Rookie needs wiring and programming help
I am a member of a rookie team and have been frustrated by several problems.
  1. how do I wire and read the kop switches as inputs?
  2. how do I get the template directory to change for the vision processing. I made the code in vision assistant and used variables wired to panals to change the directory, but I continue to get errors when the program begins. It does not even locate the first color.
  3. in the labview default code, I notice that variables, such as joystick numbers or input numbers, have dropdown boxes that contain text and numbers. How do these work and how do I make them?
All help is greatly appreciated. Thank you.
