Robot Stops Drive Control Without Being Programmed
For some reason, while we are holding a specific button (button 2 on left drive joystick) the command for driving stops. The odd part about this is we don’t have that button programmed in. Additionally we have a command for auto balancing that only works when the button that isn’t programmed(button 2) and the programmed button (button 3 on left drive joystick) are held. Any assistance in this would be appreciated. Thank you for the help.
Could you post your code? It is hard to debug that which you cannot see…
If you are running the SmartDashboard, I recommend you put:
SmartDashboard.putData(Scheduler.getInstance());
somewhere in your code. That way, you can see what commands are running on the robot, and see if one is taking over when the button is held.
