RobotPy REV 2020.1.1 update
ICYMI, we pushed out an update to the RobotPy SPARK MAX library earlier today which updates to REV’s version 1.5.2 of the SPARK MAX library.
If you were having issues running your robot code using CANSparkMax in simulation, or if you encountered the crash with a SPARK MAX disconnected from your CAN bus, this update will most likely fix your issues.
Happy coding!
