Router Connection Issues
To sum it up, our robot’s Wi-Fi connection doesn’t cut it. The connection holds from anywhere from 30 seconds to 10 minutes. Looking into the logs of the DS show incredibly high packet loss rates (Including in some cases over 100%…) and frequent disconnections (occurring at regular 2 seconds intervals) that make it basically impossible to control the robot. We’ve had this problem last year as well with the older OM5P-AN radio and this years OM5P-AC radio. This year however the problem is worse because I cannot change the the channel on the newer radio. Last year we were able to lower the loss rate by switching to a less busy channel but the newer radio is choosing channel 3 and most likely getting interference from the other networks in the building which largely occupies channels 1 and 6. We are using the 2.4Ghz band as that’s what our laptops internal Wi-Fi adapter supports.
We’ve put in an order for a 50ft cable to tether ourselves to the robot but that isn’t the solution we are looking for.
Could you post some of the driver station logs of the packet loss?
You could also follow the instructions to setup a second router like FMS Lite would (http://wpilib.screenstepslive.com/s/fms/m/offseason) even if you’re not running FMS Lite this can get you off of your laptops wireless connection and let you use 5 GHZ bands. This also more closely resembles the real setup.
First off, I may of missed read the graph on the amount of packet loss, but nonetheless it is still occurring.
Screen grab of the graph: https://drive.google.com/open?id=0B4j9bUDVhhGlZXZlbWd3akU0dW8 (We can’t think of a better way to post the log)
Secondly, I found a USB Wi-Fi adapter that supports 5Ghz and we gave that a shot instead setting up FMS lite. There was a little improvement but not as much as we were helping for. Looking through the school networks as well, they are also on the 5Ghz band but not as much.
The school techie came in and disabled the nearest node for us to reduce the strength of any interference we got some improvement again, but it didn’t solve the problem.
We did get the connection to hold for a few minutes and we pinged RoboRIO at both 172.22.11.2 and roboRIO-6188-FRC.local and both returned the same thing. Both pings would randomly time out or randomly return “Destination host unavailable”
Here’s an exported log:
Time	Trip Time	Lost Packets	Voltage	Robot Disabled
14:00:54.971	3.5	0.4	37.375	True
14:00:54.991	3.5	0.4	37.375	True
14:00:55.011	3.5	0.4	37.375	True
14:00:55.031	3.5	0.4	37.375	True
14:00:55.051	3.5	0.4	37.375	True
14:00:55.071	3.5	0.4	37.375	True
14:00:55.091	3.5	0.4	37.375	True
14:00:55.111	3.5	0.4	37.375	True
14:00:55.131	3.5	0.4	37.375	True
14:00:55.151	3.5	0.4	37.375	True
14:00:55.171	3.5	0.4	37.375	True
14:00:55.191	3.5	0.4	12.10546875	True
14:00:55.211	3.5	0.4	12.09375	True
14:00:55.231	3.5	0.4	12.11328125	True
14:00:55.251	3.5	0.4	12.11328125	True
14:00:55.271	3.5	0.4	12.09375	True
14:00:55.291	3.5	0.4	12.09765625	True
14:00:55.311	3.5	0.4	12.09375	True
14:00:55.331	3.5	0.4	12.10546875	True
14:00:55.351	3.5	0.4	12.10546875	True
14:00:55.371	3.5	0.4	12.10546875	True
14:00:55.391	3.5	0.4	12.09375	True
14:00:55.411	3.5	0.4	12.09375	True
14:00:55.431	3.5	0.4	12.09375	True
14:00:55.451	3.5	0.4	12.09765625	True
14:00:55.471	3.5	0.4	12.09765625	True
14:00:55.491	3.5	0.4	12.09765625	True
14:00:55.511	3.5	0.4	12.10546875	True
14:00:55.531	3.5	0.4	12.09765625	True
14:00:55.551	3.5	0.4	12.11328125	True
14:00:55.571	3.5	0.4	12.09765625	True
14:00:55.591	3.5	0.4	12.09765625	True
14:00:55.611	4	0	12.11328125	True
14:00:55.631	4	1	255.99609375	False
14:00:55.651	4	1	255.99609375	False
14:00:55.671	4	1	255.99609375	False
14:00:55.691	4	1	255.99609375	False
14:00:55.711	4	1	255.99609375	False
14:00:55.731	4	1	255.99609375	False
14:00:55.751	4	1	255.99609375	False
14:00:55.771	4	1	255.99609375	False
14:00:55.791	4	1	255.99609375	False
14:00:55.811	4	1	255.99609375	False
14:00:55.831	4	1	255.99609375	False
14:00:55.851	4	1	255.99609375	False
14:00:55.871	4	1	255.99609375	False
14:00:55.891	4	1	255.99609375	False
14:00:55.911	4	1	255.99609375	False
14:00:55.931	4	1	255.99609375	False
14:00:55.951	4	1	255.99609375	False
14:00:55.971	4	1	255.99609375	False
14:00:55.991	4	1	255.99609375	False
14:00:56.011	4	1	255.99609375	False
14:00:56.031	4	1	255.99609375	False
14:00:56.051	4	1	255.99609375	False
14:00:56.071	4	1	255.99609375	False
14:00:56.091	4	1	255.99609375	False
14:00:56.111	4	1	255.99609375	False
14:00:56.131	4	1	255.99609375	False
14:00:56.151	4	1	255.99609375	False
14:00:56.171	4	1	255.99609375	False
14:00:56.191	4	1	255.99609375	False
14:00:56.211	4	1	255.99609375	False
14:00:56.231	4	1	255.99609375	False
14:00:56.251	4	1	255.99609375	False
14:00:56.271	4	1	255.99609375	False
14:00:56.291	4	1	255.99609375	False
14:00:56.311	4	1	255.99609375	False
14:00:56.331	4	1	255.99609375	False
14:00:56.351	4	1	255.99609375	False
14:00:56.371	4	1	255.99609375	False
14:00:56.391	4	1	255.99609375	False
14:00:56.411	4	1	255.99609375	False
14:00:56.431	4	1	255.99609375	False
14:00:56.451	4	1	255.99609375	False
14:00:56.471	4	1	255.99609375	False
14:00:56.491	4	1	255.99609375	False
14:00:56.511	4	1	255.99609375	False
14:00:56.531	4	1	255.99609375	False
14:00:56.551	4	1	255.99609375	False
14:00:56.571	4	1	255.99609375	False
14:00:56.591	4	1	255.99609375	False
14:00:56.611	4	1	255.99609375	False
14:00:56.631	4	1.04	255.99609375	False
14:00:56.651	4	1.04	255.99609375	False
14:00:56.671	4	1.04	255.99609375	False
14:00:56.691	4	1.04	255.99609375	False
14:00:56.711	4	1.04	255.99609375	False
14:00:56.731	4	1.04	255.99609375	False
14:00:56.751	4	1.04	255.99609375	False
14:00:56.771	4	1.04	255.99609375	False
14:00:56.791	4	1.04	255.99609375	False
14:00:56.811	4	1.04	255.99609375	False
14:00:56.831	4	1.04	255.99609375	False
14:00:56.851	4	1.04	255.99609375	False
14:00:56.871	4	1.04	255.99609375	False
14:00:56.891	4	1.04	255.99609375	False
14:00:56.911	4	1.04	255.99609375	False
14:00:56.931	4	1.04	255.99609375	False
14:00:56.951	4	1.04	255.99609375	False
14:00:56.971	4	1.04	255.99609375	False
14:00:56.991	4	1.04	255.99609375	False
14:00:57.011	4	1.04	255.99609375	False
14:00:57.031	4	1.04	255.99609375	False
14:00:57.051	4	1.04	255.99609375	False
14:00:57.071	4	1.04	255.99609375	False
14:00:57.091	4	1.04	255.99609375	False
14:00:57.111	4	1.04	255.99609375	False
14:00:57.131	4	1	255.99609375	False
14:00:57.151	4	1	255.99609375	False
14:00:57.171	4	1	255.99609375	False
14:00:57.191	4	1	255.99609375	False
14:00:57.211	4	1	255.99609375	False
14:00:57.231	4	1	255.99609375	False
14:00:57.251	4	1	255.99609375	False
14:00:57.271	4	1	255.99609375	False
14:00:57.291	4	1	255.99609375	False
14:00:57.311	4	1	255.99609375	False
14:00:57.331	4	1	255.99609375	False
14:00:57.351	4	1	255.99609375	False
14:00:57.371	4	1	255.99609375	False
14:00:57.391	4	1	255.99609375	False
14:00:57.411	4	1	255.99609375	False
14:00:57.431	4	1	255.99609375	False
14:00:57.451	4	1	255.99609375	False
14:00:57.471	4	1	255.99609375	False
14:00:57.491	4	1	255.99609375	False
14:00:57.511	4	1	255.99609375	False
14:00:57.531	4	1	255.99609375	False
14:00:57.551	4	1	255.99609375	False
14:00:57.571	4	1	255.99609375	False
14:00:57.591	4	1	255.99609375	False
14:00:57.611	4	1	255.99609375	False
14:00:57.631	4	1	255.99609375	False
14:00:57.651	4	1	255.99609375	False
14:00:57.671	4	1	255.99609375	False
14:00:57.691	4	1	255.99609375	False
14:00:57.711	4	1	255.99609375	False
14:00:57.731	4	1	255.99609375	False
14:00:57.751	4	1	255.99609375	False
14:00:57.771	4	1	255.99609375	False
14:00:57.791	4	1	255.99609375	False
14:00:57.811	4	1	255.99609375	False
14:00:57.831	4	1	255.99609375	False
14:00:57.851	4	1	255.99609375	False
14:00:57.871	4	1	255.99609375	False
14:00:57.891	4	1	255.99609375	False
14:00:57.911	4	1	255.99609375	False
14:00:57.931	4	1	255.99609375	False
14:00:57.951	4	1	255.99609375	False
14:00:57.971	4	1	255.99609375	False
14:00:57.991	4	1	255.99609375	False
14:00:58.011	4	1	255.99609375	False
14:00:58.031	4	1	255.99609375	False
14:00:58.051	4	1	255.99609375	False
14:00:58.071	4	1	255.99609375	False
14:00:58.091	4	1	255.99609375	False
14:00:58.111	4	1	255.99609375	False
14:00:58.131	4	1	255.99609375	False
14:00:58.151	4	1	12.1171875	True
14:00:58.171	4	1	12.1171875	True
14:00:58.191	4	1	12.1171875	True
14:00:58.211	4	1	12.0859375	False
14:00:58.231	4	1	12.0859375	False
14:00:58.251	4	1	12.09765625	True
14:00:58.271	4	1	12.09375	True
14:00:58.291	4	1	12.0859375	False
14:00:58.311	4	1	12.0859375	False
14:00:58.331	4	1	12.09375	False
14:00:58.351	4	1	12.09375	False
14:00:58.371	4	1	12.10546875	False
14:00:58.391	4	1	12.0859375	True
14:00:58.411	4	1	12.09375	False
14:00:58.431	4	1	12.09375	True
14:00:58.451	4	1	12.09765625	False
14:00:58.471	4	1	12.08203125	False
14:00:58.491	4	1	12.0859375	False
14:00:58.511	4	1	12.0859375	False
14:00:58.531	4	1	12.09375	False
14:00:58.551	4	1	12.09375	False
14:00:58.571	4	1	12.09375	False
14:00:58.591	4	1	12.09375	False
14:00:58.611	4	1	12.0859375	False
14:00:58.631	4	1	12.09375	True
14:00:58.651	4	1	12.0859375	True
14:00:58.671	4	1	12.09765625	True
14:00:58.691	4	1	12.10546875	True
14:00:58.711	4	1	12.09375	True
14:00:58.731	4	1	12.09375	True
14:00:58.751	4	1	12.10546875	True
14:00:58.771	4	1	12.09765625	True
14:00:58.791	4	1	12.10546875	True
14:00:58.811	4	1	12.11328125	True
14:00:58.831	4	1	12.11328125	True
14:00:58.851	4	1	12.10546875	True
14:00:58.871	4	1	12.10546875	True
14:00:58.891	4	1	12.10546875	True
14:00:58.911	4	1	12.10546875	True
14:00:58.931	4	1	12.1171875	True
14:00:58.951	4	1	12.09765625	True
14:00:58.971	4	0.24	12.09375	True
14:00:58.991	4	0.24	12.11328125	True
14:00:59.011	4	1.04	255.99609375	False
14:00:59.031	4	1.04	255.99609375	False
14:00:59.051	4	1.04	255.99609375	False
14:00:59.071	4	1.04	255.99609375	False
14:00:59.091	4	1.04	255.99609375	False
14:00:59.111	4	1.04	255.99609375	False
14:00:59.131	4	1.04	255.99609375	False
14:00:59.151	4	1.04	255.99609375	False
14:00:59.171	4	1	255.99609375	False
14:00:59.191	4	1	255.99609375	False
14:00:59.211	4	1	255.99609375	False
14:00:59.231	4	1	255.99609375	False
14:00:59.251	4	1	255.99609375	False
14:00:59.271	4	1	255.99609375	False
14:00:59.291	4	1	255.99609375	False
14:00:59.311	4	1	255.99609375	False
14:00:59.331	4	1	255.99609375	False
14:00:59.351	4	1	255.99609375	False
14:00:59.371	4	1	255.99609375	False
14:00:59.391	4	1	255.99609375	False
14:00:59.411	4	1	255.99609375	False
14:00:59.431	4	1	255.99609375	False
14:00:59.451	4	1	255.99609375	False
14:00:59.471	4	1	255.99609375	False
14:00:59.491	4	1	255.99609375	False
14:00:59.511	4	1	255.99609375	False
14:00:59.531	4	1	255.99609375	False
14:00:59.551	4	1	255.99609375	False
14:00:59.571	4	1	255.99609375	False
14:00:59.591	4	1	255.99609375	False
14:00:59.611	4	1	255.99609375	False
14:00:59.631	4	1	255.99609375	False
14:00:59.651	4	1	255.99609375	False
14:00:59.671	4	1	255.99609375	False
14:00:59.691	4	1	255.99609375	False
14:00:59.711	4	1	255.99609375	False
14:00:59.731	4	1	255.99609375	False
14:00:59.751	4	1	255.99609375	False
14:00:59.771	4	1	255.99609375	False
14:00:59.791	4	1	255.99609375	False
14:00:59.811	4	1	255.99609375	False
14:00:59.831	4	1	255.99609375	False
14:00:59.851	4	1	255.99609375	False
14:00:59.871	4	1	255.99609375	False
14:00:59.891	4	1	255.99609375	False
14:00:59.911	4	1	255.99609375	False
14:00:59.931	4	1	255.99609375	False
14:00:59.951	4	1	255.99609375	False
14:00:59.971	4	1	255.99609375	False
14:00:59.991	4	1	255.99609375	False
14:01:00.011	4	1	255.99609375	False
14:01:00.031	4	1	255.99609375	False
14:01:00.051	4	1	255.99609375	False
14:01:00.071	4	1	255.99609375	False
14:01:00.091	4	1	255.99609375	False
14:01:00.111	4	1	255.99609375	False
14:01:00.131	4	1	255.99609375	False
14:01:00.151	4	1	255.99609375	False
14:01:00.171	4	1	255.99609375	False
14:01:00.191	4	1	255.99609375	False
14:01:00.211	4	1	255.99609375	False
14:01:00.231	4	1	255.99609375	False
14:01:00.251	4	1	255.99609375	False
14:01:00.271	4	1	255.99609375	False
14:01:00.291	4	1	255.99609375	False
14:01:00.311	4	1	255.99609375	False
14:01:00.331	4	1	255.99609375	False
14:01:00.351	4	1	255.99609375	False
14:01:00.371	4	1	255.99609375	False
14:01:00.391	4	1	255.99609375	False
14:01:00.411	4	1	255.99609375	False
14:01:00.431	4	1	255.99609375	False
14:01:00.451	4	1	255.99609375	False
14:01:00.471	4	1	255.99609375	False
14:01:00.491	4	1	255.99609375	False
14:01:00.511	4	1	255.99609375	False
14:01:00.531	4	1	255.99609375	False
14:01:00.551	4	1	255.99609375	False
14:01:00.571	4	1	255.99609375	False
14:01:00.591	4	1	255.99609375	False
14:01:00.611	4	1	255.99609375	False
14:01:00.631	4	1	255.99609375	False
14:01:00.651	4	1	255.99609375	False
14:01:00.671	4	1.04	255.99609375	False
14:01:00.691	4	1.04	255.99609375	False
14:01:00.711	4	1.04	255.99609375	False
14:01:00.731	4	1.04	255.99609375	False
14:01:00.751	4	1.04	255.99609375	False
14:01:00.771	4	1.04	255.99609375	False
14:01:00.791	4	1.04	255.99609375	False
14:01:00.811	4	1.04	255.99609375	False
14:01:00.831	4	1.04	255.99609375	False
14:01:00.851	4	1.04	255.99609375	False
14:01:00.871	4	1.04	255.99609375	False
14:01:00.891	4	1.04	255.99609375	False
14:01:00.911	4	1.04	255.99609375	False
14:01:00.931	4	1.04	255.99609375	False
14:01:00.951	4	1.04	255.99609375	False
14:01:00.971	4	1.04	255.99609375	False
14:01:00.991	4	1.04	255.99609375	False
14:01:01.011	4	1.04	255.99609375	False
14:01:01.031	4	1.04	255.99609375	False
14:01:01.051	4	1.04	255.99609375	False
14:01:01.071	4	1.04	255.99609375	False
14:01:01.091	4	1.04	255.99609375	False
14:01:01.111	4	1.04	255.99609375	False
14:01:01.131	4	1.04	255.99609375	False
14:01:01.151	4	1.04	255.99609375	False
14:01:01.171	4	1.04	12.09375	True
14:01:01.191	4	1.04	12.09375	True
14:01:01.211	4	1.04	12.09375	True
14:01:01.231	4	1.04	12.09375	True
14:01:01.251	4	1.04	12.09375	True
14:01:01.271	4	1.04	12.09765625	False
14:01:01.291	4	1.04	12.10546875	False
14:01:01.311	4	1.04	12.09375	False
14:01:01.331	4	1.04	12.10546875	False
14:01:01.351	4	1.04	12.10546875	False
14:01:01.371	4	1.04	12.11328125	False
14:01:01.391	4	1.04	12.09765625	False
14:01:01.411	4	1.04	12.10546875	True
14:01:01.431	4	1.04	12.09375	False
14:01:01.451	4	1.04	12.10546875	False
14:01:01.471	4	1.04	12.09765625	False
14:01:01.491	4	1.04	12.09765625	False
14:01:01.511	4	1.04	12.09375	False
14:01:01.531	4	1.04	12.09375	False
14:01:01.551	4	1.04	12.10546875	False
14:01:01.571	4	1.04	12.10546875	True
14:01:01.591	4	1.04	12.11328125	False
14:01:01.611	4	1.04	12.09765625	False
14:01:01.631	4	1.04	12.10546875	False
14:01:01.651	4	1.04	12.09375	False
14:01:01.671	4	1.04	12.09765625	False
14:01:01.691	4	1.04	12.09375	False
14:01:01.711	4	1.04	12.09765625	True
14:01:01.731	4	1.04	12.09765625	False
14:01:01.751	4	1.04	12.09765625	True
14:01:01.771	4	1.04	12.10546875	True
14:01:01.791	4	1.04	12.10546875	True
14:01:01.811	4	1.04	12.09765625	True
14:01:01.831	4	1.04	12.11328125	True
14:01:01.851	4	1.04	12.11328125	True
14:01:01.871	4	1.04	12.09765625	True
14:01:01.891	4	1.04	12.09765625	True
14:01:01.911	4	1.04	12.10546875	True
14:01:01.931	4	1.04	12.09765625	True
14:01:01.951	4	1.04	12.09765625	True
14:01:01.971	4	1.04	12.09375	True
14:01:01.991	4	1.04	12.10546875	True
14:01:02.011	4	1.04	12.09765625	True
14:01:02.031	4	0.28	12.09765625	True
14:01:02.051	4	0.28	12.10546875	True
14:01:02.071	4	0.28	12.09375	True
14:01:02.091	4	1	255.99609375	False
14:01:02.111	4	1	255.99609375	False
14:01:02.131	4	1	255.99609375	False
14:01:02.151	4	1	255.99609375	False
14:01:02.171	4	1	255.99609375	False
14:01:02.191	4	1	255.99609375	False
14:01:02.211	4	1	255.99609375	False
14:01:02.231	4	1	255.99609375	False
14:01:02.251	4	1	255.99609375	False
14:01:02.271	4	1	255.99609375	False
14:01:02.291	4	1	255.99609375	False
14:01:02.311	4	1	255.99609375	False
14:01:02.331	4	1	255.99609375	False
14:01:02.351	4	1	255.99609375	False
14:01:02.371	4	1	255.99609375	False
14:01:02.391	4	1	255.99609375	False
14:01:02.411	4	1	255.99609375	False
14:01:02.431	4	1	255.99609375	False
14:01:02.451	4	1	255.99609375	False
14:01:02.471	4	1	255.99609375	False
14:01:02.491	4	1	255.99609375	False
14:01:02.511	4	1	255.99609375	False
14:01:02.531	4	1	255.99609375	False
14:01:02.551	4	1	255.99609375	False
14:01:02.571	4	1	255.99609375	False
14:01:02.591	4	1	255.99609375	False
14:01:02.611	4	1	255.99609375	False
14:01:02.631	4	1	255.99609375	False
14:01:02.651	4	1	255.99609375	False
14:01:02.671	4	1	255.99609375	False
14:01:02.691	4	1	255.99609375	False
14:01:02.711	4	1	255.99609375	False
14:01:02.731	4	1	255.99609375	False
14:01:02.751	4	1	255.99609375	False
14:01:02.771	4	1	255.99609375	False
14:01:02.791	4	1	255.99609375	False
14:01:02.811	4	1	255.99609375	False
14:01:02.831	4	1	255.99609375	False
14:01:02.851	4	1	255.99609375	False
14:01:02.871	4	1	255.99609375	False
14:01:02.891	4	1	255.99609375	False
14:01:02.911	4	1	255.99609375	False
14:01:02.931	4	1	255.99609375	False
14:01:02.951	4	1	255.99609375	False
14:01:02.971	4	1	255.99609375	False
14:01:02.991	4	1	255.99609375	False
14:01:03.011	4	1	255.99609375	False
14:01:03.031	4	1	255.99609375	False
14:01:03.051	4	1	255.99609375	False
14:01:03.071	4	1	255.99609375	False
14:01:03.091	4	1	255.99609375	False
14:01:03.111	4	1	255.99609375	False
14:01:03.131	4	1	255.99609375	False
14:01:03.151	4	1	255.99609375	False
14:01:03.171	4	1	255.99609375	False
14:01:03.191	4	1	255.99609375	False
14:01:03.211	4	1	255.99609375	False
14:01:03.231	4	1	255.99609375	False
14:01:03.251	4	1	255.99609375	False
14:01:03.271	4	1	255.99609375	False
14:01:03.291	4	1	255.99609375	False
14:01:03.311	4	1	255.99609375	False
14:01:03.331	4	1	255.99609375	False
14:01:03.351	4	1	255.99609375	False
14:01:03.371	4	1	255.99609375	False
14:01:03.391	4	1	255.99609375	False
14:01:03.411	4	1	255.99609375	False
14:01:03.431	4	1	255.99609375	False
14:01:03.451	4	1	255.99609375	False
14:01:03.471	4	1	255.99609375	False
14:01:03.491	4	1	255.99609375	False
14:01:03.511	4	1	255.99609375	False
14:01:03.531	4	1	255.99609375	False
14:01:03.551	4	1	255.99609375	False
14:01:03.571	4	1	255.99609375	False
14:01:03.591	4	1	255.99609375	False
14:01:03.611	4	1	255.99609375	False
14:01:03.631	4	1	255.99609375	False
14:01:03.651	4	1	255.99609375	False
14:01:03.671	4	1	255.99609375	False
14:01:03.691	4	1	255.99609375	False
14:01:03.711	4	1	255.99609375	False
14:01:03.731	4	1	255.99609375	False
14:01:03.751	4	1	255.99609375	False
14:01:03.771	4	1	255.99609375	False
14:01:03.791	4	1	255.99609375	False
14:01:03.811	4	1	255.99609375	False
14:01:03.831	4	1	255.99609375	False
14:01:03.851	4	1	255.99609375	False
14:01:03.871	4	1	255.99609375	False
14:01:03.891	4	1	255.99609375	False
14:01:03.911	4	1	255.99609375	False
14:01:03.931	4	1	255.99609375	False
14:01:03.951	4	1	255.99609375	False
14:01:03.971	4	1	255.99609375	False
14:01:03.991	4	1	255.99609375	False
14:01:04.011	4	1	255.99609375	False
14:01:04.031	4	1	255.99609375	False
14:01:04.051	4	1	255.99609375	False
14:01:04.071	4	1	255.99609375	False
14:01:04.091	4	1	255.99609375	False
14:01:04.111	4	1	255.99609375	False
14:01:04.131	4	1	255.99609375	False
14:01:04.151	4	1	255.99609375	False
14:01:04.171	4	1	12.0859375	True
14:01:04.191	4	1	12.0859375	True
14:01:04.211	4	1	12.0859375	True
14:01:04.231	4	1	12.0859375	True
14:01:04.251	4	1	12.0859375	True
14:01:04.271	4	1	12.0859375	True
14:01:04.291	4	1	12.10546875	False
14:01:04.311	4	1	12.09765625	False
14:01:04.331	4	1	12.09375	False
14:01:04.351	4	1	12.08203125	True
14:01:04.371	4	1	12.0859375	False
14:01:04.391	4	1	12.10546875	False
14:01:04.411	4	1	12.09375	False
14:01:04.431	4	1	12.09765625	False
14:01:04.451	4	1	12.09765625	False
14:01:04.471	4	1	12.09765625	False
14:01:04.491	4	1	12.09765625	False
14:01:04.511	4	1	12.09765625	True
14:01:04.531	4	1	12.11328125	False
14:01:04.551	4	1	12.09765625	False
14:01:04.571	4	1	12.09375	False
14:01:04.591	4	1	12.11328125	False
14:01:04.611	4	1	12.09765625	False
14:01:04.631	4	1	12.09765625	False
14:01:04.651	4	1	12.09765625	True
14:01:04.671	4	1	12.09765625	False
14:01:04.691	4	1	12.11328125	False
14:01:04.711	4	1	12.09375	True
14:01:04.731	4	1	12.09375	False
14:01:04.751	4	1	12.09765625	False
14:01:04.771	4	1	12.09765625	True
14:01:04.791	4	1	12.10546875	True
14:01:04.811	4	1	12.10546875	True
14:01:04.831	4	1	12.09375	True
14:01:04.851	4	1	12.0859375	True
14:01:04.871	4	1	12.09765625	True
14:01:04.891	4	1	12.09375	True
14:01:04.911	4	1	12.10546875	True
14:01:04.931	4	1	12.09375	True
14:01:04.951	4	1	12.09375	True
14:01:04.971	4	1	12.09765625	True
14:01:04.991	4	1	12.09765625	True
14:01:05.011	4	0.4	12.09765625	True
14:01:05.031	4	0.4	12.09765625	True
14:01:05.051	4	0.4	12.09375	True
14:01:05.071	4	0.4	12.09765625	True
14:01:05.091	4	0.4	12.11328125	True
14:01:05.111	3.5	1	255.99609375	False
14:01:05.131	3.5	1	255.99609375	False
14:01:05.151	3.5	1	255.99609375	False
14:01:05.171	3.5	1	255.99609375	False
14:01:05.191	3.5	1	255.99609375	False
14:01:05.211	3.5	1	255.99609375	False
14:01:05.231	3.5	1	255.99609375	False
14:01:05.251	3.5	1	255.99609375	False
14:01:05.271	3.5	1	255.99609375	False
14:01:05.291	3.5	1	255.99609375	False
14:01:05.311	3.5	1	255.99609375	False
14:01:05.331	3.5	1	255.99609375	False
14:01:05.351	3.5	1	255.99609375	False
14:01:05.371	3.5	1	255.99609375	False
14:01:05.391	3.5	1	255.99609375	False
14:01:05.411	3.5	1	255.99609375	False
14:01:05.431	3.5	1	255.99609375	False
14:01:05.451	3.5	1	255.99609375	False
14:01:05.471	3.5	1	255.99609375	False
14:01:05.491	3.5	1	255.99609375	False
14:01:05.511	3.5	1	255.99609375	False
14:01:05.531	3.5	1	255.99609375	False
14:01:05.551	3.5	1	255.99609375	False
14:01:05.571	3.5	1	255.99609375	False
14:01:05.591	3.5	1	255.99609375	False
14:01:05.611	3.5	1	255.99609375	False
14:01:05.631	3.5	1	255.99609375	False
14:01:05.651	3.5	1	255.99609375	False
14:01:05.671	3.5	1	255.99609375	False
14:01:05.691	3.5	1	255.99609375	False
14:01:05.711	3.5	1	255.99609375	False
14:01:05.731	3.5	1	255.99609375	False
14:01:05.751	3.5	1	255.99609375	False
14:01:05.771	3.5	1	255.99609375	False
14:01:05.791	3.5	1	255.99609375	False
14:01:05.811	3.5	1	255.99609375	False
14:01:05.831	3.5	1	255.99609375	False
14:01:05.851	3.5	1	255.99609375	False
14:01:05.871	3.5	1	255.99609375	False
14:01:05.891	3.5	1	255.99609375	False
14:01:05.911	3.5	1	255.99609375	False
14:01:05.931	3.5	1	255.99609375	False
14:01:05.951	3.5	1	255.99609375	False
14:01:05.971	3.5	1	255.99609375	False
14:01:05.991	3.5	1	255.99609375	False
14:01:06.011	3.5	1	255.99609375	False
14:01:06.031	3.5	1	255.99609375	False
14:01:06.051	3.5	1	255.99609375	False
14:01:06.071	3.5	1	255.99609375	False
14:01:06.091	3.5	1	255.99609375	False
14:01:06.111	3.5	1	255.99609375	False
14:01:06.131	3.5	1	255.99609375	False
14:01:06.151	3.5	1	255.99609375	False
14:01:06.171	3.5	1	255.99609375	False
14:01:06.191	3.5	1	255.99609375	False
14:01:06.211	3.5	1	255.99609375	False
14:01:06.231	3.5	1	255.99609375	False
14:01:06.251	3.5	1	255.99609375	False
14:01:06.271	3.5	1	255.99609375	False
14:01:06.291	3.5	1	255.99609375	False
14:01:06.311	3.5	1	255.99609375	False
14:01:06.331	3.5	1	255.99609375	False
14:01:06.351	3.5	1	255.99609375	False
14:01:06.371	3.5	1	255.99609375	False
14:01:06.391	3.5	1	255.99609375	False
14:01:06.411	3.5	1	255.99609375	False
14:01:06.431	3.5	1	255.99609375	False
14:01:06.451	3.5	1	255.99609375	False
14:01:06.471	3.5	1	255.99609375	False
14:01:06.491	3.5	1	255.99609375	False
14:01:06.511	3.5	1	255.99609375	False
14:01:06.531	3.5	1	255.99609375	False
14:01:06.551	3.5	1	255.99609375	False
14:01:06.571	3.5	1	255.99609375	False
14:01:06.591	3.5	1	255.99609375	False
14:01:06.611	3.5	1	255.99609375	False
14:01:06.631	3.5	1	255.99609375	False
14:01:06.651	3.5	1	255.99609375	False
14:01:06.671	3.5	1	255.99609375	False
14:01:06.691	3.5	1	255.99609375	False
14:01:06.711	3.5	1	255.99609375	False
14:01:06.731	3.5	1	255.99609375	False
14:01:06.751	3.5	1	255.99609375	False
14:01:06.771	3.5	1	255.99609375	False
14:01:06.791	3.5	1	255.99609375	False
14:01:06.811	3.5	1	255.99609375	False
14:01:06.831	3.5	1	255.99609375	False
14:01:06.851	3.5	1	255.99609375	False
14:01:06.871	3.5	1	255.99609375	False
14:01:06.891	3.5	1	255.99609375	False
14:01:06.911	3.5	1	255.99609375	False
14:01:06.931	3.5	1	255.99609375	False
14:01:06.951	3.5	1	255.99609375	False
14:01:06.971	3.5	1	255.99609375	False
14:01:06.991	3.5	1	255.99609375	False
14:01:07.011	3.5	1	255.99609375	False
14:01:07.031	3.5	1	255.99609375	False
14:01:07.051	3.5	1	255.99609375	False
14:01:07.071	3.5	1	255.99609375	False
14:01:07.091	3.5	1	255.99609375	False
14:01:07.111	3.5	1	255.99609375	False
14:01:07.131	3.5	1	255.99609375	False
14:01:07.151	3.5	1	255.99609375	False
14:01:07.171	3.5	1	255.99609375	False
14:01:07.191	3.5	1	255.99609375	False
14:01:07.211	3.5	1	12.11328125	True
14:01:07.231	3.5	1	12.09375	False
14:01:07.251	3.5	1	12.09765625	True
14:01:07.271	3.5	1	12.09375	False
14:01:07.291	3.5	1	12.09375	False
14:01:07.311	3.5	1	12.09375	False
14:01:07.331	3.5	1	12.10546875	False
14:01:07.351	3.5	1	12.09765625	False
14:01:07.371	3.5	1	12.10546875	False
14:01:07.391	3.5	1	12.09765625	False
14:01:07.411	3.5	1	12.10546875	False
14:01:07.431	3.5	1	12.10546875	True
14:01:07.451	3.5	1	12.10546875	False
14:01:07.471	3.5	1	12.10546875	False
14:01:07.491	3.5	1	12.09765625	False
14:01:07.511	3.5	1	12.11328125	False
14:01:07.531	3.5	1	12.10546875	False
14:01:07.551	3.5	1	12.09765625	False
14:01:07.571	3.5	1	12.10546875	True
14:01:07.591	3.5	1	12.10546875	False
14:01:07.611	3.5	1	12.11328125	False
14:01:07.631	3.5	1	12.10546875	False
14:01:07.651	3.5	1	12.10546875	False
14:01:07.671	3.5	1	12.09375	False
14:01:07.691	3.5	1	12.09375	False
14:01:07.711	3.5	1	12.10546875	True
14:01:07.731	3.5	1	12.09765625	True
14:01:07.751	3.5	1	12.09765625	True
14:01:07.771	3.5	1	12.09375	True
14:01:07.791	3.5	1	12.09375	True
14:01:07.811	3.5	1	12.0859375	True
14:01:07.831	3.5	1	12.09375	True
14:01:07.851	3.5	1	12.09375	True
14:01:07.871	3.5	1	12.10546875	True
14:01:07.891	3.5	1	12.09765625	True
14:01:07.911	3.5	1	12.11328125	True
14:01:07.931	3.5	1	12.09765625	True
14:01:07.951	3.5	1	12.10546875	True
14:01:07.971	3.5	1	12.10546875	True
14:01:07.991	3.5	1	12.11328125	True
14:01:08.011	3.5	1	12.09765625	True
14:01:08.031	3.5	0.16	12.10546875	True
14:01:08.051	3.5	0.16	12.1171875	True
14:01:08.071	3.5	0.16	12.10546875	True
14:01:08.091	3.5	0.16	12.11328125	True
14:01:08.111	3.5	0.16	12.10546875	True
14:01:08.131	3.5	0.16	12.11328125	True
14:01:08.151	3.5	0.16	12.11328125	True
14:01:08.171	3	1	255.99609375	False
14:01:08.191	3	1	255.99609375	False
14:01:08.211	3	1	255.99609375	False
14:01:08.231	3	1	255.99609375	False
14:01:08.251	3	1	255.99609375	False
14:01:08.271	3	1	255.99609375	False
14:01:08.291	3	1	255.99609375	False
14:01:08.311	3	1	255.99609375	False
14:01:08.331	3	1	255.99609375	False
14:01:08.351	3	1	255.99609375	False
14:01:08.371	3	1	255.99609375	False
14:01:08.391	3	1	255.99609375	False
14:01:08.411	3	1	255.99609375	False
14:01:08.431	3	1	255.99609375	False
14:01:08.451	3	1	255.99609375	False
14:01:08.471	3	1	255.99609375	False
14:01:08.491	3	1	255.99609375	False
14:01:08.511	3	1	255.99609375	False
14:01:08.531	3	1	255.99609375	False
14:01:08.551	3	1	255.99609375	False
14:01:08.571	3	1	255.99609375	False
14:01:08.591	3	1	255.99609375	False
14:01:08.611	3	1	255.99609375	False
14:01:08.631	3	1	255.99609375	False
14:01:08.651	3	1	255.99609375	False
14:01:08.671	3	1	255.99609375	False
14:01:08.691	3	1	255.99609375	False
14:01:08.711	3	1	255.99609375	False
14:01:08.731	3	1	255.99609375	False
14:01:08.751	3	1	255.99609375	False
14:01:08.771	3	1	255.99609375	False
14:01:08.791	3	1	255.99609375	False
14:01:08.811	3	1	255.99609375	False
14:01:08.831	3	1	255.99609375	False
14:01:08.851	3	1	255.99609375	False
14:01:08.871	3	1	255.99609375	False
14:01:08.891	3	1	255.99609375	False
14:01:08.911	3	1	255.99609375	False
14:01:08.931	3	1	255.99609375	False
14:01:08.951	3	1	255.99609375	False
14:01:08.971	3	1	255.99609375	False
14:01:08.991	3	1	255.99609375	False
14:01:09.011	3	1	255.99609375	False
14:01:09.031	3	1	255.99609375	False
14:01:09.051	3	1	255.99609375	False
14:01:09.071	3	1	255.99609375	False
14:01:09.091	3	1	255.99609375	False
14:01:09.111	3	1	255.99609375	False
14:01:09.131	3	1	255.99609375	False
14:01:09.151	3	1	255.99609375	False
14:01:09.171	3	1	255.99609375	False
14:01:09.191	3	1	255.99609375	False
14:01:09.211	3	1	255.99609375	False
14:01:09.231	3	1	255.99609375	False
14:01:09.251	3	1	255.99609375	False
14:01:09.271	3	1	255.99609375	False
14:01:09.291	3	1	255.99609375	False
14:01:09.311	3	1	255.99609375	False
14:01:09.331	3	1	255.99609375	False
14:01:09.351	3	1	255.99609375	False
14:01:09.371	3	1	255.99609375	False
14:01:09.391	3	1	255.99609375	False
14:01:09.411	3	1	255.99609375	False
14:01:09.431	3	1	255.99609375	False
14:01:09.451	3	1	255.99609375	False
14:01:09.471	3	1	255.99609375	False
14:01:09.491	3	1	255.99609375	False
14:01:09.511	3	1	255.99609375	False
