP, kI, kD,
      new TrapezoidProfile.Constraints(kMaxVelocity, kMaxAcceleration)); // Profiled PID Control (Requires more testing)
  public void swivelUp() {
    m_swivel.set(0.2); // Sets motor speed to +20%
  public void swivelDown() {
    m_swivel.set(-0.2); // Sets motor speed to -40%
  public void stop() {
    m_swivel.set(0); // Sets motor speed to 0
  public void swivelUpPower(double power) {
    m_swivel.set(power); // Sets a constant holding power (To resist gravity)
  // Set the output of the NEO motor using the output of the ProfiledPIDController
  public void setOutput(double output) {
    m_swivel.set(output);
   // Get the current position of the NEO motor using the built-in encoder
  public double getEncoder() {
    return m_encoder.getPosition();
  // Calculate the output of the ProfiledPIDController based on the current position
  public double calculate() {
    return m_controller.calculate(getEncoder());
  // Set a target position for the NEO motor using the ProfiledPIDController
  public void setTargetPosition(double swivTargetPosition) {
    m_controller.setGoal(swivTargetPosition);
  @Override
  public void periodic() {
    SmartDashboard.putNumber("SwivelEnc", getEncoder()); // For testing
    // This method will be called once per scheduler run
    setOutput(calculate());
The ArmTelescope SubSystem
public class Telescope extends SubsystemBase {
  /** Creates a new Telescope. */
  // All reference points (For placement/collection)
  private double shortTelescopeLength = 0; // Telescope length for short setpoint
  private double midTelescopeLength = 10; // Telescope length for mid setpoint
  private double longTelescopeLength = 20; // Telescope length for long setpoint
  // Declare class variables
  private final TalonSRX m_telescope; // TalonSRX motor controller for the telescope arm
  private final Encoder m_encoder; // Encoder for the RedLine motor
  private final ProfiledPIDController m_controller; // PID controller for position control
  public double m_targetPosition; // Target position for the motor
  double dist = 0.5 * 3.14 / 1024; // ft per pulse
  // Constants for PID and motion profiling
  public Telescope() {
    m_telescope = new TalonSRX(8); // Telescoping motor CAN ID
    TalonSRXConfiguration configuration = new TalonSRXConfiguration(); // Man idk what this does
    m_encoder = new Encoder(0, 1, false, Encoder.EncodingType.k4X);
    m_encoder.setDistancePerPulse(dist);
    m_telescope.setNeutralMode(NeutralMode.Brake); // Initialize the motor as braked
    m_telescope.configAllSettings(configuration); // Man idk what this does
    // Configure the ProfiledPIDController with PID constants and constraints
  public void TelescopeOut() {
    m_telescope.set(ControlMode.PercentOutput, 0.5); // Sets motor output to +50%
  public void TelescopeIn() {
    m_telescope.set(ControlMode.PercentOutput, -0.5); // Sets motor output to -50%
    m_telescope.set(ControlMode.Position, 0); // Sets motor output to 0
  // Set a target position for the Talon SRX motor using the ProfiledPIDController
  public void setTargetPosition(double teleTargetPosition) {
    m_controller.setGoal(teleTargetPosition);
  // Get the current position of the Talon SRX motor using the MagEncoder
  public double getCurrentPosition() {
  return m_telescope.getSelectedSensorPosition();
    return m_controller.calculate(getCurrentPosition());
  // Set the output of the Talon SRX motor using the output of the ProfiledPIDController
  m_telescope.set(ControlMode.PercentOutput, output);
  @Override
    SmartDashboard.putNumber("Telescope Encoder", m_encoder.get());
    // Update the motor output with the calculated output from the ProfiledPIDController
The Arm Elevator Subsystem
public class Elevator extends SubsystemBase {
  /** Creates a new Elevator. */
  private double lowElevPosition = 0; // Position for ground collect, single substation, and dump low
  private double midElevPosition = 50; // Position for Mid cone / cube
  private double highElevPosition = 100; // Position for High cone / cube, and double substation
  // Define the elevator motor, Profiled PID controller, and Limit Switch
  private CANVenom m_elevator;
  private ProfiledPIDController m_controller;
// private DigitalInput m_limit;
  // Constructor for the elevator subsystem
  public Elevator() {
    m_elevator = new CANVenom(4);
    m_elevator.setBrakeCoastMode(BrakeCoastMode.Brake);
    m_elevator.setControlMode(ControlMode.PositionControl);
  //  m_limit = new DigitalInput(1);
  public void ElevatorUp() {
    m_elevator.set(0.2); // Sets motor speed to +20%
  public void elevatorDown() {
    m_elevator.set(-0.2); // Sets motor speed to -40%
  // Method to stop the elevator
    m_elevator.set(0);
  public void elevatorUpPower(double ePower) {
    m_elevator.set(ePower); // Sets a constant holding power (To resist gravity)
  public void setSpeed(double speed) {
    m_elevator.set(speed);
    m_elevator.set(output);
    return m_elevator.getPosition();
  public void setTargetPosition(double elevTargetPosition) {
    m_controller.setGoal(elevTargetPosition);
  @Override
    SmartDashboard.putNumber("ElevatorEnc", getEncoder());
  //  SmartDashboard.putBoolean("ElevatorLimt", m_limit.get());
The RobotContainer
public class RobotContainer {
  private final Drivetrain m_drive = new Drivetrain();
