We have done everything correctly and written the sd card appropriately . However when trying to connect to the wifi produced by the romi robot the documentation’s password does not seem to work.
We’ve tried : WPILib2021!
which does nothing. Is this password correct? or is it outdated and been changed?
Been a year+ since I’ve lasted touched our ROMI.
Did you try:
The default SSID is also written to the /boot/default-ssid.txt file, which can be read by inserting the SD card (via a reader) into a computer and opening the boot partition.
If this is an old ROMI, it’s also possible someone from your team might have changed stuff via the Web dashboard of the PI. Might want to try that too. Worst case is to just reflash the SD card.