14:01:09.531	3	1	255.99609375	False
14:01:09.551	3	1	255.99609375	False
14:01:09.571	3	1	255.99609375	False
14:01:09.591	3	1	255.99609375	False
14:01:09.611	3	1	255.99609375	False
14:01:09.631	3	1	255.99609375	False
14:01:09.651	3	1	255.99609375	False
14:01:09.671	3	1	255.99609375	False
14:01:09.691	3	1	255.99609375	False
14:01:09.711	3	1	255.99609375	False
14:01:09.731	3	1	255.99609375	False
14:01:09.751	3	1	255.99609375	False
14:01:09.771	3	1	255.99609375	False
14:01:09.791	3	1	255.99609375	False
14:01:09.811	3	1	255.99609375	False
14:01:09.831	3	1	255.99609375	False
14:01:09.851	3	1	255.99609375	False
14:01:09.871	3	1	255.99609375	False
14:01:09.891	3	1	255.99609375	False
14:01:09.911	3	1	255.99609375	False
14:01:09.931	3	1	255.99609375	False
14:01:09.951	3	1	255.99609375	False
14:01:09.971	3	1	255.99609375	False
14:01:09.991	3	1	255.99609375	False
14:01:10.011	3	1	255.99609375	False
14:01:10.031	3	1	255.99609375	False
14:01:10.051	3	1	255.99609375	False
14:01:10.071	3	1	255.99609375	False
14:01:10.091	3	1	255.99609375	False
14:01:10.111	3	1	255.99609375	False
14:01:10.131	3	1	255.99609375	False
14:01:10.151	3	1	255.99609375	False
14:01:10.171	3	1	255.99609375	False
14:01:10.191	3	1	255.99609375	False
14:01:10.211	3	1	255.99609375	False
14:01:10.231	3	1	255.99609375	False
14:01:10.251	3	1	12.09375	True
14:01:10.271	3	1	12.09375	True
14:01:10.291	3	1	12.09375	True
14:01:10.311	3	1	12.09375	True
14:01:10.331	3	1	12.09375	True
14:01:10.351	3	1	12.09375	True
14:01:10.371	3	1	12.09375	True
14:01:10.391	3	1	12.09375	True
14:01:10.411	3	1	12.09375	True
14:01:10.431	3	1	12.10546875	False
14:01:10.451	3	1	12.10546875	False
14:01:10.471	3	1	12.09375	False
14:01:10.491	3	1	12.09765625	False
14:01:10.511	3	1	12.09765625	False
14:01:10.531	3	1	12.11328125	True
14:01:10.551	3	1	12.08203125	False
14:01:10.571	3	1	12.09765625	False
14:01:10.591	3	1	12.09375	False
14:01:10.611	3	1	12.09375	False
14:01:10.631	3	1	12.0859375	False
14:01:10.651	3	1	12.09375	False
14:01:10.671	3	1	12.09375	False
14:01:10.691	3	1	12.09375	False
14:01:10.711	3	1	12.09375	False
14:01:10.731	3	1	12.09765625	True
14:01:10.751	3	1	12.09375	True
14:01:10.771	3	1	12.09765625	False
14:01:10.791	3	1	12.10546875	True
14:01:10.811	3	1	12.09765625	True
14:01:10.831	3	1	12.09765625	True
14:01:10.851	3	1	12.10546875	True
14:01:10.871	3	1	12.10546875	True
14:01:10.891	3	0.48	12.10546875	True
14:01:10.911	3	0.48	12.11328125	True
14:01:10.931	3	0.48	12.10546875	True
14:01:10.951	3	0.48	12.10546875	True
14:01:10.971	3	0.48	12.10546875	True
14:01:10.991	3	0.48	12.0859375	True
14:01:11.011	3	0.48	12.10546875	True
14:01:11.031	3	0.48	12.09765625	True
14:01:11.051	3	0.48	12.09375	True
14:01:11.071	3	0.48	12.09765625	True
14:01:11.091	3	0.48	12.09765625	True
14:01:11.111	3.5	1	255.99609375	False
14:01:11.131	3.5	1	255.99609375	False
14:01:11.151	3.5	1	255.99609375	False
14:01:11.171	3.5	1	255.99609375	False
14:01:11.191	3.5	1	255.99609375	False
14:01:11.211	3.5	1	255.99609375	False
14:01:11.231	3.5	1	255.99609375	False
14:01:11.251	3.5	1	255.99609375	False
14:01:11.271	3.5	1	255.99609375	False
14:01:11.291	3.5	1	255.99609375	False
14:01:11.311	3.5	1	255.99609375	False
14:01:11.331	3.5	1	255.99609375	False
14:01:11.351	3.5	1	255.99609375	False
14:01:11.371	3.5	1	255.99609375	False
14:01:11.391	3.5	1	255.99609375	False
14:01:11.411	3.5	1	255.99609375	False
14:01:11.431	3.5	1	255.99609375	False
14:01:11.451	3.5	1	255.99609375	False
14:01:11.471	3.5	1	255.99609375	False
14:01:11.491	3.5	1	255.99609375	False
14:01:11.511	3.5	1	255.99609375	False
14:01:11.531	3.5	1	255.99609375	False
14:01:11.551	3.5	1	255.99609375	False
14:01:11.571	3.5	1	255.99609375	False
14:01:11.591	3.5	1	255.99609375	False
14:01:11.611	3.5	1	255.99609375	False
14:01:11.631	3.5	1	255.99609375	False
14:01:11.651	3.5	1	255.99609375	False
14:01:11.671	3.5	1	255.99609375	False
14:01:11.691	3.5	1	255.99609375	False
14:01:11.711	3.5	1	255.99609375	False
14:01:11.731	3.5	1	255.99609375	False
14:01:11.751	3.5	1	255.99609375	False
14:01:11.771	3.5	1	255.99609375	False
14:01:11.791	3.5	1	255.99609375	False
14:01:11.811	3.5	1	255.99609375	False
14:01:11.831	3.5	1	255.99609375	False
14:01:11.851	3.5	1	255.99609375	False
14:01:11.871	3.5	1	255.99609375	False
14:01:11.891	3.5	1	255.99609375	False
14:01:11.911	3.5	1	255.99609375	False
14:01:11.931	3.5	1	255.99609375	False
14:01:11.951	3.5	1	255.99609375	False
14:01:11.971	3.5	1	255.99609375	False
14:01:11.991	3.5	1	255.99609375	False
14:01:12.011	3.5	1	255.99609375	False
14:01:12.031	3.5	1	255.99609375	False
14:01:12.051	3.5	1	255.99609375	False
14:01:12.071	3.5	1	255.99609375	False
14:01:12.091	3.5	1	255.99609375	False
14:01:12.111	3.5	1	255.99609375	False
14:01:12.131	3.5	1	255.99609375	False
14:01:12.151	3.5	1	255.99609375	False
14:01:12.171	3.5	1	255.99609375	False
14:01:12.191	3.5	1	255.99609375	False
14:01:12.211	3.5	1	255.99609375	False
14:01:12.231	3.5	1	255.99609375	False
14:01:12.251	3.5	1	255.99609375	False
14:01:12.271	3.5	1	255.99609375	False
14:01:12.291	3.5	1	255.99609375	False
14:01:12.311	3.5	1	255.99609375	False
14:01:12.331	3.5	1	255.99609375	False
14:01:12.351	3.5	1	255.99609375	False
14:01:12.371	3.5	1	255.99609375	False
14:01:12.391	3.5	1	255.99609375	False
14:01:12.411	3.5	1	255.99609375	False
14:01:12.431	3.5	1	255.99609375	False
14:01:12.451	3.5	1	255.99609375	False
14:01:12.471	3.5	1	255.99609375	False
14:01:12.491	3.5	1	255.99609375	False
14:01:12.511	3.5	1	255.99609375	False
14:01:12.531	3.5	1	255.99609375	False
14:01:12.551	3.5	1	255.99609375	False
14:01:12.571	3.5	1	255.99609375	False
14:01:12.591	3.5	1	255.99609375	False
14:01:12.611	3.5	1	255.99609375	False
14:01:12.631	3.5	1	255.99609375	False
14:01:12.651	3.5	1	255.99609375	False
14:01:12.671	3.5	1	255.99609375	False
14:01:12.691	3.5	1	255.99609375	False
14:01:12.711	3.5	1	255.99609375	False
14:01:12.731	3.5	1	255.99609375	False
14:01:12.751	3.5	1	255.99609375	False
14:01:12.771	3.5	1	255.99609375	False
14:01:12.791	3.5	1	255.99609375	False
14:01:12.811	3.5	1	255.99609375	False
14:01:12.831	3.5	1	255.99609375	False
14:01:12.851	3.5	1	255.99609375	False
14:01:12.871	3.5	1	255.99609375	False
14:01:12.891	3.5	1	255.99609375	False
14:01:12.911	3.5	1	255.99609375	False
14:01:12.931	3.5	1	255.99609375	False
14:01:12.951	3.5	1	255.99609375	False
14:01:12.971	3.5	1	255.99609375	False
14:01:12.991	3.5	1	255.99609375	False
14:01:13.011	3.5	1	255.99609375	False
14:01:13.031	3.5	1	255.99609375	False
14:01:13.051	3.5	1	255.99609375	False
14:01:13.071	3.5	1	255.99609375	False
14:01:13.091	3.5	1	255.99609375	False
14:01:13.111	3.5	1	255.99609375	False
14:01:13.131	3.5	1	255.99609375	False
14:01:13.151	3.5	1	255.99609375	False
14:01:13.171	3.5	1	255.99609375	False
14:01:13.191	3.5	1	255.99609375	False
14:01:13.211	3.5	1	255.99609375	False
14:01:13.231	3.5	1	255.99609375	False
14:01:13.251	3.5	1	255.99609375	False
14:01:13.271	3.5	1	255.99609375	False
14:01:13.291	3.5	1	255.99609375	False
14:01:13.311	3.5	1	12.10546875	True
14:01:13.331	3.5	1	12.10546875	True
14:01:13.351	3.5	1	12.10546875	True
14:01:13.371	3.5	1	12.10546875	False
14:01:13.391	3.5	1	12.10546875	False
14:01:13.411	3.5	1	12.11328125	False
14:01:13.431	3.5	1	12.10546875	True
14:01:13.451	3.5	1	12.10546875	False
14:01:13.471	3.5	1	12.09765625	False
14:01:13.491	3.5	1	12.09765625	True
14:01:13.511	3.5	1	12.10546875	False
14:01:13.531	3.5	1	12.09765625	False
14:01:13.551	3.5	1	12.09765625	False
14:01:13.571	3.5	1	12.09375	False
14:01:13.591	3.5	1	12.09765625	False
14:01:13.611	3.5	1	12.09765625	True
14:01:13.631	3.5	1	12.11328125	True
14:01:13.651	3.5	1	12.09765625	True
14:01:13.671	3.5	1	12.09765625	True
14:01:13.691	3.5	1	12.10546875	True
14:01:13.711	3.5	1	12.09765625	True
14:01:13.731	3.5	1	12.10546875	True
14:01:13.751	3.5	1	12.11328125	True
14:01:13.771	3.5	1	12.09765625	True
14:01:13.791	3.5	0.24	12.10546875	True
14:01:13.811	3.5	0.24	12.09765625	True
14:01:13.831	3.5	0.24	12.0859375	True
14:01:13.851	3.5	0.24	12.09375	True
14:01:13.871	3.5	0.24	12.09765625	True
14:01:13.891	3.5	0.24	12.09375	True
14:01:13.911	3.5	0.24	12.09765625	True
14:01:13.931	3.5	0.24	12.09765625	True
14:01:13.951	3.5	0.24	12.09765625	True
14:01:13.971	3.5	0.24	12.09375	True
14:01:13.991	3.5	0.24	12.125	True
14:01:14.011	3.5	1	255.99609375	False
14:01:14.031	3.5	1	255.99609375	False
14:01:14.051	3.5	1	255.99609375	False
14:01:14.071	3.5	1	255.99609375	False
14:01:14.091	3.5	1	255.99609375	False
14:01:14.111	3.5	1	255.99609375	False
14:01:14.131	3.5	1	255.99609375	False
14:01:14.151	3.5	1	255.99609375	False
14:01:14.171	3.5	1	255.99609375	False
14:01:14.191	3.5	1	255.99609375	False
14:01:14.211	3.5	1	255.99609375	False
14:01:14.231	3.5	1	255.99609375	False
14:01:14.251	3.5	1	255.99609375	False
14:01:14.271	3.5	1	255.99609375	False
14:01:14.291	3.5	1	255.99609375	False
14:01:14.311	3.5	1	255.99609375	False
14:01:14.331	3.5	1	255.99609375	False
14:01:14.351	3.5	1	255.99609375	False
14:01:14.371	3.5	1	255.99609375	False
14:01:14.391	3.5	1	255.99609375	False
14:01:14.411	3.5	1	255.99609375	False
14:01:14.431	3.5	1	255.99609375	False
14:01:14.451	3.5	1	255.99609375	False
14:01:14.471	3.5	1	255.99609375	False
14:01:14.491	3.5	1	255.99609375	False
14:01:14.511	3.5	1	255.99609375	False
14:01:14.531	3.5	1	255.99609375	False
14:01:14.551	3.5	1	255.99609375	False
14:01:14.571	3.5	1	255.99609375	False
14:01:14.591	3.5	1	255.99609375	False
14:01:14.611	3.5	1	255.99609375	False
14:01:14.631	3.5	1	255.99609375	False
14:01:14.651	3.5	1	255.99609375	False
14:01:14.671	3.5	1	255.99609375	False
14:01:14.691	3.5	1	255.99609375	False
14:01:14.711	3.5	1	255.99609375	False
14:01:14.731	3.5	1	255.99609375	False
14:01:14.751	3.5	1	255.99609375	False
14:01:14.771	3.5	1	255.99609375	False
14:01:14.791	3.5	1	255.99609375	False
14:01:14.811	3.5	1	255.99609375	False
14:01:14.831	3.5	1	255.99609375	False
14:01:14.851	3.5	1	255.99609375	False
14:01:14.871	3.5	1	255.99609375	False
14:01:14.891	3.5	1	255.99609375	False
14:01:14.911	3.5	1	255.99609375	False
14:01:14.931	3.5	1	255.99609375	False
14:01:14.951	3.5	1	255.99609375	False
14:01:14.971	3.5	1	255.99609375	False
14:01:14.991	3.5	1	255.99609375	False
14:01:15.011	3.5	1	255.99609375	False
14:01:15.031	3.5	1	255.99609375	False
14:01:15.051	3.5	1	255.99609375	False
14:01:15.071	3.5	1	255.99609375	False
14:01:15.091	3.5	1	255.99609375	False
14:01:15.111	3.5	1	255.99609375	False
14:01:15.131	3.5	1	255.99609375	False
14:01:15.151	3.5	1	255.99609375	False
14:01:15.171	3.5	1	255.99609375	False
14:01:15.191	3.5	1	255.99609375	False
14:01:15.211	3.5	1	255.99609375	False
14:01:15.231	3.5	1	255.99609375	False
14:01:15.251	3.5	1	255.99609375	False
14:01:15.271	3.5	1	255.99609375	False
14:01:15.291	3.5	1	255.99609375	False
14:01:15.311	3.5	1	255.99609375	False
14:01:15.331	3.5	1	255.99609375	False
14:01:15.351	3.5	1	255.99609375	False
14:01:15.371	3.5	1	255.99609375	False
14:01:15.391	3.5	1	255.99609375	False
14:01:15.411	3.5	1	255.99609375	False
14:01:15.431	3.5	1	255.99609375	False
14:01:15.451	3.5	1	255.99609375	False
14:01:15.471	3.5	1	255.99609375	False
14:01:15.491	3.5	1	255.99609375	False
14:01:15.511	3.5	1	255.99609375	False
14:01:15.531	3.5	1	255.99609375	False
14:01:15.551	3.5	1	255.99609375	False
14:01:15.571	3.5	1	255.99609375	False
14:01:15.591	3.5	1	255.99609375	False
14:01:15.611	3.5	1	255.99609375	False
14:01:15.631	3.5	1	255.99609375	False
14:01:15.651	3.5	1	255.99609375	False
14:01:15.671	3.5	1	255.99609375	False
14:01:15.691	3.5	1	255.99609375	False
14:01:15.711	3.5	1	255.99609375	False
14:01:15.731	3.5	1	255.99609375	False
14:01:15.751	3.5	1	255.99609375	False
14:01:15.771	3.5	1	255.99609375	False
14:01:15.791	3.5	1	255.99609375	False
14:01:15.811	3.5	1	255.99609375	False
14:01:15.831	3.5	1	255.99609375	False
14:01:15.851	3.5	1	255.99609375	False
14:01:15.871	3.5	1	255.99609375	False
14:01:15.891	3.5	1	255.99609375	False
14:01:15.911	3.5	1	255.99609375	False
14:01:15.931	3.5	1	255.99609375	False
14:01:15.951	3.5	1	255.99609375	False
14:01:15.971	3.5	1	255.99609375	False
14:01:15.991	3.5	1	255.99609375	False
14:01:16.011	3.5	1	255.99609375	False
14:01:16.031	3.5	1	255.99609375	False
14:01:16.051	3.5	1	255.99609375	False
14:01:16.071	3.5	1	255.99609375	False
14:01:16.091	3.5	1	255.99609375	False
14:01:16.111	3.5	1	255.99609375	False
14:01:16.131	3.5	1	255.99609375	False
14:01:16.151	3.5	1	255.99609375	False
14:01:16.171	3.5	1	255.99609375	False
14:01:16.191	3.5	1	255.99609375	False
14:01:16.211	3.5	1	255.99609375	False
14:01:16.231	3.5	1	255.99609375	False
14:01:16.251	3.5	1	255.99609375	False
14:01:16.271	3.5	1	255.99609375	False
14:01:16.291	3.5	1	255.99609375	False
14:01:16.311	3.5	1	255.99609375	False
14:01:16.331	3.5	1	12.11328125	True
14:01:16.351	3.5	1	12.11328125	True
14:01:16.371	3.5	1	12.11328125	True
14:01:16.391	3.5	1	12.11328125	True
14:01:16.411	3.5	1	12.11328125	True
14:01:16.431	3.5	1	12.11328125	True
14:01:16.451	3.5	1	12.11328125	True
14:01:16.471	3.5	1	12.1171875	False
14:01:16.491	3.5	1	12.1171875	False
14:01:16.511	3.5	1	12.09765625	False
14:01:16.531	3.5	1	12.09375	False
14:01:16.551	3.5	1	12.10546875	False
14:01:16.571	3.5	1	12.09375	False
14:01:16.591	3.5	1	12.10546875	False
14:01:16.611	3.5	1	12.09765625	True
14:01:16.631	3.5	1	12.09765625	False
14:01:16.651	3.5	1	12.10546875	False
14:01:16.671	3.5	1	12.10546875	False
14:01:16.691	3.5	1	12.09375	False
14:01:16.711	3.5	1	12.10546875	False
14:01:16.731	3.5	1	12.09375	True
14:01:16.751	3.5	1	12.09765625	False
14:01:16.771	3.5	1	12.09375	False
14:01:16.791	3.5	1	12.09375	False
14:01:16.811	3.5	1	12.09765625	False
14:01:16.831	3.5	1	12.09765625	False
14:01:16.851	3.5	1	12.09375	True
14:01:16.871	3.5	1	12.09375	False
14:01:16.891	3.5	1	12.0859375	False
14:01:16.911	3.5	1	12.10546875	False
14:01:16.931	3.5	1	12.09765625	False
14:01:16.951	3.5	1	12.09765625	False
14:01:16.971	3.5	1	12.09375	False
14:01:16.991	3.5	1	12.09765625	True
14:01:17.011	3.5	1	12.09765625	True
14:01:17.031	3.5	1	12.09375	True
14:01:17.051	3.5	1	12.09765625	True
14:01:17.071	3.5	1	12.10546875	True
14:01:17.091	3.5	0.36	12.09765625	True
14:01:17.111	3.5	0.36	12.10546875	True
14:01:17.131	3.5	0.36	12.09765625	True
14:01:17.151	3.5	0.36	12.09765625	True
14:01:17.171	3.5	0.36	12.09765625	True
14:01:17.191	3.5	0.36	12.11328125	True
14:01:17.211	3.5	0.36	12.09765625	True
14:01:17.231	3.5	0.36	12.09765625	True
14:01:17.251	3.5	0.36	12.10546875	True
14:01:17.271	3.5	0.36	12.10546875	True
14:01:17.291	3.5	0.36	12.09765625	True
14:01:17.311	3.5	0.36	12.11328125	True
14:01:17.331	3.5	0.36	12.11328125	True
14:01:17.351	3.5	0.36	12.09765625	True
14:01:17.371	3.5	1	255.99609375	False
14:01:17.391	3.5	1	255.99609375	False
14:01:17.411	3.5	1	255.99609375	False
14:01:17.431	3.5	1	255.99609375	False
14:01:17.451	3.5	1	255.99609375	False
14:01:17.471	3.5	1	255.99609375	False
14:01:17.491	3.5	1	255.99609375	False
14:01:17.511	3.5	1	255.99609375	False
14:01:17.531	3.5	1	255.99609375	False
14:01:17.551	3.5	1	255.99609375	False
14:01:17.571	3.5	1	255.99609375	False
14:01:17.591	3.5	1	255.99609375	False
14:01:17.611	3.5	1	255.99609375	False
14:01:17.631	3.5	1	255.99609375	False
14:01:17.651	3.5	1	255.99609375	False
14:01:17.671	3.5	1	255.99609375	False
14:01:17.691	3.5	1	255.99609375	False
14:01:17.711	3.5	1	255.99609375	False
14:01:17.731	3.5	1	255.99609375	False
14:01:17.751	3.5	1	255.99609375	False
14:01:17.771	3.5	1	255.99609375	False
14:01:17.791	3.5	1	255.99609375	False
14:01:17.811	3.5	1	255.99609375	False
14:01:17.831	3.5	1	255.99609375	False
14:01:17.851	3.5	1	255.99609375	False
14:01:17.871	3.5	1	255.99609375	False
14:01:17.891	3.5	1.04	255.99609375	False
14:01:17.911	3.5	1.04	255.99609375	False
14:01:17.931	3.5	1.04	255.99609375	False
14:01:17.951	3.5	1.04	255.99609375	False
14:01:17.971	3.5	1.04	255.99609375	False
14:01:17.991	3.5	1.04	255.99609375	False
14:01:18.011	3.5	1.04	255.99609375	False
14:01:18.031	3.5	1.04	255.99609375	False
14:01:18.051	3.5	1.04	255.99609375	False
14:01:18.071	3.5	1.04	255.99609375	False
14:01:18.091	3.5	1.04	255.99609375	False
14:01:18.111	3.5	1.04	255.99609375	False
14:01:18.131	3.5	1.04	255.99609375	False
14:01:18.151	3.5	1.04	255.99609375	False
14:01:18.171	3.5	1.04	255.99609375	False
14:01:18.191	3.5	1.04	255.99609375	False
14:01:18.211	3.5	1.04	255.99609375	False
14:01:18.231	3.5	1.04	255.99609375	False
14:01:18.251	3.5	1.04	255.99609375	False
14:01:18.271	3.5	1.04	255.99609375	False
14:01:18.291	3.5	1.04	255.99609375	False
14:01:18.311	3.5	1.04	255.99609375	False
14:01:18.331	3.5	1.04	255.99609375	False
14:01:18.351	3.5	1.04	255.99609375	False
14:01:18.371	3.5	1.04	255.99609375	False
14:01:18.391	3.5	1.04	255.99609375	False
14:01:18.411	3.5	1	255.99609375	False
14:01:18.431	3.5	1	255.99609375	False
14:01:18.451	3.5	1	255.99609375	False
14:01:18.471	3.5	1	255.99609375	False
14:01:18.491	3.5	1	255.99609375	False
14:01:18.511	3.5	1	255.99609375	False
14:01:18.531	3.5	1	255.99609375	False
14:01:18.551	3.5	1	255.99609375	False
14:01:18.571	3.5	1	255.99609375	False
14:01:18.591	3.5	1	255.99609375	False
14:01:18.611	3.5	1	255.99609375	False
14:01:18.631	3.5	1	255.99609375	False
14:01:18.651	3.5	1	255.99609375	False
14:01:18.671	3.5	1	255.99609375	False
14:01:18.691	3.5	1	255.99609375	False
14:01:18.711	3.5	1	255.99609375	False
14:01:18.731	3.5	1	255.99609375	False
14:01:18.751	3.5	1	255.99609375	False
14:01:18.771	3.5	1	255.99609375	False
14:01:18.791	3.5	1	255.99609375	False
14:01:18.811	3.5	1	255.99609375	False
14:01:18.831	3.5	1	255.99609375	False
14:01:18.851	3.5	1	255.99609375	False
14:01:18.871	3.5	1	255.99609375	False
14:01:18.891	3.5	1	255.99609375	False
14:01:18.911	3.5	1.04	255.99609375	False
14:01:18.931	3.5	1.04	255.99609375	False
14:01:18.951	3.5	1.04	255.99609375	False
14:01:18.971	3.5	1.04	255.99609375	False
14:01:18.991	3.5	1.04	255.99609375	False
14:01:19.011	3.5	1.04	255.99609375	False
14:01:19.031	3.5	1.04	255.99609375	False
14:01:19.051	3.5	1.04	255.99609375	False
14:01:19.071	3.5	1.04	255.99609375	False
14:01:19.091	3.5	1.04	255.99609375	False
14:01:19.111	3.5	1.04	255.99609375	False
14:01:19.131	3.5	1.04	255.99609375	False
14:01:19.151	3.5	1.04	255.99609375	False
14:01:19.171	3.5	1.04	255.99609375	False
14:01:19.191	3.5	1.04	255.99609375	False
14:01:19.211	3.5	1.04	255.99609375	False
14:01:19.231	3.5	1.04	255.99609375	False
14:01:19.251	3.5	1.04	255.99609375	False
14:01:19.271	3.5	1.04	255.99609375	False
14:01:19.291	3.5	1.04	255.99609375	False
14:01:19.311	3.5	1.04	255.99609375	False
14:01:19.331	3.5	1.04	255.99609375	False
14:01:19.351	3.5	1.04	255.99609375	False
14:01:19.371	3.5	1.04	255.99609375	False
14:01:19.391	3.5	1.04	255.99609375	False
14:01:19.411	3.5	1.04	255.99609375	False
14:01:19.431	3.5	1.04	12.09765625	True
14:01:19.451	3.5	1.04	12.09765625	True
14:01:19.471	3.5	1.04	12.09765625	True
14:01:19.491	3.5	1.04	12.09765625	True
14:01:19.511	3.5	1.04	12.09765625	True
14:01:19.531	3.5	1.04	12.09765625	True
14:01:19.551	3.5	1.04	12.09375	False
14:01:19.571	3.5	1.04	12.09375	False
14:01:19.591	3.5	1.04	12.09765625	False
14:01:19.611	3.5	1.04	12.0859375	False
14:01:19.631	3.5	1.04	12.09375	False
14:01:19.651	3.5	1.04	12.08203125	True
14:01:19.671	3.5	1.04	12.09765625	False
14:01:19.691	3.5	1.04	12.07421875	False
14:01:19.711	3.5	1.04	12.0859375	False
14:01:19.731	3.5	1.04	12.09765625	False
14:01:19.751	3.5	1.04	12.09375	True
14:01:19.771	3.5	0.32	12.09765625	True
14:01:19.791	3.5	0.32	12.09765625	True
14:01:19.811	3.5	0.32	12.09375	True
14:01:19.831	3.5	0.32	12.10546875	True
14:01:19.851	3.5	0.32	12.11328125	True
14:01:19.871	3.5	0.32	12.09765625	True
14:01:19.891	3.5	0.32	12.10546875	True
14:01:19.911	3.5	0.32	12.10546875	True
14:01:19.931	3.5	0.32	12.10546875	True
14:01:19.951	3.5	0.32	12.10546875	True
14:01:19.971	3.5	0.32	12.125	True
14:01:19.991	3.5	0.32	12.09765625	True
14:01:20.011	3.5	0.32	12.10546875	True
14:01:20.031	3.5	0.32	12.09765625	True
14:01:20.051	3.5	0.32	12.10546875	True
14:01:20.071	3.5	0.32	12.09765625	True
14:01:20.091	3.5	1	255.99609375	False
14:01:20.111	3.5	1	255.99609375	False
14:01:20.131	3.5	1	255.99609375	False
14:01:20.151	3.5	1	255.99609375	False
14:01:20.171	3.5	1	255.99609375	False
14:01:20.191	3.5	1	255.99609375	False
14:01:20.211	3.5	1	255.99609375	False
14:01:20.231	3.5	1	255.99609375	False
14:01:20.251	3.5	1	255.99609375	False
14:01:20.271	3.5	1	255.99609375	False
14:01:20.291	3.5	1	255.99609375	False
14:01:20.311	3.5	1	255.99609375	False
14:01:20.331	3.5	1	255.99609375	False
14:01:20.351	3.5	1	255.99609375	False
14:01:20.371	3.5	1	255.99609375	False
14:01:20.391	3.5	1	255.99609375	False
14:01:20.411	3.5	1	255.99609375	False
14:01:20.431	3.5	1	255.99609375	False
14:01:20.451	3.5	1	255.99609375	False
14:01:20.471	3.5	1	255.99609375	False
14:01:20.491	3.5	1	255.99609375	False
14:01:20.511	3.5	1	255.99609375	False
14:01:20.531	3.5	1	255.99609375	False
14:01:20.551	3.5	1	255.99609375	False
14:01:20.571	3.5	1	255.99609375	False
14:01:20.591	3.5	1	255.99609375	False
14:01:20.611	3.5	1	255.99609375	False
14:01:20.631	3.5	1	255.99609375	False
14:01:20.651	3.5	1	255.99609375	False
14:01:20.671	3.5	1	255.99609375	False
14:01:20.691	3.5	1	255.99609375	False
14:01:20.711	3.5	1	255.99609375	False
14:01:20.731	3.5	1	255.99609375	False
14:01:20.751	3.5	1	255.99609375	False
14:01:20.771	3.5	1	255.99609375	False
14:01:20.791	3.5	1	255.99609375	False
14:01:20.811	3.5	1	255.99609375	False
14:01:20.831	3.5	1	255.99609375	False
14:01:20.851	3.5	1	255.99609375	False
14:01:20.871	3.5	1	255.99609375	False
14:01:20.891	3.5	1	255.99609375	False
14:01:20.911	3.5	1	255.99609375	False
14:01:20.931	3.5	1	255.99609375	False
14:01:20.951	3.5	1	255.99609375	False
14:01:20.971	3.5	1	255.99609375	False
14:01:20.991	3.5	1	255.99609375	False
14:01:21.011	3.5	1	255.99609375	False
14:01:21.031	3.5	1	255.99609375	False
14:01:21.051	3.5	1	255.99609375	False
14:01:21.071	3.5	1	255.99609375	False
14:01:21.091	3.5	1	255.99609375	False
14:01:21.111	3.5	1	255.99609375	False
14:01:21.131	3.5	1	255.99609375	False
14:01:21.151	3.5	1	255.99609375	False
14:01:21.171	3.5	1	255.99609375	False
14:01:21.191	3.5	1	255.99609375	False
14:01:21.211	3.5	1	255.99609375	False
14:01:21.231	3.5	1	255.99609375	False
14:01:21.251	3.5	1	255.99609375	False
14:01:21.271	3.5	1	255.99609375	False
14:01:21.291	3.5	1	255.99609375	False
14:01:21.311	3.5	1	255.99609375	False
14:01:21.331	3.5	1	255.99609375	False
14:01:21.351	3.5	1	255.99609375	False
14:01:21.371	3.5	1	255.99609375	False
14:01:21.391	3.5	1	255.99609375	False
14:01:21.411	3.5	1	255.99609375	False
14:01:21.431	3.5	1	255.99609375	False
14:01:21.451	3.5	1	255.99609375	False
14:01:21.471	3.5	1	255.99609375	False
14:01:21.491	3.5	1	255.99609375	False
14:01:21.511	3.5	1	255.99609375	False
14:01:21.531	3.5	1	255.99609375	False
14:01:21.551	3.5	1	255.99609375	False
14:01:21.571	3.5	1	255.99609375	False
14:01:21.591	3.5	1	255.99609375	False
14:01:21.611	3.5	1	255.99609375	False
14:01:21.631	3.5	1	255.99609375	False
14:01:21.651	3.5	1	255.99609375	False
14:01:21.671	3.5	1	255.99609375	False
14:01:21.691	3.5	1	255.99609375	False
14:01:21.711	3.5	1	255.99609375	False
14:01:21.731	3.5	1	255.99609375	False
14:01:21.751	3.5	1	255.99609375	False
14:01:21.771	3.5	1	255.99609375	False
14:01:21.791	3.5	1	255.99609375	False
14:01:21.811	3.5	1	255.99609375	False
14:01:21.831	3.5	1	255.99609375	False
14:01:21.851	3.5	1	255.99609375	False
14:01:21.871	3.5	1	255.99609375	False
14:01:21.891	3.5	1	255.99609375	False
14:01:21.911	3.5	1	255.99609375	False
14:01:21.931	3.5	1	255.99609375	False
14:01:21.951	3.5	1	255.99609375	False
14:01:21.971	3.5	1	255.99609375	False
14:01:21.991	3.5	1	255.99609375	False
14:01:22.011	3.5	1	255.99609375	False
14:01:22.031	3.5	1	255.99609375	False
14:01:22.051	3.5	1	255.99609375	False
14:01:22.071	3.5	1	255.99609375	False
14:01:22.091	3.5	1	255.99609375	False
14:01:22.111	3.5	1	255.99609375	False
14:01:22.131	3.5	1	255.99609375	False
14:01:22.151	3.5	1	255.99609375	False
14:01:22.171	3.5	1	255.99609375	False
14:01:22.191	3.5	1	255.99609375	False
14:01:22.211	3.5	1	255.99609375	False
14:01:22.231	3.5	1	255.99609375	False
14:01:22.251	3.5	1	255.99609375	False
14:01:22.271	3.5	1	255.99609375	False
14:01:22.291	3.5	1	255.99609375	False
14:01:22.311	3.5	1	255.99609375	False
14:01:22.331	3.5	1	255.99609375	False
14:01:22.351	3.5	1	255.99609375	False
14:01:22.371	3.5	1	255.99609375	False
14:01:22.391	3.5	1	255.99609375	False
14:01:22.411	3.5	1	255.99609375	False
14:01:22.431	3.5	1	12.10546875	True
14:01:22.451	3.5	1	12.10546875	True
14:01:22.471	3.5	1	12.10546875	True
14:01:22.491	3.5	1	12.10546875	True
14:01:22.511	3.5	1	12.10546875	True
14:01:22.531	3.5	1	12.10546875	True
14:01:22.551	3.5	1	12.10546875	True
14:01:22.571	3.5	1	12.10546875	True
14:01:22.591	3.5	1	12.1171875	False
14:01:22.611	3.5	1	12.10546875	False
14:01:22.631	3.5	1	12.09765625	False
14:01:22.651	3.5	1	12.09765625	False
14:01:22.671	3.5	1	12.09765625	False
14:01:22.691	3.5	1	12.10546875	False
14:01:22.711	3.5	1	12.10546875	True
14:01:22.731	3.5	1	12.11328125	True
14:01:22.751	3.5	1	12.09765625	False
14:01:22.771	3.5	1	12.09765625	False
14:01:22.791	3.5	0.36	12.09765625	True
14:01:22.811	3.5	0.36	12.10546875	True
14:01:22.831	3.5	0.36	12.11328125	True
14:01:22.851	3.5	0.36	12.10546875	True
14:01:22.871	3.5	0.36	12.09765625	True
14:01:22.891	3.5	0.36	12.09765625	True
14:01:22.911	3.5	0.36	12.10546875	True
14:01:22.931	3.5	0.36	12.09375	True
14:01:22.951	3.5	0.36	12.09375	True
14:01:22.971	3.5	0.36	12.09765625	True
14:01:22.991	3.5	0.36	12.09765625	True
14:01:23.011	3.5	0.36	12.09375	True
14:01:23.031	3.5	0.36	12.09375	True
14:01:23.051	3.5	0.36	12.09765625	True
14:01:23.071	3.5	0.36	12.09375	True
14:01:23.091	3.5	0.36	12.09375	True
14:01:23.111	3.5	0.36	12.09375	True
14:01:23.131	3.5	1.08	255.99609375	False
14:01:23.151	3.5	1.08	255.99609375	False
14:01:23.171	3.5	1.08	255.99609375	False
14:01:23.191	3.5	1.08	255.99609375	False
14:01:23.211	3.5	1.08	255.99609375	False
14:01:23.231	3.5	1.08	255.99609375	False
14:01:23.251	3.5	1.08	255.99609375	False
14:01:23.271	3.5	1.08	255.99609375	False
14:01:23.291	3.5	1.08	255.99609375	False
14:01:23.311	3.5	1.08	255.99609375	False
14:01:23.331	3.5	1.08	255.99609375	False
14:01:23.351	3.5	1.08	255.99609375	False
14:01:23.371	3.5	1.08	255.99609375	False
14:01:23.391	3.5	1.08	255.99609375	False
14:01:23.411	3.5	1.08	255.99609375	False
14:01:23.431	3.5	1.08	255.99609375	False
14:01:23.451	3.5	1.08	255.99609375	False
14:01:23.471	3.5	1	255.99609375	False
14:01:23.491	3.5	1	255.99609375	False
14:01:23.511	3.5	1	255.99609375	False
14:01:23.531	3.5	1	255.99609375	False
14:01:23.551	3.5	1	255.99609375	False
14:01:23.571	3.5	1	255.99609375	False
14:01:23.591	3.5	1	255.99609375	False
14:01:23.611	3.5	1	255.99609375	False
14:01:23.631	3.5	1	255.99609375	False
14:01:23.651	3.5	1	255.99609375	False
14:01:23.671	3.5	1	255.99609375	False
14:01:23.691	3.5	1	255.99609375	False
14:01:23.711	3.5	1	255.99609375	False
14:01:23.731	3.5	1	255.99609375	False
14:01:23.751	3.5	1	255.99609375	False
14:01:23.771	3.5	1	255.99609375	False
14:01:23.791	3.5	1	255.99609375	False
14:01:23.811	3.5	1	255.99609375	False
14:01:23.831	3.5	1	255.99609375	False
14:01:23.851	3.5	1	255.99609375	False
14:01:23.871	3.5	1	255.99609375	False
14:01:23.891	3.5	1	255.99609375	False
14:01:23.911	3.5	1	255.99609375	False
14:01:23.931	3.5	1	255.99609375	False
14:01:23.951	3.5	1	255.99609375	False
14:01:23.971	3.5	1	255.99609375	False
14:01:23.991	3.5	1	255.99609375	False
14:01:24.011	3.5	1	255.99609375	False
14:01:24.031	3.5	1	255.99609375	False
14:01:24.051	3.5	1	255.99609375	False
14:01:24.071	3.5	1	255.99609375	False
14:01:24.091	3.5	1	255.99609375	False
14:01:24.111	3.5	1	255.99609375	False
14:01:24.131	3.5	1	255.99609375	False
14:01:24.151	3.5	1	255.99609375	False
14:01:24.171	3.5	1	255.99609375	False
14:01:24.191	3.5	1	255.99609375	False
14:01:24.211	3.5	1	255.99609375	False
14:01:24.231	3.5	1	255.99609375	False
14:01:24.251	3.5	1	255.99609375	False
14:01:24.271	3.5	1	255.99609375	False
14:01:24.291	3.5	1	255.99609375	False
14:01:24.311	3.5	1	255.99609375	False
14:01:24.331	3.5	1	255.99609375	False
14:01:24.351	3.5	1	255.99609375	False
14:01:24.371	3.5	1	255.99609375	False
14:01:24.391	3.5	1	255.99609375	False
14:01:24.411	3.5	1	255.99609375	False
14:01:24.431	3.5	1	255.99609375	False
14:01:24.451	3.5	1	255.99609375	False
14:01:24.471	3.5	1	255.99609375	False
14:01:24.491	3.5	1	255.99609375	False
14:01:24.511	3.5	1	255.99609375	False
14:01:24.531	3.5	1	255.99609375	False
14:01:24.551	3.5	1	255.99609375	False
14:01:24.571	3.5	1	255.99609375	False
14:01:24.591	3.5	1	255.99609375	False
14:01:24.611	3.5	1	255.99609375	False
14:01:24.631	3.5	1	255.99609375	False
14:01:24.651	3.5	1	255.99609375	False
14:01:24.671	3.5	1	255.99609375	False
14:01:24.691	3.5	1	255.99609375	False
14:01:24.711	3.5	1	255.99609375	False
14:01:24.731	3.5	1	255.99609375	False
14:01:24.751	3.5	1	255.99609375	False
14:01:24.771	3.5	1	255.99609375	False
