RobotPy 2013.1 Released
Peter hasn’t put an announcement here, so I figured I’d mention it. You can find the release at FirstForge here: http://firstforge.wpi.edu/sf/frs/do/listReleases/projects.robotpy/frs.robotpy
How does this differ from the github version of Robot.py here: https://github.com/robotpy/robotpy?
The directory structures don’t really line up, but most of the code that does is identical (except for linebreaks)?
The code on github is the source code for RobotPy, if you want to compile it yourself. The file on FirstForge is a zipfile that contains the built components after compilation, along with some utility files and such.
Basically, if you want to build it yourself and/or make changes, use github. If you just want to use RobotPy and install it quickly, use the precompiled binaries from FirstForge.
