Hey
Does anyone know how to get rotation sensors to work in LabView?
we are trying to get the to work for autonomous mode
So foar I have found that they are under encoders in Labview, but still do not know how to get them to work
Thanks everyone
Which rotation sensors are you using? I’ve been looking for a good set for a long time!
Jacob
Just the ones that came with the KOP
most likely the ones off andy mark
It’s a bit complex, but LabVIEW has an example (Encoder Example) that spells out all that you need to setup. It assumes a digital quad encoder, so a different type, such as a single or an analog one that came in the KOP with the magnets, would be handled differently.
From the Getting Started window select “More…” at the bottom right under Examples.
Then select “Encoder Example”
Open up the Block diagram and you can copy/paste the code over to your project.
It breaks down like this:
Begin.vi
DIO Opens for two channels (assuming a quad encoder like the KOP US Digital ones)
Convert to Digital Source
Encoder Open
Encoder Config Timer
Encoder Start
Encoder Refnum
Autonomous Independent.vi
Encoder refnum
Encoder Get
Finish.vi
*]Close encoder
Checkout http://www.usdigital.com/first for the encoder assembly guide.
Ah, the wheel encoders. I thought you had meant just a simple rotation sensor.
Jacob
Thank you, I figured out how to start them
can you post some diagrams of how I could use the encoders control the motors in the autonomous mode?
Thanks