14:01:24.791	3.5	1	255.99609375	False
14:01:24.811	3.5	1	255.99609375	False
14:01:24.831	3.5	1	255.99609375	False
14:01:24.851	3.5	1	255.99609375	False
14:01:24.871	3.5	1	255.99609375	False
14:01:24.891	3.5	1	255.99609375	False
14:01:24.911	3.5	1	255.99609375	False
14:01:24.931	3.5	1	255.99609375	False
14:01:24.951	3.5	1	255.99609375	False
14:01:24.971	3.5	1	255.99609375	False
14:01:24.991	3.5	1	255.99609375	False
14:01:25.011	3.5	1	255.99609375	False
14:01:25.031	3.5	1	255.99609375	False
14:01:25.051	3.5	1	255.99609375	False
14:01:25.071	3.5	1	255.99609375	False
14:01:25.091	3.5	1	255.99609375	False
14:01:25.111	3.5	1	255.99609375	False
14:01:25.131	3.5	1	255.99609375	False
14:01:25.151	3.5	1	255.99609375	False
14:01:25.171	3.5	1	255.99609375	False
14:01:25.191	3.5	1	255.99609375	False
14:01:25.211	3.5	1	255.99609375	False
14:01:25.231	3.5	1	255.99609375	False
14:01:25.251	3.5	1	255.99609375	False
14:01:25.271	3.5	1	255.99609375	False
14:01:25.291	3.5	1	255.99609375	False
14:01:25.311	3.5	1	255.99609375	False
14:01:25.331	3.5	1	255.99609375	False
14:01:25.351	3.5	1	255.99609375	False
14:01:25.371	3.5	1	255.99609375	False
14:01:25.391	3.5	1	255.99609375	False
14:01:25.411	3.5	1	255.99609375	False
14:01:25.431	3.5	1	255.99609375	False
14:01:25.451	3.5	1	255.99609375	False
14:01:25.471	3.5	1	12.11328125	True
14:01:25.491	3.5	1	12.11328125	True
14:01:25.511	3.5	1	12.09765625	False
14:01:25.531	3.5	1	12.10546875	False
14:01:25.551	3.5	1	12.11328125	False
14:01:25.571	3.5	1	12.11328125	False
14:01:25.591	3.5	1	12.10546875	False
14:01:25.611	3.5	1	12.09765625	True
14:01:25.631	3.5	1	12.10546875	False
14:01:25.651	3.5	1	12.09375	False
14:01:25.671	3.5	1	12.09375	False
14:01:25.691	3.5	1	12.09765625	True
14:01:25.711	3.5	1	12.09765625	True
14:01:25.731	3.5	1	12.10546875	False
14:01:25.751	3.5	1	12.09765625	False
14:01:25.771	3.5	1	12.09765625	False
14:01:25.791	3.5	1	12.09375	False
14:01:25.811	3.5	1	12.09765625	True
14:01:25.831	3.5	1	12.09375	True
14:01:25.851	3.5	0.2	12.10546875	True
14:01:25.871	3.5	0.2	12.11328125	True
14:01:25.891	3.5	0.2	12.11328125	True
14:01:25.911	3.5	0.2	12.09765625	True
14:01:25.931	3.5	0.2	12.09375	True
14:01:25.951	3.5	0.2	12.10546875	True
14:01:25.971	3.5	0.2	12.10546875	True
14:01:25.991	3.5	0.2	12.09375	True
14:01:26.011	3.5	0.2	12.0859375	True
14:01:26.031	3.5	0.2	12.09375	True
14:01:26.051	3.5	0.2	12.11328125	True
14:01:26.071	3.5	0.2	12.09375	True
14:01:26.091	3.5	0.2	12.10546875	True
14:01:26.111	3.5	0.2	12.10546875	True
14:01:26.131	3.5	0.2	12.10546875	True
14:01:26.151	3.5	0.2	12.11328125	True
14:01:26.171	3.5	0.2	12.09375	True
14:01:26.191	3.5	0.2	12.10546875	True
14:01:26.211	3.5	0.2	12.11328125	True
14:01:26.231	3.5	0.2	12.10546875	True
14:01:26.251	3	1	255.99609375	False
14:01:26.271	3	1	255.99609375	False
14:01:26.291	3	1	255.99609375	False
14:01:26.311	3	1	255.99609375	False
14:01:26.331	3	1	255.99609375	False
14:01:26.351	3	1	255.99609375	False
14:01:26.371	3	1	255.99609375	False
14:01:26.391	3	1	255.99609375	False
14:01:26.411	3	1	255.99609375	False
14:01:26.431	3	1	255.99609375	False
14:01:26.451	3	1	255.99609375	False
14:01:26.471	3	1	255.99609375	False
14:01:26.491	3	1	255.99609375	False
14:01:26.511	3	1	255.99609375	False
14:01:26.531	3	1	255.99609375	False
14:01:26.551	3	1	255.99609375	False
14:01:26.571	3	1	255.99609375	False
14:01:26.591	3	1	255.99609375	False
14:01:26.611	3	1	255.99609375	False
14:01:26.631	3	1	255.99609375	False
14:01:26.651	3	1	255.99609375	False
14:01:26.671	3	1	255.99609375	False
14:01:26.691	3	1	255.99609375	False
14:01:26.711	3	1	255.99609375	False
14:01:26.731	3	1	255.99609375	False
14:01:26.751	3	1	255.99609375	False
14:01:26.771	3	1	255.99609375	False
14:01:26.791	3	1	255.99609375	False
14:01:26.811	3	1	255.99609375	False
14:01:26.831	3	1	255.99609375	False
14:01:26.851	3	1	255.99609375	False
14:01:26.871	3	1	255.99609375	False
14:01:26.891	3	1	255.99609375	False
14:01:26.911	3	1	255.99609375	False
14:01:26.931	3	1	255.99609375	False
14:01:26.951	3	1	255.99609375	False
14:01:26.971	3	1	255.99609375	False
14:01:26.991	3	1	255.99609375	False
14:01:27.011	3	1	255.99609375	False
14:01:27.031	3	1	255.99609375	False
14:01:27.051	3	1	255.99609375	False
14:01:27.071	3	1	255.99609375	False
14:01:27.091	3	1	255.99609375	False
14:01:27.111	3	1	255.99609375	False
14:01:27.131	3	1	255.99609375	False
14:01:27.151	3	1	255.99609375	False
14:01:27.171	3	1	255.99609375	False
14:01:27.191	3	1	255.99609375	False
14:01:27.211	3	1	255.99609375	False
14:01:27.231	3	1	255.99609375	False
14:01:27.251	3	1	255.99609375	False
14:01:27.271	3	1	255.99609375	False
14:01:27.291	3	1	255.99609375	False
14:01:27.311	3	1	255.99609375	False
14:01:27.331	3	1	255.99609375	False
14:01:27.351	3	1	255.99609375	False
14:01:27.371	3	1	255.99609375	False
14:01:27.391	3	1	255.99609375	False
14:01:27.411	3	1	255.99609375	False
14:01:27.431	3	1	255.99609375	False
14:01:27.451	3	1	255.99609375	False
14:01:27.471	3	1	255.99609375	False
14:01:27.491	3	1	255.99609375	False
14:01:27.511	3	1	255.99609375	False
14:01:27.531	3	1	255.99609375	False
14:01:27.551	3	1	255.99609375	False
14:01:27.571	3	1	255.99609375	False
14:01:27.591	3	1	255.99609375	False
14:01:27.611	3	1	255.99609375	False
14:01:27.631	3	1	255.99609375	False
14:01:27.651	3	1	255.99609375	False
14:01:27.671	3	1	255.99609375	False
14:01:27.691	3	1	255.99609375	False
14:01:27.711	3	1	255.99609375	False
14:01:27.731	3	1	255.99609375	False
14:01:27.751	3	1	255.99609375	False
14:01:27.771	3	1	255.99609375	False
14:01:27.791	3	1	255.99609375	False
14:01:27.811	3	1	255.99609375	False
14:01:27.831	3	1	255.99609375	False
14:01:27.851	3	1	255.99609375	False
14:01:27.871	3	1	255.99609375	False
14:01:27.891	3	1	255.99609375	False
14:01:27.911	3	1	255.99609375	False
14:01:27.931	3	1	255.99609375	False
14:01:27.951	3	1	255.99609375	False
14:01:27.971	3	1	255.99609375	False
14:01:27.991	3	1	255.99609375	False
14:01:28.011	3	1	255.99609375	False
14:01:28.031	3	1	255.99609375	False
14:01:28.051	3	1	255.99609375	False
14:01:28.071	3	1	255.99609375	False
14:01:28.091	3	1	255.99609375	False
14:01:28.111	3	1	255.99609375	False
14:01:28.131	3	1	255.99609375	False
14:01:28.151	3	1	255.99609375	False
14:01:28.171	3	1	255.99609375	False
14:01:28.191	3	1	255.99609375	False
14:01:28.211	3	1	255.99609375	False
14:01:28.231	3	1	255.99609375	False
14:01:28.251	3	1	255.99609375	False
14:01:28.271	3	1	255.99609375	False
14:01:28.291	3	1	255.99609375	False
14:01:28.311	3	1	255.99609375	False
14:01:28.331	3	1	255.99609375	False
14:01:28.351	3	1	255.99609375	False
14:01:28.371	3	1	255.99609375	False
14:01:28.391	3	1	255.99609375	False
14:01:28.411	3	1	255.99609375	False
14:01:28.431	3	1	255.99609375	False
14:01:28.451	3	1	255.99609375	False
14:01:28.471	3	1	255.99609375	False
14:01:28.491	3	1	255.99609375	False
14:01:28.511	3	0.48	12.10546875	True
14:01:28.531	3	0.48	12.10546875	True
14:01:28.551	3	0.48	12.10546875	True
14:01:28.571	3	0.48	12.10546875	True
14:01:28.591	3	0.48	12.10546875	True
14:01:28.611	3	0.48	12.10546875	True
14:01:28.631	3	0.48	12.10546875	True
14:01:28.651	3	0.48	12.10546875	True
14:01:28.671	3	0.48	12.10546875	True
14:01:28.691	3	0.48	12.10546875	True
14:01:28.711	3	0.48	12.10546875	True
14:01:28.731	3	0.48	12.10546875	True
14:01:28.751	3	0.48	12.09765625	False
14:01:28.771	3	0.48	12.0859375	False
14:01:28.791	3	0.48	12.09765625	False
14:01:28.811	3	0.48	12.09765625	False
14:01:28.831	3	0.48	12.09375	False
14:01:28.851	3	0.48	12.09375	True
14:01:28.871	3	0.48	12.09375	False
14:01:28.891	3	0.48	12.09375	False
14:01:28.911	3	0.48	12.09375	False
14:01:28.931	3	0.48	12.09375	False
14:01:28.951	3	0.48	12.09375	False
14:01:28.971	3	0.48	12.08203125	False
14:01:28.991	3	0.48	12.0859375	False
14:01:29.011	3	0.48	12.09765625	False
14:01:29.031	3	0.48	12.09765625	False
14:01:29.051	3	0.48	12.09765625	True
14:01:29.071	3	0.48	12.09765625	False
14:01:29.091	3	0.48	12.09375	False
14:01:29.111	3	0.48	12.10546875	False
14:01:29.131	3	0.48	12.09375	False
14:01:29.151	3	0.48	12.09765625	False
14:01:29.171	3	0.48	12.09765625	False
14:01:29.191	3	0.48	12.09375	False
14:01:29.211	3	0.48	12.09375	False
14:01:29.231	3	0.48	12.09375	True
14:01:29.251	3	0.48	12.09765625	True
14:01:29.271	3	0.48	12.09375	True
14:01:29.291	3	0.48	12.10546875	True
14:01:29.311	3	0.48	12.11328125	True
14:01:29.331	3	0.48	12.11328125	True
14:01:29.351	3	0.48	12.10546875	True
14:01:29.371	3	0.48	12.11328125	True
14:01:29.391	3	0.48	12.10546875	True
14:01:29.411	3	0.48	12.10546875	True
14:01:29.431	3	0.48	12.09765625	True
14:01:29.451	3	0.48	12.09765625	True
14:01:29.471	3	0.48	12.09765625	True
14:01:29.491	3.5	1.16	255.99609375	False
14:01:29.511	3.5	1.16	255.99609375	False
14:01:29.531	3.5	1.16	255.99609375	False
14:01:29.551	3.5	1.16	255.99609375	False
14:01:29.571	3.5	1	255.99609375	False
14:01:29.591	3.5	1	255.99609375	False
14:01:29.611	3.5	1	255.99609375	False
14:01:29.631	3.5	1	255.99609375	False
14:01:29.651	3.5	1	255.99609375	False
14:01:29.671	3.5	1	255.99609375	False
14:01:29.691	3.5	1	255.99609375	False
14:01:29.711	3.5	1	255.99609375	False
14:01:29.731	3.5	1	255.99609375	False
14:01:29.751	3.5	1	255.99609375	False
14:01:29.771	3.5	1	255.99609375	False
14:01:29.791	3.5	1	255.99609375	False
14:01:29.811	3.5	1	255.99609375	False
14:01:29.831	3.5	1	255.99609375	False
14:01:29.851	3.5	1	255.99609375	False
14:01:29.871	3.5	1	255.99609375	False
14:01:29.891	3.5	1	255.99609375	False
14:01:29.911	3.5	1	255.99609375	False
14:01:29.931	3.5	1	255.99609375	False
14:01:29.951	3.5	1	255.99609375	False
14:01:29.971	3.5	1	255.99609375	False
14:01:29.991	3.5	1	255.99609375	False
14:01:30.011	3.5	1	255.99609375	False
14:01:30.031	3.5	1	255.99609375	False
14:01:30.051	3.5	1	255.99609375	False
14:01:30.071	3.5	1	255.99609375	False
14:01:30.091	3.5	1	255.99609375	False
14:01:30.111	3.5	1	255.99609375	False
14:01:30.131	3.5	1	255.99609375	False
14:01:30.151	3.5	1	255.99609375	False
14:01:30.171	3.5	1	255.99609375	False
14:01:30.191	3.5	1	255.99609375	False
14:01:30.211	3.5	1	255.99609375	False
14:01:30.231	3.5	1	255.99609375	False
14:01:30.251	3.5	1	255.99609375	False
14:01:30.271	3.5	1	255.99609375	False
14:01:30.291	3.5	1	255.99609375	False
14:01:30.311	3.5	1	255.99609375	False
14:01:30.331	3.5	1	255.99609375	False
14:01:30.351	3.5	1	255.99609375	False
14:01:30.371	3.5	1	255.99609375	False
14:01:30.391	3.5	1	255.99609375	False
14:01:30.411	3.5	1	255.99609375	False
14:01:30.431	3.5	1	255.99609375	False
14:01:30.451	3.5	1	255.99609375	False
14:01:30.471	3.5	1	255.99609375	False
14:01:30.491	3.5	1	255.99609375	False
14:01:30.511	3.5	1	255.99609375	False
14:01:30.531	3.5	1	255.99609375	False
14:01:30.551	3.5	1	255.99609375	False
14:01:30.571	3.5	1	255.99609375	False
14:01:30.591	3.5	1.04	255.99609375	False
14:01:30.611	3.5	1.04	255.99609375	False
14:01:30.631	3.5	1.04	255.99609375	False
14:01:30.651	3.5	1.04	255.99609375	False
14:01:30.671	3.5	1.04	255.99609375	False
14:01:30.691	3.5	1.04	255.99609375	False
14:01:30.711	3.5	1.04	255.99609375	False
14:01:30.731	3.5	1.04	255.99609375	False
14:01:30.751	3.5	1.04	255.99609375	False
14:01:30.771	3.5	1.04	255.99609375	False
14:01:30.791	3.5	1.04	255.99609375	False
14:01:30.811	3.5	1.04	255.99609375	False
14:01:30.831	3.5	1.04	255.99609375	False
14:01:30.851	3.5	1.04	255.99609375	False
14:01:30.871	3.5	1.04	255.99609375	False
14:01:30.891	3.5	1.04	255.99609375	False
14:01:30.911	3.5	1.04	255.99609375	False
14:01:30.931	3.5	1.04	255.99609375	False
14:01:30.951	3.5	1.04	255.99609375	False
14:01:30.971	3.5	1.04	255.99609375	False
14:01:30.991	3.5	1.04	255.99609375	False
14:01:31.011	3.5	1.04	255.99609375	False
14:01:31.031	3.5	1.04	255.99609375	False
14:01:31.051	3.5	1.04	255.99609375	False
14:01:31.071	3.5	1.04	255.99609375	False
14:01:31.091	3.5	1	255.99609375	False
14:01:31.111	3.5	1	255.99609375	False
14:01:31.131	3.5	1	255.99609375	False
14:01:31.151	3.5	1	255.99609375	False
14:01:31.171	3.5	1	255.99609375	False
14:01:31.191	3.5	1	255.99609375	False
14:01:31.211	3.5	1	255.99609375	False
14:01:31.231	3.5	1	255.99609375	False
14:01:31.251	3.5	1	255.99609375	False
14:01:31.271	3.5	1	255.99609375	False
14:01:31.291	3.5	1	255.99609375	False
14:01:31.311	3.5	1	255.99609375	False
14:01:31.331	3.5	1	255.99609375	False
14:01:31.351	3.5	1	255.99609375	False
14:01:31.371	3.5	1	255.99609375	False
14:01:31.391	3.5	1	255.99609375	False
14:01:31.411	3.5	1	255.99609375	False
14:01:31.431	3.5	1	255.99609375	False
14:01:31.451	3.5	1	255.99609375	False
14:01:31.471	3.5	1	255.99609375	False
14:01:31.491	3.5	1	255.99609375	False
14:01:31.511	3.5	1	255.99609375	False
14:01:31.531	3.5	1	255.99609375	False
14:01:31.551	3.5	1	255.99609375	False
14:01:31.571	3.5	1	255.99609375	False
14:01:31.591	3.5	0.28	12.0859375	True
14:01:31.611	3.5	0.28	12.0859375	True
14:01:31.631	3.5	0.28	12.0859375	True
14:01:31.651	3.5	0.28	12.0859375	True
14:01:31.671	3.5	0.28	12.0859375	True
14:01:31.691	3.5	0.28	12.0859375	True
14:01:31.711	3.5	0.28	12.0859375	True
14:01:31.731	3.5	0.28	12.0859375	True
14:01:31.751	3.5	0.28	12.10546875	False
14:01:31.771	3.5	0.28	12.09765625	False
14:01:31.791	3.5	0.28	12.09765625	False
14:01:31.811	3.5	0.28	12.09375	False
14:01:31.831	3.5	0.28	12.0859375	False
14:01:31.851	3.5	0.28	12.11328125	False
14:01:31.871	3.5	0.28	12.09375	False
14:01:31.891	3.5	0.28	12.09765625	False
14:01:31.911	3.5	0.28	12.09375	False
14:01:31.931	3.5	0.28	12.09765625	True
14:01:31.951	3.5	0.28	12.10546875	False
14:01:31.971	3.5	0.28	12.09765625	True
14:01:31.991	3.5	0.28	12.10546875	False
14:01:32.011	3.5	0.28	12.09765625	True
14:01:32.031	3.5	0.28	12.09375	False
14:01:32.051	3.5	0.28	12.09765625	False
14:01:32.071	3.5	0.28	12.09765625	False
14:01:32.091	3.5	0.28	12.11328125	False
14:01:32.111	3.5	0.28	12.09375	True
14:01:32.131	3.5	0.28	12.10546875	True
14:01:32.151	3.5	0.28	12.10546875	True
14:01:32.171	3.5	0.28	12.0859375	True
14:01:32.191	3.5	0.28	12.11328125	True
14:01:32.211	3.5	0.28	12.1171875	True
14:01:32.231	3.5	0.28	12.11328125	True
14:01:32.251	3.5	0.28	12.0859375	True
14:01:32.271	3.5	0.28	12.09375	True
14:01:32.291	3.5	0.28	12.10546875	True
14:01:32.311	3.5	0.28	12.09375	True
14:01:32.331	3.5	0.28	12.1171875	True
14:01:32.351	3.5	0.28	12.10546875	True
14:01:32.371	3.5	0.28	12.09765625	True
14:01:32.391	3.5	0.28	12.09375	True
14:01:32.411	3.5	0.28	255.99609375	False
14:01:32.431	3.5	0.28	255.99609375	False
14:01:32.451	3.5	0.28	255.99609375	False
14:01:32.471	3.5	0.28	255.99609375	False
14:01:32.491	3.5	0.28	255.99609375	False
14:01:32.511	3.5	0.28	255.99609375	False
14:01:32.531	3.5	0.28	255.99609375	False
14:01:32.551	3.5	0.28	255.99609375	False
14:01:32.571	3.5	0.28	255.99609375	False
14:01:32.591	3.5	0.28	255.99609375	False
14:01:32.611	3	1	255.99609375	False
14:01:32.631	3	1	255.99609375	False
14:01:32.651	3	1	255.99609375	False
14:01:32.671	3	1	255.99609375	False
14:01:32.691	3	1	255.99609375	False
14:01:32.711	3	1	255.99609375	False
14:01:32.731	3	1	255.99609375	False
14:01:32.751	3	1	255.99609375	False
14:01:32.771	3	1	255.99609375	False
14:01:32.791	3	1	255.99609375	False
14:01:32.811	3	1	255.99609375	False
14:01:32.831	3	1	255.99609375	False
14:01:32.851	3	1	255.99609375	False
14:01:32.871	3	1	255.99609375	False
14:01:32.891	3	1	255.99609375	False
14:01:32.911	3	1	255.99609375	False
14:01:32.931	3	1	255.99609375	False
14:01:32.951	3	1	255.99609375	False
14:01:32.971	3	1	255.99609375	False
14:01:32.991	3	1	255.99609375	False
14:01:33.011	3	1	255.99609375	False
14:01:33.031	3	1	255.99609375	False
14:01:33.051	3	1	255.99609375	False
14:01:33.071	3	1	255.99609375	False
14:01:33.091	3	1	255.99609375	False
14:01:33.111	3	1.04	255.99609375	False
14:01:33.131	3	1.04	255.99609375	False
14:01:33.151	3	1.04	255.99609375	False
14:01:33.171	3	1.04	255.99609375	False
14:01:33.191	3	1.04	255.99609375	False
14:01:33.211	3	1.04	255.99609375	False
14:01:33.231	3	1.04	255.99609375	False
14:01:33.251	3	1.04	255.99609375	False
14:01:33.271	3	1.04	255.99609375	False
14:01:33.291	3	1.04	255.99609375	False
14:01:33.311	3	1.04	255.99609375	False
14:01:33.331	3	1.04	255.99609375	False
14:01:33.351	3	1.04	255.99609375	False
14:01:33.371	3	1.04	255.99609375	False
14:01:33.391	3	1.04	255.99609375	False
14:01:33.411	3	1.04	255.99609375	False
14:01:33.431	3	1.04	255.99609375	False
14:01:33.451	3	1.04	255.99609375	False
14:01:33.471	3	1.04	255.99609375	False
14:01:33.491	3	1.04	255.99609375	False
14:01:33.511	3	1.04	255.99609375	False
14:01:33.531	3	1.04	255.99609375	False
14:01:33.551	3	1.04	255.99609375	False
14:01:33.571	3	1.04	255.99609375	False
14:01:33.591	3	1.04	255.99609375	False
14:01:33.611	3	1	255.99609375	False
14:01:33.631	3	1	255.99609375	False
14:01:33.651	3	1	255.99609375	False
14:01:33.671	3	1	255.99609375	False
14:01:33.691	3	1	255.99609375	False
14:01:33.711	3	1	255.99609375	False
14:01:33.731	3	1	255.99609375	False
14:01:33.751	3	1	255.99609375	False
14:01:33.771	3	1	255.99609375	False
14:01:33.791	3	1	255.99609375	False
14:01:33.811	3	1	255.99609375	False
14:01:33.831	3	1	255.99609375	False
14:01:33.851	3	1	255.99609375	False
14:01:33.871	3	1	255.99609375	False
14:01:33.891	3	1	255.99609375	False
14:01:33.911	3	1	255.99609375	False
14:01:33.931	3	1	255.99609375	False
14:01:33.951	3	1	255.99609375	False
14:01:33.971	3	1	255.99609375	False
14:01:33.991	3	1	255.99609375	False
14:01:34.011	3	1	255.99609375	False
14:01:34.031	3	1	255.99609375	False
14:01:34.051	3	1	255.99609375	False
14:01:34.071	3	1	255.99609375	False
14:01:34.091	3	1	255.99609375	False
14:01:34.111	3	1	255.99609375	False
14:01:34.131	3	1	255.99609375	False
14:01:34.151	3	1	255.99609375	False
14:01:34.171	3	1	255.99609375	False
14:01:34.191	3	1	255.99609375	False
14:01:34.211	3	1	255.99609375	False
14:01:34.231	3	1	255.99609375	False
14:01:34.251	3	1	255.99609375	False
14:01:34.271	3	1	255.99609375	False
14:01:34.291	3	1	255.99609375	False
14:01:34.311	3	1	255.99609375	False
14:01:34.331	3	1	255.99609375	False
14:01:34.351	3	1	255.99609375	False
14:01:34.371	3	1	255.99609375	False
14:01:34.391	3	1	255.99609375	False
14:01:34.411	3	1	255.99609375	False
14:01:34.431	3	1	255.99609375	False
14:01:34.451	3	1	255.99609375	False
14:01:34.471	3	1	255.99609375	False
14:01:34.491	3	1	255.99609375	False
14:01:34.511	3	1	255.99609375	False
14:01:34.531	3	1	255.99609375	False
14:01:34.551	3	1	255.99609375	False
14:01:34.571	3	1	255.99609375	False
14:01:34.591	3	1	255.99609375	False
14:01:34.611	3	1	255.99609375	False
14:01:34.631	3	1	12.09375	True
14:01:34.651	3	1	12.09375	True
14:01:34.671	3	1	12.09375	True
14:01:34.691	3	1	12.09375	True
14:01:34.711	3	1	12.09375	True
14:01:34.731	3	1	12.09375	True
14:01:34.751	3	1	12.09765625	False
14:01:34.771	3	1	12.09375	False
14:01:34.791	3	1	12.09765625	True
14:01:34.811	3	1	12.10546875	False
14:01:34.831	3	1	12.10546875	False
14:01:34.851	3	1	12.09765625	False
14:01:34.871	3	1	12.09765625	False
14:01:34.891	3	1	12.09375	True
14:01:34.911	3	1	12.09375	True
14:01:34.931	3	1	12.10546875	True
14:01:34.951	3	1	12.09765625	True
14:01:34.971	3	1	12.10546875	True
14:01:34.991	3	1	12.09375	True
14:01:35.011	3	1	12.10546875	True
14:01:35.031	3	1	12.10546875	True
14:01:35.051	3	1	12.09375	True
14:01:35.071	3	1	12.0859375	True
14:01:35.091	3	1	12.09765625	True
14:01:35.111	3	1	12.09765625	True
14:01:35.131	3	1	12.09375	True
14:01:35.151	3	1	12.09765625	True
14:01:35.171	3	1	12.11328125	True
14:01:35.191	3	1	12.09765625	True
14:01:35.211	3	1	12.11328125	True
14:01:35.231	3	0.32	12.09765625	True
14:01:35.251	3	1	255.99609375	False
14:01:35.271	3	1	255.99609375	False
14:01:35.291	3	1	255.99609375	False
14:01:35.311	3	1	255.99609375	False
14:01:35.331	3	1	255.99609375	False
14:01:35.351	3	1	255.99609375	False
14:01:35.371	3	1	255.99609375	False
14:01:35.391	3	1	255.99609375	False
14:01:35.411	3	1	255.99609375	False
14:01:35.431	3	1	255.99609375	False
14:01:35.451	3	1	255.99609375	False
14:01:35.471	3	1	255.99609375	False
14:01:35.491	3	1	255.99609375	False
14:01:35.511	3	1	255.99609375	False
14:01:35.531	3	1	255.99609375	False
14:01:35.551	3	1	255.99609375	False
14:01:35.571	3	1	255.99609375	False
14:01:35.591	3	1	255.99609375	False
14:01:35.611	3	1	255.99609375	False
14:01:35.631	3	1	255.99609375	False
14:01:35.651	3	1	255.99609375	False
14:01:35.671	3	1	255.99609375	False
14:01:35.691	3	1	255.99609375	False
14:01:35.711	3	1	255.99609375	False
14:01:35.731	3	1	255.99609375	False
14:01:35.751	3	1	255.99609375	False
14:01:35.771	3	1	255.99609375	False
14:01:35.791	3	1	255.99609375	False
14:01:35.811	3	1	255.99609375	False
14:01:35.831	3	1	255.99609375	False
14:01:35.851	3	1	255.99609375	False
14:01:35.871	3	1	255.99609375	False
14:01:35.891	3	1	255.99609375	False
14:01:35.911	3	1	255.99609375	False
14:01:35.931	3	1	255.99609375	False
14:01:35.951	3	1	255.99609375	False
14:01:35.971	3	1	255.99609375	False
14:01:35.991	3	1	255.99609375	False
14:01:36.011	3	1	255.99609375	False
14:01:36.031	3	1	255.99609375	False
14:01:36.051	3	1	255.99609375	False
14:01:36.071	3	1	255.99609375	False
14:01:36.091	3	1	255.99609375	False
14:01:36.111	3	1	255.99609375	False
14:01:36.131	3	1	255.99609375	False
14:01:36.151	3	1	255.99609375	False
14:01:36.171	3	1	255.99609375	False
14:01:36.191	3	1	255.99609375	False
14:01:36.211	3	1	255.99609375	False
14:01:36.231	3	1	255.99609375	False
14:01:36.251	3	1	255.99609375	False
14:01:36.271	3	1	255.99609375	False
14:01:36.291	3	1	255.99609375	False
14:01:36.311	3	1	255.99609375	False
14:01:36.331	3	1	255.99609375	False
14:01:36.351	3	1	255.99609375	False
14:01:36.371	3	1	255.99609375	False
14:01:36.391	3	1	255.99609375	False
14:01:36.411	3	1	255.99609375	False
14:01:36.431	3	1	255.99609375	False
14:01:36.451	3	1	255.99609375	False
14:01:36.471	3	1	255.99609375	False
14:01:36.491	3	1	255.99609375	False
14:01:36.511	3	1	255.99609375	False
14:01:36.531	3	1	255.99609375	False
14:01:36.551	3	1	255.99609375	False
14:01:36.571	3	1	255.99609375	False
14:01:36.591	3	1	255.99609375	False
14:01:36.611	3	1	255.99609375	False
14:01:36.631	3	1	255.99609375	False
14:01:36.651	3	1	255.99609375	False
14:01:36.671	3	1	255.99609375	False
14:01:36.691	3	1	255.99609375	False
14:01:36.711	3	1	255.99609375	False
14:01:36.731	3	1	255.99609375	False
14:01:36.751	3	1	255.99609375	False
14:01:36.771	3	1	255.99609375	False
14:01:36.791	3	1	255.99609375	False
14:01:36.811	3	1	255.99609375	False
14:01:36.831	3	1	255.99609375	False
14:01:36.851	3	1	255.99609375	False
14:01:36.871	3	1	255.99609375	False
14:01:36.891	3	1	255.99609375	False
14:01:36.911	3	1	255.99609375	False
14:01:36.931	3	1	255.99609375	False
14:01:36.951	3	1	255.99609375	False
14:01:36.971	3	1	255.99609375	False
14:01:36.991	3	1	255.99609375	False
14:01:37.011	3	1	255.99609375	False
14:01:37.031	3	1	255.99609375	False
14:01:37.051	3	1	255.99609375	False
14:01:37.071	3	1	255.99609375	False
14:01:37.091	3	1	255.99609375	False
14:01:37.111	3	1	255.99609375	False
14:01:37.131	3	1	255.99609375	False
14:01:37.151	3	1	255.99609375	False
14:01:37.171	3	1	255.99609375	False
14:01:37.191	3	1	255.99609375	False
14:01:37.211	3	1	255.99609375	False
14:01:37.231	3	1	255.99609375	False
14:01:37.251	3	1	255.99609375	False
14:01:37.271	3	1	255.99609375	False
14:01:37.291	3	1	255.99609375	False
14:01:37.311	3	1	255.99609375	False
14:01:37.331	3	1	255.99609375	False
14:01:37.351	3	1	255.99609375	False
14:01:37.371	3	1	255.99609375	False
14:01:37.391	3	1	255.99609375	False
14:01:37.411	3	1	255.99609375	False
14:01:37.431	3	1	255.99609375	False
14:01:37.451	3	1	255.99609375	False
14:01:37.471	3	1	255.99609375	False
14:01:37.491	3	1	255.99609375	False
14:01:37.511	3	1	255.99609375	False
14:01:37.531	3	1	255.99609375	False
14:01:37.551	3	1	255.99609375	False
14:01:37.571	3	1	255.99609375	False
14:01:37.591	3	1	255.99609375	False
14:01:37.611	3	1	255.99609375	False
14:01:37.631	3	1	12.11328125	True
14:01:37.651	3	1	12.10546875	False
14:01:37.671	3	1	12.10546875	False
14:01:37.691	3	1	12.10546875	False
14:01:37.711	3	1	12.09375	False
14:01:37.731	3	1	12.09375	False
14:01:37.751	3	1	12.10546875	False
14:01:37.771	3	1	12.11328125	False
14:01:37.791	3	1	12.10546875	False
14:01:37.811	3	1	12.11328125	True
14:01:37.831	3	1	12.09375	False
14:01:37.851	3	1	12.09765625	False
14:01:37.871	3	1	12.09765625	False
14:01:37.891	3	1	12.09375	False
14:01:37.911	3	1	12.09375	True
14:01:37.931	3	1	12.09375	True
14:01:37.951	3	1	12.10546875	True
14:01:37.971	3	1	12.11328125	True
14:01:37.991	3	1	12.09375	True
14:01:38.011	3	1	12.11328125	True
14:01:38.031	3	1	12.09765625	True
14:01:38.051	3	1	12.09375	True
14:01:38.071	3	1	12.09375	True
14:01:38.091	3	1	12.09765625	True
14:01:38.111	3	1	12.09765625	True
14:01:38.131	3	1	12.09765625	True
14:01:38.151	3	1	12.10546875	True
14:01:38.171	3	1	12.09765625	True
14:01:38.191	3	1	12.09765625	True
14:01:38.211	3	1	12.09765625	True
14:01:38.231	3	1	12.10546875	True
14:01:38.251	3	1	12.11328125	True
14:01:38.271	3	1	12.11328125	True
14:01:38.291	3	1	12.09765625	True
14:01:38.311	3.5	0.16	12.11328125	True
14:01:38.331	3.5	0.16	12.09765625	True
14:01:38.351	3.5	0.16	12.10546875	True
14:01:38.371	3.5	0.16	12.09765625	True
14:01:38.391	3	1	255.99609375	False
14:01:38.411	3	1	255.99609375	False
14:01:38.431	3	1	255.99609375	False
14:01:38.451	3	1	255.99609375	False
14:01:38.471	3	1	255.99609375	False
14:01:38.491	3	1	255.99609375	False
14:01:38.511	3	1	255.99609375	False
14:01:38.531	3	1	255.99609375	False
14:01:38.551	3	1	255.99609375	False
14:01:38.571	3	1	255.99609375	False
14:01:38.591	3	1	255.99609375	False
14:01:38.611	3	1	255.99609375	False
14:01:38.631	3	1	255.99609375	False
14:01:38.651	3	1	255.99609375	False
14:01:38.671	3	1	255.99609375	False
14:01:38.691	3	1	255.99609375	False
14:01:38.711	3	1	255.99609375	False
14:01:38.731	3	1	255.99609375	False
14:01:38.751	3	1	255.99609375	False
14:01:38.771	3	1	255.99609375	False
14:01:38.791	3	1	255.99609375	False
14:01:38.811	3	1	255.99609375	False
14:01:38.831	3	1	255.99609375	False
14:01:38.851	3	1	255.99609375	False
14:01:38.871	3	1	255.99609375	False
14:01:38.891	3	1	255.99609375	False
14:01:38.911	3	1	255.99609375	False
14:01:38.931	3	1	255.99609375	False
14:01:38.951	3	1	255.99609375	False
14:01:38.971	3	1	255.99609375	False
14:01:38.991	3	1	255.99609375	False
14:01:39.011	3	1	255.99609375	False
14:01:39.031	3	1	255.99609375	False
14:01:39.051	3	1	255.99609375	False
14:01:39.071	3	1	255.99609375	False
14:01:39.091	3	1	255.99609375	False
14:01:39.111	3	1	255.99609375	False
14:01:39.131	3	1	255.99609375	False
14:01:39.151	3	1	255.99609375	False
14:01:39.171	3	1	255.99609375	False
14:01:39.191	3	1	255.99609375	False
14:01:39.211	3	1	255.99609375	False
14:01:39.231	3	1	255.99609375	False
14:01:39.251	3	1	255.99609375	False
14:01:39.271	3	1	255.99609375	False
14:01:39.291	3	1	255.99609375	False
14:01:39.311	3	1	255.99609375	False
14:01:39.331	3	1	255.99609375	False
14:01:39.351	3	1	255.99609375	False
14:01:39.371	3	1	255.99609375	False
14:01:39.391	3	1	255.99609375	False
14:01:39.411	3	1	255.99609375	False
14:01:39.431	3	1	255.99609375	False
14:01:39.451	3	1	255.99609375	False
14:01:39.471	3	1	255.99609375	False
14:01:39.491	3	1	255.99609375	False
14:01:39.511	3	1	255.99609375	False
14:01:39.531	3	1	255.99609375	False
14:01:39.551	3	1	255.99609375	False
14:01:39.571	3	1	255.99609375	False
14:01:39.591	3	1	255.99609375	False
14:01:39.611	3	1	255.99609375	False
14:01:39.631	3	1	255.99609375	False
14:01:39.651	3	1	255.99609375	False
14:01:39.671	3	1	255.99609375	False
14:01:39.691	3	1	255.99609375	False
14:01:39.711	3	1	255.99609375	False
14:01:39.731	3	1	255.99609375	False
14:01:39.751	3	1	255.99609375	False
14:01:39.771	3	1	255.99609375	False
14:01:39.791	3	1	255.99609375	False
14:01:39.811	3	1	255.99609375	False
14:01:39.831	3	1	255.99609375	False
14:01:39.851	3	1	255.99609375	False
14:01:39.871	3	1	255.99609375	False
14:01:39.891	3	1	255.99609375	False
14:01:39.911	3	1	255.99609375	False
14:01:39.931	3	1	255.99609375	False
14:01:39.951	3	1	255.99609375	False
14:01:39.971	3	1	255.99609375	False
14:01:39.991	3	1	255.99609375	False
14:01:40.011	3	1	255.99609375	False
14:01:40.031	3	1	255.99609375	False
14:01:40.051	3	1	255.99609375	False
14:01:40.071	3	1	255.99609375	False
14:01:40.091	3	1	255.99609375	False
14:01:40.111	3	1	255.99609375	False
14:01:40.131	3	1	255.99609375	False
14:01:40.151	3	1	255.99609375	False
14:01:40.171	3	1	255.99609375	False
14:01:40.191	3	1	255.99609375	False
14:01:40.211	3	1	255.99609375	False
14:01:40.231	3	1	255.99609375	False
14:01:40.251	3	1	255.99609375	False
14:01:40.271	3	1	255.99609375	False
14:01:40.291	3	1	255.99609375	False
14:01:40.311	3	1	255.99609375	False
14:01:40.331	3	1	255.99609375	False
14:01:40.351	3	1	255.99609375	False
14:01:40.371	3	1	255.99609375	False
14:01:40.391	3	1	255.99609375	False
14:01:40.411	3	1	255.99609375	False
14:01:40.431	3	1	255.99609375	False
14:01:40.451	3	1	255.99609375	False
14:01:40.471	3	1	255.99609375	False
14:01:40.491	3	1	255.99609375	False
14:01:40.511	3	1	255.99609375	False
