Romi pose angle decreasing rapidly at rest (100x gyro drift)
We’re trying to get going on pose estimation and path planning with our Romi. The issue we’re facing is that our reported pose angle is decreasing at about 3 degrees/second while the Romi is at rest. There is gyro z angle negative drift but it’s orders of magnitude lower. (maybe 0.03 degrees per second) I’m assuming it’s something wrong in the pose estimator update we’re running in periodic but I can’t see where. Here’s the drivetrain subsystem where all this is managed. Any pointers on this code or to an example to review would be appreciated - thanks!
// Copyright (c) FIRST and other WPILib contributors.
// Open Source Software; you can modify and/or share it under the terms of
// the WPILib BSD license file in the root directory of this project.
package frc.robot.subsystems;
import edu.wpi.first.math.VecBuilder;
import edu.wpi.first.math.estimator.DifferentialDrivePoseEstimator;
import edu.wpi.first.math.geometry.Pose2d;
import edu.wpi.first.math.geometry.Rotation2d;
import edu.wpi.first.math.kinematics.DifferentialDriveKinematics;
import edu.wpi.first.math.util.Units;
import edu.wpi.first.networktables.DoubleArrayTopic;
import edu.wpi.first.networktables.DoublePublisher;
import edu.wpi.first.networktables.DoubleTopic;
import edu.wpi.first.networktables.IntegerArrayTopic;
import edu.wpi.first.networktables.NetworkTable;
import edu.wpi.first.networktables.NetworkTableInstance;
import edu.wpi.first.util.sendable.SendableRegistry;
import edu.wpi.first.wpilibj.BuiltInAccelerometer;
import edu.wpi.first.wpilibj.Encoder;
import edu.wpi.first.wpilibj.drive.DifferentialDrive;
import edu.wpi.first.wpilibj.motorcontrol.Spark;
import edu.wpi.first.wpilibj.romi.RomiGyro;
import edu.wpi.first.wpilibj.smartdashboard.Field2d;
import edu.wpi.first.wpilibj2.command.Command;
import edu.wpi.first.wpilibj2.command.SubsystemBase;
import java.util.function.DoubleSupplier;
public class Drive extends SubsystemBase {
  private static final double kCountsPerRevolution = 1440.0;
  private static final double kWheelDiameterInch = 2.75591; // 70 mm
  private static final double kWheelDiameterMeter = Units.inchesToMeters(kWheelDiameterInch);
  private final DifferentialDriveKinematics m_kinematics =
    new DifferentialDriveKinematics(Units.inchesToMeters(5.5));
  // The Romi has the left and right motors set to
  // PWM channels 0 and 1 respectively
  private final Spark m_leftMotor = new Spark(0);
  private final Spark m_rightMotor = new Spark(1);
  // The Romi has onboard encoders that are hardcoded
  // to use DIO pins 4/5 and 6/7 for the left and right
  private final Encoder m_leftEncoder = new Encoder(4, 5);
  private final Encoder m_rightEncoder = new Encoder(6, 7);
  // Set up the differential drive controller
  private final DifferentialDrive m_drive =
      new DifferentialDrive(m_leftMotor::set, m_rightMotor::set);
  // Set up the RomiGyro
  private final RomiGyro m_gyro = new RomiGyro();
  // Set up the BuiltInAccelerometer
  private final BuiltInAccelerometer m_accelerometer = new BuiltInAccelerometer();
  Field2d m_fieldApproximation = new Field2d(); //may need to initialize pose
  // declare here for methods access, init in constructor
  DifferentialDrivePoseEstimator m_poseEstimator;
  // NT data for testing or tracking purposes
  private final NetworkTableInstance ntInstance = NetworkTableInstance.getDefault();
  private final NetworkTable ntDriveTable = ntInstance.getTable("drive");
  DoublePublisher gyro_x = ntDriveTable.getDoubleTopic("gyro_x").publish();
  DoublePublisher gyro_y =ntDriveTable.getDoubleTopic("gyro_y").publish();
  DoublePublisher gyro_z =ntDriveTable.getDoubleTopic("gyro_z").publish();
  DoublePublisher left_dist =ntDriveTable.getDoubleTopic("left_dist").publish();
  DoublePublisher right_dist =ntDriveTable.getDoubleTopic("right_dist").publish();
  DoublePublisher field_x =ntDriveTable.getDoubleTopic("field_x").publish();
  DoublePublisher field_y =ntDriveTable.getDoubleTopic("field_y").publish();
  DoublePublisher field_angle =ntDriveTable.getDoubleTopic("field_angle").publish();
  /** Creates a new Drive subsystem. */
  public Drive() {
    SendableRegistry.addChild(m_drive, m_leftMotor);
    SendableRegistry.addChild(m_drive, m_rightMotor);
    SendableRegistry.addChild(m_drive, m_gyro);
    // We need to invert one side of the drivetrain so that positive voltages
    // result in both sides moving forward. Depending on how your robot's
    // gearbox is constructed, you might have to invert the left side instead.
