We are attempting to deploy code to our robot with robotpy. Below is the error we have gotten. Thanks!
py -m robotpy
usage: __main__.py [-h] [--main MAIN_FILE] [-v] [--ignore-plugin-errors]
{add-tests,coverage,create-physics,deploy,deploy-info,init,installer,profiler,project,run,sim,sync,test,undeploy} ...
RobotPy CLI. See below for subcommands to accomplish various tasks for your robot project.
positional arguments:
subcommands
add-tests Adds default pyfrc tests to your robot project directory
coverage Wraps other commands by running them via the coverage module.
create-physics Create physics
deploy Installs requirements and uploads code to the robot and executes it immediately
deploy-info Displays information about code deployed to robot.
init Initializes a robot project
installer Manage RobotPy on your RoboRIO
profiler Wraps other commands by running them via the built in cProfile module.
project Manage your robot project
run Executes the robot code using the currently installed HAL (this is probably not what you want unless you're on the roboRIO)
sim Runs the robot using WPILib's GUI HAL Simulator
sync Downloads RoboRIO requirements and installs requirements locally
test Executes unit tests on the robot code using a special pytest plugin
undeploy Removes current Python robot code from a RoboRIO
options:
-h, --help show this help message and exit
--main MAIN_FILE The file that contains your main robot class
-v, --verbose Enable debug logging
Ignore errors caused by RobotPy plugins (probably should fix or replace instead!)
PS C:\BSHS_Robotics\Offseason-Python-2024> py -m robotpy deploy
16:34:00:187 INFO : deploy : Running tests: C:\Users\stolb\AppData\Local\Programs\Python\Python312\python.exe -m robotpy --main C:\BSHS_Robotics\Offseason-Python-2024\robot.py test
16:34:00:845 WARNING : pyfrc.physics : Cannot enable physics support, C:\BSHS_Robotics\Offseason-Python-2024\physics.py not found
=================================================================== test session starts ===================================================================
platform win32 -- Python 3.12.3, pytest-8.1.1, pluggy-1.4.0
rootdir: C:\BSHS_Robotics\Offseason-Python-2024
configfile: pyproject.toml
plugins: reraise-2.1.2
collected 1 item
pyfrc_test.py . [100%]
==================================================================== 1 passed in 0.05s ====================================================================
ERROR: large files found (larger than 250000 bytes)
- C:\BSHS_Robotics\Offseason-Python-2024\lib\python3.11\site-packages\_cffi_backend.cpython-311-x86_64-linux-gnu.so (1064368 bytes)
- C:\BSHS_Robotics\Offseason-Python-2024\lib\python3.11\site-packages\bcrypt\_bcrypt.abi3.so (641888 bytes)
- C:\BSHS_Robotics\Offseason-Python-2024\lib\python3.11\site-packages\cryptography\hazmat\bindings\_rust.abi3.so (10478000 bytes)
- C:\BSHS_Robotics\Offseason-Python-2024\lib\python3.11\site-packages\hal\_wpiHal.cpython-311-x86_64-linux-gnu.so (3019512 bytes)
- C:\BSHS_Robotics\Offseason-Python-2024\lib\python3.11\site-packages\hal\_wpiHal.pyi (263588 bytes)
- C:\BSHS_Robotics\Offseason-Python-2024\lib\python3.11\site-packages\hal\lib\libwpiHal.so (877624 bytes)
- C:\BSHS_Robotics\Offseason-Python-2024\lib\python3.11\site-packages\hal\simulation\_simulation.cpython-311-x86_64-linux-gnu.so (885568 bytes)
- C:\BSHS_Robotics\Offseason-Python-2024\lib\python3.11\site-packages\halsim_gui\lib\libhalsim_gui.so (13823640 bytes)
- C:\BSHS_Robotics\Offseason-Python-2024\lib\python3.11\site-packages\nacl\_sodium.abi3.so (2740136 bytes)
- C:\BSHS_Robotics\Offseason-Python-2024\lib\python3.11\site-packages\navx\_navx.cpython-311-x86_64-linux-gnu.so (567608 bytes)
- C:\BSHS_Robotics\Offseason-Python-2024\lib\python3.11\site-packages\ntcore\_ntcore.cpython-311-x86_64-linux-gnu.so (5548032 bytes)
- C:\BSHS_Robotics\Offseason-Python-2024\lib\python3.11\site-packages\ntcore\_ntcore\__init__.pyi (274119 bytes)