14:01:40.531	3	1	255.99609375	False
14:01:40.551	3	1	255.99609375	False
14:01:40.571	3	1	255.99609375	False
14:01:40.591	3	1	255.99609375	False
14:01:40.611	3	1	255.99609375	False
14:01:40.631	3	1	255.99609375	False
14:01:40.651	3	1	255.99609375	False
14:01:40.671	3	1	12.0859375	True
14:01:40.691	3	1	12.0859375	True
14:01:40.711	3	1	12.0859375	True
14:01:40.731	3	1	12.0859375	True
14:01:40.751	3	1	12.0859375	True
14:01:40.771	3	1	12.0859375	True
14:01:40.791	3	1	12.0859375	True
14:01:40.811	3	1	12.0859375	True
14:01:40.831	3	1	12.09765625	True
14:01:40.851	3	1	12.09765625	False
14:01:40.871	3	1	12.10546875	False
14:01:40.891	3	1	12.09375	False
14:01:40.911	3	1	12.10546875	False
14:01:40.931	3	1	12.09765625	False
14:01:40.951	3	1	12.09765625	True
14:01:40.971	3	1	12.09375	False
14:01:40.991	3	1	12.0859375	False
14:01:41.011	3	1	12.09375	False
14:01:41.031	3	1	12.10546875	False
14:01:41.051	3	1	12.09375	True
14:01:41.071	3	1	12.09765625	False
14:01:41.091	3	1	12.09765625	False
14:01:41.111	3	1	12.09375	False
14:01:41.131	3	1	12.09765625	False
14:01:41.151	3	1	12.09375	False
14:01:41.171	3	1	12.09375	True
14:01:41.191	3	1	12.09375	False
14:01:41.211	3	1	12.0859375	True
14:01:41.231	3	1	12.10546875	True
14:01:41.251	3	1	12.11328125	True
14:01:41.271	3	1	12.09765625	True
14:01:41.291	3	1	12.10546875	True
14:01:41.311	3	1	12.10546875	True
14:01:41.331	3	1	12.11328125	True
14:01:41.351	3	1	12.10546875	True
14:01:41.371	3	1	12.10546875	True
14:01:41.391	3	1	12.10546875	True
14:01:41.411	3	1	12.09765625	True
14:01:41.431	3	0.44	12.09765625	True
14:01:41.451	3	0.44	12.10546875	True
14:01:41.471	3	0.44	12.09765625	True
14:01:41.491	3	0.44	12.09375	True
14:01:41.511	3	0.44	12.11328125	True
14:01:41.531	3	0.44	12.10546875	True
14:01:41.551	3	1	255.99609375	False
14:01:41.571	3	1	255.99609375	False
14:01:41.591	3	1	255.99609375	False
14:01:41.611	3	1	255.99609375	False
14:01:41.631	3	1	255.99609375	False
14:01:41.651	3	1	255.99609375	False
14:01:41.671	3	1	255.99609375	False
14:01:41.691	3	1	255.99609375	False
14:01:41.711	3	1	255.99609375	False
14:01:41.731	3	1.04	255.99609375	False
14:01:41.751	3	1.04	255.99609375	False
14:01:41.771	3	1.04	255.99609375	False
14:01:41.791	3	1.04	255.99609375	False
14:01:41.811	3	1.04	255.99609375	False
14:01:41.831	3	1.04	255.99609375	False
14:01:41.851	3	1.04	255.99609375	False
14:01:41.871	3	1.04	255.99609375	False
14:01:41.891	3	1.04	255.99609375	False
14:01:41.911	3	1.04	255.99609375	False
14:01:41.931	3	1.04	255.99609375	False
14:01:41.951	3	1.04	255.99609375	False
14:01:41.971	3	1.04	255.99609375	False
14:01:41.991	3	1.04	255.99609375	False
14:01:42.011	3	1.04	255.99609375	False
14:01:42.031	3	1.04	255.99609375	False
14:01:42.051	3	1.04	255.99609375	False
14:01:42.071	3	1.04	255.99609375	False
14:01:42.091	3	1.04	255.99609375	False
14:01:42.111	3	1.04	255.99609375	False
14:01:42.131	3	1.04	255.99609375	False
14:01:42.151	3	1.04	255.99609375	False
14:01:42.171	3	1.04	255.99609375	False
14:01:42.191	3	1.04	255.99609375	False
14:01:42.211	3	1.04	255.99609375	False
14:01:42.231	3	1	255.99609375	False
14:01:42.251	3	1	255.99609375	False
14:01:42.271	3	1	255.99609375	False
14:01:42.291	3	1	255.99609375	False
14:01:42.311	3	1	255.99609375	False
14:01:42.331	3	1	255.99609375	False
14:01:42.351	3	1	255.99609375	False
14:01:42.371	3	1	255.99609375	False
14:01:42.391	3	1	255.99609375	False
14:01:42.411	3	1	255.99609375	False
14:01:42.431	3	1	255.99609375	False
14:01:42.451	3	1	255.99609375	False
14:01:42.471	3	1	255.99609375	False
14:01:42.491	3	1	255.99609375	False
14:01:42.511	3	1	255.99609375	False
14:01:42.531	3	1	255.99609375	False
14:01:42.551	3	1	255.99609375	False
14:01:42.571	3	1	255.99609375	False
14:01:42.591	3	1	255.99609375	False
14:01:42.611	3	1	255.99609375	False
14:01:42.631	3	1	255.99609375	False
14:01:42.651	3	1	255.99609375	False
14:01:42.671	3	1	255.99609375	False
14:01:42.691	3	1	255.99609375	False
14:01:42.711	3	1	255.99609375	False
14:01:42.731	3	1	255.99609375	False
14:01:42.751	3	1	255.99609375	False
14:01:42.771	3	1	255.99609375	False
14:01:42.791	3	1	255.99609375	False
14:01:42.811	3	1	255.99609375	False
14:01:42.831	3	1	255.99609375	False
14:01:42.851	3	1	255.99609375	False
14:01:42.871	3	1	255.99609375	False
14:01:42.891	3	1	255.99609375	False
14:01:42.911	3	1	255.99609375	False
14:01:42.931	3	1	255.99609375	False
14:01:42.951	3	1	255.99609375	False
14:01:42.971	3	1	255.99609375	False
14:01:42.991	3	1	255.99609375	False
14:01:43.011	3	1	255.99609375	False
14:01:43.031	3	1	255.99609375	False
14:01:43.051	3	1	255.99609375	False
14:01:43.071	3	1	255.99609375	False
14:01:43.091	3	1	255.99609375	False
14:01:43.111	3	1	255.99609375	False
14:01:43.131	3	1	255.99609375	False
14:01:43.151	3	1	255.99609375	False
14:01:43.171	3	1	255.99609375	False
14:01:43.191	3	1	255.99609375	False
14:01:43.211	3	1	255.99609375	False
14:01:43.231	3	1	255.99609375	False
14:01:43.251	3	1	255.99609375	False
14:01:43.271	3	1	255.99609375	False
14:01:43.291	3	1	255.99609375	False
14:01:43.311	3	1	255.99609375	False
14:01:43.331	3	1	255.99609375	False
14:01:43.351	3	1	255.99609375	False
14:01:43.371	3	1	255.99609375	False
14:01:43.391	3	1	255.99609375	False
14:01:43.411	3	1	255.99609375	False
14:01:43.431	3	1	255.99609375	False
14:01:43.451	3	1	255.99609375	False
14:01:43.471	3	1	255.99609375	False
14:01:43.491	3	1	255.99609375	False
14:01:43.511	3	1	255.99609375	False
14:01:43.531	3	1	255.99609375	False
14:01:43.551	3	1	255.99609375	False
14:01:43.571	3	1	255.99609375	False
14:01:43.591	3	1	255.99609375	False
14:01:43.611	3	1	255.99609375	False
14:01:43.631	3	1	255.99609375	False
14:01:43.651	3	1	255.99609375	False
14:01:43.671	3	1	255.99609375	False
14:01:43.691	3	1	255.99609375	False
14:01:43.711	3	1	255.99609375	False
14:01:43.731	3	1	255.99609375	False
14:01:43.751	3	1	12.09765625	True
14:01:43.771	3	1	12.09765625	True
14:01:43.791	3	1	12.09765625	True
14:01:43.811	3	1	12.09765625	True
14:01:43.831	3	1	12.09765625	True
14:01:43.851	3	1	12.09765625	True
14:01:43.871	3	1	12.09765625	True
14:01:43.891	3	1	12.09765625	True
14:01:43.911	3	1	12.09765625	False
14:01:43.931	3	1	12.10546875	False
14:01:43.951	3	1	12.11328125	False
14:01:43.971	3	1	12.1171875	False
14:01:43.991	3	1	12.11328125	False
14:01:44.011	3	1	12.09765625	True
14:01:44.031	3	1	12.09765625	False
14:01:44.051	3	1	12.11328125	False
14:01:44.071	3	1	12.10546875	False
14:01:44.091	3	1	12.09765625	True
14:01:44.111	3	1	12.09375	True
14:01:44.131	3	1	12.09375	False
14:01:44.151	3	1	12.10546875	False
14:01:44.171	3	1	12.09765625	False
14:01:44.191	3	1	12.10546875	True
14:01:44.211	3	1	12.10546875	True
14:01:44.231	3	1	12.09765625	True
14:01:44.251	3	1	12.0859375	True
14:01:44.271	3	1	12.09375	True
14:01:44.291	3	1	12.09375	True
14:01:44.311	3	1	12.10546875	True
14:01:44.331	3.5	0.44	12.09765625	True
14:01:44.351	3.5	0.44	12.10546875	True
14:01:44.371	3.5	0.44	12.10546875	True
14:01:44.391	3.5	0.44	12.09375	True
14:01:44.411	3.5	0.44	12.10546875	True
14:01:44.431	3.5	0.44	12.10546875	True
14:01:44.451	3.5	0.44	12.09765625	True
14:01:44.471	3.5	0.44	12.11328125	True
14:01:44.491	3.5	1	255.99609375	False
14:01:44.511	3.5	1	255.99609375	False
14:01:44.531	3.5	1	255.99609375	False
14:01:44.551	3.5	1	255.99609375	False
14:01:44.571	3.5	1	255.99609375	False
14:01:44.591	3.5	1	255.99609375	False
14:01:44.611	3.5	1	255.99609375	False
14:01:44.631	3.5	1	255.99609375	False
14:01:44.651	3.5	1	255.99609375	False
14:01:44.671	3.5	1	255.99609375	False
14:01:44.691	3.5	1	255.99609375	False
14:01:44.711	3.5	1	255.99609375	False
14:01:44.731	3.5	1	255.99609375	False
14:01:44.751	3.5	1	255.99609375	False
14:01:44.771	3.5	1	255.99609375	False
14:01:44.791	3.5	1	255.99609375	False
14:01:44.811	3.5	1	255.99609375	False
14:01:44.831	3.5	1	255.99609375	False
14:01:44.851	3.5	1	255.99609375	False
14:01:44.871	3.5	1	255.99609375	False
14:01:44.891	3.5	1	255.99609375	False
14:01:44.911	3.5	1	255.99609375	False
14:01:44.931	3.5	1	255.99609375	False
14:01:44.951	3.5	1	255.99609375	False
14:01:44.971	3.5	1	255.99609375	False
14:01:44.991	3.5	1	255.99609375	False
14:01:45.011	3.5	1	255.99609375	False
14:01:45.031	3.5	1	255.99609375	False
14:01:45.051	3.5	1	255.99609375	False
14:01:45.071	3.5	1	255.99609375	False
14:01:45.091	3.5	1	255.99609375	False
14:01:45.111	3.5	1	255.99609375	False
14:01:45.131	3.5	1	255.99609375	False
14:01:45.151	3.5	1	255.99609375	False
14:01:45.171	3.5	1	255.99609375	False
14:01:45.191	3.5	1	255.99609375	False
14:01:45.211	3.5	1	255.99609375	False
14:01:45.231	3.5	1	255.99609375	False
14:01:45.251	3.5	1	255.99609375	False
14:01:45.271	3.5	1	255.99609375	False
14:01:45.291	3.5	1	255.99609375	False
14:01:45.311	3.5	1	255.99609375	False
14:01:45.331	3.5	1	255.99609375	False
14:01:45.351	3.5	1	255.99609375	False
14:01:45.371	3.5	1	255.99609375	False
14:01:45.391	3.5	1	255.99609375	False
14:01:45.411	3.5	1	255.99609375	False
14:01:45.431	3.5	1	255.99609375	False
14:01:45.451	3.5	1	255.99609375	False
14:01:45.471	3.5	1	255.99609375	False
14:01:45.491	3.5	1	255.99609375	False
14:01:45.511	3.5	1	255.99609375	False
14:01:45.531	3.5	1	255.99609375	False
14:01:45.551	3.5	1	255.99609375	False
14:01:45.571	3.5	1	255.99609375	False
14:01:45.591	3.5	1	255.99609375	False
14:01:45.611	3.5	1	255.99609375	False
14:01:45.631	3.5	1	255.99609375	False
14:01:45.651	3.5	1	255.99609375	False
14:01:45.671	3.5	1	255.99609375	False
14:01:45.691	3.5	1	255.99609375	False
14:01:45.711	3.5	1	255.99609375	False
14:01:45.731	3.5	1	255.99609375	False
14:01:45.751	3.5	1	255.99609375	False
14:01:45.771	3.5	1	255.99609375	False
14:01:45.791	3.5	1	255.99609375	False
14:01:45.811	3.5	1	255.99609375	False
14:01:45.831	3.5	1	255.99609375	False
14:01:45.851	3.5	1	255.99609375	False
14:01:45.871	3.5	1	255.99609375	False
14:01:45.891	3.5	1	255.99609375	False
14:01:45.911	3.5	1	255.99609375	False
14:01:45.931	3.5	1	255.99609375	False
14:01:45.951	3.5	1	255.99609375	False
14:01:45.971	3.5	1	255.99609375	False
14:01:45.991	3.5	1	255.99609375	False
14:01:46.011	3.5	1	255.99609375	False
14:01:46.031	3.5	1	255.99609375	False
14:01:46.051	3.5	1	255.99609375	False
14:01:46.071	3.5	1	255.99609375	False
14:01:46.091	3.5	1	255.99609375	False
14:01:46.111	3.5	1	255.99609375	False
14:01:46.131	3.5	1	255.99609375	False
14:01:46.151	3.5	1	255.99609375	False
14:01:46.171	3.5	1	255.99609375	False
14:01:46.191	3.5	1	255.99609375	False
14:01:46.211	3.5	1	255.99609375	False
14:01:46.231	3.5	1	255.99609375	False
14:01:46.251	3.5	1	255.99609375	False
14:01:46.271	3.5	1	255.99609375	False
14:01:46.291	3.5	1	255.99609375	False
14:01:46.311	3.5	1	255.99609375	False
14:01:46.331	3.5	1	255.99609375	False
14:01:46.351	3.5	1	255.99609375	False
14:01:46.371	3.5	1	255.99609375	False
14:01:46.391	3.5	1	255.99609375	False
14:01:46.411	3.5	1	255.99609375	False
14:01:46.431	3.5	1	255.99609375	False
14:01:46.451	3.5	1	255.99609375	False
14:01:46.471	3.5	1	255.99609375	False
14:01:46.491	3.5	1	255.99609375	False
14:01:46.511	3.5	1	255.99609375	False
14:01:46.531	3.5	1	255.99609375	False
14:01:46.551	3.5	1	255.99609375	False
14:01:46.571	3.5	1	255.99609375	False
14:01:46.591	3.5	1	255.99609375	False
14:01:46.611	3.5	1	255.99609375	False
14:01:46.631	3.5	1	255.99609375	False
14:01:46.651	3.5	1	255.99609375	False
14:01:46.671	3.5	1	255.99609375	False
14:01:46.691	3.5	1	255.99609375	False
14:01:46.711	3.5	1	255.99609375	False
14:01:46.731	3.5	1	255.99609375	False
14:01:46.751	3.5	1	255.99609375	False
14:01:46.771	3.5	1	12.09765625	True
14:01:46.791	3.5	1	12.09765625	True
14:01:46.811	3.5	1	12.09765625	False
14:01:46.831	3.5	1	12.09765625	False
14:01:46.851	3.5	1	12.10546875	False
14:01:46.871	3.5	1	12.10546875	False
14:01:46.891	3.5	1	12.09765625	False
14:01:46.911	3.5	1	12.11328125	False
14:01:46.931	3.5	1	12.10546875	False
14:01:46.951	3.5	1	12.0859375	False
14:01:46.971	3.5	1	12.08203125	True
14:01:46.991	3.5	1	12.09765625	False
14:01:47.011	3.5	1	12.10546875	False
14:01:47.031	3.5	1	12.10546875	True
14:01:47.051	3.5	1	12.10546875	False
14:01:47.071	3.5	1	12.09765625	False
14:01:47.091	3.5	1	12.09375	False
14:01:47.111	3.5	1	12.09375	False
14:01:47.131	3.5	1	12.09375	False
14:01:47.151	3.5	1	12.09375	True
14:01:47.171	3.5	1	12.09375	False
14:01:47.191	3.5	1	12.09765625	False
14:01:47.211	3.5	1	12.10546875	False
14:01:47.231	3.5	1	12.09375	False
14:01:47.251	3.5	1	12.10546875	True
14:01:47.271	3.5	1	12.09765625	False
14:01:47.291	3.5	1	12.09765625	True
14:01:47.311	3.5	1	12.11328125	True
14:01:47.331	3.5	1	12.09765625	True
14:01:47.351	3.5	1	12.09765625	True
14:01:47.371	3.5	1	12.09765625	True
14:01:47.391	3.5	1	12.09375	True
14:01:47.411	3.5	1	12.09375	True
14:01:47.431	3.5	1	12.10546875	True
14:01:47.451	3.5	1	12.09765625	True
14:01:47.471	3.5	1	12.09765625	True
14:01:47.491	3.5	1	12.09765625	True
14:01:47.511	3.5	0.24	12.09765625	True
14:01:47.531	3.5	0.24	12.09375	True
14:01:47.551	3.5	0.24	12.09765625	True
14:01:47.571	3.5	0.24	12.10546875	True
14:01:47.591	3.5	0.24	12.10546875	True
14:01:47.611	3.5	0.24	12.09765625	True
14:01:47.631	3.5	0.24	12.09765625	True
14:01:47.651	3.5	0.24	12.11328125	True
14:01:47.671	3.5	0.24	12.11328125	True
14:01:47.691	3.5	0.24	12.10546875	True
14:01:47.711	3	1	255.99609375	False
14:01:47.731	3	1	255.99609375	False
14:01:47.751	3	1	255.99609375	False
14:01:47.771	3	1	255.99609375	False
14:01:47.791	3	1	255.99609375	False
14:01:47.811	3	1	255.99609375	False
14:01:47.831	3	1	255.99609375	False
14:01:47.851	3	1	255.99609375	False
14:01:47.871	3	1	255.99609375	False
14:01:47.891	3	1	255.99609375	False
14:01:47.911	3	1	255.99609375	False
14:01:47.931	3	1	255.99609375	False
14:01:47.951	3	1	255.99609375	False
14:01:47.971	3	1	255.99609375	False
14:01:47.991	3	1	255.99609375	False
14:01:48.011	3	1	255.99609375	False
14:01:48.031	3	1	255.99609375	False
14:01:48.051	3	1	255.99609375	False
14:01:48.071	3	1	255.99609375	False
14:01:48.091	3	1	255.99609375	False
14:01:48.111	3	1	255.99609375	False
14:01:48.131	3	1	255.99609375	False
14:01:48.151	3	1	255.99609375	False
14:01:48.171	3	1	255.99609375	False
14:01:48.191	3	1	255.99609375	False
14:01:48.211	3	1	255.99609375	False
14:01:48.231	3	1	255.99609375	False
14:01:48.251	3	1	255.99609375	False
14:01:48.271	3	1	255.99609375	False
14:01:48.291	3	1	255.99609375	False
14:01:48.311	3	1	255.99609375	False
14:01:48.331	3	1	255.99609375	False
14:01:48.351	3	1	255.99609375	False
14:01:48.371	3	1	255.99609375	False
14:01:48.391	3	1	255.99609375	False
14:01:48.411	3	1	255.99609375	False
14:01:48.431	3	1	255.99609375	False
14:01:48.451	3	1	255.99609375	False
14:01:48.471	3	1	255.99609375	False
14:01:48.491	3	1	255.99609375	False
14:01:48.511	3	1	255.99609375	False
14:01:48.531	3	1	255.99609375	False
14:01:48.551	3	1	255.99609375	False
14:01:48.571	3	1	255.99609375	False
14:01:48.591	3	1	255.99609375	False
14:01:48.611	3	1	255.99609375	False
14:01:48.631	3	1	255.99609375	False
14:01:48.651	3	1	255.99609375	False
14:01:48.671	3	1	255.99609375	False
14:01:48.691	3	1	255.99609375	False
14:01:48.711	3	1	255.99609375	False
14:01:48.731	3	1	255.99609375	False
14:01:48.751	3	1	255.99609375	False
14:01:48.771	3	1	255.99609375	False
14:01:48.791	3	1	255.99609375	False
14:01:48.811	3	1	255.99609375	False
14:01:48.831	3	1	255.99609375	False
14:01:48.851	3	1	255.99609375	False
14:01:48.871	3	1	255.99609375	False
14:01:48.891	3	1	255.99609375	False
14:01:48.911	3	1	255.99609375	False
14:01:48.931	3	1	255.99609375	False
14:01:48.951	3	1	255.99609375	False
14:01:48.971	3	1	255.99609375	False
14:01:48.991	3	1	255.99609375	False
14:01:49.011	3	1	255.99609375	False
14:01:49.031	3	1	255.99609375	False
14:01:49.051	3	1	255.99609375	False
14:01:49.071	3	1	255.99609375	False
14:01:49.091	3	1	255.99609375	False
14:01:49.111	3	1	255.99609375	False
14:01:49.131	3	1	255.99609375	False
14:01:49.151	3	1	255.99609375	False
14:01:49.171	3	1	255.99609375	False
14:01:49.191	3	1	255.99609375	False
14:01:49.211	3	1	255.99609375	False
14:01:49.231	3	1	255.99609375	False
14:01:49.251	3	1	255.99609375	False
14:01:49.271	3	1	255.99609375	False
14:01:49.291	3	1	255.99609375	False
14:01:49.311	3	1	255.99609375	False
14:01:49.331	3	1	255.99609375	False
14:01:49.351	3	1	255.99609375	False
14:01:49.371	3	1	255.99609375	False
14:01:49.391	3	1	255.99609375	False
14:01:49.411	3	1	255.99609375	False
14:01:49.431	3	1	255.99609375	False
14:01:49.451	3	1	255.99609375	False
14:01:49.471	3	1	255.99609375	False
14:01:49.491	3	1	255.99609375	False
14:01:49.511	3	1	255.99609375	False
14:01:49.531	3	1	255.99609375	False
14:01:49.551	3	1	255.99609375	False
14:01:49.571	3	1	255.99609375	False
14:01:49.591	3	1	255.99609375	False
14:01:49.611	3	1	255.99609375	False
14:01:49.631	3	1	255.99609375	False
14:01:49.651	3	1	255.99609375	False
14:01:49.671	3	1	255.99609375	False
14:01:49.691	3	1	255.99609375	False
14:01:49.711	3	1	255.99609375	False
14:01:49.731	3	1	255.99609375	False
14:01:49.751	3	1	255.99609375	False
14:01:49.771	3	1	255.99609375	False
14:01:49.791	3	1	255.99609375	False
14:01:49.811	3	1	12.11328125	True
14:01:49.831	3	1	12.11328125	True
14:01:49.851	3	1	12.11328125	True
14:01:49.871	3	1	12.11328125	True
14:01:49.891	3	1	12.11328125	True
14:01:49.911	3	1	12.11328125	True
14:01:49.931	3	1	12.10546875	False
14:01:49.951	3	1	12.09375	False
14:01:49.971	3	1	12.09375	False
14:01:49.991	3	1	12.08203125	False
14:01:50.011	3	1	12.09765625	False
14:01:50.031	3	1	12.09375	False
14:01:50.051	3	1	12.09375	False
14:01:50.071	3	1	12.09765625	False
14:01:50.091	3	1	12.09765625	False
14:01:50.111	3	1	12.09375	False
14:01:50.131	3	1	12.09765625	False
14:01:50.151	3	1	12.09765625	True
14:01:50.171	3	1	12.08203125	False
14:01:50.191	3	1	12.09375	False
14:01:50.211	3	1	12.09765625	True
14:01:50.231	3	1	12.10546875	False
14:01:50.251	3	1	12.09375	False
14:01:50.271	3	1	12.0859375	False
14:01:50.291	3	1	12.09375	False
14:01:50.311	3	1	12.09765625	False
14:01:50.331	3	1	12.09375	True
14:01:50.351	3	1	12.09765625	True
14:01:50.371	3	1	12.09765625	True
14:01:50.391	3	1	12.09765625	True
14:01:50.411	3	1	12.09765625	True
14:01:50.431	3	1	12.10546875	True
14:01:50.451	3	1	12.10546875	True
14:01:50.471	3	0.32	12.10546875	True
14:01:50.491	3	0.32	12.10546875	True
14:01:50.511	3	0.32	12.09765625	True
14:01:50.531	3	0.32	12.11328125	True
14:01:50.551	3	0.32	12.10546875	True
14:01:50.571	3	0.32	12.10546875	True
14:01:50.591	3	0.32	12.11328125	True
14:01:50.611	3	0.32	12.09375	True
14:01:50.631	3	0.32	12.09375	True
14:01:50.651	3	0.32	12.09375	True
14:01:50.671	3	0.32	12.09765625	True
14:01:50.691	3	0.32	12.09375	True
14:01:50.711	3.5	1	255.99609375	False
14:01:50.731	3.5	1	255.99609375	False
14:01:50.751	3.5	1	255.99609375	False
14:01:50.771	3.5	1	255.99609375	False
14:01:50.791	3.5	1	255.99609375	False
14:01:50.811	3.5	1	255.99609375	False
14:01:50.831	3.5	1	255.99609375	False
14:01:50.851	3.5	1	255.99609375	False
14:01:50.871	3.5	1	255.99609375	False
14:01:50.891	3.5	1	255.99609375	False
14:01:50.911	3.5	1	255.99609375	False
14:01:50.931	3.5	1	255.99609375	False
14:01:50.951	3.5	1	255.99609375	False
14:01:50.971	3.5	1	255.99609375	False
14:01:50.991	3.5	1	255.99609375	False
14:01:51.011	3.5	1	255.99609375	False
14:01:51.031	3.5	1	255.99609375	False
14:01:51.051	3.5	1	255.99609375	False
14:01:51.071	3.5	1	255.99609375	False
14:01:51.091	3.5	1	255.99609375	False
14:01:51.111	3.5	1	255.99609375	False
14:01:51.131	3.5	1	255.99609375	False
14:01:51.151	3.5	1	255.99609375	False
14:01:51.171	3.5	1	255.99609375	False
14:01:51.191	3.5	1	255.99609375	False
14:01:51.211	3.5	1	255.99609375	False
14:01:51.231	3.5	1	255.99609375	False
14:01:51.251	3.5	1	255.99609375	False
14:01:51.271	3.5	1	255.99609375	False
14:01:51.291	3.5	1	255.99609375	False
14:01:51.311	3.5	1	255.99609375	False
14:01:51.331	3.5	1	255.99609375	False
14:01:51.351	3.5	1.04	255.99609375	False
14:01:51.371	3.5	1.04	255.99609375	False
14:01:51.391	3.5	1.04	255.99609375	False
14:01:51.411	3.5	1.04	255.99609375	False
14:01:51.431	3.5	1.04	255.99609375	False
14:01:51.451	3.5	1.04	255.99609375	False
14:01:51.471	3.5	1.04	255.99609375	False
14:01:51.491	3.5	1.04	255.99609375	False
14:01:51.511	3.5	1.04	255.99609375	False
14:01:51.531	3.5	1.04	255.99609375	False
14:01:51.551	3.5	1.04	255.99609375	False
14:01:51.571	3.5	1.04	255.99609375	False
14:01:51.591	3.5	1.04	255.99609375	False
14:01:51.611	3.5	1.04	255.99609375	False
14:01:51.631	3.5	1.04	255.99609375	False
14:01:51.651	3.5	1.04	255.99609375	False
14:01:51.671	3.5	1.04	255.99609375	False
14:01:51.691	3.5	1.04	255.99609375	False
14:01:51.711	3.5	1.04	255.99609375	False
14:01:51.731	3.5	1.04	255.99609375	False
14:01:51.751	3.5	1.04	255.99609375	False
14:01:51.771	3.5	1.04	255.99609375	False
14:01:51.791	3.5	1.04	255.99609375	False
14:01:51.811	3.5	1.04	255.99609375	False
14:01:51.831	3.5	1.04	255.99609375	False
14:01:51.851	3.5	1	255.99609375	False
14:01:51.871	3.5	1	255.99609375	False
14:01:51.891	3.5	1	255.99609375	False
14:01:51.911	3.5	1	255.99609375	False
14:01:51.931	3.5	1	255.99609375	False
14:01:51.951	3.5	1	255.99609375	False
14:01:51.971	3.5	1	255.99609375	False
14:01:51.991	3.5	1	255.99609375	False
14:01:52.011	3.5	1	255.99609375	False
14:01:52.031	3.5	1	255.99609375	False
14:01:52.051	3.5	1	255.99609375	False
14:01:52.071	3.5	1	255.99609375	False
14:01:52.091	3.5	1	255.99609375	False
14:01:52.111	3.5	1	255.99609375	False
14:01:52.131	3.5	1	255.99609375	False
14:01:52.151	3.5	1	255.99609375	False
14:01:52.171	3.5	1	255.99609375	False
14:01:52.191	3.5	1	255.99609375	False
14:01:52.211	3.5	1	255.99609375	False
14:01:52.231	3.5	1	255.99609375	False
14:01:52.251	3.5	1	255.99609375	False
14:01:52.271	3.5	1	255.99609375	False
14:01:52.291	3.5	1	255.99609375	False
14:01:52.311	3.5	1	255.99609375	False
14:01:52.331	3.5	1	255.99609375	False
14:01:52.351	3.5	0.96	12.09765625	True
14:01:52.371	3.5	0.96	12.09765625	True
14:01:52.391	3.5	0.96	12.09765625	True
14:01:52.411	3.5	0.96	12.09765625	True
14:01:52.431	3.5	0.96	12.09765625	True
14:01:52.451	3.5	0.96	12.09765625	True
14:01:52.471	3.5	0.96	12.09765625	True
14:01:52.491	3.5	0.96	12.09765625	True
14:01:52.511	3.5	0.96	12.09765625	True
14:01:52.531	3.5	0.96	12.09765625	True
14:01:52.551	3.5	0.96	12.09765625	True
14:01:52.571	3.5	0.96	12.09765625	True
14:01:52.591	3.5	0.96	12.09765625	True
14:01:52.611	3.5	0.96	12.09765625	True
14:01:52.631	3.5	0.96	12.09765625	True
14:01:52.651	3.5	0.96	12.09765625	True
14:01:52.671	3.5	0.96	12.09765625	True
14:01:52.691	3.5	0.96	12.09765625	True
14:01:52.711	3.5	0.96	12.09765625	True
14:01:52.731	3.5	0.96	12.09765625	True
14:01:52.751	3.5	0.96	12.09765625	True
14:01:52.771	3.5	0.96	12.09765625	True
14:01:52.791	3.5	0.96	12.09765625	True
14:01:52.811	3.5	0.96	12.09765625	True
14:01:52.831	3.5	0.96	12.09765625	True
14:01:52.851	3.5	0.96	12.09375	False
14:01:52.871	3.5	0.96	12.09375	False
14:01:52.891	3.5	0.96	12.10546875	False
14:01:52.911	3.5	0.96	12.09765625	False
14:01:52.931	3.5	0.96	12.08203125	True
14:01:52.951	3.5	0.96	12.09375	False
14:01:52.971	3.5	0.96	12.09375	False
14:01:52.991	3.5	0.96	12.0859375	True
14:01:53.011	3.5	0.96	12.10546875	False
14:01:53.031	3.5	0.96	12.0859375	False
14:01:53.051	3.5	0.96	12.07421875	False
14:01:53.071	3.5	0.96	12.0859375	False
14:01:53.091	3.5	0.96	12.0859375	False
14:01:53.111	3.5	0.96	12.0859375	False
14:01:53.131	3.5	0.96	12.09765625	False
14:01:53.151	3.5	0.96	12.08203125	False
14:01:53.171	3.5	0.96	12.09765625	False
14:01:53.191	3.5	0.96	12.08203125	True
14:01:53.211	3.5	0.96	12.08203125	False
14:01:53.231	3.5	0.96	12.0859375	False
14:01:53.251	3.5	0.96	12.0859375	False
14:01:53.271	3.5	0.96	12.09375	False
14:01:53.291	3.5	0.96	12.09375	False
14:01:53.311	3.5	0.96	12.09375	False
14:01:53.331	3.5	0.96	12.0859375	False
14:01:53.351	3.5	0.96	12.0859375	True
14:01:53.371	3.5	0.96	12.09765625	False
14:01:53.391	3.5	0.96	12.0859375	False
14:01:53.411	3.5	0.96	12.09375	False
14:01:53.431	3.5	0.96	12.09375	False
14:01:53.451	3.5	0.96	12.0859375	True
14:01:53.471	3.5	0.96	12.09375	True
14:01:53.491	3.5	0.96	12.09375	True
14:01:53.511	3.5	0.96	12.10546875	True
14:01:53.531	3.5	0.96	12.10546875	True
14:01:53.551	3.5	0.96	12.11328125	True
14:01:53.571	3.5	0.96	12.09765625	True
14:01:53.591	3.5	0.96	12.10546875	True
14:01:53.611	3.5	0.96	12.10546875	True
14:01:53.631	3.5	0.96	12.11328125	True
14:01:53.651	3	0.12	12.09765625	True
14:01:53.671	3	0.12	12.11328125	True
14:01:53.691	3	0.12	12.10546875	True
14:01:53.711	3	0.12	12.10546875	True
14:01:53.731	3	0.12	12.09375	True
14:01:53.751	3	0.12	12.09375	True
14:01:53.771	3	0.12	12.09375	True
14:01:53.791	3	0.12	12.09375	True
14:01:53.811	3	0.12	12.09375	True
14:01:53.831	3	0.12	12.10546875	True
14:01:53.851	3	0.12	12.09765625	True
14:01:53.871	3	0.12	12.09375	True
14:01:53.891	3	0.12	12.09765625	True
14:01:53.911	3	0.12	12.09765625	True
14:01:53.931	3	1	255.99609375	False
14:01:53.951	3	1	255.99609375	False
14:01:53.971	3	1	255.99609375	False
14:01:53.991	3	1	255.99609375	False
14:01:54.011	3	1	255.99609375	False
14:01:54.031	3	1	255.99609375	False
14:01:54.051	3	1	255.99609375	False
14:01:54.071	3	1	255.99609375	False
14:01:54.091	3	1	255.99609375	False
14:01:54.111	3	1	255.99609375	False
14:01:54.131	3	1	255.99609375	False
14:01:54.151	3	1	255.99609375	False
14:01:54.171	3	1	255.99609375	False
14:01:54.191	3	1	255.99609375	False
14:01:54.211	3	1	255.99609375	False
14:01:54.231	3	1	255.99609375	False
14:01:54.251	3	1	255.99609375	False
14:01:54.271	3	1	255.99609375	False
14:01:54.291	3	1	255.99609375	False
14:01:54.311	3	1	255.99609375	False
14:01:54.331	3	1	255.99609375	False
14:01:54.351	3	1	255.99609375	False
14:01:54.371	3	1	255.99609375	False
14:01:54.391	3	1	255.99609375	False
14:01:54.411	3	1	255.99609375	False
14:01:54.431	3	1	255.99609375	False
14:01:54.451	3	1	255.99609375	False
14:01:54.471	3	1	255.99609375	False
14:01:54.491	3	1	255.99609375	False
14:01:54.511	3	1	255.99609375	False
14:01:54.531	3	1	255.99609375	False
14:01:54.551	3	1	255.99609375	False
14:01:54.571	3	1	255.99609375	False
14:01:54.591	3	1	255.99609375	False
14:01:54.611	3	1	255.99609375	False
14:01:54.631	3	1	255.99609375	False
14:01:54.651	3	1	255.99609375	False
14:01:54.671	3	1	255.99609375	False
14:01:54.691	3	1	255.99609375	False
14:01:54.711	3	1	255.99609375	False
14:01:54.731	3	1	255.99609375	False
14:01:54.751	3	1	255.99609375	False
14:01:54.771	3	1	255.99609375	False
14:01:54.791	3	1	255.99609375	False
14:01:54.811	3	1	255.99609375	False
14:01:54.831	3	1	255.99609375	False
14:01:54.851	3	1	255.99609375	False
14:01:54.871	3	1	255.99609375	False
14:01:54.891	3	1	255.99609375	False
14:01:54.911	3	1	255.99609375	False
14:01:54.931	3	1	255.99609375	False
14:01:54.951	3	1	255.99609375	False
14:01:54.971	3	1	255.99609375	False
14:01:54.991	3	1	255.99609375	False
14:01:55.011	3	1	255.99609375	False
14:01:55.031	3	1	255.99609375	False
14:01:55.051	3	1	255.99609375	False
14:01:55.071	3	1	255.99609375	False
14:01:55.091	3	1	255.99609375	False
14:01:55.111	3	1	255.99609375	False
14:01:55.131	3	1	255.99609375	False
14:01:55.151	3	1	255.99609375	False
14:01:55.171	3	1	255.99609375	False
14:01:55.191	3	1	255.99609375	False
14:01:55.211	3	1	255.99609375	False
14:01:55.231	3	1	255.99609375	False
14:01:55.251	3	1	255.99609375	False
14:01:55.271	3	1	255.99609375	False
14:01:55.291	3	1	255.99609375	False
14:01:55.311	3	1	255.99609375	False
14:01:55.331	3	1	255.99609375	False
14:01:55.351	3	1	255.99609375	False
14:01:55.371	3	1	255.99609375	False
14:01:55.391	3	1	255.99609375	False
14:01:55.411	3	1	255.99609375	False
14:01:55.431	3	1	255.99609375	False
14:01:55.451	3	1	255.99609375	False
14:01:55.471	3	1	255.99609375	False
14:01:55.491	3	1	255.99609375	False
14:01:55.511	3	1	255.99609375	False
14:01:55.531	3	1	255.99609375	False
14:01:55.551	3	1	255.99609375	False
14:01:55.571	3	1	255.99609375	False
14:01:55.591	3	1	255.99609375	False
14:01:55.611	3	1	255.99609375	False
14:01:55.631	3	1	255.99609375	False
14:01:55.651	3	1	255.99609375	False
14:01:55.671	3	1	255.99609375	False
14:01:55.691	3	1	255.99609375	False
14:01:55.711	3	1	255.99609375	False
14:01:55.731	3	1	255.99609375	False
14:01:55.751	3	1	255.99609375	False
14:01:55.771	3	1	255.99609375	False
14:01:55.791	3	1	255.99609375	False
14:01:55.811	3	1	255.99609375	False
14:01:55.831	3	1	255.99609375	False
14:01:55.851	3	1	255.99609375	False
14:01:55.871	3	1	255.99609375	False
14:01:55.891	3	1	12.11328125	True
14:01:55.911	3	1	12.11328125	True
14:01:55.931	3	1	12.09765625	False
14:01:55.951	3	1	12.11328125	False
14:01:55.971	3	1	12.09765625	True
14:01:55.991	3	1	12.10546875	True
14:01:56.011	3	1	12.10546875	False
14:01:56.031	3	1	12.11328125	False
14:01:56.051	3	1	12.09375	False
14:01:56.071	3	1	12.09765625	False
14:01:56.091	3	1	12.09765625	False
14:01:56.111	3	1	12.09765625	False
14:01:56.131	3	1	12.09765625	True
14:01:56.151	3	1	12.10546875	False
14:01:56.171	3	1	12.09765625	False
14:01:56.191	3	1	12.09375	False
14:01:56.211	3	1	12.09765625	False
14:01:56.231	3	1	12.09375	True
14:01:56.251	3	1	12.09765625	True