    m_rightMotor.setInverted(true);
    m_rightMotor.setSafetyEnabled(false);
    m_leftMotor.setSafetyEnabled(false);
    m_drive.setSafetyEnabled(false);
    // Use meters as unit for encoder distances since pose estimators require
    m_leftEncoder.setDistancePerPulse((Math.PI * kWheelDiameterMeter) / kCountsPerRevolution);
    m_rightEncoder.setDistancePerPulse((Math.PI * kWheelDiameterMeter) / kCountsPerRevolution);
    // only direct calls to reset since once pose estimator created need to use public methods
    m_leftEncoder.reset();
    m_rightEncoder.reset();
    m_gyro.reset();
    /* Here we use DifferentialDrivePoseEstimator so that we can fuse odometry readings. The
    numbers used  below are robot specific, and should be tuned. */
    m_poseEstimator = new DifferentialDrivePoseEstimator(
            m_kinematics,
            new Rotation2d(getGyroAngleZ()),
            m_leftEncoder.getDistance(),
            m_rightEncoder.getDistance(),
            new Pose2d(),
            VecBuilder.fill(0.05, 0.05, Units.degreesToRadians(5)),
            VecBuilder.fill(0.5, 0.5, Units.degreesToRadians(30)));
    SmartDashboard.putData("FieldEstimation", m_fieldApproximation);
   * Returns a command that drives the robot with arcade controls.
   * @param fwd the commanded forward movement
   * @param rot the commanded rotation
  public Command arcadeDriveCommand(DoubleSupplier fwd, DoubleSupplier rot) {
    // A split-stick arcade command, with forward/backward controlled by the left
    // hand, and turning controlled by the right.
    System.out.println("Returning arcade drive");
    return run(() -> m_drive.arcadeDrive(fwd.getAsDouble(), rot.getAsDouble()))
        .withName("arcadeDrive");
   * Returns a command that drives the robot forward a specified distance at a specified speed.
   * @param distanceMeters The distance to drive forward in meters
   * @param speed The fraction of max speed at which to drive
  public Command driveDistanceCommand(double distanceMeters, double speed) {
    return runOnce(
              // Reset encoders at the start of the command
              resetEncoders();
        // Drive forward at specified speed
        .andThen(run(() -> m_drive.arcadeDrive(speed, 0)))
        // End command when we've traveled the specified distance
        .until(
                Math.max(m_leftEncoder.getDistance(), m_rightEncoder.getDistance())
                    >= distanceMeters)
        // Stop the drive when the command ends
        .finallyDo(interrupted -> m_drive.stopMotor());
  public Command rotateDegreesCommand(double angleDegrees, double speed) {
    return runOnce(
              // Reset gyro at the start of the command
              resetGyro();
        // Rotate at specified speed
        .andThen(run(() -> m_drive.arcadeDrive(0, speed)))
        // End command when we've rotated the specified angle
        .until(
                Math.abs(getGyroAngleZ()) >= angleDegrees)
  public int getLeftEncoderCount() {
    return m_leftEncoder.get();
  public int getRightEncoderCount() {
    return m_rightEncoder.get();
  public double getLeftDistanceMeter() {
    return m_leftEncoder.getDistance();
  public double getRightDistanceMeter() {
    return m_rightEncoder.getDistance();
  public double getAverageDistanceMeter() {
    return (getLeftDistanceMeter() + getRightDistanceMeter()) / 2.0;
   * The acceleration in the X-axis.