- C:\BSHS_Robotics\Offseason-Python-2024\lib\python3.11\site-packages\ntcore\lib\libntcore.so (1575936 bytes)
- C:\BSHS_Robotics\Offseason-Python-2024\lib\python3.11\site-packages\phoenix6\configs\config_groups.py (271703 bytes)
- C:\BSHS_Robotics\Offseason-Python-2024\lib\python3.11\site-packages\phoenix6\lib\libCTRE_PhoenixTools.so (3041224 bytes)
- C:\BSHS_Robotics\Offseason-Python-2024\lib\python3.11\site-packages\phoenix6\lib\libCTRE_PhoenixTools_Sim.so (2983688 bytes)
- C:\BSHS_Robotics\Offseason-Python-2024\lib\python3.11\site-packages\phoenix6\lib\libCTRE_SimProTalonFX.so (322792 bytes)
- C:\BSHS_Robotics\Offseason-Python-2024\lib\python3.11\site-packages\pip\_vendor\certifi\cacert.pem (279760 bytes)
- C:\BSHS_Robotics\Offseason-Python-2024\lib\python3.11\site-packages\rev\_rev.cpython-311-x86_64-linux-gnu.so (2672880 bytes)
- C:\BSHS_Robotics\Offseason-Python-2024\lib\python3.11\site-packages\robotpy_apriltag\_apriltag.cpython-311-x86_64-linux-gnu.so (817256 bytes)
- C:\BSHS_Robotics\Offseason-Python-2024\lib\python3.11\site-packages\robotpy_apriltag\lib\libapriltag.so (1823712 bytes)
- C:\BSHS_Robotics\Offseason-Python-2024\lib\python3.11\site-packages\setuptools\config\_validate_pyproject\fastjsonschema_validations.py (270934 bytes)
- C:\BSHS_Robotics\Offseason-Python-2024\lib\python3.11\site-packages\wpilib\_impl\lib\libwpilibc.so (1868912 bytes)
- C:\BSHS_Robotics\Offseason-Python-2024\lib\python3.11\site-packages\wpilib\_wpilib.cpython-311-x86_64-linux-gnu.so (8587744 bytes)
- C:\BSHS_Robotics\Offseason-Python-2024\lib\python3.11\site-packages\wpilib\_wpilib\__init__.pyi (483201 bytes)
- C:\BSHS_Robotics\Offseason-Python-2024\lib\python3.11\site-packages\wpilib\counter\_counter.cpython-311-x86_64-linux-gnu.so (495408 bytes)
- C:\BSHS_Robotics\Offseason-Python-2024\lib\python3.11\site-packages\wpilib\drive\_drive.cpython-311-x86_64-linux-gnu.so (568752 bytes)
- C:\BSHS_Robotics\Offseason-Python-2024\lib\python3.11\site-packages\wpilib\event\_event.cpython-311-x86_64-linux-gnu.so (364216 bytes)
- C:\BSHS_Robotics\Offseason-Python-2024\lib\python3.11\site-packages\wpilib\interfaces\_interfaces.cpython-311-x86_64-linux-gnu.so (662600 bytes)
- C:\BSHS_Robotics\Offseason-Python-2024\lib\python3.11\site-packages\wpilib\shuffleboard\_shuffleboard.cpython-311-x86_64-linux-gnu.so (2536232 bytes)
- C:\BSHS_Robotics\Offseason-Python-2024\lib\python3.11\site-packages\wpilib\simulation\_simulation.cpython-311-x86_64-linux-gnu.so (3753984 bytes)
- C:\BSHS_Robotics\Offseason-Python-2024\lib\python3.11\site-packages\wpimath\_controls\_controls.cpython-311-x86_64-linux-gnu.so (7866864 bytes)
- C:\BSHS_Robotics\Offseason-Python-2024\lib\python3.11\site-packages\wpimath\_impl\lib\libwpimath.so (2837856 bytes)
- C:\BSHS_Robotics\Offseason-Python-2024\lib\python3.11\site-packages\wpimath\filter\_filter.cpython-311-x86_64-linux-gnu.so (484528 bytes)
- C:\BSHS_Robotics\Offseason-Python-2024\lib\python3.11\site-packages\wpimath\geometry\_geometry.cpython-311-x86_64-linux-gnu.so (1426976 bytes)
- C:\BSHS_Robotics\Offseason-Python-2024\lib\python3.11\site-packages\wpimath\interpolation\_interpolation.cpython-311-x86_64-linux-gnu.so (638896 bytes)
- C:\BSHS_Robotics\Offseason-Python-2024\lib\python3.11\site-packages\wpimath\kinematics\_kinematics.cpython-311-x86_64-linux-gnu.so (2647832 bytes)
- C:\BSHS_Robotics\Offseason-Python-2024\lib\python3.11\site-packages\wpimath\spline\_spline.cpython-311-x86_64-linux-gnu.so (533792 bytes)
- C:\BSHS_Robotics\Offseason-Python-2024\lib\python3.11\site-packages\wpinet\lib\libwpinet.so (1262600 bytes)
- C:\BSHS_Robotics\Offseason-Python-2024\lib\python3.11\site-packages\wpiutil\_wpiutil.cpython-311-x86_64-linux-gnu.so (1820528 bytes)
- C:\BSHS_Robotics\Offseason-Python-2024\lib\python3.11\site-packages\wpiutil\include\google\protobuf\descriptor.pb.h (626521 bytes)
