has anyone though of using blower type fans to make the robot float? I don’t know if this violates any rules but it is still a creative idea. I was looking at a magazine we kids can make there own “floating cars” and it is just a blower fan system or vacume on reverse. like I said I don’t know if it is against the rules but if anyone considers it… Ask FIRST
Our build team threw the idea out so I haven’t researched if the rules would allow it. It would make things interesting by blowing the float rings everywhere!
We played with the idea of building a hoverbot but non of the mentors would hear of it. If the skirt is designed right, a vaccuum cleaner motor is sufficient for lifting a 100+lb bot. You still need a drive fan though.
1 there is alot of contact on a first field, the odds of the skirt getting torn of folded up so it forms a poor seal with the floor are pretty high.
Also a hover bot would just be pushed around the field, it would be like an air hockey puck.
For any one who was looking at this strategy to score points at the end of the match, keep in mind that power is shut off and the robot wont be able to keep hovering.
The only way to have 3 robots off the ground for your alliance would be to force an opponent to stay in your home zone, and everyone piles on top of it. No point in thinking about making a hovercraft for this game. Hovercrafts in general are cool!
Theoretically, you could lift up your two alliance partners while being supported in the air by pool tubes. That seems to be the only legal way to have all 3 robots off the carpet.
Section 7.3.6, Rule <G56> -
“ROBOTS score bonus points at the end of the match if they are entirely in their HOME ZONE, not in contact with any element of the field (carpet, alliance station, goal, etc. - note that for the purposes of this rule, GAME PIECES are considered field elements) and the lowest point of the ROBOT is higher than 4 inches and/or 12 inches above the carpeted field surface.”
P.S.
Remember to drop any tube you are holding before climbing a friendly nearby ramp.
Your robot cuts off at the end of the match. This would be impossibel to keep it off the ground without any power…( well…if you could use your mind to keep it up i guess you could use brain power )
These are the same people that say having a monkey for a pet is a bad idea.
I think in the future, both ideas will have their place in the world of FIRST.