14:01:56.271	3	1	12.11328125	True
14:01:56.291	3	1	12.10546875	True
14:01:56.311	3	1	12.11328125	True
14:01:56.331	3	1	12.11328125	True
14:01:56.351	3	1	12.09765625	True
14:01:56.371	3	0.16	12.09765625	True
14:01:56.391	3	0.16	12.09375	True
14:01:56.411	3	0.16	12.09375	True
14:01:56.431	3	0.16	12.09375	True
14:01:56.451	3	0.16	12.09765625	True
14:01:56.471	3	0.16	12.09375	True
14:01:56.491	3	0.16	12.11328125	True
14:01:56.511	3	0.16	12.09765625	True
14:01:56.531	3	0.16	12.0859375	True
14:01:56.551	3	0.16	12.10546875	True
14:01:56.571	3	0.16	12.10546875	True
14:01:56.591	3	0.16	12.1171875	True
14:01:56.611	3	0.16	12.11328125	True
14:01:56.631	3	0.16	12.09765625	True
14:01:56.651	3	0.16	12.09765625	True
14:01:56.671	3	0.16	12.10546875	True
14:01:56.691	3	1	255.99609375	False
14:01:56.711	3	1	255.99609375	False
14:01:56.731	3	1	255.99609375	False
14:01:56.751	3	1	255.99609375	False
14:01:56.771	3	1	255.99609375	False
14:01:56.791	3	1	255.99609375	False
14:01:56.811	3	1	255.99609375	False
14:01:56.831	3	1	255.99609375	False
14:01:56.851	3	1	255.99609375	False
14:01:56.871	3	1	255.99609375	False
14:01:56.891	3	1	255.99609375	False
14:01:56.911	3	1	255.99609375	False
14:01:56.931	3	1	255.99609375	False
14:01:56.951	3	1	255.99609375	False
14:01:56.971	3	1	255.99609375	False
14:01:56.991	3	1	255.99609375	False
14:01:57.011	3	1	255.99609375	False
14:01:57.031	3	1	255.99609375	False
14:01:57.051	3	1	255.99609375	False
14:01:57.071	3	1	255.99609375	False
14:01:57.091	3	1	255.99609375	False
14:01:57.111	3	1	255.99609375	False
14:01:57.131	3	1	255.99609375	False
14:01:57.151	3	1	255.99609375	False
14:01:57.171	3	1	255.99609375	False
14:01:57.191	3	1	255.99609375	False
14:01:57.211	3	1	255.99609375	False
14:01:57.231	3	1	255.99609375	False
14:01:57.251	3	1	255.99609375	False
14:01:57.271	3	1	255.99609375	False
14:01:57.291	3	1	255.99609375	False
14:01:57.311	3	1	255.99609375	False
14:01:57.331	3	1	255.99609375	False
14:01:57.351	3	1	255.99609375	False
14:01:57.371	3	1	255.99609375	False
14:01:57.391	3	1	255.99609375	False
14:01:57.411	3	1	255.99609375	False
14:01:57.431	3	1	255.99609375	False
14:01:57.451	3	1	255.99609375	False
14:01:57.471	3	1	255.99609375	False
14:01:57.491	3	1	255.99609375	False
14:01:57.511	3	1	255.99609375	False
14:01:57.531	3	1	255.99609375	False
14:01:57.551	3	1	255.99609375	False
14:01:57.571	3	1	255.99609375	False
14:01:57.591	3	1	255.99609375	False
14:01:57.611	3	1	255.99609375	False
14:01:57.631	3	1	255.99609375	False
14:01:57.651	3	1	255.99609375	False
14:01:57.671	3	1	255.99609375	False
14:01:57.691	3	1	255.99609375	False
14:01:57.711	3	1	255.99609375	False
14:01:57.731	3	1	255.99609375	False
14:01:57.751	3	1	255.99609375	False
14:01:57.771	3	1	255.99609375	False
14:01:57.791	3	1	255.99609375	False
14:01:57.811	3	1	255.99609375	False
14:01:57.831	3	1	255.99609375	False
14:01:57.851	3	1	255.99609375	False
14:01:57.871	3	1	255.99609375	False
14:01:57.891	3	1	255.99609375	False
14:01:57.911	3	1	255.99609375	False
14:01:57.931	3	1.04	255.99609375	False
14:01:57.951	3	1.04	255.99609375	False
14:01:57.971	3	1.04	255.99609375	False
14:01:57.991	3	1.04	255.99609375	False
14:01:58.011	3	1.04	255.99609375	False
14:01:58.031	3	1.04	255.99609375	False
14:01:58.051	3	1.04	255.99609375	False
14:01:58.071	3	1.04	255.99609375	False
14:01:58.091	3	1.04	255.99609375	False
14:01:58.111	3	1.04	255.99609375	False
14:01:58.131	3	1.04	255.99609375	False
14:01:58.151	3	1.04	255.99609375	False
14:01:58.171	3	1.04	255.99609375	False
14:01:58.191	3	1.04	255.99609375	False
14:01:58.211	3	1.04	255.99609375	False
14:01:58.231	3	1.04	255.99609375	False
14:01:58.251	3	1.04	255.99609375	False
14:01:58.271	3	1.04	255.99609375	False
14:01:58.291	3	1.04	255.99609375	False
14:01:58.311	3	1.04	255.99609375	False
14:01:58.331	3	1.04	255.99609375	False
14:01:58.351	3	1.04	255.99609375	False
14:01:58.371	3	1.04	255.99609375	False
14:01:58.391	3	1.04	255.99609375	False
14:01:58.411	3	1.04	255.99609375	False
14:01:58.431	3	1.04	255.99609375	False
14:01:58.451	3	1	255.99609375	False
14:01:58.471	3	1	255.99609375	False
14:01:58.491	3	1	255.99609375	False
14:01:58.511	3	1	255.99609375	False
14:01:58.531	3	1	255.99609375	False
14:01:58.551	3	1	255.99609375	False
14:01:58.571	3	1	255.99609375	False
14:01:58.591	3	1	255.99609375	False
14:01:58.611	3	1	255.99609375	False
14:01:58.631	3	1	255.99609375	False
14:01:58.651	3	1	255.99609375	False
14:01:58.671	3	1	255.99609375	False
14:01:58.691	3	1	255.99609375	False
14:01:58.711	3	1	255.99609375	False
14:01:58.731	3	1	255.99609375	False
14:01:58.751	3	1	255.99609375	False
14:01:58.771	3	1	255.99609375	False
14:01:58.791	3	1	255.99609375	False
14:01:58.811	3	1	255.99609375	False
14:01:58.831	3	1	255.99609375	False
14:01:58.851	3	1	255.99609375	False
14:01:58.871	3	1	255.99609375	False
14:01:58.891	3	1	255.99609375	False
14:01:58.911	3	1	255.99609375	False
14:01:58.931	3	1	255.99609375	False
14:01:58.951	3	1	12.10546875	True
14:01:58.971	3	1	12.10546875	True
14:01:58.991	3	1	12.09765625	False
14:01:59.011	3	1	12.09375	False
14:01:59.031	3	1	12.09375	False
14:01:59.051	3	1	12.09765625	False
14:01:59.071	3	1	12.09375	False
14:01:59.091	3	1	12.09765625	False
14:01:59.111	3	1	12.10546875	True
14:01:59.131	3	1	12.09765625	True
14:01:59.151	3	1	12.0859375	False
14:01:59.171	3	1	12.0859375	True
14:01:59.191	3	1	12.09375	True
14:01:59.211	3	1	12.10546875	True
14:01:59.231	3	0.2	12.09765625	True
14:01:59.251	3	0.2	12.09765625	True
14:01:59.271	3	0.2	12.09375	True
14:01:59.291	3	0.2	12.09765625	True
14:01:59.311	3	0.2	12.11328125	True
14:01:59.331	3	0.2	12.10546875	True
14:01:59.351	3	0.2	12.10546875	True
14:01:59.371	3	0.2	12.10546875	True
14:01:59.391	3	0.2	12.09765625	True
14:01:59.411	3	0.2	12.11328125	True
14:01:59.431	3	0.2	12.1171875	True
14:01:59.451	3	0.2	12.10546875	True
14:01:59.471	3	0.2	12.11328125	True
14:01:59.491	3	0.2	12.09765625	True
14:01:59.511	3	0.2	12.09765625	True
14:01:59.531	3	0.2	12.1171875	True
14:01:59.551	3	0.2	12.10546875	True
14:01:59.571	3	0.2	12.09765625	True
14:01:59.591	3	0.2	12.10546875	True
14:01:59.611	3	1	255.99609375	False
14:01:59.631	3	1	255.99609375	False
14:01:59.651	3	1	255.99609375	False
14:01:59.671	3	1	255.99609375	False
14:01:59.691	3	1	255.99609375	False
14:01:59.711	3	1	255.99609375	False
14:01:59.731	3	1	255.99609375	False
14:01:59.751	3	1	255.99609375	False
14:01:59.771	3	1	255.99609375	False
14:01:59.791	3	1	255.99609375	False
14:01:59.811	3	1	255.99609375	False
14:01:59.831	3	1	255.99609375	False
14:01:59.851	3	1	255.99609375	False
14:01:59.871	3	1	255.99609375	False
14:01:59.891	3	1	255.99609375	False
14:01:59.911	3	1	255.99609375	False
14:01:59.931	3	1	255.99609375	False
14:01:59.951	3	1	255.99609375	False
14:01:59.971	3	1	255.99609375	False
14:01:59.991	3	1.04	255.99609375	False
14:02:00.011	3	1.04	255.99609375	False
14:02:00.031	3	1.04	255.99609375	False
14:02:00.051	3	1.04	255.99609375	False
14:02:00.071	3	1.04	255.99609375	False
14:02:00.091	3	1.04	255.99609375	False
14:02:00.111	3	1.04	255.99609375	False
14:02:00.131	3	1.04	255.99609375	False
14:02:00.151	3	1.04	255.99609375	False
14:02:00.171	3	1.04	255.99609375	False
14:02:00.191	3	1.04	255.99609375	False
14:02:00.211	3	1.04	255.99609375	False
14:02:00.231	3	1.04	255.99609375	False
14:02:00.251	3	1.04	255.99609375	False
14:02:00.271	3	1.04	255.99609375	False
14:02:00.291	3	1.04	255.99609375	False
14:02:00.311	3	1.04	255.99609375	False
14:02:00.331	3	1.04	255.99609375	False
14:02:00.351	3	1.04	255.99609375	False
14:02:00.371	3	1.04	255.99609375	False
14:02:00.391	3	1.04	255.99609375	False
14:02:00.411	3	1.04	255.99609375	False
14:02:00.431	3	1.04	255.99609375	False
14:02:00.451	3	1.04	255.99609375	False
14:02:00.471	3	1.04	255.99609375	False
14:02:00.491	3	1	255.99609375	False
14:02:00.511	3	1	255.99609375	False
14:02:00.531	3	1	255.99609375	False
14:02:00.551	3	1	255.99609375	False
14:02:00.571	3	1	255.99609375	False
14:02:00.591	3	1	255.99609375	False
14:02:00.611	3	1	255.99609375	False
14:02:00.631	3	1	255.99609375	False
14:02:00.651	3	1	255.99609375	False
14:02:00.671	3	1	255.99609375	False
14:02:00.691	3	1	255.99609375	False
14:02:00.711	3	1	255.99609375	False
14:02:00.731	3	1	255.99609375	False
14:02:00.751	3	1	255.99609375	False
14:02:00.771	3	1	255.99609375	False
14:02:00.791	3	1	255.99609375	False
14:02:00.811	3	1	255.99609375	False
14:02:00.831	3	1	255.99609375	False
14:02:00.851	3	1	255.99609375	False
14:02:00.871	3	1	255.99609375	False
14:02:00.891	3	1	255.99609375	False
14:02:00.911	3	1	255.99609375	False
14:02:00.931	3	1	255.99609375	False
14:02:00.951	3	1	255.99609375	False
14:02:00.971	3	1	255.99609375	False
14:02:00.991	3	1	255.99609375	False
14:02:01.011	3	1	255.99609375	False
14:02:01.031	3	1	255.99609375	False
14:02:01.051	3	1	255.99609375	False
14:02:01.071	3	1	255.99609375	False
14:02:01.091	3	1	255.99609375	False
14:02:01.111	3	1	255.99609375	False
14:02:01.131	3	1	255.99609375	False
14:02:01.151	3	1	255.99609375	False
14:02:01.171	3	1	255.99609375	False
14:02:01.191	3	1	255.99609375	False
14:02:01.211	3	1	255.99609375	False
14:02:01.231	3	1	255.99609375	False
14:02:01.251	3	1	255.99609375	False
14:02:01.271	3	1	255.99609375	False
14:02:01.291	3	1	255.99609375	False
14:02:01.311	3	1	255.99609375	False
14:02:01.331	3	1	255.99609375	False
14:02:01.351	3	1	255.99609375	False
14:02:01.371	3	1	255.99609375	False
14:02:01.391	3	1	255.99609375	False
14:02:01.411	3	1	255.99609375	False
14:02:01.431	3	1	255.99609375	False
14:02:01.451	3	1	255.99609375	False
14:02:01.471	3	1	255.99609375	False
14:02:01.491	3	1	255.99609375	False
14:02:01.511	3	1	255.99609375	False
14:02:01.531	3	1	255.99609375	False
14:02:01.551	3	1	255.99609375	False
14:02:01.571	3	1	255.99609375	False
14:02:01.591	3	1	255.99609375	False
14:02:01.611	3	1	255.99609375	False
14:02:01.631	3	1	255.99609375	False
14:02:01.651	3	1	255.99609375	False
14:02:01.671	3	1	255.99609375	False
14:02:01.691	3	1	255.99609375	False
14:02:01.711	3	1	255.99609375	False
14:02:01.731	3	1	255.99609375	False
14:02:01.751	3	1	255.99609375	False
14:02:01.771	3	1	255.99609375	False
14:02:01.791	3	1	255.99609375	False
14:02:01.811	3	1	255.99609375	False
14:02:01.831	3	1	255.99609375	False
14:02:01.851	3	1	255.99609375	False
14:02:01.871	3	1	255.99609375	False
14:02:01.891	3	1	255.99609375	False
14:02:01.911	3	1	255.99609375	False
14:02:01.931	3	1	255.99609375	False
14:02:01.951	3	1	255.99609375	False
14:02:01.971	3	1	255.99609375	False
14:02:01.991	3	1	255.99609375	False
14:02:02.011	3	0.44	12.09375	True
14:02:02.031	3	0.44	12.09375	True
14:02:02.051	3	0.44	12.09375	True
14:02:02.071	3	0.44	12.09375	True
14:02:02.091	3	0.44	12.09375	True
14:02:02.111	3	0.44	12.09375	True
14:02:02.131	3	0.44	12.09375	True
14:02:02.151	3	0.44	12.09375	True
14:02:02.171	3	0.44	12.09375	True
14:02:02.191	3	0.44	12.09375	True
14:02:02.211	3	0.44	12.09375	True
14:02:02.231	3	0.44	12.09375	False
14:02:02.251	3	0.44	12.10546875	False
14:02:02.271	3	0.44	12.10546875	False
14:02:02.291	3	0.44	12.10546875	False
14:02:02.311	3	0.44	12.10546875	True
14:02:02.331	3	0.44	12.10546875	False
14:02:02.351	3	0.44	12.09375	False
14:02:02.371	3	0.44	12.10546875	True
14:02:02.391	3	0.44	12.09765625	False
14:02:02.411	3	0.44	12.09375	False
14:02:02.431	3	0.44	12.10546875	False
14:02:02.451	3	0.44	12.10546875	False
14:02:02.471	3	0.44	12.10546875	False
14:02:02.491	3	0.44	12.1171875	False
14:02:02.511	3	0.44	12.0859375	True
14:02:02.531	3	0.44	12.09375	False
14:02:02.551	3	0.44	12.09375	False
14:02:02.571	3	0.44	12.11328125	True
14:02:02.591	3	0.44	12.10546875	True
14:02:02.611	3	0.44	12.09375	True
14:02:02.631	3	0.44	12.09375	True
14:02:02.651	3	0.44	12.10546875	True
14:02:02.671	3	0.44	12.10546875	True
14:02:02.691	3	0.44	12.09765625	True
14:02:02.711	3	0.44	12.09765625	True
14:02:02.731	3	0.44	12.09375	True
14:02:02.751	3	0.44	12.09375	True
14:02:02.771	3	0.44	12.10546875	True
14:02:02.791	3	1.12	255.99609375	False
14:02:02.811	3	1.12	255.99609375	False
14:02:02.831	3	1.12	255.99609375	False
14:02:02.851	3	1.12	255.99609375	False
14:02:02.871	3	1.12	255.99609375	False
14:02:02.891	3	1.12	255.99609375	False
14:02:02.911	3	1.12	255.99609375	False
14:02:02.931	3	1.12	255.99609375	False
14:02:02.951	3	1.12	255.99609375	False
14:02:02.971	3	1.12	255.99609375	False
14:02:02.991	3	1	255.99609375	False
14:02:03.011	3	1	255.99609375	False
14:02:03.031	3	1	255.99609375	False
14:02:03.051	3	1	255.99609375	False
14:02:03.071	3	1	255.99609375	False
14:02:03.091	3	1	255.99609375	False
14:02:03.111	3	1	255.99609375	False
14:02:03.131	3	1	255.99609375	False
14:02:03.151	3	1	255.99609375	False
14:02:03.171	3	1	255.99609375	False
14:02:03.191	3	1	255.99609375	False
14:02:03.211	3	1	255.99609375	False
14:02:03.231	3	1	255.99609375	False
14:02:03.251	3	1	255.99609375	False
14:02:03.271	3	1	255.99609375	False
14:02:03.291	3	1	255.99609375	False
14:02:03.311	3	1	255.99609375	False
14:02:03.331	3	1	255.99609375	False
14:02:03.351	3	1	255.99609375	False
14:02:03.371	3	1	255.99609375	False
14:02:03.391	3	1	255.99609375	False
14:02:03.411	3	1	255.99609375	False
14:02:03.431	3	1	255.99609375	False
14:02:03.451	3	1	255.99609375	False
14:02:03.471	3	1	255.99609375	False
14:02:03.491	3	1	255.99609375	False
14:02:03.511	3	1	255.99609375	False
14:02:03.531	3	1	255.99609375	False
14:02:03.551	3	1	255.99609375	False
14:02:03.571	3	1	255.99609375	False
14:02:03.591	3	1	255.99609375	False
14:02:03.611	3	1	255.99609375	False
14:02:03.631	3	1	255.99609375	False
14:02:03.651	3	1	255.99609375	False
14:02:03.671	3	1	255.99609375	False
14:02:03.691	3	1	255.99609375	False
14:02:03.711	3	1	255.99609375	False
14:02:03.731	3	1	255.99609375	False
14:02:03.751	3	1	255.99609375	False
14:02:03.771	3	1	255.99609375	False
14:02:03.791	3	1	255.99609375	False
14:02:03.811	3	1	255.99609375	False
14:02:03.831	3	1	255.99609375	False
14:02:03.851	3	1	255.99609375	False
14:02:03.871	3	1	255.99609375	False
14:02:03.891	3	1	255.99609375	False
14:02:03.911	3	1	255.99609375	False
14:02:03.931	3	1	255.99609375	False
14:02:03.951	3	1	255.99609375	False
14:02:03.971	3	1	255.99609375	False
14:02:03.991	3	1	255.99609375	False
14:02:04.011	3	1	255.99609375	False
14:02:04.031	3	1	255.99609375	False
14:02:04.051	3	1	255.99609375	False
14:02:04.071	3	1	255.99609375	False
14:02:04.091	3	1	255.99609375	False
14:02:04.111	3	1	255.99609375	False
14:02:04.131	3	1	255.99609375	False
14:02:04.151	3	1	255.99609375	False
14:02:04.171	3	1	255.99609375	False
14:02:04.191	3	1	255.99609375	False
14:02:04.211	3	1	255.99609375	False
14:02:04.231	3	1	255.99609375	False
14:02:04.251	3	1	255.99609375	False
14:02:04.271	3	1	255.99609375	False
14:02:04.291	3	1	255.99609375	False
14:02:04.311	3	1	255.99609375	False
14:02:04.331	3	1	255.99609375	False
14:02:04.351	3	1	255.99609375	False
14:02:04.371	3	1	255.99609375	False
14:02:04.391	3	1	255.99609375	False
14:02:04.411	3	1	255.99609375	False
14:02:04.431	3	1	255.99609375	False
14:02:04.451	3	1	255.99609375	False
14:02:04.471	3	1	255.99609375	False
14:02:04.491	3	1	255.99609375	False
14:02:04.511	3	1.04	255.99609375	False
14:02:04.531	3	1.04	255.99609375	False
14:02:04.551	3	1.04	255.99609375	False
14:02:04.571	3	1.04	255.99609375	False
14:02:04.591	3	1.04	255.99609375	False
14:02:04.611	3	1.04	255.99609375	False
14:02:04.631	3	1.04	255.99609375	False
14:02:04.651	3	1.04	255.99609375	False
14:02:04.671	3	1.04	255.99609375	False
14:02:04.691	3	1.04	255.99609375	False
14:02:04.711	3	1.04	255.99609375	False
14:02:04.731	3	1.04	255.99609375	False
14:02:04.751	3	1.04	255.99609375	False
14:02:04.771	3	1.04	255.99609375	False
14:02:04.791	3	1.04	255.99609375	False
14:02:04.811	3	1.04	255.99609375	False
14:02:04.831	3	1.04	255.99609375	False
14:02:04.851	3	1.04	255.99609375	False
14:02:04.871	3	1.04	255.99609375	False
14:02:04.891	3	1.04	255.99609375	False
14:02:04.911	3	1.04	255.99609375	False
14:02:04.931	3	1.04	255.99609375	False
14:02:04.951	3	1.04	255.99609375	False
14:02:04.971	3	1.04	255.99609375	False
14:02:04.991	3	1.04	255.99609375	False
14:02:05.011	3	1.04	12.09765625	True
14:02:05.031	3	1.04	12.09765625	True
14:02:05.051	3	1.04	12.09765625	True
14:02:05.071	3	1.04	12.10546875	False
14:02:05.091	3	1.04	12.09765625	False
14:02:05.111	3	1.04	12.09765625	False
14:02:05.131	3	1.04	12.10546875	True
14:02:05.151	3	1.04	12.09765625	True
14:02:05.171	3	1.04	12.09765625	False
14:02:05.191	3	1.04	12.10546875	False
14:02:05.211	3	1.04	12.10546875	False
14:02:05.231	3	1.04	12.09765625	False
14:02:05.251	3	1.04	12.1171875	False
14:02:05.271	3	0.16	12.09765625	True
14:02:05.291	3	0.16	12.10546875	True
14:02:05.311	3	0.16	12.09375	True
14:02:05.331	3	0.16	12.10546875	True
14:02:05.351	3	0.16	12.09765625	True
14:02:05.371	3	0.16	12.11328125	True
14:02:05.391	3	0.16	12.10546875	True
14:02:05.411	3	0.16	12.09375	True
14:02:05.431	3	0.16	12.09375	True
14:02:05.451	3	0.16	12.11328125	True
14:02:05.471	3	0.16	12.0859375	True
14:02:05.491	3	0.16	12.09765625	True
14:02:05.511	3	0.16	12.10546875	True
14:02:05.531	3	0.16	12.11328125	True
14:02:05.551	3	0.16	12.09375	True
14:02:05.571	3	0.16	12.10546875	True
14:02:05.591	3	0.16	12.10546875	True
14:02:05.611	3	0.16	12.09765625	True
14:02:05.631	3	0.16	12.10546875	True
14:02:05.651	3	0.16	12.1171875	True
14:02:05.671	3	0.16	12.09765625	True
14:02:05.691	3	0.16	12.09765625	True
14:02:05.711	3	1	255.99609375	False
14:02:05.731	3	1	255.99609375	False
14:02:05.751	3	1	255.99609375	False
14:02:05.771	3	1	255.99609375	False
14:02:05.791	3	1	255.99609375	False
14:02:05.811	3	1	255.99609375	False
14:02:05.831	3	1	255.99609375	False
14:02:05.851	3	1	255.99609375	False
14:02:05.871	3	1	255.99609375	False
14:02:05.891	3	1	255.99609375	False
14:02:05.911	3	1	255.99609375	False
14:02:05.931	3	1	255.99609375	False
14:02:05.951	3	1	255.99609375	False
14:02:05.971	3	1	255.99609375	False
14:02:05.991	3	1	255.99609375	False
14:02:06.011	3	1	255.99609375	False
14:02:06.031	3	1	255.99609375	False
14:02:06.051	3	1	255.99609375	False
14:02:06.071	3	1	255.99609375	False
14:02:06.091	3	1	255.99609375	False
14:02:06.111	3	1	255.99609375	False
14:02:06.131	3	1	255.99609375	False
14:02:06.151	3	1	255.99609375	False
14:02:06.171	3	1	255.99609375	False
14:02:06.191	3	1	255.99609375	False
14:02:06.211	3	1	255.99609375	False
14:02:06.231	3	1	255.99609375	False
14:02:06.251	3	1	255.99609375	False
14:02:06.271	3	1	255.99609375	False
14:02:06.291	3	1	255.99609375	False
14:02:06.311	3	1	255.99609375	False
14:02:06.331	3	1	255.99609375	False
14:02:06.351	3	1	255.99609375	False
14:02:06.371	3	1	255.99609375	False
14:02:06.391	3	1	255.99609375	False
14:02:06.411	3	1	255.99609375	False
14:02:06.431	3	1	255.99609375	False
14:02:06.451	3	1	255.99609375	False
14:02:06.471	3	1	255.99609375	False
14:02:06.491	3	1	255.99609375	False
14:02:06.511	3	1	255.99609375	False
14:02:06.531	3	1	255.99609375	False
14:02:06.551	3	1	255.99609375	False
14:02:06.571	3	1	255.99609375	False
14:02:06.591	3	1	255.99609375	False
14:02:06.611	3	1	255.99609375	False
14:02:06.631	3	1	255.99609375	False
14:02:06.651	3	1	255.99609375	False
14:02:06.671	3	1	255.99609375	False
14:02:06.691	3	1	255.99609375	False
14:02:06.711	3	1	255.99609375	False
14:02:06.731	3	1	255.99609375	False
14:02:06.751	3	1	255.99609375	False
14:02:06.771	3	1	255.99609375	False
14:02:06.791	3	1	255.99609375	False
14:02:06.811	3	1	255.99609375	False
14:02:06.831	3	1	255.99609375	False
14:02:06.851	3	1	255.99609375	False
14:02:06.871	3	1	255.99609375	False
14:02:06.891	3	1	255.99609375	False
14:02:06.911	3	1	255.99609375	False
14:02:06.931	3	1	255.99609375	False
14:02:06.951	3	1	255.99609375	False
14:02:06.971	3	1	255.99609375	False
14:02:06.991	3	1	255.99609375	False
14:02:07.011	3	1	255.99609375	False
14:02:07.031	3	1	255.99609375	False
14:02:07.051	3	1	255.99609375	False
14:02:07.071	3	1	255.99609375	False
14:02:07.091	3	1	255.99609375	False
14:02:07.111	3	1	255.99609375	False
14:02:07.131	3	1	255.99609375	False
14:02:07.151	3	1	255.99609375	False
14:02:07.171	3	1	255.99609375	False
14:02:07.191	3	1	255.99609375	False
14:02:07.211	3	1	255.99609375	False
14:02:07.231	3	1	255.99609375	False
14:02:07.251	3	1	255.99609375	False
14:02:07.271	3	1	255.99609375	False
14:02:07.291	3	1	255.99609375	False
14:02:07.311	3	1	255.99609375	False
14:02:07.331	3	1	255.99609375	False
14:02:07.351	3	1	255.99609375	False
14:02:07.371	3	1	255.99609375	False
14:02:07.391	3	1	255.99609375	False
14:02:07.411	3	1	255.99609375	False
14:02:07.431	3	1	255.99609375	False
14:02:07.451	3	1	255.99609375	False
14:02:07.471	3	1	255.99609375	False
14:02:07.491	3	1	255.99609375	False
14:02:07.511	3	1	255.99609375	False
14:02:07.531	3	1	255.99609375	False
14:02:07.551	3	1	255.99609375	False
14:02:07.571	3	1	255.99609375	False
14:02:07.591	3	1	255.99609375	False
14:02:07.611	3	1	255.99609375	False
14:02:07.631	3	1	255.99609375	False
14:02:07.651	3	1	255.99609375	False
14:02:07.671	3	1	255.99609375	False
14:02:07.691	3	1	255.99609375	False
14:02:07.711	3	1	255.99609375	False
14:02:07.731	3	1	255.99609375	False
14:02:07.751	3	1	255.99609375	False
14:02:07.771	3	1	255.99609375	False
14:02:07.791	3	1	255.99609375	False
14:02:07.811	3	1	255.99609375	False
14:02:07.831	3	1	255.99609375	False
14:02:07.851	3	1	255.99609375	False
14:02:07.871	3	1	255.99609375	False
14:02:07.891	3	1	255.99609375	False
14:02:07.911	3	1	255.99609375	False
14:02:07.931	3	1	255.99609375	False
14:02:07.951	3	1	255.99609375	False
14:02:07.971	3	1	255.99609375	False
14:02:07.991	3	1	255.99609375	False
14:02:08.011	3	1	255.99609375	False
14:02:08.031	3	1	255.99609375	False
14:02:08.051	3	0.16	12.09765625	True
14:02:08.071	3	0.16	12.09765625	True
14:02:08.091	3	0.16	12.09765625	True
14:02:08.111	3	0.16	12.09765625	True
14:02:08.131	3	0.16	12.09765625	True
14:02:08.151	3	0.16	12.10546875	True
14:02:08.171	3	0.16	12.09765625	False
14:02:08.191	3	0.16	12.09765625	False
14:02:08.211	3	0.16	12.11328125	False
14:02:08.231	3	0.16	12.10546875	False
14:02:08.251	3	0.16	12.10546875	False
14:02:08.271	3	0.16	12.09375	False
14:02:08.291	3	0.16	12.09765625	False
14:02:08.311	3	0.16	12.09765625	True
14:02:08.331	3	0.16	12.11328125	False
14:02:08.351	3	0.16	12.09765625	False
14:02:08.371	3	0.16	12.09765625	False
14:02:08.391	3	0.16	12.10546875	False
14:02:08.411	3	0.16	12.09765625	True
14:02:08.431	3	0.16	12.09765625	False
14:02:08.451	3	0.16	12.09765625	False
14:02:08.471	3	0.16	12.09765625	False
14:02:08.491	3	0.16	12.0859375	False
14:02:08.511	3	0.16	12.09765625	False
14:02:08.531	3	0.16	12.09765625	True
14:02:08.551	3	0.16	12.09375	True
14:02:08.571	3	0.16	12.0859375	True
14:02:08.591	3	0.16	12.09765625	True
14:02:08.611	3	0.16	12.09375	True
14:02:08.631	3	0.16	12.09765625	True
14:02:08.651	3	0.16	12.09765625	True
14:02:08.671	3	0.16	12.0859375	True
14:02:08.691	3	0.16	12.09375	True
14:02:08.711	3	0.16	12.09765625	True
14:02:08.731	3	0.16	12.11328125	True
14:02:08.751	3	0.16	12.10546875	True
14:02:08.771	3	0.16	12.09765625	True
14:02:08.791	3	0.16	12.10546875	True
14:02:08.811	3	0.16	12.09765625	True
14:02:08.831	3	0.16	12.09765625	True
14:02:08.851	3	0.16	12.10546875	True
14:02:08.871	3	0.16	12.10546875	True
14:02:08.891	3	0.16	12.10546875	True
14:02:08.911	3	0.16	12.10546875	True
14:02:08.931	3	1.12	255.99609375	False
14:02:08.951	3	1.12	255.99609375	False
14:02:08.971	3	1.12	255.99609375	False
14:02:08.991	3	1.12	255.99609375	False
14:02:09.011	3	1.12	255.99609375	False
14:02:09.031	3	1.12	255.99609375	False
14:02:09.051	3	1.12	255.99609375	False
14:02:09.071	3	1.12	255.99609375	False
14:02:09.091	3	1	255.99609375	False
14:02:09.111	3	1	255.99609375	False
14:02:09.131	3	1	255.99609375	False
14:02:09.151	3	1	255.99609375	False
14:02:09.171	3	1	255.99609375	False
14:02:09.191	3	1	255.99609375	False
14:02:09.211	3	1	255.99609375	False
14:02:09.231	3	1	255.99609375	False
14:02:09.251	3	1	255.99609375	False
14:02:09.271	3	1	255.99609375	False
14:02:09.291	3	1	255.99609375	False
14:02:09.311	3	1	255.99609375	False
14:02:09.331	3	1	255.99609375	False
14:02:09.351	3	1	255.99609375	False
14:02:09.371	3	1	255.99609375	False
14:02:09.391	3	1	255.99609375	False
14:02:09.411	3	1	255.99609375	False
14:02:09.431	3	1	255.99609375	False
14:02:09.451	3	1	255.99609375	False
14:02:09.471	3	1	255.99609375	False
14:02:09.491	3	1	255.99609375	False
14:02:09.511	3	1	255.99609375	False
14:02:09.531	3	1	255.99609375	False
14:02:09.551	3	1	255.99609375	False
14:02:09.571	3	1	255.99609375	False
14:02:09.591	3	1	255.99609375	False
14:02:09.611	3	1	255.99609375	False
14:02:09.631	3	1	255.99609375	False
14:02:09.651	3	1	255.99609375	False
14:02:09.671	3	1	255.99609375	False
14:02:09.691	3	1	255.99609375	False
14:02:09.711	3	1	255.99609375	False
14:02:09.731	3	1	255.99609375	False
14:02:09.751	3	1	255.99609375	False
14:02:09.771	3	1	255.99609375	False
14:02:09.791	3	1	255.99609375	False
14:02:09.811	3	1	255.99609375	False
14:02:09.831	3	1	255.99609375	False
14:02:09.851	3	1	255.99609375	False
14:02:09.871	3	1	255.99609375	False
14:02:09.891	3	1	255.99609375	False
14:02:09.911	3	1	255.99609375	False
14:02:09.931	3	1	255.99609375	False
14:02:09.951	3	1	255.99609375	False
14:02:09.971	3	1	255.99609375	False
14:02:09.991	3	1	255.99609375	False
14:02:10.011	3	1	255.99609375	False
14:02:10.031	3	1	255.99609375	False
14:02:10.051	3	1	255.99609375	False
14:02:10.071	3	1	255.99609375	False
14:02:10.091	3	1	255.99609375	False
14:02:10.111	3	1	255.99609375	False
14:02:10.131	3	1	255.99609375	False
14:02:10.151	3	1	255.99609375	False
14:02:10.171	3	1	255.99609375	False
14:02:10.191	3	1	255.99609375	False
14:02:10.211	3	1	255.99609375	False
14:02:10.231	3	1	255.99609375	False
14:02:10.251	3	1	255.99609375	False
14:02:10.271	3	1	255.99609375	False
14:02:10.291	3	1	255.99609375	False
14:02:10.311	3	1	255.99609375	False
14:02:10.331	3	1	255.99609375	False
14:02:10.351	3	1	255.99609375	False
14:02:10.371	3	1	255.99609375	False
14:02:10.391	3	1	255.99609375	False
14:02:10.411	3	1	255.99609375	False
14:02:10.431	3	1	255.99609375	False
14:02:10.451	3	1	255.99609375	False
14:02:10.471	3	1	255.99609375	False
14:02:10.491	3	1	255.99609375	False
14:02:10.511	3	1	255.99609375	False
14:02:10.531	3	1	255.99609375	False
14:02:10.551	3	1	255.99609375	False
14:02:10.571	3	1	255.99609375	False
14:02:10.591	3	1	255.99609375	False
14:02:10.611	3	1	255.99609375	False
14:02:10.631	3	1	255.99609375	False
14:02:10.651	3	1	255.99609375	False
14:02:10.671	3	1	255.99609375	False
14:02:10.691	3	1	255.99609375	False
14:02:10.711	3	1	255.99609375	False
14:02:10.731	3	1	255.99609375	False
14:02:10.751	3	1	255.99609375	False
14:02:10.771	3	1	255.99609375	False
14:02:10.791	3	1	255.99609375	False
14:02:10.811	3	1	255.99609375	False
14:02:10.831	3	1	255.99609375	False
14:02:10.851	3	1	255.99609375	False
14:02:10.871	3	1	255.99609375	False
14:02:10.891	3	1	255.99609375	False
14:02:10.911	3	1	255.99609375	False
14:02:10.931	3	1	255.99609375	False
14:02:10.951	3	1	255.99609375	False
14:02:10.971	3	1	255.99609375	False
14:02:10.991	3	1	255.99609375	False
14:02:11.011	3	1	255.99609375	False
14:02:11.031	3	1	255.99609375	False
14:02:11.051	3	1	255.99609375	False
14:02:11.071	3	1	255.99609375	False
14:02:11.091	3	0.24	12.09375	True
14:02:11.111	3	0.24	12.09375	True
14:02:11.131	3	0.24	12.09375	True
14:02:11.151	3	0.24	12.09375	True
14:02:11.171	3	0.24	12.09375	True
14:02:11.191	3	0.24	12.09375	True
14:02:11.211	3	0.24	12.09765625	False
14:02:11.231	3	0.24	12.08203125	False
14:02:11.251	3	0.24	12.09375	True
14:02:11.271	3	0.24	12.10546875	True
14:02:11.291	3	0.24	12.08203125	False
14:02:11.311	3	0.24	12.0859375	False
14:02:11.331	3	0.24	12.09375	False
14:02:11.351	3	0.24	12.09375	False
14:02:11.371	3	0.24	12.0859375	True
14:02:11.391	3	0.24	12.09765625	True
14:02:11.411	3	0.24	12.09765625	True
14:02:11.431	3	0.24	12.09765625	True
14:02:11.451	3	0.24	12.09765625	True
14:02:11.471	3	0.24	12.09375	True
14:02:11.491	3	0.24	12.09765625	True
14:02:11.511	3	0.24	12.10546875	True
14:02:11.531	3	0.24	12.09375	True
14:02:11.551	3	0.24	12.10546875	True
14:02:11.571	3	0.24	12.09375	True
14:02:11.591	3	0.24	12.09375	True
14:02:11.611	3	0.24	12.11328125	True
14:02:11.631	3	0.24	12.09375	True
14:02:11.651	3	0.24	12.09765625	True
14:02:11.671	3	0.24	12.09375	True
14:02:11.691	3	0.24	12.09375	True
14:02:11.711	3	0.12	12.09765625	True
14:02:11.731	3	0.12	12.09375	True
14:02:11.751	3	1	255.99609375	False
14:02:11.771	3	1	255.99609375	False
14:02:11.791	3	1	255.99609375	False
14:02:11.811	3	1	255.99609375	False
14:02:11.831	3	1	255.99609375	False
14:02:11.851	3	1	255.99609375	False
14:02:11.871	3	1	255.99609375	False
14:02:11.891	3	1	255.99609375	False
14:02:11.911	3	1	255.99609375	False
14:02:11.931	3	1	255.99609375	False
14:02:11.951	3	1	255.99609375	False
14:02:11.971	3	1	255.99609375	False
14:02:11.991	3	1	255.99609375	False
14:02:12.011	3	1	255.99609375	False
14:02:12.031	3	1	255.99609375	False
14:02:12.051	3	1	255.99609375	False
14:02:12.071	3	1	255.99609375	False
14:02:12.091	3	1	255.99609375	False
