I was playing around with the simulator today (not the websim), and using the default robot.py project (the one in the docs), it seemed like no matter what I put the speed value to in the arcade drive, the robot went backwards off the SIM screen. The encoders were negative as well.
Any idea what I am doing wrong?
Thanks.
~Mr. R.^2
P.S. Thank you all for adding in the elements for this year’s game.
It is this one. I am working in auto as I have not yet installed pygame on the team’s programming machine yet.
!/usr/bin/env python3
This is a good foundation to build your robot code on
import wpilib
import wpilib.drive
class MyRobot(wpilib.TimedRobot):
def robotInit(self):
This function is called upon program startup and
should be used for any initialization code.
self.left_motor = wpilib.Spark(0)
self.right_motor = wpilib.Spark(1)
self.drive = wpilib.drive.DifferentialDrive(self.left_motor, self.right_motor)
self.stick = wpilib.Joystick(1)
self.timer = wpilib.Timer()
def autonomousInit(self):
"""This function is run once each time the robot enters autonomous mode."""
self.timer.reset()
self.timer.start()
def autonomousPeriodic(self):
"""This function is called periodically during autonomous."""
# Drive for two seconds
if self.timer.get() < 2.0:
self.drive.arcadeDrive(-0.5, 0) # Drive forwards at half speed
else:
self.drive.arcadeDrive(0, 0) # Stop robot
def teleopPeriodic(self):
"""This function is called periodically during operator control."""
self.drive.arcadeDrive(self.stick.getY(), self.stick.getX())
if __name__ == "__main__":
wpilib.run(MyRobot)
This seems to match the getting-started example, which doesn’t have a physics implementation associated with it. That means your physics.py is doing something wrong. Can you post your physics.py also – or maybe you might consider starting with one of the existing physics examples?
Created on Sep 16, 2018
@author: Leko
# See the documentation for more details on how this works
# The idea here is you provide a simulation object that overrides specific
# pieces of WPILib, and modifies motors/sensors accordingly depending on the
# state of the simulation. An example of this would be measuring a motor
# moving for a set period of time, and then changing a limit switch to turn
# on after that period of time. This can help you do more complex simulations
# of your robot code without too much extra effort.
import math
from pyfrc.physics import motor_cfgs, tankmodel
from pyfrc.physics.units import units
class PhysicsEngine(object):
Simulates a motor moving something that strikes two limit switches,
one on each end of the track. Obviously, this is not particularly
realistic, but it's good enough to illustrate the point
def __init__(self, physics_controller):
:param physics_controller: `pyfrc.physics.core.PhysicsInterface` object
to communicate simulation effects to
self.physics_controller = physics_controller
self.position = 0
# Change these parameters to fit your robot!
bumper_width = 3.25*units.inch
self.drivetrain = tankmodel.TankModel.theory(
motor_cfgs.MOTOR_CFG_CIM, # motor configuration
110*units.lbs, # robot mass
10.71, # drivetrain gear ratio
2, # motors per side
22*units.inch, # robot wheelbase
23*units.inch + bumper_width*2, # robot width
32*units.inch + bumper_width*2, # robot length
6*units.inch # wheel diameter
# Precompute the encoder constant
# -> encoder counts per revolution / wheel circumference
self.kEncoder = 360 / (0.5 * math.pi)
self.l_distance = 0
self.r_distance = 0
def update_sim(self, hal_data, now, tm_diff):
Called when the simulation parameters for the program need to be
updated.
:param now: The current time as a float
:param tm_diff: The amount of time that has passed since the last
time that this function was called
# Simulate the drivetrain
l_motor = hal_data['pwm'][1]['value']
r_motor = hal_data['pwm'][2]['value']
x, y, angle = self.drivetrain.get_distance(l_motor, r_motor, tm_diff)
self.physics_controller.distance_drive(x, y, angle)
# Update encoders
self.l_distance += self.drivetrain.l_velocity * tm_diff
self.r_distance += self.drivetrain.r_velocity * tm_diff
hal_data['encoder'][0]['count'] = int(self.l_distance * self.kEncoder)
hal_data['encoder'][1]['count'] = int(self.r_distance * self.kEncoder)
I’m not sure if this is the best place to post this, but has there been any work done, or any desire, to have a more powerful physics engine integrated into the robotpy simulator? I was thinking of working on this integration (box2D seems to be the one coming up the most often), but I don’t want to work on something that would not have much value for the robotpy community even right out of the gate.
Hey @warren.parsons, sounds like the sort of thing that would be appropriate in a new thread.
However, the idea of enhanced physics has definitely come up in the past, and we’ve done some work towards improving them over the years. I think the primary problem is just someone needs to do the work of (a) identifying a suitable engine and (b) actually doing the work.
@AmoryG has done some work with robotpy-websim, and has integrated Matter.js (a 2D rigid body physics engine) with it. Eventually I’d like for the websim to be our default so that it would be easier to build C++/Java backends for it, but I haven’t really taken the time to play with that yet. I’d encourage you to take a look and see if that meets your needs.
I am sorry for resurrecting an old post, but it seemed most relevant.
I can’t seem to find much documentation for the hal_data structure in the simulator. Specifically how would you access motor/controller values for a CAN motor; would you just swap ‘can’ for ‘pwm’ in the hal_data data structure access?
I would like to read more about this part of the simulator. Could someone point me to the best document describing it?