   * @return The acceleration of the Romi along the X-axis in Gs
  public double getAccelX() {
    return m_accelerometer.getX();
   * The acceleration in the Y-axis.
   * @return The acceleration of the Romi along the Y-axis in Gs
  public double getAccelY() {
    return m_accelerometer.getY();
   * The acceleration in the Z-axis.
   * @return The acceleration of the Romi along the Z-axis in Gs
  public double getAccelZ() {
    return m_accelerometer.getZ();
   * Current angle of the Romi around the X-axis.
   * @return The current angle of the Romi in degrees
  public double getGyroAngleX() {
    return m_gyro.getAngleX();
   * Current angle of the Romi around the Y-axis.
  public double getGyroAngleY() {
    return m_gyro.getAngleY();
   * Current angle of the Romi around the Z-axis.
  public double getGyroAngleZ() {
    return m_gyro.getAngleZ();
  /** Reset the gyro. Update pose estimator*/
  public void resetGyro() {
    Pose2d curr_pose = m_poseEstimator.getEstimatedPosition();
    m_gyro.reset();
    m_poseEstimator.resetPosition(
      new Rotation2d(getGyroAngleZ()), m_leftEncoder.getDistance(), m_rightEncoder.getDistance(), curr_pose);
  //** Reset the encoders, Update pose estimator */
  public void resetEncoders() {
  /** Updates the field-relative position. */
  public void updateOdometry() {
    m_poseEstimator.update(
        new Rotation2d(getGyroAngleZ()), m_leftEncoder.getDistance(), m_rightEncoder.getDistance());
    m_fieldApproximation.setRobotPose(m_poseEstimator.getEstimatedPosition());
    // Publish cameraToObject transformation to networktables --this would normally be handled by
    // the
    // computer vision solution.
    //publishCameraToObject(
    //    m_objectInField, m_robotToCamera, m_cameraToObjectEntry, m_drivetrainSimulator);
    // Compute the robot's field-relative position exclusively from vision measurements.
    //Pose3d visionMeasurement3d =
    //    objectToRobotPose(m_objectInField, m_robotToCamera, m_cameraToObjectEntry);
    // Convert robot pose from Pose3d to Pose2d needed to apply vision measurements.
    //Pose2d visionMeasurement2d = visionMeasurement3d.toPose2d();
    // Apply vision measurements. For simulation purposes only, we don't input a latency delay -- on
    // a real robot, this must be calculated based either on known latency or timestamps.
    //m_poseEstimator.addVisionMeasurement(visionMeasurement2d, Timer.getFPGATimestamp());
    gyro_x.set(getGyroAngleX());
    gyro_y.set(getGyroAngleY());
    gyro_z.set(getGyroAngleZ());
    left_dist.set(getLeftDistanceMeter());
    right_dist.set(getRightDistanceMeter());
    field_x.set(m_poseEstimator.getEstimatedPosition().getTranslation().getX());
    field_y.set(m_poseEstimator.getEstimatedPosition().getTranslation().getY());
    field_angle.set(m_poseEstimator.getEstimatedPosition().getRotation().getDegrees());
  @Override
  public void periodic() {
    // This method will be called once per scheduler run
    updateOdometry();
A unit error between radians and degrees would be ~60x off.
Thanks @Joe_Ross this was indeed the issue.
The RomiGyro class getAngle methods returns degrees but the gyroAngle argument to the DifferentialDrivePoseEstimator methods wants a Rotation2D object whose default constructor wants radians.