14:02:12.111	3	1	255.99609375	False
14:02:12.131	3	1	255.99609375	False
14:02:12.151	3	1	255.99609375	False
14:02:12.171	3	1	255.99609375	False
14:02:12.191	3	1	255.99609375	False
14:02:12.211	3	1	255.99609375	False
14:02:12.231	3	1	255.99609375	False
14:02:12.251	3	1	255.99609375	False
14:02:12.271	3	1	255.99609375	False
14:02:12.291	3	1	255.99609375	False
14:02:12.311	3	1	255.99609375	False
14:02:12.331	3	1	255.99609375	False
14:02:12.351	3	1	255.99609375	False
14:02:12.371	3	1	255.99609375	False
14:02:12.391	3	1	255.99609375	False
14:02:12.411	3	1	255.99609375	False
14:02:12.431	3	1	255.99609375	False
14:02:12.451	3	1	255.99609375	False
14:02:12.471	3	1	255.99609375	False
14:02:12.491	3	1	255.99609375	False
14:02:12.511	3	1	255.99609375	False
14:02:12.531	3	1	255.99609375	False
14:02:12.551	3	1	255.99609375	False
14:02:12.571	3	1	255.99609375	False
14:02:12.591	3	1	255.99609375	False
14:02:12.611	3	1	255.99609375	False
14:02:12.631	3	1	255.99609375	False
14:02:12.651	3	1.04	255.99609375	False
14:02:12.671	3	1.04	255.99609375	False
14:02:12.691	3	1.04	255.99609375	False
14:02:12.711	3	1.04	255.99609375	False
14:02:12.731	3	1.04	255.99609375	False
14:02:12.751	3	1.04	255.99609375	False
14:02:12.771	3	1.04	255.99609375	False
14:02:12.791	3	1.04	255.99609375	False
14:02:12.811	3	1.04	255.99609375	False
14:02:12.831	3	1.04	255.99609375	False
14:02:12.851	3	1.04	255.99609375	False
14:02:12.871	3	1.04	255.99609375	False
14:02:12.891	3	1.04	255.99609375	False
14:02:12.911	3	1.04	255.99609375	False
14:02:12.931	3	1.04	255.99609375	False
14:02:12.951	3	1.04	255.99609375	False
14:02:12.971	3	1.04	255.99609375	False
14:02:12.991	3	1.04	255.99609375	False
14:02:13.011	3	1.04	255.99609375	False
14:02:13.031	3	1.04	255.99609375	False
14:02:13.051	3	1.04	255.99609375	False
14:02:13.071	3	1.04	255.99609375	False
14:02:13.091	3	1.04	255.99609375	False
14:02:13.111	3	1.04	255.99609375	False
14:02:13.131	3	1.04	255.99609375	False
14:02:13.151	3	1.04	255.99609375	False
14:02:13.171	3	1	255.99609375	False
14:02:13.191	3	1	255.99609375	False
14:02:13.211	3	1	255.99609375	False
14:02:13.231	3	1	255.99609375	False
14:02:13.251	3	1	255.99609375	False
14:02:13.271	3	1	255.99609375	False
14:02:13.291	3	1	255.99609375	False
14:02:13.311	3	1	255.99609375	False
14:02:13.331	3	1	255.99609375	False
14:02:13.351	3	1	255.99609375	False
14:02:13.371	3	1	255.99609375	False
14:02:13.391	3	1	255.99609375	False
14:02:13.411	3	1	255.99609375	False
14:02:13.431	3	1	255.99609375	False
14:02:13.451	3	1	255.99609375	False
14:02:13.471	3	1	255.99609375	False
14:02:13.491	3	1	255.99609375	False
14:02:13.511	3	1	255.99609375	False
14:02:13.531	3	1	255.99609375	False
14:02:13.551	3	1	255.99609375	False
14:02:13.571	3	1	255.99609375	False
14:02:13.591	3	1	255.99609375	False
14:02:13.611	3	1	255.99609375	False
14:02:13.631	3	1	255.99609375	False
14:02:13.651	3	1	255.99609375	False
14:02:13.671	3	1	12.09375	True
14:02:13.691	3	1	12.09375	True
14:02:13.711	3	1	12.09375	True
14:02:13.731	3	1	12.09375	True
14:02:13.751	3	1	12.09375	True
14:02:13.771	3	1	12.09375	True
14:02:13.791	3	1	12.09375	True
14:02:13.811	3	1	12.09375	True
14:02:13.831	3	1	12.09375	True
14:02:13.851	3	1	12.09375	True
14:02:13.871	3	1	12.09375	True
14:02:13.891	3	1	12.09375	True
14:02:13.911	3	1	12.09375	True
14:02:13.931	3	1	12.09375	True
14:02:13.951	3	1	12.09375	True
14:02:13.971	3	1	12.09375	True
14:02:13.991	3	1	12.09375	True
14:02:14.011	3	1	12.09375	True
14:02:14.031	3	1	12.09375	True
14:02:14.051	3	1	12.09375	True
14:02:14.071	3	1	12.09375	True
14:02:14.091	3	1	12.09375	True
14:02:14.111	3	1	12.09375	True
14:02:14.131	3	1	12.09375	True
14:02:14.151	3	1	12.09375	True
14:02:14.171	3	1	12.09375	False
14:02:14.191	3	1	12.09765625	False
14:02:14.211	3	1	12.09765625	False
14:02:14.231	3	1	12.09375	True
14:02:14.251	3	1	12.09375	False
14:02:14.271	3	1	12.09765625	False
14:02:14.291	3	1	12.09765625	False
14:02:14.311	3	1	12.09375	False
14:02:14.331	3	1	12.08203125	False
14:02:14.351	3	1	12.09375	False
14:02:14.371	3	1	12.09375	False
14:02:14.391	3	1	12.0859375	False
14:02:14.411	3	1	12.0859375	False
14:02:14.431	3	1	12.09375	False
14:02:14.451	3	1	12.0859375	False
14:02:14.471	3	1	12.0859375	False
14:02:14.491	3	1	12.0859375	False
14:02:14.511	3	1	12.06640625	True
14:02:14.531	3	1	12.10546875	True
14:02:14.551	3	1	12.10546875	True
14:02:14.571	3	1	12.10546875	True
14:02:14.591	3	1	12.11328125	True
14:02:14.611	3	1	12.11328125	True
14:02:14.631	3	1	12.10546875	True
14:02:14.651	3	1	12.10546875	True
14:02:14.671	3	1	12.10546875	True
14:02:14.691	3	1	12.11328125	True
14:02:14.711	3	1	12.09765625	True
14:02:14.731	3	1	12.09765625	True
14:02:14.751	3	1	12.0859375	True
14:02:14.771	3	1	12.09765625	True
14:02:14.791	3	1	12.10546875	True
14:02:14.811	3	1	12.09765625	True
14:02:14.831	3	1	12.09765625	True
14:02:14.851	3	1	12.08203125	True
14:02:14.871	3	1	12.09765625	True
14:02:14.891	3	1	12.09765625	True
14:02:14.911	3	0.08	12.09765625	True
14:02:14.931	3	0.08	12.10546875	True
14:02:14.951	3	0.08	12.09765625	True
14:02:14.971	3	0.08	12.09765625	True
14:02:14.991	3	1	255.99609375	False
14:02:15.011	3	1	255.99609375	False
14:02:15.031	3	1	255.99609375	False
14:02:15.051	3	1	255.99609375	False
14:02:15.071	3	1	255.99609375	False
14:02:15.091	3	1	255.99609375	False
14:02:15.111	3	1	255.99609375	False
14:02:15.131	3	1	255.99609375	False
14:02:15.151	3	1	255.99609375	False
14:02:15.171	3	1	255.99609375	False
14:02:15.191	3	1	255.99609375	False
14:02:15.211	3	1	255.99609375	False
14:02:15.231	3	1	255.99609375	False
14:02:15.251	3	1	255.99609375	False
14:02:15.271	3	1	255.99609375	False
14:02:15.291	3	1	255.99609375	False
14:02:15.311	3	1	255.99609375	False
14:02:15.331	3	1	255.99609375	False
14:02:15.351	3	1	255.99609375	False
14:02:15.371	3	1	255.99609375	False
14:02:15.391	3	1	255.99609375	False
14:02:15.411	3	1	255.99609375	False
14:02:15.431	3	1	255.99609375	False
14:02:15.451	3	1	255.99609375	False
14:02:15.471	3	1	255.99609375	False
14:02:15.491	3	1	255.99609375	False
14:02:15.511	3	1	255.99609375	False
14:02:15.531	3	1	255.99609375	False
14:02:15.551	3	1	255.99609375	False
14:02:15.571	3	1	255.99609375	False
14:02:15.591	3	1	255.99609375	False
14:02:15.611	3	1	255.99609375	False
14:02:15.631	3	1	255.99609375	False
14:02:15.651	3	1	255.99609375	False
14:02:15.671	3	1	255.99609375	False
14:02:15.691	3	1.04	255.99609375	False
14:02:15.711	3	1.04	255.99609375	False
14:02:15.731	3	1.04	255.99609375	False
14:02:15.751	3	1.04	255.99609375	False
14:02:15.771	3	1.04	255.99609375	False
14:02:15.791	3	1.04	255.99609375	False
14:02:15.811	3	1.04	255.99609375	False
14:02:15.831	3	1.04	255.99609375	False
14:02:15.851	3	1.04	255.99609375	False
14:02:15.871	3	1.04	255.99609375	False
14:02:15.891	3	1.04	255.99609375	False
14:02:15.911	3	1.04	255.99609375	False
14:02:15.931	3	1.04	255.99609375	False
14:02:15.951	3	1.04	255.99609375	False
14:02:15.971	3	1.04	255.99609375	False
14:02:15.991	3	1.04	255.99609375	False
14:02:16.011	3	1.04	255.99609375	False
14:02:16.031	3	1.04	255.99609375	False
14:02:16.051	3	1.04	255.99609375	False
14:02:16.071	3	1.04	255.99609375	False
14:02:16.091	3	1.04	255.99609375	False
14:02:16.111	3	1.04	255.99609375	False
14:02:16.131	3	1.04	255.99609375	False
14:02:16.151	3	1.04	255.99609375	False
14:02:16.171	3	1.04	255.99609375	False
14:02:16.191	3	1.04	255.99609375	False
14:02:16.211	3	1	255.99609375	False
14:02:16.231	3	1	255.99609375	False
14:02:16.251	3	1	255.99609375	False
14:02:16.271	3	1	255.99609375	False
14:02:16.291	3	1	255.99609375	False
14:02:16.311	3	1	255.99609375	False
14:02:16.331	3	1	255.99609375	False
14:02:16.351	3	1	255.99609375	False
14:02:16.371	3	1	255.99609375	False
14:02:16.391	3	1	255.99609375	False
14:02:16.411	3	1	255.99609375	False
14:02:16.431	3	1	255.99609375	False
14:02:16.451	3	1	255.99609375	False
14:02:16.471	3	1	255.99609375	False
14:02:16.491	3	1	255.99609375	False
14:02:16.511	3	1	255.99609375	False
14:02:16.531	3	1	255.99609375	False
14:02:16.551	3	1	255.99609375	False
14:02:16.571	3	1	255.99609375	False
14:02:16.591	3	1	255.99609375	False
14:02:16.611	3	1	255.99609375	False
14:02:16.631	3	1	255.99609375	False
14:02:16.651	3	1	255.99609375	False
14:02:16.671	3	1	255.99609375	False
14:02:16.691	3	1	255.99609375	False
14:02:16.711	3	1	255.99609375	False
14:02:16.731	3	1	255.99609375	False
14:02:16.751	3	1	255.99609375	False
14:02:16.771	3	1	255.99609375	False
14:02:16.791	3	1	255.99609375	False
14:02:16.811	3	1	255.99609375	False
14:02:16.831	3	1	255.99609375	False
14:02:16.851	3	1	255.99609375	False
14:02:16.871	3	1	255.99609375	False
14:02:16.891	3	1	255.99609375	False
14:02:16.911	3	1	255.99609375	False
14:02:16.931	3	1	255.99609375	False
14:02:16.951	3	1	255.99609375	False
14:02:16.971	3	1	255.99609375	False
14:02:16.991	3	1	255.99609375	False
14:02:17.011	3	1	255.99609375	False
14:02:17.031	3	1	255.99609375	False
14:02:17.051	3	1	255.99609375	False
14:02:17.071	3	1	255.99609375	False
14:02:17.091	3	1	255.99609375	False
14:02:17.111	3	1	255.99609375	False
14:02:17.131	3	1	255.99609375	False
14:02:17.151	3	1	255.99609375	False
14:02:17.171	3	1	255.99609375	False
14:02:17.191	3	1	255.99609375	False
14:02:17.211	3	1	12.10546875	True
14:02:17.231	3	1	12.10546875	True
14:02:17.251	3	1	12.10546875	True
14:02:17.271	3	1	12.10546875	True
14:02:17.291	3	1	12.10546875	False
14:02:17.311	3	1	12.10546875	True
14:02:17.331	3	1	12.09375	True
14:02:17.351	3	1	12.11328125	False
14:02:17.371	3	1	12.09765625	False
14:02:17.391	3	1	12.10546875	False
14:02:17.411	3	1	12.09375	False
14:02:17.431	3	1	12.10546875	True
14:02:17.451	3	1	12.09375	True
14:02:17.471	3	1	12.09765625	False
14:02:17.491	3	1	12.09375	False
14:02:17.511	3	1	12.0859375	True
14:02:17.531	3	1	12.09375	True
14:02:17.551	3	1	12.0859375	True
14:02:17.571	3	1	12.09765625	True
14:02:17.591	3	1	12.09375	True
14:02:17.611	3	1	12.11328125	True
14:02:17.631	3	1	12.09375	True
14:02:17.651	3	1	12.09375	True
14:02:17.671	3	1	12.09375	True
14:02:17.691	3	1	12.09765625	True
14:02:17.711	3	1	12.10546875	True
14:02:17.731	3	1	12.09765625	True
14:02:17.751	3	0.28	12.10546875	True
14:02:17.771	3	0.28	12.09765625	True
14:02:17.791	3	0.28	12.09765625	True
14:02:17.811	3	0.28	12.10546875	True
14:02:17.831	3	0.28	12.11328125	True
14:02:17.851	3	0.28	12.11328125	True
14:02:17.871	3	1	255.99609375	False
14:02:17.891	3	1	255.99609375	False
14:02:17.911	3	1	255.99609375	False
14:02:17.931	3	1	255.99609375	False
14:02:17.951	3	1	255.99609375	False
14:02:17.971	3	1	255.99609375	False
14:02:17.991	3	1	255.99609375	False
14:02:18.011	3	1	255.99609375	False
14:02:18.031	3	1	255.99609375	False
14:02:18.051	3	1	255.99609375	False
14:02:18.071	3	1	255.99609375	False
14:02:18.091	3	1	255.99609375	False
14:02:18.111	3	1	255.99609375	False
14:02:18.131	3	1	255.99609375	False
14:02:18.151	3	1	255.99609375	False
14:02:18.171	3	1	255.99609375	False
14:02:18.191	3	1	255.99609375	False
14:02:18.211	3	1	255.99609375	False
14:02:18.231	3	1	255.99609375	False
14:02:18.251	3	1	255.99609375	False
14:02:18.271	3	1	255.99609375	False
14:02:18.291	3	1	255.99609375	False
14:02:18.311	3	1	255.99609375	False
14:02:18.331	3	1	255.99609375	False
14:02:18.351	3	1	255.99609375	False
14:02:18.371	3	1	255.99609375	False
14:02:18.391	3	1	255.99609375	False
14:02:18.411	3	1	255.99609375	False
14:02:18.431	3	1	255.99609375	False
14:02:18.451	3	1	255.99609375	False
14:02:18.471	3	1	255.99609375	False
14:02:18.491	3	1	255.99609375	False
14:02:18.511	3	1	255.99609375	False
14:02:18.531	3	1	255.99609375	False
14:02:18.551	3	1	255.99609375	False
14:02:18.571	3	1	255.99609375	False
14:02:18.591	3	1	255.99609375	False
14:02:18.611	3	1	255.99609375	False
14:02:18.631	3	1	255.99609375	False
14:02:18.651	3	1	255.99609375	False
14:02:18.671	3	1	255.99609375	False
14:02:18.691	3	1	255.99609375	False
14:02:18.711	3	1	255.99609375	False
14:02:18.731	3	1	255.99609375	False
14:02:18.751	3	1	255.99609375	False
14:02:18.771	3	1	255.99609375	False
14:02:18.791	3	1	255.99609375	False
14:02:18.811	3	1	255.99609375	False
14:02:18.831	3	1	255.99609375	False
14:02:18.851	3	1	255.99609375	False
14:02:18.871	3	1	255.99609375	False
14:02:18.891	3	1	255.99609375	False
14:02:18.911	3	1	255.99609375	False
14:02:18.931	3	1	255.99609375	False
14:02:18.951	3	1	255.99609375	False
14:02:18.971	3	1	255.99609375	False
14:02:18.991	3	1	255.99609375	False
14:02:19.011	3	1	255.99609375	False
14:02:19.031	3	1	255.99609375	False
14:02:19.051	3	1	255.99609375	False
14:02:19.071	3	1	255.99609375	False
14:02:19.091	3	1	255.99609375	False
14:02:19.111	3	1	255.99609375	False
14:02:19.131	3	1	255.99609375	False
14:02:19.151	3	1	255.99609375	False
14:02:19.171	3	1	255.99609375	False
14:02:19.191	3	1	255.99609375	False
14:02:19.211	3	1	255.99609375	False
14:02:19.231	3	1.04	255.99609375	False
14:02:19.251	3	1.04	255.99609375	False
14:02:19.271	3	1.04	255.99609375	False
14:02:19.291	3	1.04	255.99609375	False
14:02:19.311	3	1.04	255.99609375	False
14:02:19.331	3	1.04	255.99609375	False
14:02:19.351	3	1.04	255.99609375	False
14:02:19.371	3	1.04	255.99609375	False
14:02:19.391	3	1.04	255.99609375	False
14:02:19.411	3	1.04	255.99609375	False
14:02:19.431	3	1.04	255.99609375	False
14:02:19.451	3	1.04	255.99609375	False
14:02:19.471	3	1.04	255.99609375	False
14:02:19.491	3	1.04	255.99609375	False
14:02:19.511	3	1.04	255.99609375	False
14:02:19.531	3	1.04	255.99609375	False
14:02:19.551	3	1.04	255.99609375	False
14:02:19.571	3	1.04	255.99609375	False
14:02:19.591	3	1.04	255.99609375	False
14:02:19.611	3	1.04	255.99609375	False
14:02:19.631	3	1.04	255.99609375	False
14:02:19.651	3	1.04	255.99609375	False
14:02:19.671	3	1.04	255.99609375	False
14:02:19.691	3	1.04	255.99609375	False
14:02:19.711	3	1.04	255.99609375	False
14:02:19.731	3	1	255.99609375	False
14:02:19.751	3	1	255.99609375	False
14:02:19.771	3	1	255.99609375	False
14:02:19.791	3	1	255.99609375	False
14:02:19.811	3	1	255.99609375	False
14:02:19.831	3	1	255.99609375	False
14:02:19.851	3	1	255.99609375	False
14:02:19.871	3	1	255.99609375	False
14:02:19.891	3	1	255.99609375	False
14:02:19.911	3	1	255.99609375	False
14:02:19.931	3	1	255.99609375	False
14:02:19.951	3	1	255.99609375	False
14:02:19.971	3	1	255.99609375	False
14:02:19.991	3	1	255.99609375	False
14:02:20.011	3	1	255.99609375	False
14:02:20.031	3	1	255.99609375	False
14:02:20.051	3	1	255.99609375	False
14:02:20.071	3	1	255.99609375	False
14:02:20.091	3	1	255.99609375	False
14:02:20.111	3	1	255.99609375	False
14:02:20.131	3	1	255.99609375	False
14:02:20.151	3	1	255.99609375	False
14:02:20.171	3	1	255.99609375	False
14:02:20.191	3	1	255.99609375	False
14:02:20.211	3	1	255.99609375	False
14:02:20.231	3	1	12.10546875	True
14:02:20.251	3	1	12.10546875	True
14:02:20.271	3	1	12.10546875	True
14:02:20.291	3	1	12.10546875	True
14:02:20.311	3	1	12.10546875	True
14:02:20.331	3	1	12.10546875	True
14:02:20.351	3	1	12.09375	True
14:02:20.371	3	1	12.11328125	False
14:02:20.391	3	1	12.09765625	False
14:02:20.411	3	1	12.10546875	False
14:02:20.431	3	1	12.0859375	False
14:02:20.451	3	1	12.09375	False
14:02:20.471	3	1	12.09375	False
14:02:20.491	3	1	12.0859375	False
14:02:20.511	3	1	12.08203125	False
14:02:20.531	3	1	12.09375	True
14:02:20.551	3	1	12.0859375	False
14:02:20.571	3	1	12.0859375	False
14:02:20.591	3	1	12.09375	True
14:02:20.611	3	1	12.09375	False
14:02:20.631	3	1	12.10546875	False
14:02:20.651	3	1	12.08203125	False
14:02:20.671	3	1	12.08203125	False
14:02:20.691	3	1	12.09765625	False
14:02:20.711	3	1	12.08203125	True
14:02:20.731	3	1	12.09765625	True
14:02:20.751	3	1	12.09765625	True
14:02:20.771	3	1	12.09375	True
14:02:20.791	3	1	12.09765625	True
14:02:20.811	3	1	12.09765625	True
14:02:20.831	3	1	12.09765625	True
14:02:20.851	3	1	12.10546875	True
14:02:20.871	3	1	12.09375	True
14:02:20.891	3	1	12.09765625	True
14:02:20.911	3	1	12.09765625	True
14:02:20.931	3	0.28	12.09765625	True
14:02:20.951	3	0.28	12.10546875	True
14:02:20.971	3	0.28	12.09765625	True
14:02:20.991	3	0.28	12.09375	True
14:02:21.011	3	0.28	12.09765625	True
14:02:21.031	3	0.28	12.0859375	True
14:02:21.051	3	0.28	12.09765625	True
14:02:21.071	3	0.28	12.09375	True
14:02:21.091	3	1	255.99609375	False
14:02:21.111	3	1	255.99609375	False
14:02:21.131	3	1	255.99609375	False
14:02:21.151	3	1	255.99609375	False
14:02:21.171	3	1	255.99609375	False
14:02:21.191	3	1	255.99609375	False
14:02:21.211	3	1	255.99609375	False
14:02:21.231	3	1	255.99609375	False
14:02:21.251	3	1	255.99609375	False
14:02:21.271	3	1	255.99609375	False
14:02:21.291	3	1	255.99609375	False
14:02:21.311	3	1	255.99609375	False
14:02:21.331	3	1	255.99609375	False
14:02:21.351	3	1	255.99609375	False
14:02:21.371	3	1	255.99609375	False
14:02:21.391	3	1	255.99609375	False
14:02:21.411	3	1	255.99609375	False
14:02:21.431	3	1	255.99609375	False
14:02:21.451	3	1	255.99609375	False
14:02:21.471	3	1	255.99609375	False
14:02:21.491	3	1	255.99609375	False
14:02:21.511	3	1	255.99609375	False
14:02:21.531	3	1	255.99609375	False
14:02:21.551	3	1	255.99609375	False
14:02:21.571	3	1	255.99609375	False
14:02:21.591	3	1	255.99609375	False
14:02:21.611	3	1	255.99609375	False
14:02:21.631	3	1	255.99609375	False
14:02:21.651	3	1	255.99609375	False
14:02:21.671	3	1	255.99609375	False
14:02:21.691	3	1	255.99609375	False
14:02:21.711	3	1	255.99609375	False
14:02:21.731	3	1	255.99609375	False
14:02:21.751	3	1	255.99609375	False
14:02:21.771	3	1.04	255.99609375	False
14:02:21.791	3	1.04	255.99609375	False
14:02:21.811	3	1.04	255.99609375	False
14:02:21.831	3	1.04	255.99609375	False
14:02:21.851	3	1.04	255.99609375	False
14:02:21.871	3	1.04	255.99609375	False
14:02:21.891	3	1.04	255.99609375	False
14:02:21.911	3	1.04	255.99609375	False
14:02:21.931	3	1.04	255.99609375	False
14:02:21.951	3	1.04	255.99609375	False
14:02:21.971	3	1.04	255.99609375	False
14:02:21.991	3	1.04	255.99609375	False
14:02:22.011	3	1.04	255.99609375	False
14:02:22.031	3	1.04	255.99609375	False
14:02:22.051	3	1.04	255.99609375	False
14:02:22.071	3	1.04	255.99609375	False
14:02:22.091	3	1.04	255.99609375	False
14:02:22.111	3	1.04	255.99609375	False
14:02:22.131	3	1.04	255.99609375	False
14:02:22.151	3	1.04	255.99609375	False
14:02:22.171	3	1.04	255.99609375	False
14:02:22.191	3	1.04	255.99609375	False
14:02:22.211	3	1.04	255.99609375	False
14:02:22.231	3	1.04	255.99609375	False
14:02:22.251	3	1.04	255.99609375	False
14:02:22.271	3	1	255.99609375	False
14:02:22.291	3	1	255.99609375	False
14:02:22.311	3	1	255.99609375	False
14:02:22.331	3	1	255.99609375	False
14:02:22.351	3	1	255.99609375	False
14:02:22.371	3	1	255.99609375	False
14:02:22.391	3	1	255.99609375	False
14:02:22.411	3	1	255.99609375	False
14:02:22.431	3	1	255.99609375	False
14:02:22.451	3	1	255.99609375	False
14:02:22.471	3	1	255.99609375	False
14:02:22.491	3	1	255.99609375	False
14:02:22.511	3	1	255.99609375	False
14:02:22.531	3	1	255.99609375	False
14:02:22.551	3	1	255.99609375	False
14:02:22.571	3	1	255.99609375	False
14:02:22.591	3	1	255.99609375	False
14:02:22.611	3	1	255.99609375	False
14:02:22.631	3	1	255.99609375	False
14:02:22.651	3	1	255.99609375	False
14:02:22.671	3	1	255.99609375	False
14:02:22.691	3	1	255.99609375	False
14:02:22.711	3	1	255.99609375	False
14:02:22.731	3	1	255.99609375	False
14:02:22.751	3	1	255.99609375	False
14:02:22.771	3	1	255.99609375	False
14:02:22.791	3	1.04	255.99609375	False
14:02:22.811	3	1.04	255.99609375	False
14:02:22.831	3	1.04	255.99609375	False
14:02:22.851	3	1.04	255.99609375	False
14:02:22.871	3	1.04	255.99609375	False
14:02:22.891	3	1.04	255.99609375	False
14:02:22.911	3	1.04	255.99609375	False
14:02:22.931	3	1.04	255.99609375	False
14:02:22.951	3	1.04	255.99609375	False
14:02:22.971	3	1.04	255.99609375	False
14:02:22.991	3	1.04	255.99609375	False
14:02:23.011	3	1.04	255.99609375	False
14:02:23.031	3	1.04	255.99609375	False
14:02:23.051	3	1.04	255.99609375	False
14:02:23.071	3	1.04	255.99609375	False
14:02:23.091	3	1.04	255.99609375	False
14:02:23.111	3	1.04	255.99609375	False
14:02:23.131	3	1.04	255.99609375	False
14:02:23.151	3	1.04	255.99609375	False
14:02:23.171	3	1.04	255.99609375	False
14:02:23.191	3	1.04	255.99609375	False
14:02:23.211	3	1.04	255.99609375	False
14:02:23.231	3	1.04	255.99609375	False
14:02:23.251	3	1.04	255.99609375	False
14:02:23.271	3	1.04	255.99609375	False
14:02:23.291	3	1.04	12.0859375	True
14:02:23.311	3	1.04	12.0859375	True
14:02:23.331	3	1.04	12.0859375	True
14:02:23.351	3	1.04	12.0859375	True
14:02:23.371	3	1.04	12.0859375	True
14:02:23.391	3	1.04	12.0859375	True
14:02:23.411	3	1.04	12.09765625	False
14:02:23.431	3	1.04	12.10546875	False
14:02:23.451	3	1.04	12.10546875	False
14:02:23.471	3	1.04	12.09765625	False
14:02:23.491	3	1.04	12.09765625	True
14:02:23.511	3	1.04	12.10546875	False
14:02:23.531	3	1.04	12.09375	True
14:02:23.551	3	1.04	12.09765625	False
14:02:23.571	3	1.04	12.0859375	False
14:02:23.591	3	1.04	12.10546875	False
14:02:23.611	3	1.04	12.09765625	False
14:02:23.631	3	1.04	12.10546875	False
14:02:23.651	3	1.04	12.09765625	True
14:02:23.671	3	1.04	12.09765625	True
14:02:23.691	3	1.04	12.11328125	True
14:02:23.711	3	1.04	12.09765625	True
14:02:23.731	3	1.04	12.09765625	True
14:02:23.751	3	1.04	12.09375	True
14:02:23.771	3	1.04	12.10546875	True
14:02:23.791	3	1.04	12.09765625	True
14:02:23.811	3.5	0.28	12.10546875	True
14:02:23.831	3.5	0.28	12.0859375	True
14:02:23.851	3.5	0.28	12.09375	True
14:02:23.871	3.5	0.28	12.09765625	True
14:02:23.891	3.5	0.28	12.0859375	True
14:02:23.911	3.5	0.28	12.09765625	True
14:02:23.931	3.5	0.28	12.0859375	True
14:02:23.951	3.5	0.28	12.09375	True
14:02:23.971	3.5	0.28	12.09765625	True
14:02:23.991	3.5	0.28	12.09765625	True
14:02:24.011	3.5	0.28	12.09765625	True
14:02:24.031	3	1	255.99609375	False
14:02:24.051	3	1	255.99609375	False
14:02:24.071	3	1	255.99609375	False
14:02:24.091	3	1	255.99609375	False
14:02:24.111	3	1	255.99609375	False
14:02:24.131	3	1	255.99609375	False
14:02:24.151	3	1	255.99609375	False
14:02:24.171	3	1	255.99609375	False
14:02:24.191	3	1	255.99609375	False
14:02:24.211	3	1	255.99609375	False
14:02:24.231	3	1	255.99609375	False
14:02:24.251	3	1	255.99609375	False
14:02:24.271	3	1	255.99609375	False
14:02:24.291	3	1	255.99609375	False
14:02:24.311	3	1	255.99609375	False
14:02:24.331	3	1	255.99609375	False
14:02:24.351	3	1	255.99609375	False
14:02:24.371	3	1	255.99609375	False
14:02:24.391	3	1	255.99609375	False
14:02:24.411	3	1	255.99609375	False
14:02:24.431	3	1	255.99609375	False
14:02:24.451	3	1	255.99609375	False
14:02:24.471	3	1	255.99609375	False
14:02:24.491	3	1	255.99609375	False
14:02:24.511	3	1	255.99609375	False
14:02:24.531	3	1	255.99609375	False
14:02:24.551	3	1	255.99609375	False
14:02:24.571	3	1	255.99609375	False
14:02:24.591	3	1	255.99609375	False
14:02:24.611	3	1	255.99609375	False
14:02:24.631	3	1	255.99609375	False
14:02:24.651	3	1	255.99609375	False
14:02:24.671	3	1	255.99609375	False
14:02:24.691	3	1	255.99609375	False
14:02:24.711	3	1	255.99609375	False
14:02:24.731	3	1	255.99609375	False
14:02:24.751	3	1	255.99609375	False
14:02:24.771	3	1	255.99609375	False
14:02:24.791	3	1	255.99609375	False
14:02:24.811	3	1	255.99609375	False
14:02:24.831	3	1	255.99609375	False
14:02:24.851	3	1	255.99609375	False
14:02:24.871	3	1	255.99609375	False
14:02:24.891	3	1	255.99609375	False
14:02:24.911	3	1	255.99609375	False
14:02:24.931	3	1	255.99609375	False
14:02:24.951	3	1	255.99609375	False
14:02:24.971	3	1	255.99609375	False
14:02:24.991	3	1	255.99609375	False
14:02:25.011	3	1	255.99609375	False
14:02:25.031	3	1	255.99609375	False
14:02:25.051	3	1	255.99609375	False
14:02:25.071	3	1	255.99609375	False
14:02:25.091	3	1	255.99609375	False
14:02:25.111	3	1	255.99609375	False
14:02:25.131	3	1	255.99609375	False
14:02:25.151	3	1	255.99609375	False
14:02:25.171	3	1	255.99609375	False
14:02:25.191	3	1	255.99609375	False
14:02:25.211	3	1	255.99609375	False
14:02:25.231	3	1	255.99609375	False
14:02:25.251	3	1	255.99609375	False
14:02:25.271	3	1	255.99609375	False
14:02:25.291	3	1	255.99609375	False
14:02:25.311	3	1	255.99609375	False
14:02:25.331	3	1	255.99609375	False
14:02:25.351	3	1	255.99609375	False
14:02:25.371	3	1	255.99609375	False
14:02:25.391	3	1	255.99609375	False
14:02:25.411	3	1	255.99609375	False
14:02:25.431	3	1	255.99609375	False
14:02:25.451	3	1	255.99609375	False
14:02:25.471	3	1	255.99609375	False
14:02:25.491	3	1	255.99609375	False
14:02:25.511	3	1	255.99609375	False
14:02:25.531	3	1	255.99609375	False
14:02:25.551	3	1	255.99609375	False
14:02:25.571	3	1	255.99609375	False
14:02:25.591	3	1	255.99609375	False
14:02:25.611	3	1	255.99609375	False
14:02:25.631	3	1	255.99609375	False
14:02:25.651	3	1	255.99609375	False
14:02:25.671	3	1	255.99609375	False
14:02:25.691	3	1	255.99609375	False
14:02:25.711	3	1	255.99609375	False
14:02:25.731	3	1	255.99609375	False
14:02:25.751	3	1	255.99609375	False
14:02:25.771	3	1	255.99609375	False
14:02:25.791	3	1	255.99609375	False
14:02:25.811	3	1	255.99609375	False
14:02:25.831	3	1	255.99609375	False
14:02:25.851	3	1	255.99609375	False
14:02:25.871	3	1	255.99609375	False
14:02:25.891	3	1	255.99609375	False
14:02:25.911	3	1	255.99609375	False
14:02:25.931	3	1	255.99609375	False
14:02:25.951	3	1	255.99609375	False
14:02:25.971	3	1	255.99609375	False
14:02:25.991	3	1	255.99609375	False
14:02:26.011	3	1	255.99609375	False
14:02:26.031	3	1	255.99609375	False
14:02:26.051	3	1	255.99609375	False
14:02:26.071	3	1	255.99609375	False
14:02:26.091	3	1	255.99609375	False
14:02:26.111	3	1	255.99609375	False
14:02:26.131	3	1	255.99609375	False
14:02:26.151	3	1	255.99609375	False
14:02:26.171	3	1	255.99609375	False
14:02:26.191	3	1	255.99609375	False
14:02:26.211	3	1	255.99609375	False
14:02:26.231	3	1	255.99609375	False
14:02:26.251	3	1	255.99609375	False
14:02:26.271	3	1	255.99609375	False
14:02:26.291	3	1	255.99609375	False
14:02:26.311	3	1	255.99609375	False
14:02:26.331	3	1	12.10546875	True
14:02:26.351	3	1	12.10546875	True
14:02:26.371	3	1	12.10546875	True
14:02:26.391	3	1	12.10546875	True
14:02:26.411	3	1	12.10546875	True
14:02:26.431	3	1	12.10546875	True
14:02:26.451	3	1	12.10546875	True
14:02:26.471	3	1	12.11328125	False
14:02:26.491	3	1	12.09375	False
14:02:26.511	3	1	12.11328125	True
14:02:26.531	3	1	12.09375	False
14:02:26.551	3	1	12.09765625	True
14:02:26.571	3	1	12.10546875	False
14:02:26.591	3	1	12.09375	False
14:02:26.611	3	1	12.09375	False
14:02:26.631	3	1	12.09765625	False
14:02:26.651	3	1	12.09765625	False
14:02:26.671	3	1	12.0859375	True
14:02:26.691	3	1	12.09375	False
14:02:26.711	3	1	12.0859375	False
14:02:26.731	3	1	12.09765625	False
14:02:26.751	3	1	12.09765625	False
14:02:26.771	3	1	12.09765625	False
14:02:26.791	3	1	12.10546875	True
14:02:26.811	3	1	12.0859375	True
14:02:26.831	3	1	12.09375	True
14:02:26.851	3	1	12.09375	True
14:02:26.871	3	0.4	12.09765625	True
14:02:26.891	3	0.4	12.09765625	True
14:02:26.911	3	0.4	12.09375	True
14:02:26.931	3	0.4	12.0859375	True
14:02:26.951	3	0.4	12.09375	True
14:02:26.971	3	0.4	12.09765625	True
14:02:26.991	3	0.4	12.10546875	True
14:02:27.011	3	0.4	12.09375	True
14:02:27.031	3	0.4	12.10546875	True
14:02:27.051	3	0.4	12.09375	True
14:02:27.071	3	0.4	12.09765625	True
14:02:27.091	3	0.4	12.11328125	True
14:02:27.111	3.5	1	255.99609375	False
14:02:27.131	3.5	1	255.99609375	False
14:02:27.151	3.5	1	255.99609375	False
14:02:27.171	3.5	1	255.99609375	False
14:02:27.191	3.5	1	255.99609375	False
14:02:27.211	3.5	1	255.99609375	False
14:02:27.231	3.5	1	255.99609375	False
14:02:27.251	3.5	1	255.99609375	False
14:02:27.271	3.5	1	255.99609375	False
14:02:27.291	3.5	1	255.99609375	False
14:02:27.311	3.5	1	255.99609375	False
14:02:27.331	3.5	1	255.99609375	False
14:02:27.351	3.5	1	255.99609375	False
14:02:27.371	3.5	1	255.99609375	False
14:02:27.391	3.5	1	255.99609375	False
14:02:27.411	3.5	1	255.99609375	False
14:02:27.431	3.5	1	255.99609375	False
14:02:27.451	3.5	1	255.99609375	False
14:02:27.471	3.5	1	255.99609375	False
14:02:27.491	3.5	1	255.99609375	False
14:02:27.511	3.5	1	255.99609375	False
14:02:27.531	3.5	1	255.99609375	False
14:02:27.551	3.5	1	255.99609375	False
14:02:27.571	3.5	1	255.99609375	False
14:02:27.591	3.5	1	255.99609375	False
14:02:27.611	3.5	1	255.99609375	False
14:02:27.631	3.5	1	255.99609375	False
14:02:27.651	3.5	1	255.99609375	False
14:02:27.671	3.5	1	255.99609375	False
14:02:27.691	3.5	1	255.99609375	False
14:02:27.711	3.5	1	255.99609375	False
14:02:27.731	3.5	1	255.99609375	False
14:02:27.751	3.5	1	255.99609375	False
14:02:27.771	3.5	1	255.99609375	False
14:02:27.791	3.5	1	255.99609375	False
14:02:27.811	3.5	1	255.99609375	False
14:02:27.831	3.5	1	255.99609375	False
14:02:27.851	3.5	1	255.99609375	False
14:02:27.871	3.5	1	255.99609375	False
14:02:27.891	3.5	1	255.99609375	False
14:02:27.911	3.5	1	255.99609375	False
14:02:27.931	3.5	1	255.99609375	False
14:02:27.951	3.5	1	255.99609375	False
14:02:27.971	3.5	1	255.99609375	False
14:02:27.991	3.5	1	255.99609375	False
14:02:28.011	3.5	1	255.99609375	False
14:02:28.031	3.5	1	255.99609375	False
14:02:28.051	3.5	1	255.99609375	False
