In python, the use of an InterruptableSensorBase inherited by a class containing a limit switch raises a " Not Implemented" error. Is there any equivalent to use of InterruptableSensorBase (which should be spelled Interruptible) that would run a command when the limit switch is hit/interrupted?
If you are subclassing InterruptableSensorBase
, you must also implement getAnalogTriggerTypeForRouting()
and getPortHandleForRouting()
(similarly to Java).
Just glancing at the source code for those functions, it seems they are also Not Implemented. https://robotpy.readthedocs.io/projects/wpilib/en/stable/_modules/wpilib/interruptablesensorbase.html#InterruptableSensorBase.getAnalogTriggerTypeForRouting