 private final Elevator elevator = new Elevator();
  private final Swivel swivel = new Swivel();
  private final Telescope telescope = new Telescope();
  private final Claw m_claw = new Claw();
  private static Joystick driver = new Joystick(0);
  private static Joystick driver2 = new Joystick(1);
  public static Joystick operator = new Joystick(2);
  /** The container for the robot. Contains subsystems, OI devices, and commands. */
  public RobotContainer() {
    // Configure the trigger bindings
    configureBindings();
    m_drive.setDefaultCommand(
        new RunCommand(
            () -> m_drive.drive(driver.getRawAxis(1), driver.getRawAxis(0), driver2.getRawAxis(0)),
            m_drive));
  private void configureBindings() {
    // Driver Buttons
    final JoystickButton driverRightThumb = new JoystickButton(driver2, 2);
    // Operator Buttons
    final JoystickButton triggerButton = new JoystickButton(operator, 1); // Place Dump Low
    final JoystickButton thumbButton = new JoystickButton(operator, 2); // Toggle Claw
    final JoystickButton button3 = new JoystickButton(operator, 3); // Claw In
    final JoystickButton button4 = new JoystickButton(operator, 4); // Claw Out
    final JoystickButton button5 = new JoystickButton(operator, 5); // Grab Ground Position
    final JoystickButton button6 = new JoystickButton(operator, 6); // Home Position
    final JoystickButton button7 = new JoystickButton(operator, 7); // Place High Cone
    final JoystickButton button8 = new JoystickButton(operator, 8); // Place High Cube
    final JoystickButton button9 = new JoystickButton(operator, 9); // Place Mid Cone
    final JoystickButton button10 = new JoystickButton(operator, 10); // Place Mid Cube
    final JoystickButton button11 = new JoystickButton(operator, 11); // Single Substation Position
    final JoystickButton button12 = new JoystickButton(operator, 12); // Double Substation Position
    // final POVButton povPadUp = new POVButton(operator, 0); // Swivel Up
    // final POVButton povPadDown = new POVButton(operator, 180); // Swivel Down
    // final POVButton povPadRight = new POVButton(operator, 90); // Telescope Out
    // final POVButton povPadLeft = new POVButton(operator, 270); // Telescope In
    // Driver Command Bindings
    driverRightThumb.onTrue(new ToggleButterfly(m_drive));
    // Operator Command Bindings
    // triggerButton.onTrue
    thumbButton.onTrue(new ToggleClaw(m_claw));
    button3.whileTrue(new ClawIn(m_claw));
    button4.whileTrue(new ClawOut(m_claw));
    button5.onTrue(new GrabGround(swivel, 100, telescope, 100, elevator, 100));
    // button6.onTrue(new)
    // button7.onTrue(new)
    // button8.onTrue(new)
    // button9.onTrue(new)
    // button10.onTrue(new)
    // button11.onTrue(new GrabSubSingle(swivel, 100, telescope, 100, elevator, 100));
    // button12.onTrue(new GrabSubDouble(swivel, 100, telescope, 100, elevator, 100));
    // povPadRight.whileTrue(new TelescopeOut(m_tele));
    // povPadUp.whileTrue(new SwivelUp(m_swivel));
    // povPadDown.whileTrue(new SwivelDown(m_swivel));
    // povPadLeft.whileTrue(new TelescopeIn(m_tele));
  public Command getAutonomousCommand() {
    // An example command will be run in autonomous
    return new AutoDriveForward(m_drive);
Couple comments, but not necessarily a solution…
  1. Since youre setting output in periodic, your Up/Down/stop methods will never work right. They’ll get overwritten right away.
  2. Depending on units and gearing involved in the mechanism, a kP of 0.1 may be small (as you likely intended) or VERY large. It’s not uncommon to have kP set to numbers orders of magnitude smaller than that.
For your issue, I believe 2 is the cause. For an explanation why, lets talk through what kP represents. In a P controller (PID with I and D set to 0), your motor output will be directly proportional to your system error, essentially kP * (setpoint - currentEncoderPosition). You’re using encoder.getPosition(), which I believe will return a running count of ticks (unless you’ve scaled it somehow, such as with the SparkMax setPositionConversionFactor). You’re not setting a default setpoint for your controller, so lets assume 0 for now. The encoder may not give a clean signal, especially if it’s reading values upsteam of a reduction (i.e. motor->encoder->chain/belt reduction->mechanism) where slight perturbations will change its value. So lets say the encoder records a very slight change, 4 ticks. Putting those numbers into the calculation, we have an output of 0.1 * (4 - 0) or 0.4, nearly half power for the motor! If the erroneous reading from the encoder is even higher (which is quite likely), then you could saturate your output very easily by calculating a value above 1.0.
So my suggestion is to comment out the setOutput call in periodic and graph both the encoder position and the result of calculate(). This can help you find the right order of magnitude for kP. Then its just a matter of tuning it so it does exactly what you want. You’ll have to do this for each of the 3 subsystems.
For a bit more added reading, and depending on the actual mechanism design, you likely want at least one of those subsystems to use some kind of feed forward (i.e. ArmFeedForward to account for gravity) to make kP not have to do nearly as much work.