14:02:28.071	3.5	1	255.99609375	False
14:02:28.091	3.5	1	255.99609375	False
14:02:28.111	3.5	1	255.99609375	False
14:02:28.131	3.5	1	255.99609375	False
14:02:28.151	3.5	1	255.99609375	False
14:02:28.171	3.5	1	255.99609375	False
14:02:28.191	3.5	1	255.99609375	False
14:02:28.211	3.5	1	255.99609375	False
14:02:28.231	3.5	1	255.99609375	False
14:02:28.251	3.5	1	255.99609375	False
14:02:28.271	3.5	1	255.99609375	False
14:02:28.291	3.5	1	255.99609375	False
14:02:28.311	3.5	1	255.99609375	False
14:02:28.331	3.5	1	255.99609375	False
14:02:28.351	3.5	1	255.99609375	False
14:02:28.371	3.5	1	255.99609375	False
14:02:28.391	3.5	1	255.99609375	False
14:02:28.411	3.5	1	255.99609375	False
14:02:28.431	3.5	1	255.99609375	False
14:02:28.451	3.5	1	255.99609375	False
14:02:28.471	3.5	1	255.99609375	False
14:02:28.491	3.5	1	255.99609375	False
14:02:28.511	3.5	1	255.99609375	False
14:02:28.531	3.5	1	255.99609375	False
14:02:28.551	3.5	1	255.99609375	False
14:02:28.571	3.5	1	255.99609375	False
14:02:28.591	3.5	1	255.99609375	False
14:02:28.611	3.5	1	255.99609375	False
14:02:28.631	3.5	1	255.99609375	False
14:02:28.651	3.5	1	255.99609375	False
14:02:28.671	3.5	1	255.99609375	False
14:02:28.691	3.5	1	255.99609375	False
14:02:28.711	3.5	1	255.99609375	False
14:02:28.731	3.5	1	255.99609375	False
14:02:28.751	3.5	1	255.99609375	False
14:02:28.771	3.5	1	255.99609375	False
14:02:28.791	3.5	1	255.99609375	False
14:02:28.811	3.5	1	255.99609375	False
14:02:28.831	3.5	1	255.99609375	False
14:02:28.851	3.5	1	255.99609375	False
14:02:28.871	3.5	1	255.99609375	False
14:02:28.891	3.5	1	255.99609375	False
14:02:28.911	3.5	1	255.99609375	False
14:02:28.931	3.5	1	255.99609375	False
14:02:28.951	3.5	1	255.99609375	False
14:02:28.971	3.5	1	255.99609375	False
14:02:28.991	3.5	1	255.99609375	False
14:02:29.011	3.5	1	255.99609375	False
14:02:29.031	3.5	1	255.99609375	False
14:02:29.051	3.5	1	255.99609375	False
14:02:29.071	3.5	1	255.99609375	False
14:02:29.091	3.5	1	255.99609375	False
14:02:29.111	3.5	1	255.99609375	False
14:02:29.131	3.5	1	255.99609375	False
14:02:29.151	3.5	1	255.99609375	False
14:02:29.171	3.5	1	255.99609375	False
14:02:29.191	3.5	1	255.99609375	False
14:02:29.211	3.5	1	255.99609375	False
14:02:29.231	3.5	1	255.99609375	False
14:02:29.251	3.5	1	255.99609375	False
14:02:29.271	3.5	1	255.99609375	False
14:02:29.291	3.5	1	255.99609375	False
14:02:29.311	3.5	1	255.99609375	False
14:02:29.331	3.5	1	255.99609375	False
14:02:29.351	3.5	1	12.09765625	True
14:02:29.371	3.5	1	12.09765625	True
14:02:29.391	3.5	1	12.09765625	True
14:02:29.411	3.5	1	12.09765625	True
14:02:29.431	3.5	1	12.09765625	True
14:02:29.451	3.5	1	12.09765625	True
14:02:29.471	3.5	1	12.09765625	True
14:02:29.491	3.5	1	12.10546875	False
14:02:29.511	3.5	1	12.09375	False
14:02:29.531	3.5	1	12.09765625	False
14:02:29.551	3.5	1	12.09375	False
14:02:29.571	3.5	1	12.09375	False
14:02:29.591	3.5	1	12.09375	False
14:02:29.611	3.5	1	12.0859375	False
14:02:29.631	3.5	1	12.09375	True
14:02:29.651	3.5	1	12.09765625	False
14:02:29.671	3.5	1	12.09765625	False
14:02:29.691	3.5	1	12.09375	False
14:02:29.711	3.5	1	12.09375	True
14:02:29.731	3.5	1	12.0859375	False
14:02:29.751	3.5	1	12.09375	False
14:02:29.771	3.5	1	12.09375	False
14:02:29.791	3.5	1	12.09765625	True
14:02:29.811	3.5	1	12.09765625	True
14:02:29.831	3.5	1	12.09375	True
14:02:29.851	3.5	0.4	12.09765625	True
14:02:29.871	3.5	0.4	12.09765625	True
14:02:29.891	3.5	0.4	12.09765625	True
14:02:29.911	3.5	0.4	12.10546875	True
14:02:29.931	3.5	0.4	12.11328125	True
14:02:29.951	3.5	0.4	12.0859375	True
14:02:29.971	3.5	0.4	12.10546875	True
14:02:29.991	3.5	0.4	12.09375	True
14:02:30.011	3.5	0.4	12.10546875	True
14:02:30.031	3.5	0.4	12.09765625	True
14:02:30.051	3.5	0.4	12.10546875	True
14:02:30.071	3.5	0.4	12.09765625	True
14:02:30.091	3.5	0.4	12.09765625	True
14:02:30.111	3.5	0.4	12.09765625	True
14:02:30.131	3.5	0.4	12.0859375	True
14:02:30.151	3.5	1	255.99609375	False
14:02:30.171	3.5	1	255.99609375	False
14:02:30.191	3.5	1	255.99609375	False
14:02:30.211	3.5	1	255.99609375	False
14:02:30.231	3.5	1	255.99609375	False
14:02:30.251	3.5	1	255.99609375	False
14:02:30.271	3.5	1	255.99609375	False
14:02:30.291	3.5	1	255.99609375	False
14:02:30.311	3.5	1	255.99609375	False
14:02:30.331	3.5	1	255.99609375	False
14:02:30.351	3.5	1	255.99609375	False
14:02:30.371	3.5	1	255.99609375	False
14:02:30.391	3.5	1	255.99609375	False
14:02:30.411	3.5	1	255.99609375	False
14:02:30.431	3.5	1	255.99609375	False
14:02:30.451	3.5	1	255.99609375	False
14:02:30.471	3.5	1	255.99609375	False
14:02:30.491	3.5	1	255.99609375	False
14:02:30.511	3.5	1	255.99609375	False
14:02:30.531	3.5	1	255.99609375	False
14:02:30.551	3.5	1	255.99609375	False
14:02:30.571	3.5	1	255.99609375	False
14:02:30.591	3.5	1	255.99609375	False
14:02:30.611	3.5	1	255.99609375	False
14:02:30.631	3.5	1	255.99609375	False
14:02:30.651	3.5	1	255.99609375	False
14:02:30.671	3.5	1	255.99609375	False
14:02:30.691	3.5	1	255.99609375	False
14:02:30.711	3.5	1	255.99609375	False
14:02:30.731	3.5	1	255.99609375	False
14:02:30.751	3.5	1	255.99609375	False
14:02:30.771	3.5	1	255.99609375	False
14:02:30.791	3.5	1	255.99609375	False
14:02:30.811	3.5	1	255.99609375	False
14:02:30.831	3.5	1	255.99609375	False
14:02:30.851	3.5	1	255.99609375	False
14:02:30.871	3.5	1	255.99609375	False
14:02:30.891	3.5	1	255.99609375	False
14:02:30.911	3.5	1	255.99609375	False
14:02:30.931	3.5	1	255.99609375	False
14:02:30.951	3.5	1	255.99609375	False
14:02:30.971	3.5	1	255.99609375	False
14:02:30.991	3.5	1	255.99609375	False
14:02:31.011	3.5	1	255.99609375	False
14:02:31.031	3.5	1	255.99609375	False
14:02:31.051	3.5	1	255.99609375	False
14:02:31.071	3.5	1	255.99609375	False
14:02:31.091	3.5	1	255.99609375	False
14:02:31.111	3.5	1	255.99609375	False
14:02:31.131	3.5	1	255.99609375	False
14:02:31.151	3.5	1	255.99609375	False
14:02:31.171	3.5	1	255.99609375	False
14:02:31.191	3.5	1	255.99609375	False
14:02:31.211	3.5	1	255.99609375	False
14:02:31.231	3.5	1	255.99609375	False
14:02:31.251	3.5	1	255.99609375	False
14:02:31.271	3.5	1	255.99609375	False
14:02:31.291	3.5	1	255.99609375	False
14:02:31.311	3.5	1	255.99609375	False
14:02:31.331	3.5	1	255.99609375	False
14:02:31.351	3.5	1	255.99609375	False
14:02:31.371	3.5	1	255.99609375	False
14:02:31.391	3.5	1	255.99609375	False
14:02:31.411	3.5	1.04	255.99609375	False
14:02:31.431	3.5	1.04	255.99609375	False
14:02:31.451	3.5	1.04	255.99609375	False
14:02:31.471	3.5	1.04	255.99609375	False
14:02:31.491	3.5	1.04	255.99609375	False
14:02:31.511	3.5	1.04	255.99609375	False
14:02:31.531	3.5	1.04	255.99609375	False
14:02:31.551	3.5	1.04	255.99609375	False
14:02:31.571	3.5	1.04	255.99609375	False
14:02:31.591	3.5	1.04	255.99609375	False
14:02:31.611	3.5	1.04	255.99609375	False
14:02:31.631	3.5	1.04	255.99609375	False
14:02:31.651	3.5	1.04	255.99609375	False
14:02:31.671	3.5	1.04	255.99609375	False
14:02:31.691	3.5	1.04	255.99609375	False
14:02:31.711	3.5	1.04	255.99609375	False
14:02:31.731	3.5	1.04	255.99609375	False
14:02:31.751	3.5	1.04	255.99609375	False
14:02:31.771	3.5	1.04	255.99609375	False
14:02:31.791	3.5	1.04	255.99609375	False
14:02:31.811	3.5	1.04	255.99609375	False
14:02:31.831	3.5	1.04	255.99609375	False
14:02:31.851	3.5	1.04	255.99609375	False
14:02:31.871	3.5	1.04	255.99609375	False
14:02:31.891	3.5	1.04	255.99609375	False
14:02:31.911	3.5	1	255.99609375	False
14:02:31.931	3.5	1	255.99609375	False
14:02:31.951	3.5	1	255.99609375	False
14:02:31.971	3.5	1	255.99609375	False
14:02:31.991	3.5	1	255.99609375	False
14:02:32.011	3.5	1	255.99609375	False
14:02:32.031	3.5	1	255.99609375	False
14:02:32.051	3.5	1	255.99609375	False
14:02:32.071	3.5	1	255.99609375	False
14:02:32.091	3.5	1	255.99609375	False
14:02:32.111	3.5	1	255.99609375	False
14:02:32.131	3.5	1	255.99609375	False
14:02:32.151	3.5	1	255.99609375	False
14:02:32.171	3.5	1	255.99609375	False
14:02:32.191	3.5	1	255.99609375	False
14:02:32.211	3.5	1	255.99609375	False
14:02:32.231	3.5	1	255.99609375	False
14:02:32.251	3.5	1	255.99609375	False
14:02:32.271	3.5	1	255.99609375	False
14:02:32.291	3.5	1	255.99609375	False
14:02:32.311	3.5	1	255.99609375	False
14:02:32.331	3.5	1	255.99609375	False
14:02:32.351	3.5	1	255.99609375	False
14:02:32.371	3.5	1	255.99609375	False
14:02:32.391	3.5	1	255.99609375	False
14:02:32.411	3.5	1	255.99609375	False
14:02:32.431	3.5	0.6	12.09375	True
14:02:32.451	3.5	0.6	12.09375	True
14:02:32.471	3.5	0.6	12.09375	True
14:02:32.491	3.5	0.6	12.09375	True
14:02:32.511	3.5	0.6	12.09375	True
14:02:32.531	3.5	0.6	12.09375	True
14:02:32.551	3.5	0.6	12.09375	True
14:02:32.571	3.5	0.6	12.09375	True
14:02:32.591	3.5	0.6	12.09375	True
14:02:32.611	3.5	0.6	12.09375	True
14:02:32.631	3.5	0.6	12.09375	True
14:02:32.651	3.5	0.6	12.09375	True
14:02:32.671	3.5	0.6	12.09375	True
14:02:32.691	3.5	0.6	12.09375	True
14:02:32.711	3.5	0.6	12.09375	True
14:02:32.731	3.5	0.6	12.09375	False
14:02:32.751	3.5	0.6	12.10546875	False
14:02:32.771	3.5	0.6	12.0859375	False
14:02:32.791	3.5	0.6	12.0859375	False
14:02:32.811	3.5	0.6	12.09375	False
14:02:32.831	3.5	0.6	12.0859375	True
14:02:32.851	3.5	0.6	12.09375	False
14:02:32.871	3.5	0.6	12.10546875	True
14:02:32.891	3.5	0.6	12.09375	False
14:02:32.911	3.5	0.6	12.09375	False
14:02:32.931	3.5	0.6	12.0859375	True
14:02:32.951	3.5	0.6	12.09375	True
14:02:32.971	3.5	0.6	12.09765625	True
14:02:32.991	3.5	0.6	12.09765625	True
14:02:33.011	3.5	0.6	12.09765625	True
14:02:33.031	3.5	0.6	12.09375	True
14:02:33.051	3.5	0.6	12.09765625	True
14:02:33.071	3.5	0.6	12.0859375	True
14:02:33.091	3.5	1.12	255.99609375	False
14:02:33.111	3.5	1.12	255.99609375	False
14:02:33.131	3.5	1.12	255.99609375	False
14:02:33.151	3.5	1.12	255.99609375	False
14:02:33.171	3.5	1.12	255.99609375	False
14:02:33.191	3.5	1.12	255.99609375	False
14:02:33.211	3.5	1.12	255.99609375	False
14:02:33.231	3.5	1.12	255.99609375	False
14:02:33.251	3.5	1.12	255.99609375	False
14:02:33.271	3.5	1.12	255.99609375	False
14:02:33.291	3.5	1.12	255.99609375	False
14:02:33.311	3.5	1.12	255.99609375	False
14:02:33.331	3.5	1.12	255.99609375	False
14:02:33.351	3.5	1.12	255.99609375	False
14:02:33.371	3.5	1.12	255.99609375	False
14:02:33.391	3.5	1.12	255.99609375	False
14:02:33.411	3.5	1.12	255.99609375	False
14:02:33.431	3.5	1.12	255.99609375	False
14:02:33.451	3.5	1	255.99609375	False
14:02:33.471	3.5	1	255.99609375	False
14:02:33.491	3.5	1	255.99609375	False
14:02:33.511	3.5	1	255.99609375	False
14:02:33.531	3.5	1	255.99609375	False
14:02:33.551	3.5	1	255.99609375	False
14:02:33.571	3.5	1	255.99609375	False
14:02:33.591	3.5	1	255.99609375	False
14:02:33.611	3.5	1	255.99609375	False
14:02:33.631	3.5	1	255.99609375	False
14:02:33.651	3.5	1	255.99609375	False
14:02:33.671	3.5	1	255.99609375	False
14:02:33.691	3.5	1	255.99609375	False
14:02:33.711	3.5	1	255.99609375	False
14:02:33.731	3.5	1	255.99609375	False
14:02:33.751	3.5	1	255.99609375	False
14:02:33.771	3.5	1	255.99609375	False
14:02:33.791	3.5	1	255.99609375	False
14:02:33.811	3.5	1	255.99609375	False
14:02:33.831	3.5	1	255.99609375	False
14:02:33.851	3.5	1	255.99609375	False
14:02:33.871	3.5	1	255.99609375	False
14:02:33.891	3.5	1	255.99609375	False
14:02:33.911	3.5	1	255.99609375	False
14:02:33.931	3.5	1	255.99609375	False
14:02:33.951	3.5	1	255.99609375	False
14:02:33.971	3.5	1	255.99609375	False
14:02:33.991	3.5	1	255.99609375	False
14:02:34.011	3.5	1	255.99609375	False
14:02:34.031	3.5	1	255.99609375	False
14:02:34.051	3.5	1	255.99609375	False
14:02:34.071	3.5	1	255.99609375	False
14:02:34.091	3.5	1	255.99609375	False
14:02:34.111	3.5	1	255.99609375	False
14:02:34.131	3.5	1	255.99609375	False
14:02:34.151	3.5	1	255.99609375	False
14:02:34.171	3.5	1	255.99609375	False
14:02:34.191	3.5	1	255.99609375	False
14:02:34.211	3.5	1	255.99609375	False
14:02:34.231	3.5	1	255.99609375	False
14:02:34.251	3.5	1	255.99609375	False
14:02:34.271	3.5	1	255.99609375	False
14:02:34.291	3.5	1	255.99609375	False
14:02:34.311	3.5	1	255.99609375	False
14:02:34.331	3.5	1	255.99609375	False
14:02:34.351	3.5	1	255.99609375	False
14:02:34.371	3.5	1	255.99609375	False
14:02:34.391	3.5	1	255.99609375	False
14:02:34.411	3.5	1	255.99609375	False
14:02:34.431	3.5	1	255.99609375	False
14:02:34.451	3.5	1	255.99609375	False
14:02:34.471	3.5	1	255.99609375	False
14:02:34.491	3.5	1	255.99609375	False
14:02:34.511	3.5	1	255.99609375	False
14:02:34.531	3.5	1	255.99609375	False
14:02:34.551	3.5	1	255.99609375	False
14:02:34.571	3.5	1	255.99609375	False
14:02:34.591	3.5	1	255.99609375	False
14:02:34.611	3.5	1	255.99609375	False
14:02:34.631	3.5	1	255.99609375	False
14:02:34.651	3.5	1	255.99609375	False
14:02:34.671	3.5	1	255.99609375	False
14:02:34.691	3.5	1	255.99609375	False
14:02:34.711	3.5	1	255.99609375	False
14:02:34.731	3.5	1	255.99609375	False
14:02:34.751	3.5	1	255.99609375	False
14:02:34.771	3.5	1	255.99609375	False
14:02:34.791	3.5	1	255.99609375	False
14:02:34.811	3.5	1	255.99609375	False
14:02:34.831	3.5	1	255.99609375	False
14:02:34.851	3.5	1	255.99609375	False
14:02:34.871	3.5	1	255.99609375	False
14:02:34.891	3.5	1	255.99609375	False
14:02:34.911	3.5	1	255.99609375	False
14:02:34.931	3.5	1	255.99609375	False
14:02:34.951	3.5	1.04	255.99609375	False
14:02:34.971	3.5	1.04	255.99609375	False
14:02:34.991	3.5	1.04	255.99609375	False
14:02:35.011	3.5	1.04	255.99609375	False
14:02:35.031	3.5	1.04	255.99609375	False
14:02:35.051	3.5	1.04	255.99609375	False
14:02:35.071	3.5	1.04	255.99609375	False
14:02:35.091	3.5	1.04	255.99609375	False
14:02:35.111	3.5	1.04	255.99609375	False
14:02:35.131	3.5	1.04	255.99609375	False
14:02:35.151	3.5	1.04	255.99609375	False
14:02:35.171	3.5	1.04	255.99609375	False
14:02:35.191	3.5	1.04	255.99609375	False
14:02:35.211	3.5	1.04	255.99609375	False
14:02:35.231	3.5	1.04	255.99609375	False
14:02:35.251	3.5	1.04	255.99609375	False
14:02:35.271	3.5	1.04	255.99609375	False
14:02:35.291	3.5	1.04	255.99609375	False
14:02:35.311	3.5	1.04	255.99609375	False
14:02:35.331	3.5	1.04	255.99609375	False
14:02:35.351	3.5	1.04	255.99609375	False
14:02:35.371	3.5	1.04	255.99609375	False
14:02:35.391	3.5	1.04	255.99609375	False
14:02:35.411	3.5	1.04	255.99609375	False
14:02:35.431	3.5	1.04	255.99609375	False
14:02:35.451	3.5	0.32	12.09765625	True
14:02:35.471	3.5	0.32	12.09765625	True
14:02:35.491	3.5	0.32	12.09765625	True
14:02:35.511	3.5	0.32	12.09765625	True
14:02:35.531	3.5	0.32	12.09765625	True
14:02:35.551	3.5	0.32	12.09765625	True
14:02:35.571	3.5	0.32	12.09765625	True
14:02:35.591	3.5	0.32	12.09765625	True
14:02:35.611	3.5	0.32	12.09765625	True
14:02:35.631	3.5	0.32	12.10546875	False
14:02:35.651	3.5	0.32	12.09765625	False
14:02:35.671	3.5	0.32	12.10546875	False
14:02:35.691	3.5	0.32	12.09765625	True
14:02:35.711	3.5	0.32	12.09765625	False
14:02:35.731	3.5	0.32	12.09375	False
14:02:35.751	3.5	0.32	12.09375	True
14:02:35.771	3.5	0.32	12.11328125	False
14:02:35.791	3.5	0.32	12.09375	False
14:02:35.811	3.5	0.32	12.09765625	False
14:02:35.831	3.5	0.32	12.09375	True
14:02:35.851	3.5	0.32	12.10546875	False
14:02:35.871	3.5	0.32	12.09375	False
14:02:35.891	3.5	0.32	12.09765625	True
14:02:35.911	3.5	0.32	12.09765625	True
14:02:35.931	3.5	0.32	12.09375	True
14:02:35.951	3.5	0.32	12.09375	True
14:02:35.971	3.5	0.32	12.09375	True
14:02:35.991	3.5	0.32	12.0859375	True
14:02:36.011	3.5	0.32	12.09765625	True
14:02:36.031	3.5	0.32	12.09375	True
14:02:36.051	3.5	0.32	12.09375	True
14:02:36.071	3.5	0.32	12.09375	True
14:02:36.091	3.5	0.32	12.11328125	True
14:02:36.111	3.5	0.32	12.10546875	True
14:02:36.131	3.5	0.32	12.10546875	True
14:02:36.151	3.5	0.32	12.09765625	True
14:02:36.171	3.5	1.12	255.99609375	False
14:02:36.191	3.5	1.12	255.99609375	False
14:02:36.211	3.5	1.12	255.99609375	False
14:02:36.231	3.5	1.12	255.99609375	False
14:02:36.251	3.5	1.12	255.99609375	False
14:02:36.271	3.5	1.12	255.99609375	False
14:02:36.291	3.5	1.12	255.99609375	False
14:02:36.311	3.5	1.12	255.99609375	False
14:02:36.331	3.5	1.12	255.99609375	False
14:02:36.351	3.5	1.12	255.99609375	False
14:02:36.371	3.5	1.12	255.99609375	False
14:02:36.391	3.5	1.12	255.99609375	False
14:02:36.411	3.5	1.12	255.99609375	False
14:02:36.431	3.5	1.12	255.99609375	False
14:02:36.451	3.5	1	255.99609375	False
14:02:36.471	3.5	1	255.99609375	False
14:02:36.491	3.5	1	255.99609375	False
14:02:36.511	3.5	1	255.99609375	False
14:02:36.531	3.5	1	255.99609375	False
14:02:36.551	3.5	1	255.99609375	False
14:02:36.571	3.5	1	255.99609375	False
14:02:36.591	3.5	1	255.99609375	False
14:02:36.611	3.5	1	255.99609375	False
14:02:36.631	3.5	1	255.99609375	False
14:02:36.651	3.5	1	255.99609375	False
14:02:36.671	3.5	1	255.99609375	False
14:02:36.691	3.5	1	255.99609375	False
14:02:36.711	3.5	1	255.99609375	False
14:02:36.731	3.5	1	255.99609375	False
14:02:36.751	3.5	1	255.99609375	False
14:02:36.771	3.5	1	255.99609375	False
14:02:36.791	3.5	1	255.99609375	False
14:02:36.811	3.5	1	255.99609375	False
14:02:36.831	3.5	1	255.99609375	False
14:02:36.851	3.5	1	255.99609375	False
14:02:36.871	3.5	1	255.99609375	False
14:02:36.891	3.5	1	255.99609375	False
14:02:36.911	3.5	1	255.99609375	False
14:02:36.931	3.5	1	255.99609375	False
14:02:36.951	3.5	1	255.99609375	False
14:02:36.971	3.5	1	255.99609375	False
14:02:36.991	3.5	1	255.99609375	False
14:02:37.011	3.5	1	255.99609375	False
14:02:37.031	3.5	1	255.99609375	False
14:02:37.051	3.5	1	255.99609375	False
14:02:37.071	3.5	1	255.99609375	False
14:02:37.091	3.5	1	255.99609375	False
14:02:37.111	3.5	1	255.99609375	False
14:02:37.131	3.5	1	255.99609375	False
14:02:37.151	3.5	1	255.99609375	False
14:02:37.171	3.5	1	255.99609375	False
14:02:37.191	3.5	1	255.99609375	False
14:02:37.211	3.5	1	255.99609375	False
14:02:37.231	3.5	1	255.99609375	False
14:02:37.251	3.5	1	255.99609375	False
14:02:37.271	3.5	1	255.99609375	False
14:02:37.291	3.5	1	255.99609375	False
14:02:37.311	3.5	1	255.99609375	False
14:02:37.331	3.5	1	255.99609375	False
14:02:37.351	3.5	1	255.99609375	False
14:02:37.371	3.5	1	255.99609375	False
14:02:37.391	3.5	1	255.99609375	False
14:02:37.411	3.5	1	255.99609375	False
14:02:37.431	3.5	1	255.99609375	False
14:02:37.451	3.5	1	255.99609375	False
14:02:37.471	3.5	1	255.99609375	False
14:02:37.491	3.5	1	255.99609375	False
14:02:37.511	3.5	1	255.99609375	False
14:02:37.531	3.5	1	255.99609375	False
14:02:37.551	3.5	1	255.99609375	False
14:02:37.571	3.5	1	255.99609375	False
14:02:37.591	3.5	1	255.99609375	False
14:02:37.611	3.5	1	255.99609375	False
14:02:37.631	3.5	1	255.99609375	False
14:02:37.651	3.5	1	255.99609375	False
14:02:37.671	3.5	1	255.99609375	False
14:02:37.691	3.5	1	255.99609375	False
14:02:37.711	3.5	1	255.99609375	False
14:02:37.731	3.5	1	255.99609375	False
14:02:37.751	3.5	1	255.99609375	False
14:02:37.771	3.5	1	255.99609375	False
14:02:37.791	3.5	1	255.99609375	False
14:02:37.811	3.5	1	255.99609375	False
14:02:37.831	3.5	1	255.99609375	False
14:02:37.851	3.5	1	255.99609375	False
14:02:37.871	3.5	1	255.99609375	False
14:02:37.891	3.5	1	255.99609375	False
14:02:37.911	3.5	1	255.99609375	False
14:02:37.931	3.5	1	255.99609375	False
14:02:37.951	3.5	1	255.99609375	False
14:02:37.971	3.5	1	255.99609375	False
14:02:37.991	3.5	1	255.99609375	False
14:02:38.011	3.5	1	255.99609375	False
14:02:38.031	3.5	1	255.99609375	False
14:02:38.051	3.5	1	255.99609375	False
14:02:38.071	3.5	1	255.99609375	False
14:02:38.091	3.5	1	255.99609375	False
14:02:38.111	3.5	1	255.99609375	False
14:02:38.131	3.5	1	255.99609375	False
14:02:38.151	3.5	1	255.99609375	False
14:02:38.171	3.5	1	255.99609375	False
14:02:38.191	3.5	1	255.99609375	False
14:02:38.211	3.5	1	255.99609375	False
14:02:38.231	3.5	1	255.99609375	False
14:02:38.251	3.5	1	255.99609375	False
14:02:38.271	3.5	1	255.99609375	False
14:02:38.291	3.5	1	255.99609375	False
14:02:38.311	3.5	1	255.99609375	False
14:02:38.331	3.5	1	255.99609375	False
14:02:38.351	3.5	1	255.99609375	False
14:02:38.371	3.5	1	255.99609375	False
14:02:38.391	3.5	1	255.99609375	False
14:02:38.411	3.5	1	255.99609375	False
14:02:38.431	3.5	1	255.99609375	False
14:02:38.451	3.5	1	255.99609375	False
14:02:38.471	3.5	0.28	12.10546875	True
14:02:38.491	3.5	0.28	12.10546875	True
14:02:38.511	3.5	0.28	12.10546875	True
14:02:38.531	3.5	0.28	12.10546875	True
14:02:38.551	3.5	0.28	12.10546875	True
14:02:38.571	3.5	0.28	12.10546875	True
14:02:38.591	3.5	0.28	12.10546875	True
14:02:38.611	3.5	0.28	12.10546875	True
14:02:38.631	3.5	0.28	12.09375	False
14:02:38.651	3.5	0.28	12.09765625	False
14:02:38.671	3.5	0.28	12.10546875	False
14:02:38.691	3.5	0.28	12.09765625	False
14:02:38.711	3.5	0.28	12.09765625	True
14:02:38.731	3.5	0.28	12.10546875	False
14:02:38.751	3.5	0.28	12.09375	True
14:02:38.771	3.5	0.28	12.09765625	False
14:02:38.791	3.5	0.28	12.0859375	True
14:02:38.811	3.5	0.28	12.08203125	True
14:02:38.831	3.5	0.28	12.09375	True
14:02:38.851	3.5	0.28	12.09375	True
14:02:38.871	3.5	0.28	12.0859375	True
14:02:38.891	3.5	0.28	12.09765625	True
14:02:38.911	3.5	0.28	12.09765625	True
14:02:38.931	3.5	0.28	12.09375	True
14:02:38.951	3.5	0.28	12.11328125	True
14:02:38.971	3.5	0.28	12.09375	True
14:02:38.991	3.5	0.28	12.09375	True
14:02:39.011	3.5	0.28	12.09765625	True
14:02:39.031	3.5	0.28	12.10546875	True
14:02:39.051	3.5	0.28	12.10546875	True
14:02:39.071	3.5	0.28	12.10546875	True
14:02:39.091	3.5	0.28	12.09765625	True
14:02:39.111	3.5	0.28	12.1171875	True
14:02:39.131	3.5	0.28	12.10546875	True
14:02:39.151	3.5	0.28	12.0859375	True
14:02:39.171	3.5	1.12	255.99609375	False
14:02:39.191	3.5	1.12	255.99609375	False
14:02:39.211	3.5	1.12	255.99609375	False
14:02:39.231	3.5	1.12	255.99609375	False
14:02:39.251	3.5	1.12	255.99609375	False
14:02:39.271	3.5	1.12	255.99609375	False
14:02:39.291	3.5	1.12	255.99609375	False
14:02:39.311	3.5	1.12	255.99609375	False
14:02:39.331	3.5	1.12	255.99609375	False
14:02:39.351	3.5	1.12	255.99609375	False
14:02:39.371	3.5	1.12	255.99609375	False
14:02:39.391	3.5	1.12	255.99609375	False
14:02:39.411	3.5	1.12	255.99609375	False
14:02:39.431	3.5	1.12	255.99609375	False
14:02:39.451	3.5	1.12	255.99609375	False
14:02:39.471	3.5	1.12	255.99609375	False
14:02:39.491	3.5	1.12	255.99609375	False
14:02:39.511	3.5	1.12	255.99609375	False
14:02:39.531	3.5	1	255.99609375	False
14:02:39.551	3.5	1	255.99609375	False
14:02:39.571	3.5	1	255.99609375	False
14:02:39.591	3.5	1	255.99609375	False
14:02:39.611	3.5	1	255.99609375	False
14:02:39.631	3.5	1	255.99609375	False
14:02:39.651	3.5	1	255.99609375	False
14:02:39.671	3.5	1	255.99609375	False
14:02:39.691	3.5	1	255.99609375	False
14:02:39.711	3.5	1	255.99609375	False
14:02:39.731	3.5	1	255.99609375	False
14:02:39.751	3.5	1	255.99609375	False
14:02:39.771	3.5	1	255.99609375	False
14:02:39.791	3.5	1	255.99609375	False
14:02:39.811	3.5	1	255.99609375	False
14:02:39.831	3.5	1	255.99609375	False
14:02:39.851	3.5	1	255.99609375	False
14:02:39.871	3.5	1	255.99609375	False
14:02:39.891	3.5	1	255.99609375	False
14:02:39.911	3.5	1	255.99609375	False
14:02:39.931	3.5	1	255.99609375	False
14:02:39.951	3.5	1	255.99609375	False
14:02:39.971	3.5	1	255.99609375	False
14:02:39.991	3.5	1	255.99609375	False
14:02:40.011	3.5	1	255.99609375	False
14:02:40.031	3.5	1	255.99609375	False
14:02:40.051	3.5	1	255.99609375	False
14:02:40.071	3.5	1	255.99609375	False
14:02:40.091	3.5	1	255.99609375	False
14:02:40.111	3.5	1	255.99609375	False
14:02:40.131	3.5	1	255.99609375	False
14:02:40.151	3.5	1	255.99609375	False
14:02:40.171	3.5	1	255.99609375	False
14:02:40.191	3.5	1	255.99609375	False
14:02:40.211	3.5	1	255.99609375	False
14:02:40.231	3.5	1	255.99609375	False
14:02:40.251	3.5	1	255.99609375	False
14:02:40.271	3.5	1	255.99609375	False
14:02:40.291	3.5	1	255.99609375	False
14:02:40.311	3.5	1	255.99609375	False
14:02:40.331	3.5	1	255.99609375	False
14:02:40.351	3.5	1	255.99609375	False
14:02:40.371	3.5	1	255.99609375	False
14:02:40.391	3.5	1	255.99609375	False
14:02:40.411	3.5	1	255.99609375	False
14:02:40.431	3.5	1	255.99609375	False
14:02:40.451	3.5	1	255.99609375	False
14:02:40.471	3.5	1	255.99609375	False
14:02:40.491	3.5	1	255.99609375	False
14:02:40.511	3.5	1	255.99609375	False
14:02:40.531	3.5	1	255.99609375	False
14:02:40.551	3.5	1	255.99609375	False
14:02:40.571	3.5	1	255.99609375	False
14:02:40.591	3.5	1	255.99609375	False
14:02:40.611	3.5	1	255.99609375	False
14:02:40.631	3.5	1	255.99609375	False
14:02:40.651	3.5	1	255.99609375	False
14:02:40.671	3.5	1	255.99609375	False
14:02:40.691	3.5	1	255.99609375	False
14:02:40.711	3.5	1	255.99609375	False
14:02:40.731	3.5	1	255.99609375	False
14:02:40.751	3.5	1	255.99609375	False
14:02:40.771	3.5	1	255.99609375	False
14:02:40.791	3.5	1	255.99609375	False
14:02:40.811	3.5	1	255.99609375	False
14:02:40.831	3.5	1	255.99609375	False
14:02:40.851	3.5	1	255.99609375	False
14:02:40.871	3.5	1	255.99609375	False
14:02:40.891	3.5	1	255.99609375	False
14:02:40.911	3.5	1	255.99609375	False
14:02:40.931	3.5	1	255.99609375	False
14:02:40.951	3.5	1	255.99609375	False
14:02:40.971	3.5	1	255.99609375	False
14:02:40.991	3.5	1	255.99609375	False
14:02:41.011	3.5	1	255.99609375	False
14:02:41.031	3.5	1	255.99609375	False
14:02:41.051	3.5	1	255.99609375	False
14:02:41.071	3.5	1	255.99609375	False
14:02:41.091	3.5	1	255.99609375	False
14:02:41.111	3.5	1	255.99609375	False
14:02:41.131	3.5	1	255.99609375	False
14:02:41.151	3.5	1	255.99609375	False
14:02:41.171	3.5	1	255.99609375	False
14:02:41.191	3.5	1	255.99609375	False
14:02:41.211	3.5	1	255.99609375	False
14:02:41.231	3.5	1	255.99609375	False
14:02:41.251	3.5	1	255.99609375	False
14:02:41.271	3.5	1	255.99609375	False
14:02:41.291	3.5	1	255.99609375	False
14:02:41.311	3.5	1	255.99609375	False
14:02:41.331	3.5	1	255.99609375	False
14:02:41.351	3.5	1	255.99609375	False
14:02:41.371	3.5	1	255.99609375	False
14:02:41.391	3.5	1	255.99609375	False
14:02:41.411	3.5	1	255.99609375	False
14:02:41.431	3.5	1	255.99609375	False
14:02:41.451	3.5	1	255.99609375	False
14:02:41.471	3.5	1	255.99609375	False
14:02:41.491	3.5	1	255.99609375	False
14:02:41.511	3.5	1	255.99609375	False
14:02:41.531	3.5	0.2	12.0859375	True
14:02:41.551	3.5	0.2	12.0859375	True
14:02:41.571	3.5	0.2	12.0859375	True
14:02:41.591	3.5	0.2	12.0859375	True
14:02:41.611	3.5	0.2	12.0859375	True
14:02:41.631	3.5	0.2	12.09765625	False
14:02:41.651	3.5	0.2	12.09765625	False
14:02:41.671	3.5	0.2	12.09765625	False
14:02:41.691	3.5	0.2	12.0859375	False
14:02:41.711	3.5	0.2	12.0859375	False
14:02:41.731	3.5	0.2	12.10546875	False
14:02:41.751	3.5	0.2	12.10546875	True
14:02:41.771	3.5	0.2	12.09765625	False
14:02:41.791	3.5	0.2	12.0859375	False
14:02:41.811	3.5	0.2	12.09765625	False
14:02:41.831	3.5	0.2	12.09765625	True
14:02:41.851	3.5	0.2	12.09375	False
14:02:41.871	3.5	0.2	12.09375	False
14:02:41.891	3.5	0.2	12.09375	False
14:02:41.911	3.5	0.2	12.09375	False
14:02:41.931	3.5	0.2	12.09375	False
14:02:41.951	3.5	0.2	12.09375	False
14:02:41.971	3.5	0.2	12.09375	False
14:02:41.991	3.5	0.2	12.09375	True
14:02:42.011	3.5	0.2	12.09765625	False
14:02:42.031	3.5	0.2	12.09765625	True
14:02:42.051	3.5	0.2	12.10546875	True
14:02:42.071	3.5	0.2	12.10546875	True
14:02:42.091	3.5	0.2	12.10546875	True
14:02:42.111	3.5	0.2	12.10546875	True
14:02:42.131	3.5	0.2	12.11328125	True
14:02:42.151	3.5	0.2	12.09375	True
14:02:42.171	3.5	0.2	12.09765625	True
14:02:42.191	3.5	0.2	12.10546875	True
14:02:42.211	3.5	0.2	12.10546875	True
14:02:42.231	3.5	0.2	12.09765625	True
14:02:42.251	3.5	0.2	12.09375	True
14:02:42.271	3.5	0.2	12.09765625	True
14:02:42.291	3.5	0.2	12.09765625	True
14:02:42.311	3.5	0.2	12.09765625	True
14:02:42.331	3.5	0.2	12.0859375	True
14:02:42.351	3.5	0.2	12.09765625	True
14:02:42.371	3.5	0.2	12.09765625	True
14:02:42.391	3	1.12	255.99609375	False
14:02:42.411	3	1.12	255.99609375	False
14:02:42.431	3	1.12	255.99609375	False
14:02:42.451	3	1.12	255.99609375	False
14:02:42.471	3	1.12	255.99609375	False
14:02:42.491	3	1.12	255.99609375	False
14:02:42.511	3	1.12	255.99609375	False
14:02:42.531	3	1.12	255.99609375	False
14:02:42.551	3	1	255.99609375	False
14:02:42.571	3	1	255.99609375	False
14:02:42.591	3	1	255.99609375	False
14:02:42.611	3	1	255.99609375	False
14:02:42.631	3	1	255.99609375	False
14:02:42.651	3	1	255.99609375	False
14:02:42.671	3	1	255.99609375	False
14:02:42.691	3	1	255.99609375	False
14:02:42.711	3	1	255.99609375	False
14:02:42.731	3	1	255.99609375	False
14:02:42.751	3	1	255.99609375	False
14:02:42.771	3	1	255.99609375	False
14:02:42.791	3	1	255.99609375	False
14:02:42.811	3	1	255.99609375	False
14:02:42.831	3	1	255.99609375	False
14:02:42.851	3	1	255.99609375	False
14:02:42.871	3	1	255.99609375	False
14:02:42.891	3	1	255.99609375	False
14:02:42.911	3	1	255.99609375	False
14:02:42.931	3	1	255.99609375	False
14:02:42.951	3	1	255.99609375	False
14:02:42.971	3	1	255.99609375	False
14:02:42.991	3	1	255.99609375	False
14:02:43.011	3	1	255.99609375	False
14:02:43.031	3	1	255.99609375	False
14:02:43.051	3	1	255.99609375	False
14:02:43.071	3	1	255.99609375	False
14:02:43.091	3	1	255.99609375	False
14:02:43.111	3	1	255.99609375	False
14:02:43.131	3	1	255.99609375	False
14:02:43.151	3	1	255.99609375	False
14:02:43.171	3	1	255.99609375	False
