It seems that the template for the command based robot spawns a subdirectory called triggers. Along with this when you use the new>other dialog there is a trigger option alongside the command and subsystem options. Has anyone played with this, and what is its use? I see no subcategory on my copy of the WPIlibs.
Its not exactly the same but you can check this thread, its talking about the new threads http://www.chiefdelphi.com/forums/showthread.php?t=132118
Thanks, the gist of it is that anything that isn’t involved with a Joystick event can be used with Triggers. If I understood the links properly.
