I am new to programming and extremely new to a lot of mechanical stuff in general, so my team gave me something to work on over the holidays, but I am very confused.
I will try and be as specific as possible to receive help
They gave me an edubot controller, a battery, a charger, 2 servos, a serial to usb converter, and something called a BEI GyroChip
I know what the battery, charger, and serial -> usb cable do/are for, but how would i hook up the rest of thie stuff to the control
The servos plug into any PWM available on your controller. Setting the value (0-254) of the PWM will turn the servo to a particular spot. The same spot everytime you use a particular value.
The gyro plugs into an analog input on the controller (one of the first inputs based on User_Initialization() in user_routines.c). If it doesn’t already have a connector attached you’ll have to make one out of a PWM cable. You get values from it doing something like “x = Get_Analog_Value(rc_ana_in01);“ The neutral position of the gyro will be close to 512. When the gyro is twisted slowly in one direction you’ll get numbers between 0 and 512 only while you are twisting it. Do the same in the other direction and you’ll get numbers between 512 and 1023. If you keep track of these numbers you can tell if your robot is driving straight or not and correct. It can also be used to make precise turns, to say 45 degrees if you calibrated it.
This particular gyro is no longer “street legal” to use on your competition robot, but it’s good to learn with. This one will be overly sensitive to turns or sudden movements that are too quick, and will more easily lose track of the original robot heading.
Do a search on “gyro” for a lot of threads on the subject.
Yes, learn to use MPLAB.
How about putting something like this where it says “/* Add your own code here. */” in the file “user_routines.c” in the routine “[size=2]Process_Data_From_Master_uP”
[/size]
static unsigned char servo1=0; //Put these two lines right before the "Getdata" call
static unsigned char counter=0; // ditto
//Put these lines after "Add your own code"
if (counter < 20) // about half a second in the slow loop
counter++;
else
counter = 0;
if (servo1 < 255)
servo1++; // servo1 will slowly step through each of it’s positions
else
servo1 = 0; // servo1 will quickly reset to the zero position
pwm03 = servo1;
You’ll need to install MPLAB, IFI_Loader, and the mcc18 compiler on your computer.
Download the default EDU code from http://innovationfirst.com/FIRSTRobotics/documentation.htm (this will have a default.hex file that can be downloaded into the controller without having to edit anything with MPLAB) Save the original .zip file so you can restore the default code if some edit goes terribly wrong.
To edit the default code:
Start MPLAB
Select File -> Open Workspace…
Browse to the EDU default code folder
Open Default.mcw
Make your code changes
Use the “Build All” icon or select Project -> Build All (this will create a .hex file)
Start IFI_Loader
Browse to the default code folder
Select “Default.hex”
Connect the serial cable from your computer to the EDU controller
Turn on the EDU controller
Press the “Prog” button until the program light turns orange
C:…\EDU_Default_02-16-04\user_routines.c:249:Error: syntax error
Halting build on first failure as requested.
BUILD FAILED: Mon Dec 20 16:36:48 2004
here is the snippet i edited
* FUNCTION NAME: Process_Data_From_Master_uP
* PURPOSE: Executes every 17ms when it gets new data from the master
* microprocessor.
* CALLED FROM: main.c
* ARGUMENTS: none
* RETURNS: void
void Process_Data_From_Master_uP(void)
Getdata(&rxdata); /* Get fresh data from the master microprocessor. */
Default_Routine(); /* Optional. See below. */
static char servo1=0;
static char counter=0;
counter++;
else
counter = 0;
if (servo1 < 254)
else
pwm03 = servo1;
printf("PWM OUT 7 = %d, PWM OUT 8 = %d
",(int)pwm07,(int)pwm08); /* printf EXAMPLE */
Putdata(&txdata); /* DO NOT CHANGE! */
(sorry if i am being annoying, im just new at this)
XP will. [edit2] But you probably have to install that particular device driver the first time. An install CD should have come with the converter, or you might be able to download the driver from keyspan.
Are you getting a download error using IFI_Loader?
Sometimes those adaptors auto connect to a different COM port than it advertises. You can run through and try all the possible COM ports in IFI_Loader by choosing “PortSettings” and COM1, try to download, then COM2, and try to download, etc.
[edit]
I misunderstood.
Do you have the controller or will you try that later?
For those of you reading along…
The error doyler got was because one of the path and filenames was too long for MPLAB to handle. Combined they cannot be more than 62 characters or so. The usual solution is to keep the directory for all your FIRST code at the top level of the C drive, i.e., “C:\FIRST” not on your desktop because that’s really at “C:\Documents and Settings\doyler\Desktop” which is already 41 characters long.
