I am attempting to image a new/2011 Classmate using the “2011 Image for '11 Classmate” flash drive and following the instructions in “HOW TO SET UP YOUR 2011 DRIVER STATION”. I can get to the point where it says:
Image applied successfully!
Press any key to continue…
When I press a key, the command prompt sits at the F:\ drive and does nothing, so I either exit the command prompt or reboot the Classmate manually.
Then it bluescreens and reboots to the standard Windows Error Recovery screen immediately when the screen with a progress bar and "© Microsoft Corporation shows up. None of the options work, but when I boot to safe mode, the last thing it loads before crashing is \Windows\system32\DRIVERS\classpnp.sys
I’m afraid that I may have a bad image, since I’ve tried everything I can think of - even using different USB ports, removing the USB drive before and after pressing a key to continue, leaving it in, etc…
Please let me know if you have any ideas how I should proceed.