- C:\BSHS_Robotics\Offseason-Python-2024\lib\python3.11\site-packages\wpiutil\include\wpi\mpack.h (269374 bytes)
- C:\BSHS_Robotics\Offseason-Python-2024\lib\python3.11\site-packages\wpiutil\lib\libwpiutil.so (4308360 bytes)
Upload anyways? [y/n]n
16:34:06:093 INFO : deploy : Running tests: C:\Users\stolb\AppData\Local\Programs\Python\Python312\python.exe -m robotpy --main C:\BSHS_Robotics\Offseason-Python-2024\robot.py test
16:34:06:714 WARNING : pyfrc.physics : Cannot enable physics support, C:\BSHS_Robotics\Offseason-Python-2024\physics.py not found
collected 1 item
==================================================================== 1 passed in 0.04s ====================================================================
Upload anyways? [y/n]y
16:34:08:017 INFO : deploy : Robot project requirements:
16:34:08:018 INFO : deploy : - robotpy[apriltag,commands2,navx,pathplannerlib,phoenix6,photonvision,rev]==2024.3.2.2
16:34:08:115 INFO : robotpy.installer : Settings loaded from C:\BSHS_Robotics\Offseason-Python-2024\.wpilib\wpilib_preferences.json
16:34:08:116 INFO : robotpy.installer : Finding robot for team 9445
ERROR: Could not find team 9445 robot
16:34:49:622 INFO : deploy : Running tests: C:\Users\stolb\AppData\Local\Programs\Python\Python312\python.exe -m robotpy --main C:\BSHS_Robotics\Offseason-Python-2024\robot.py test
16:34:50:254 WARNING : pyfrc.physics : Cannot enable physics support, C:\BSHS_Robotics\Offseason-Python-2024\physics.py not found
collected 1 item
16:34:51:786 INFO : deploy : Robot project requirements:
16:34:51:787 INFO : deploy : - robotpy[apriltag,commands2,navx,pathplannerlib,phoenix6,photonvision,rev]==2024.3.2.2
16:34:51:861 INFO : robotpy.installer : Settings loaded from C:\BSHS_Robotics\Offseason-Python-2024\.wpilib\wpilib_preferences.json
16:34:51:861 INFO : robotpy.installer : Finding robot for team 9445
16:34:51:867 INFO : robotpy.installer : -> Robot is at 10.94.45.2
16:34:51:868 INFO : robotpy.installer : Connecting to robot via SSH at 10.94.45.2
16:34:51:980 INFO : paramiko.transport : Connected (version 2.0, client OpenSSH_8.3)
16:34:52:106 INFO : paramiko.transport : Auth banner: b'NI Linux Real-Time (run mode)\n\nLog in with your NI-Auth credentials.\n\n'
16:34:52:107 INFO : paramiko.transport : Authentication (password) successful!
16:34:52:107 INFO : robotpy.installer : RobotPy Installer 2024.2.2
16:34:52:107 INFO : robotpy.installer : -> caching files at C:\Users\stolb\wpilib\2024\robotpy
16:34:52:196 INFO : robotpy.installer : Clearing FRC C++/Java user programs if present
Traceback (most recent call last):
File "<frozen runpy>", line 198, in _run_module_as_main
File "<frozen runpy>", line 88, in _run_code
File "C:\Users\stolb\AppData\Local\Programs\Python\Python312\Lib\site-packages\robotpy\__main__.py", line 4, in <module>
main()
File "C:\Users\stolb\AppData\Local\Programs\Python\Python312\Lib\site-packages\robotpy\main.py", line 314, in main
retval = subcommand.run(**kwargs)
File "C:\Users\stolb\AppData\Local\Programs\Python\Python312\Lib\site-packages\robotpy_installer\utils.py", line 188, in wrapper
return func(*args, **kwargs)
File "C:\Users\stolb\AppData\Local\Programs\Python\Python312\Lib\site-packages\robotpy_installer\cli_deploy.py", line 249, in run
self._ensure_requirements(
File "C:\Users\stolb\AppData\Local\Programs\Python\Python312\Lib\site-packages\robotpy_installer\cli_deploy.py", line 390, in _ensure_requirements
pkgdata = self._get_robot_packages(ssh)
File "C:\Users\stolb\AppData\Local\Programs\Python\Python312\Lib\site-packages\robotpy_installer\cli_deploy.py", line 349, in _get_robot_packages
self._robot_packages = pypackages.make_packages(rio_packages)
File "C:\Users\stolb\AppData\Local\Programs\Python\Python312\Lib\site-packages\robotpy_installer\pypackages.py", line 198, in make_packages
else [Version(v) for v in version]
TypeError: 'NoneType' object is not iterable
