You most likely have CAN bus numbering error(Switched CAN wires, or a wrong CAN number) / or a non-compiled vendordep file and it is not allocated into the build.gradle file
The WPI Library keeps track of which “resources” (in this case, a PWM Channel) have already been allocated by your software. So if, say, you allocate PWM Channel 1, and then try to allocate PWM Channel 1 again, at that moment an Exception will be generated.
So it’s recommended to review the PWM channel usage in your code to find the “overlap”.
Thanks everyone, it was a problem with the auton shooter code we made. We commented it out and it worked. I have another question though: when we made the auton for the drive train, we had to require the drive subsystem. We wrote our shooter code all in robot.java, so is there no way for us to require it and create auton for it?
If you’re using the new command-based framework, you really shouldn’t have to make any changes to Robot.java. If using the old framework, you shouldn’t need much in Robot.java
Can you share your code? It would help us identify issues.
