Robot Signal Light
We can’t seem to figure out how to wire this. Can someone help? Please be specific with your directions and the materials that we will need. Thanks so much!
http://www.usfirst.org/community/frc/content.aspx?id=10934
Download the Power Distribution Diagram.
http://forums.usfirst.org/showthread.php?t=11829&highlight=robot+signal+light
Use 22AWG wire per the Q&A response.
Feel free to use whatever connector you’d like to plug into the 2 pin port on the Digital Sidecar.
Russ
Does the Signal light need to be a certain height or does it just need to be visible?..
The rule does not specify any specific height. Wiring it looks pretty simple from examining the power distribution drawing.
Just visible from 3’ in front of the robot in starting position. See <R58>.