14:02:43.191	3	1	255.99609375	False
14:02:43.211	3	1	255.99609375	False
14:02:43.231	3	1	255.99609375	False
14:02:43.251	3	1	255.99609375	False
14:02:43.271	3	1	255.99609375	False
14:02:43.291	3	1	255.99609375	False
14:02:43.311	3	1	255.99609375	False
14:02:43.331	3	1	255.99609375	False
14:02:43.351	3	1	255.99609375	False
14:02:43.371	3	1	255.99609375	False
14:02:43.391	3	1	255.99609375	False
14:02:43.411	3	1	255.99609375	False
14:02:43.431	3	1	255.99609375	False
14:02:43.451	3	1	255.99609375	False
14:02:43.471	3	1	255.99609375	False
14:02:43.491	3	1	255.99609375	False
14:02:43.511	3	1	255.99609375	False
14:02:43.531	3	1	255.99609375	False
14:02:43.551	3	1	255.99609375	False
14:02:43.571	3	1	255.99609375	False
14:02:43.591	3	1	255.99609375	False
14:02:43.611	3	1	255.99609375	False
14:02:43.631	3	1	255.99609375	False
14:02:43.651	3	1	255.99609375	False
14:02:43.671	3	1	255.99609375	False
14:02:43.691	3	1	255.99609375	False
14:02:43.711	3	1	255.99609375	False
14:02:43.731	3	1	255.99609375	False
14:02:43.751	3	1	255.99609375	False
14:02:43.771	3	1	255.99609375	False
14:02:43.791	3	1	255.99609375	False
14:02:43.811	3	1	255.99609375	False
14:02:43.831	3	1	255.99609375	False
14:02:43.851	3	1	255.99609375	False
14:02:43.871	3	1	255.99609375	False
14:02:43.891	3	1	255.99609375	False
14:02:43.911	3	1	255.99609375	False
14:02:43.931	3	1	255.99609375	False
14:02:43.951	3	1	255.99609375	False
14:02:43.971	3	1	255.99609375	False
14:02:43.991	3	1	255.99609375	False
14:02:44.011	3	1	255.99609375	False
14:02:44.031	3	1	255.99609375	False
14:02:44.051	3	1	255.99609375	False
14:02:44.071	3	1	255.99609375	False
14:02:44.091	3	1	255.99609375	False
14:02:44.111	3	1	255.99609375	False
14:02:44.131	3	1	255.99609375	False
14:02:44.151	3	1	255.99609375	False
14:02:44.171	3	1	255.99609375	False
14:02:44.191	3	1	255.99609375	False
14:02:44.211	3	1	255.99609375	False
14:02:44.231	3	1	255.99609375	False
14:02:44.251	3	1	255.99609375	False
14:02:44.271	3	1	255.99609375	False
14:02:44.291	3	1	255.99609375	False
14:02:44.311	3	1	255.99609375	False
14:02:44.331	3	1	255.99609375	False
14:02:44.351	3	1	255.99609375	False
14:02:44.371	3	1	255.99609375	False
14:02:44.391	3	1	255.99609375	False
14:02:44.411	3	1	255.99609375	False
14:02:44.431	3	1	255.99609375	False
14:02:44.451	3	1	255.99609375	False
14:02:44.471	3	1	255.99609375	False
14:02:44.491	3	1	255.99609375	False
14:02:44.511	3	1	255.99609375	False
14:02:44.531	3	1	255.99609375	False
14:02:44.551	3	0.24	12.09765625	True
14:02:44.571	3	0.24	12.09765625	True
14:02:44.591	3	0.24	12.09765625	True
14:02:44.611	3	0.24	12.09765625	True
14:02:44.631	3	0.24	12.09765625	True
14:02:44.651	3	0.24	12.09765625	True
14:02:44.671	3	0.24	12.0859375	True
14:02:44.691	3	0.24	12.09375	False
14:02:44.711	3	0.24	12.09765625	False
14:02:44.731	3	0.24	12.10546875	False
14:02:44.751	3	0.24	12.09765625	False
14:02:44.771	3	0.24	12.09765625	False
14:02:44.791	3	0.24	12.09375	False
14:02:44.811	3	0.24	12.09375	False
14:02:44.831	3	0.24	12.10546875	False
14:02:44.851	3	0.24	12.0859375	True
14:02:44.871	3	0.24	12.09375	False
14:02:44.891	3	0.24	12.09765625	False
14:02:44.911	3	0.24	12.09765625	False
14:02:44.931	3	0.24	12.09765625	False
14:02:44.951	3	0.24	12.09375	False
14:02:44.971	3	0.24	12.09765625	False
14:02:44.991	3	0.24	12.09375	False
14:02:45.011	3	0.24	12.09375	False
14:02:45.031	3	0.24	12.09765625	True
14:02:45.051	3	0.24	12.10546875	True
14:02:45.071	3	0.24	12.10546875	False
14:02:45.091	3	0.24	12.09765625	True
14:02:45.111	3	0.24	12.11328125	True
14:02:45.131	3	0.24	12.10546875	True
14:02:45.151	3	0.24	12.10546875	True
14:02:45.171	3	0.24	12.09375	True
14:02:45.191	3	0.24	12.09375	True
14:02:45.211	3	0.24	12.10546875	True
14:02:45.231	3	0.24	12.09765625	True
14:02:45.251	3	0.24	12.09765625	True
14:02:45.271	3	0.24	12.10546875	True
14:02:45.291	3	0.24	12.09765625	True
14:02:45.311	3	0.24	12.10546875	True
14:02:45.331	3	0.24	12.09375	True
14:02:45.351	3	0.24	12.10546875	True
14:02:45.371	3	0.24	12.09375	True
14:02:45.391	3	0.24	12.09765625	True
14:02:45.411	3	0.24	12.09765625	True
14:02:45.431	3	0.24	12.09375	True
14:02:45.451	3	0.24	12.09765625	True
14:02:45.471	3	1.12	255.99609375	False
14:02:45.491	3	1.12	255.99609375	False
14:02:45.511	3	1.12	255.99609375	False
14:02:45.531	3	1.12	255.99609375	False
14:02:45.551	3	1.12	255.99609375	False
14:02:45.571	3	1.12	255.99609375	False
14:02:45.591	3	1.12	255.99609375	False
14:02:45.611	3	1.12	255.99609375	False
14:02:45.631	3	1.12	255.99609375	False
14:02:45.651	3	1.12	255.99609375	False
14:02:45.671	3	1.12	255.99609375	False
14:02:45.691	3	1.12	255.99609375	False
14:02:45.711	3	1.12	255.99609375	False
14:02:45.731	3	1.12	255.99609375	False
14:02:45.751	3	1.12	255.99609375	False
14:02:45.771	3	1.12	255.99609375	False
14:02:45.791	3	1.12	255.99609375	False
14:02:45.811	3	1.12	255.99609375	False
14:02:45.831	3	1.12	255.99609375	False
14:02:45.851	3	1.12	255.99609375	False
14:02:45.871	3	1.12	255.99609375	False
14:02:45.891	3	1.12	255.99609375	False
14:02:45.911	3	1.12	255.99609375	False
14:02:45.931	3	1.12	255.99609375	False
14:02:45.951	3	1.12	255.99609375	False
14:02:45.971	3	1.12	255.99609375	False
14:02:45.991	3	1.12	255.99609375	False
14:02:46.011	3	1.12	255.99609375	False
14:02:46.031	3	1.12	255.99609375	False
14:02:46.051	3	1.12	255.99609375	False
14:02:46.071	3	1.12	255.99609375	False
14:02:46.091	3	1.12	255.99609375	False
14:02:46.111	3	1	255.99609375	False
14:02:46.131	3	1	255.99609375	False
14:02:46.151	3	1	255.99609375	False
14:02:46.171	3	1	255.99609375	False
14:02:46.191	3	1	255.99609375	False
14:02:46.211	3	1	255.99609375	False
14:02:46.231	3	1	255.99609375	False
14:02:46.251	3	1	255.99609375	False
14:02:46.271	3	1	255.99609375	False
14:02:46.291	3	1	255.99609375	False
14:02:46.311	3	1	255.99609375	False
14:02:46.331	3	1	255.99609375	False
14:02:46.351	3	1	255.99609375	False
14:02:46.371	3	1	255.99609375	False
14:02:46.391	3	1	255.99609375	False
14:02:46.411	3	1	255.99609375	False
14:02:46.431	3	1	255.99609375	False
14:02:46.451	3	1	255.99609375	False
14:02:46.471	3	1	255.99609375	False
14:02:46.491	3	1	255.99609375	False
14:02:46.511	3	1	255.99609375	False
14:02:46.531	3	1	255.99609375	False
14:02:46.551	3	1	255.99609375	False
14:02:46.571	3	1	255.99609375	False
14:02:46.591	3	1	255.99609375	False
14:02:46.611	3	1	255.99609375	False
14:02:46.631	3	1	255.99609375	False
14:02:46.651	3	1	255.99609375	False
14:02:46.671	3	1	255.99609375	False
14:02:46.691	3	1	255.99609375	False
14:02:46.711	3	1	255.99609375	False
14:02:46.731	3	1	255.99609375	False
14:02:46.751	3	1	255.99609375	False
14:02:46.771	3	1	255.99609375	False
14:02:46.791	3	1	255.99609375	False
14:02:46.811	3	1	255.99609375	False
14:02:46.831	3	1	255.99609375	False
14:02:46.851	3	1	255.99609375	False
14:02:46.871	3	1	255.99609375	False
14:02:46.891	3	1	255.99609375	False
14:02:46.911	3	1	255.99609375	False
14:02:46.931	3	1	255.99609375	False
14:02:46.951	3	1	255.99609375	False
14:02:46.971	3	1	255.99609375	False
14:02:46.991	3	1	255.99609375	False
14:02:47.011	3	1	255.99609375	False
14:02:47.031	3	1	255.99609375	False
14:02:47.051	3	1	255.99609375	False
14:02:47.071	3	1	255.99609375	False
14:02:47.091	3	1	255.99609375	False
14:02:47.111	3	1	255.99609375	False
14:02:47.131	3	1	255.99609375	False
14:02:47.151	3	1	255.99609375	False
14:02:47.171	3	1	255.99609375	False
14:02:47.191	3	1	255.99609375	False
14:02:47.211	3	1	255.99609375	False
14:02:47.231	3	1	255.99609375	False
14:02:47.251	3	1	255.99609375	False
14:02:47.271	3	1	255.99609375	False
14:02:47.291	3	1	255.99609375	False
14:02:47.311	3	1	255.99609375	False
14:02:47.331	3	1	255.99609375	False
14:02:47.351	3	1	255.99609375	False
14:02:47.371	3	1	255.99609375	False
14:02:47.391	3	1	255.99609375	False
14:02:47.411	3	1	255.99609375	False
14:02:47.431	3	1	255.99609375	False
14:02:47.451	3	1	255.99609375	False
14:02:47.471	3	1	255.99609375	False
14:02:47.491	3	1	255.99609375	False
14:02:47.511	3	1	255.99609375	False
14:02:47.531	3	1	255.99609375	False
14:02:47.551	3	1	255.99609375	False
14:02:47.571	3	1	255.99609375	False
14:02:47.591	3	1	255.99609375	False
14:02:47.611	3	1	12.10546875	True
14:02:47.631	3	1	12.10546875	True
14:02:47.651	3	1	12.10546875	True
14:02:47.671	3	1	12.10546875	True
14:02:47.691	3	1	12.10546875	True
14:02:47.711	3	1	12.09765625	False
14:02:47.731	3	1	12.10546875	False
14:02:47.751	3	1	12.10546875	False
14:02:47.771	3	1	12.10546875	False
14:02:47.791	3	1	12.09765625	False
14:02:47.811	3	1	12.10546875	True
14:02:47.831	3	1	12.09375	False
14:02:47.851	3	1	12.09765625	True
14:02:47.871	3	1	12.09765625	False
14:02:47.891	3	1	12.09765625	False
14:02:47.911	3	1	12.09375	False
14:02:47.931	3	1	12.09375	False
14:02:47.951	3	1	12.08203125	False
14:02:47.971	3	1	12.09375	False
14:02:47.991	3	1	12.09765625	True
14:02:48.011	3	1	12.09375	False
14:02:48.031	3	1	12.09375	True
14:02:48.051	3	1	12.09375	True
14:02:48.071	3	1	12.09375	True
14:02:48.091	3	1	12.09765625	True
14:02:48.111	3	1	12.09375	True
14:02:48.131	3	1	12.0859375	True
14:02:48.151	3	1	12.0859375	True
14:02:48.171	3	1	12.09375	True
14:02:48.191	3	1	12.0859375	True
14:02:48.211	3	1	12.0859375	True
14:02:48.231	3	1	12.0859375	True
14:02:48.251	3	1	12.0859375	True
14:02:48.271	3	1	12.09765625	True
14:02:48.291	3	1	12.09765625	True
14:02:48.311	3	1	12.10546875	True
14:02:48.331	3	1	12.09765625	True
14:02:48.351	3	1	12.09765625	True
14:02:48.371	3	1	12.09765625	True
14:02:48.391	4	0.36	12.09765625	True
14:02:48.411	4	0.36	12.09765625	True
14:02:48.431	4	0.36	12.09375	True
14:02:48.451	5	0.96	255.99609375	False
14:02:48.471	5	0.96	255.99609375	False
14:02:48.491	5	0.96	255.99609375	False
14:02:48.511	5	0.96	255.99609375	False
14:02:48.531	5	0.96	255.99609375	False
14:02:48.551	5	0.96	255.99609375	False
14:02:48.571	5	0.96	255.99609375	False
14:02:48.591	5	0.96	255.99609375	False
14:02:48.611	5	0.96	255.99609375	False
14:02:48.631	5	0.96	255.99609375	False
14:02:48.651	5	0.96	255.99609375	False
14:02:48.671	5	1	255.99609375	False
14:02:48.691	5	1	255.99609375	False
14:02:48.711	5	1	255.99609375	False
14:02:48.731	5	1	255.99609375	False
14:02:48.751	5	1	255.99609375	False
14:02:48.771	5	1	255.99609375	False
14:02:48.791	5	1	255.99609375	False
14:02:48.811	5	1	255.99609375	False
14:02:48.831	5	1	255.99609375	False
14:02:48.851	5	1	255.99609375	False
14:02:48.871	5	1	255.99609375	False
14:02:48.891	5	1	255.99609375	False
14:02:48.911	5	1	255.99609375	False
14:02:48.931	5	1	255.99609375	False
14:02:48.951	5	1	255.99609375	False
14:02:48.971	5	1	255.99609375	False
14:02:48.991	5	1	255.99609375	False
14:02:49.011	5	1	255.99609375	False
14:02:49.031	5	1	255.99609375	False
14:02:49.051	5	1	255.99609375	False
14:02:49.071	5	1	255.99609375	False
14:02:49.091	5	1	255.99609375	False
14:02:49.111	5	1	255.99609375	False
14:02:49.131	5	1	255.99609375	False
14:02:49.151	5	1	255.99609375	False
14:02:49.171	5	1	255.99609375	False
14:02:49.191	5	1	255.99609375	False
14:02:49.211	5	1	255.99609375	False
14:02:49.231	5	1	255.99609375	False
14:02:49.251	5	1	255.99609375	False
14:02:49.271	5	1	255.99609375	False
14:02:49.291	5	1	255.99609375	False
14:02:49.311	5	1	255.99609375	False
14:02:49.331	5	1	255.99609375	False
14:02:49.351	5	1	255.99609375	False
14:02:49.371	5	1	255.99609375	False
14:02:49.391	5	1	255.99609375	False
14:02:49.411	5	1	255.99609375	False
14:02:49.431	5	1	255.99609375	False
14:02:49.451	5	1	255.99609375	False
14:02:49.471	5	1	255.99609375	False
14:02:49.491	5	1	255.99609375	False
14:02:49.511	5	1	255.99609375	False
14:02:49.531	5	1	255.99609375	False
14:02:49.551	5	1	255.99609375	False
14:02:49.571	5	1	255.99609375	False
14:02:49.591	5	1	255.99609375	False
14:02:49.611	5	1	255.99609375	False
14:02:49.631	5	1	255.99609375	False
14:02:49.651	5	1	255.99609375	False
14:02:49.671	5	1	255.99609375	False
14:02:49.691	5	1	255.99609375	False
14:02:49.711	5	1	255.99609375	False
14:02:49.731	5	1	255.99609375	False
14:02:49.751	5	1	255.99609375	False
14:02:49.771	5	1	255.99609375	False
14:02:49.791	5	1	255.99609375	False
14:02:49.811	5	1	255.99609375	False
14:02:49.831	5	1	255.99609375	False
14:02:49.851	5	1	255.99609375	False
14:02:49.871	5	1	255.99609375	False
14:02:49.891	5	1	255.99609375	False
14:02:49.911	5	1	255.99609375	False
14:02:49.931	5	1	255.99609375	False
14:02:49.951	5	1	255.99609375	False
14:02:49.971	5	1	255.99609375	False
14:02:49.991	5	1	255.99609375	False
14:02:50.011	5	1	255.99609375	False
14:02:50.031	5	1	255.99609375	False
14:02:50.051	5	1	255.99609375	False
14:02:50.071	5	1	255.99609375	False
14:02:50.091	5	1	255.99609375	False
14:02:50.111	5	1	255.99609375	False
14:02:50.131	5	1	255.99609375	False
14:02:50.151	5	1	255.99609375	False
14:02:50.171	5	1	255.99609375	False
14:02:50.191	5	1	255.99609375	False
14:02:50.211	5	1	255.99609375	False
14:02:50.231	5	1	255.99609375	False
14:02:50.251	5	1	255.99609375	False
14:02:50.271	5	1	255.99609375	False
14:02:50.291	5	1	255.99609375	False
14:02:50.311	5	1	255.99609375	False
14:02:50.331	5	1	255.99609375	False
14:02:50.351	5	1	255.99609375	False
14:02:50.371	5	1	255.99609375	False
14:02:50.391	5	1	255.99609375	False
14:02:50.411	5	1	255.99609375	False
14:02:50.431	5	1	255.99609375	False
14:02:50.451	5	1	255.99609375	False
14:02:50.471	5	1	255.99609375	False
14:02:50.491	5	1	255.99609375	False
14:02:50.511	5	1	255.99609375	False
14:02:50.531	5	1	255.99609375	False
14:02:50.551	5	1	255.99609375	False
14:02:50.571	5	1	255.99609375	False
14:02:50.591	5	1	255.99609375	False
14:02:50.611	5	1	255.99609375	False
14:02:50.631	5	1	255.99609375	False
14:02:50.651	5	1	255.99609375	False
14:02:50.671	5	1	255.99609375	False
14:02:50.691	5	1	12.09375	True
14:02:50.711	5	1	12.09375	True
14:02:50.731	5	1	12.09375	True
14:02:50.751	5	1	12.09375	True
14:02:50.771	5	1	12.09375	True
14:02:50.791	5	1	12.09375	True
14:02:50.811	5	1	12.09375	True
14:02:50.831	5	1	12.09375	True
14:02:50.851	5	1	12.09375	True
14:02:50.871	5	1	12.09375	True
14:02:50.891	5	1	12.09375	True
14:02:50.911	5	1	12.09375	True
14:02:50.931	5	1	12.10546875	False
14:02:50.951	5	1	12.10546875	False
14:02:50.971	5	1	12.10546875	False
14:02:50.991	5	1	12.11328125	False
14:02:51.011	5	1	12.09765625	False
14:02:51.031	5	1	12.1171875	False
14:02:51.051	5	1	12.10546875	False
14:02:51.071	5	1	12.09375	False
14:02:51.091	5	1	12.09765625	False
14:02:51.111	5	1	12.10546875	False
14:02:51.131	5	1	12.09375	False
14:02:51.151	5	1	12.09765625	True
14:02:51.171	5	1	12.09375	False
14:02:51.191	5	1	12.10546875	False
14:02:51.211	5	1	12.10546875	False
14:02:51.231	5	1	12.10546875	False
14:02:51.251	5	1	12.10546875	False
14:02:51.271	5	1	12.10546875	False
14:02:51.291	5	1	12.09765625	False
14:02:51.311	5	1	12.09375	False
14:02:51.331	5	1	12.09765625	True
14:02:51.351	5	1	12.09765625	False
14:02:51.371	5	1	12.09765625	True
14:02:51.391	5	1	12.09765625	False
14:02:51.411	5	1	12.09765625	False
14:02:51.431	5	1	12.09765625	False
14:02:51.451	5	1	12.09765625	False
14:02:51.471	5	1	12.10546875	False
14:02:51.491	5	1	12.09765625	False
14:02:51.511	5	1	12.10546875	False
14:02:51.531	5	1	12.09375	True
14:02:51.551	5	1	12.10546875	True
14:02:51.571	5	1	12.10546875	True
14:02:51.591	5	1	12.10546875	True
14:02:51.611	5	1	12.09765625	True
14:02:51.631	5	1	12.10546875	True
14:02:51.651	5	1	12.09375	True
14:02:51.671	5	0.56	12.09765625	True
14:02:51.691	5	0.56	12.09375	True
14:02:51.711	5	0.56	12.09765625	True
14:02:51.731	5	0.56	12.09375	True
14:02:51.751	5	1	255.99609375	False
14:02:51.771	5	1	255.99609375	False
14:02:51.791	5	1	255.99609375	False
14:02:51.811	5	1	255.99609375	False
14:02:51.831	5	1	255.99609375	False
14:02:51.851	5	1	255.99609375	False
14:02:51.871	5	1	255.99609375	False
14:02:51.891	5	1	255.99609375	False
14:02:51.911	5	1	255.99609375	False
14:02:51.931	5	1	255.99609375	False
14:02:51.951	5	1	255.99609375	False
14:02:51.971	5	1	255.99609375	False
14:02:51.991	5	1	255.99609375	False
14:02:52.011	5	1	255.99609375	False
14:02:52.031	5	1	255.99609375	False
14:02:52.051	5	1	255.99609375	False
14:02:52.071	5	1	255.99609375	False
14:02:52.091	5	1	255.99609375	False
14:02:52.111	5	1	255.99609375	False
14:02:52.131	5	1	255.99609375	False
14:02:52.151	5	1	255.99609375	False
14:02:52.171	5	1	255.99609375	False
14:02:52.191	5	1	255.99609375	False
14:02:52.211	5	1	255.99609375	False
14:02:52.231	5	1	255.99609375	False
14:02:52.251	5	1	255.99609375	False
14:02:52.271	5	1	255.99609375	False
14:02:52.291	5	1	255.99609375	False
14:02:52.311	5	1	255.99609375	False
14:02:52.331	5	1	255.99609375	False
14:02:52.351	5	1	255.99609375	False
14:02:52.371	5	1	255.99609375	False
14:02:52.391	5	1	255.99609375	False
14:02:52.411	5	1	255.99609375	False
14:02:52.431	5	1	255.99609375	False
14:02:52.451	5	1	255.99609375	False
14:02:52.471	5	1	255.99609375	False
14:02:52.491	5	1	255.99609375	False
14:02:52.511	5	1	255.99609375	False
14:02:52.531	5	1	255.99609375	False
14:02:52.551	5	1	255.99609375	False
14:02:52.571	5	1	255.99609375	False
14:02:52.591	5	1	255.99609375	False
14:02:52.611	5	1	255.99609375	False
14:02:52.631	5	1	255.99609375	False
14:02:52.651	5	1	255.99609375	False
14:02:52.671	5	1	255.99609375	False
14:02:52.691	5	1.04	255.99609375	False
14:02:52.711	5	1.04	255.99609375	False
14:02:52.731	5	1.04	255.99609375	False
14:02:52.751	5	1.04	255.99609375	False
14:02:52.771	5	1.04	255.99609375	False
14:02:52.791	5	1.04	255.99609375	False
14:02:52.811	5	1.04	255.99609375	False
14:02:52.831	5	1.04	255.99609375	False
14:02:52.851	5	1.04	255.99609375	False
14:02:52.871	5	1.04	255.99609375	False
14:02:52.891	5	1.04	255.99609375	False
14:02:52.911	5	1.04	255.99609375	False
14:02:52.931	5	1.04	255.99609375	False
14:02:52.951	5	1.04	255.99609375	False
14:02:52.971	5	1.04	255.99609375	False
14:02:52.991	5	1.04	255.99609375	False
14:02:53.011	5	1.04	255.99609375	False
14:02:53.031	5	1.04	255.99609375	False
14:02:53.051	5	1.04	255.99609375	False
14:02:53.071	5	1.04	255.99609375	False
14:02:53.091	5	1.04	255.99609375	False
14:02:53.111	5	1.04	255.99609375	False
14:02:53.131	5	1.04	255.99609375	False
14:02:53.151	5	1.04	255.99609375	False
14:02:53.171	5	1.04	255.99609375	False
14:02:53.191	5	1	255.99609375	False
14:02:53.211	5	1	255.99609375	False
14:02:53.231	5	1	255.99609375	False
14:02:53.251	5	1	255.99609375	False
14:02:53.271	5	1	255.99609375	False
14:02:53.291	5	1	255.99609375	False
14:02:53.311	5	1	255.99609375	False
14:02:53.331	5	1	255.99609375	False
14:02:53.351	5	1	255.99609375	False
14:02:53.371	5	1	255.99609375	False
14:02:53.391	5	1	255.99609375	False
14:02:53.411	5	1	255.99609375	False
14:02:53.431	5	1	255.99609375	False
14:02:53.451	5	1	255.99609375	False
14:02:53.471	5	1	255.99609375	False
14:02:53.491	5	1	255.99609375	False
14:02:53.511	5	1	255.99609375	False
14:02:53.531	5	1	255.99609375	False
14:02:53.551	5	1	255.99609375	False
14:02:53.571	5	1	255.99609375	False
14:02:53.591	5	1	255.99609375	False
14:02:53.611	5	1	255.99609375	False
14:02:53.631	5	1	255.99609375	False
14:02:53.651	5	1	255.99609375	False
14:02:53.671	5	1	255.99609375	False
14:02:53.691	5	1	12.0859375	True
14:02:53.711	5	1	12.0859375	True
14:02:53.731	5	1	12.0859375	True
14:02:53.751	5	1	12.0859375	True
14:02:53.771	5	1	12.0859375	True
14:02:53.791	5	1	12.0859375	True
14:02:53.811	5	1	12.09375	False
14:02:53.831	5	1	12.10546875	False
14:02:53.851	5	1	12.10546875	False
14:02:53.871	5	1	12.09765625	False
14:02:53.891	5	1	12.09765625	False
14:02:53.911	5	1	12.10546875	True
14:02:53.931	5	1	12.09375	False
14:02:53.951	5	1	12.09765625	False
14:02:53.971	5	1	12.09375	False
14:02:53.991	5	1	12.09375	True
14:02:54.011	5	1	12.10546875	True
14:02:54.031	5	1	12.09375	True
14:02:54.051	5	1	12.10546875	True
14:02:54.071	5	1	12.10546875	True
14:02:54.091	5	1	12.09765625	True
14:02:54.111	5	1	12.10546875	True
14:02:54.131	5	1	12.10546875	True
14:02:54.151	5	1	12.11328125	True
14:02:54.171	5	1	12.09765625	True
14:02:54.191	5	1	12.09765625	True
14:02:54.211	5	1	12.09375	True
14:02:54.231	5	1	12.0859375	True
14:02:54.251	5	1	12.09765625	True
14:02:54.271	5	0.28	12.09375	True
14:02:54.291	5	0.28	12.09375	True
14:02:54.311	5	0.28	12.10546875	True
14:02:54.331	5	0.28	12.09765625	True
14:02:54.351	5	0.28	12.0859375	True
14:02:54.371	5	0.28	12.10546875	True
14:02:54.391	5	1	255.99609375	False
14:02:54.411	5	1	255.99609375	False
14:02:54.431	5	1	255.99609375	False
14:02:54.451	5	1	255.99609375	False
14:02:54.471	5	1	255.99609375	False
14:02:54.491	5	1	255.99609375	False
14:02:54.511	5	1	255.99609375	False
14:02:54.531	5	1	255.99609375	False
14:02:54.551	5	1	255.99609375	False
14:02:54.571	5	1	255.99609375	False
14:02:54.591	5	1	255.99609375	False
14:02:54.611	5	1	255.99609375	False
14:02:54.631	5	1	255.99609375	False
14:02:54.651	5	1	255.99609375	False
14:02:54.671	5	1	255.99609375	False
14:02:54.691	5	1	255.99609375	False
14:02:54.711	5	1	255.99609375	False
14:02:54.731	5	1	255.99609375	False
14:02:54.751	5	1	255.99609375	False
14:02:54.771	5	1	255.99609375	False
14:02:54.791	5	1	255.99609375	False
14:02:54.811	5	1	255.99609375	False
14:02:54.831	5	1	255.99609375	False
14:02:54.851	5	1	255.99609375	False
14:02:54.871	5	1	255.99609375	False
14:02:54.891	5	1	255.99609375	False
14:02:54.911	5	1	255.99609375	False
14:02:54.931	5	1	255.99609375	False
14:02:54.951	5	1	255.99609375	False
14:02:54.971	5	1	255.99609375	False
14:02:54.991	5	1	255.99609375	False
14:02:55.011	5	1	255.99609375	False
14:02:55.031	5	1	255.99609375	False
14:02:55.051	5	1	255.99609375	False
14:02:55.071	5	1	255.99609375	False
14:02:55.091	5	1	255.99609375	False
14:02:55.111	5	1	255.99609375	False
14:02:55.131	5	1	255.99609375	False
14:02:55.151	5	1	255.99609375	False
14:02:55.171	5	1	255.99609375	False
14:02:55.191	5	1	255.99609375	False
14:02:55.211	5	1	255.99609375	False
14:02:55.231	5	1	255.99609375	False
14:02:55.251	5	1	255.99609375	False
14:02:55.271	5	1	255.99609375	False
14:02:55.291	5	1	255.99609375	False
14:02:55.311	5	1	255.99609375	False
14:02:55.331	5	1	255.99609375	False
14:02:55.351	5	1	255.99609375	False
14:02:55.371	5	1	255.99609375	False
14:02:55.391	5	1	255.99609375	False
14:02:55.411	5	1	255.99609375	False
14:02:55.431	5	1	255.99609375	False
14:02:55.451	5	1	255.99609375	False
14:02:55.471	5	1	255.99609375	False
14:02:55.491	5	1	255.99609375	False
14:02:55.511	5	1	255.99609375	False
14:02:55.531	5	1	255.99609375	False
14:02:55.551	5	1	255.99609375	False
14:02:55.571	5	1	255.99609375	False
14:02:55.591	5	1	255.99609375	False
14:02:55.611	5	1	255.99609375	False
14:02:55.631	5	1	255.99609375	False
14:02:55.651	5	1	255.99609375	False
14:02:55.671	5	1	255.99609375	False
14:02:55.691	5	1	255.99609375	False
14:02:55.711	5	1	255.99609375	False
14:02:55.731	5	1	255.99609375	False
14:02:55.751	5	1	255.99609375	False
14:02:55.771	5	1	255.99609375	False
14:02:55.791	5	1	255.99609375	False
14:02:55.811	5	1	255.99609375	False
14:02:55.831	5	1	255.99609375	False
14:02:55.851	5	1	255.99609375	False
14:02:55.871	5	1	255.99609375	False
14:02:55.891	5	1	255.99609375	False
14:02:55.911	5	1	255.99609375	False
14:02:55.931	5	1	255.99609375	False
14:02:55.951	5	1	255.99609375	False
14:02:55.971	5	1	255.99609375	False
14:02:55.991	5	1	255.99609375	False
14:02:56.011	5	1	255.99609375	False
14:02:56.031	5	1	255.99609375	False
14:02:56.051	5	1	255.99609375	False
14:02:56.071	5	1	255.99609375	False
14:02:56.091	5	1	255.99609375	False
14:02:56.111	5	1	255.99609375	False
14:02:56.131	5	1	255.99609375	False
14:02:56.151	5	1	255.99609375	False
14:02:56.171	5	1	255.99609375	False
14:02:56.191	5	1	255.99609375	False
14:02:56.211	5	1	255.99609375	False
14:02:56.231	5	1	255.99609375	False
14:02:56.251	5	1	255.99609375	False
14:02:56.271	5	1	255.99609375	False
14:02:56.291	5	1	255.99609375	False
14:02:56.311	5	1	255.99609375	False
14:02:56.331	5	1	255.99609375	False
14:02:56.351	5	1	255.99609375	False
14:02:56.371	5	1	255.99609375	False
14:02:56.391	5	1	255.99609375	False
14:02:56.411	5	1	255.99609375	False
14:02:56.431	5	1	255.99609375	False
14:02:56.451	5	1	255.99609375	False
14:02:56.471	5	1	255.99609375	False
14:02:56.491	5	1	255.99609375	False
14:02:56.511	5	1	255.99609375	False
14:02:56.531	5	1	255.99609375	False
14:02:56.551	5	1	255.99609375	False
14:02:56.571	5	1	255.99609375	False
14:02:56.591	5	1	255.99609375	False
14:02:56.611	5	1	255.99609375	False
14:02:56.631	5	1	255.99609375	False
14:02:56.651	5	1	255.99609375	False
14:02:56.671	5	1	255.99609375	False
14:02:56.691	5	1	255.99609375	False
14:02:56.711	5	1	255.99609375	False
14:02:56.731	5	1	12.10546875	True
14:02:56.751	5	1	12.10546875	True
14:02:56.771	5	1	12.10546875	True
14:02:56.791	5	1	12.10546875	True
14:02:56.811	5	1	12.10546875	True
14:02:56.831	5	1	12.10546875	True
14:02:56.851	5	1	12.10546875	True
14:02:56.871	5	1	12.10546875	True
14:02:56.891	5	1	12.10546875	True
14:02:56.911	5	1	12.10546875	True
14:02:56.931	5	1	12.09375	False
14:02:56.951	5	1	12.09375	False
14:02:56.971	5	1	12.08203125	False
14:02:56.991	5	1	12.0859375	False
14:02:57.011	5	1	12.10546875	False
14:02:57.031	5	1	12.09765625	True
14:02:57.051	5	1	12.10546875	False
14:02:57.071	5	1	12.0859375	False
14:02:57.091	5	1	12.0859375	False
14:02:57.111	5	1	12.09765625	False
14:02:57.131	5	1	12.09375	True
14:02:57.151	5	1	12.10546875	True
14:02:57.171	5	1	12.0859375	False
14:02:57.191	5	1	12.09375	True
14:02:57.211	5	1	12.10546875	True
14:02:57.231	5	1	12.09375	True
14:02:57.251	5	1	12.09765625	True
14:02:57.271	5	1	12.09375	True
14:02:57.291	5	1	12.09375	True
14:02:57.311	5	0.52	12.09375	True
14:02:57.331	5	0.52	12.09765625	True
14:02:57.351	5	0.52	12.09375	True
14:02:57.371	5	0.52	12.09765625	True
14:02:57.391	5	0.52	12.09375	True
14:02:57.411	5	0.52	12.11328125	True
14:02:57.431	5	0.52	12.11328125	True
14:02:57.451	5	0.52	12.09765625	True
14:02:57.471	5	1	255.99609375	False
14:02:57.491	5	1	255.99609375	False
14:02:57.511	5	1	255.99609375	False
14:02:57.531	5	1	255.99609375	False
14:02:57.551	5	1	255.99609375	False
14:02:57.571	5	1	255.99609375	False
14:02:57.591	5	1	255.99609375	False
14:02:57.611	5	1	255.99609375	False
14:02:57.631	5	1	255.99609375	False
14:02:57.651	5	1	255.99609375	False
14:02:57.671	5	1	255.99609375	False
14:02:57.691	5	1	255.99609375	False
14:02:57.711	5	1	255.99609375	False
14:02:57.731	5	1	255.99609375	False
14:02:57.751	5	1	255.99609375	False
14:02:57.771	5	1	255.99609375	False
14:02:57.791	5	1	255.99609375	False
14:02:57.811	5	1	255.99609375	False
14:02:57.831	5	1	255.99609375	False
14:02:57.851	5	1	255.99609375	False
14:02:57.871	5	1	255.99609375	False
14:02:57.891	5	1	255.99609375	False
14:02:57.911	5	1	255.99609375	False
14:02:57.931	5	1	255.99609375	False
14:02:57.951	5	1	255.99609375	False
14:02:57.971	5	1	255.99609375	False
14:02:57.991	5	1	255.99609375	False
14:02:58.011	5	1	255.99609375	False
14:02:58.031	5	1	255.99609375	False
14:02:58.051	5	1	255.99609375	False
14:02:58.071	5	1	255.99609375	False
14:02:58.091	5	1	255.99609375	False
14:02:58.111	5	1	255.99609375	False
14:02:58.131	5	1	255.99609375	False
14:02:58.151	5	1	255.99609375	False
14:02:58.171	5	1	255.99609375	False
14:02:58.191	5	1	255.99609375	False
14:02:58.211	5	1	255.99609375	False
14:02:58.231	5	1	255.99609375	False
14:02:58.251	5	1	255.99609375	False
14:02:58.271	5	1	255.99609375	False
14:02:58.291	5	1	255.99609375	False
14:02:58.311	5	1	255.99609375	False
14:02:58.331	5	1	255.99609375	False
14:02:58.351	5	1	255.99609375	False
14:02:58.371	5	1	255.99609375	False
14:02:58.391	5	1	255.99609375	False
14:02:58.411	5	1	255.99609375	False
14:02:58.431	5	1	255.99609375	False
14:02:58.451	5	1	255.99609375	False
14:02:58.471	5	1	255.99609375	False
14:02:58.491	5	1	255.99609375	False
14:02:58.511	5	1	255.99609375	False
14:02:58.531	5	1	255.99609375	False
14:02:58.551	5	1	255.99609375	False
14:02:58.571	5	1	255.99609375	False
14:02:58.591	5	1	255.99609375	False
14:02:58.611	5	1	255.99609375	False
14:02:58.631	5	1	255.99609375	False
14:02:58.651	5	1	255.99609375	False
14:02:58.671	5	1	255.99609375	False
14:02:58.691	5	1	255.99609375	False
14:02:58.711	5	1	255.99609375	False
14:02:58.731	5	1	255.99609375	False
14:02:58.751	5	1	255.99609375	False
14:02:58.771	5	1	255.99609375	False
14:02:58.791	5	1	255.99609375	False
14:02:58.811	5	1	255.99609375	False
14:02:58.831	5	1	255.99609375	False
14:02:58.851	5	1	255.99609375	False
14:02:58.871	5	1	255.99609375	False
14:02:58.891	5	1	255.99609375	False
14:02:58.911	5	1	255.99609375	False
14:02:58.931	5	1	255.99609375	False
14:02:58.951	5	1	255.99609375	False
14:02:58.971	5	1	255.99609375	False
14:02:58.991	5	1	255.99609375	False
14:02:59.011	5	1	255.99609375	False
14:02:59.031	5	1	255.99609375	False
14:02:59.051	5	1	255.99609375	False
14:02:59.071	5	1	255.99609375	False
14:02:59.091	5	1	255.99609375	False
14:02:59.111	5	1	255.99609375	False
14:02:59.131	5	1	255.99609375	False
14:02:59.151	5	1	255.99609375	False
14:02:59.171	5	1	255.99609375	False
14:02:59.191	5	1	255.99609375	False
14:02:59.211	5	1	255.99609375	False
14:02:59.231	5	1	255.99609375	False
14:02:59.251	5	1	255.99609375	False
14:02:59.271	5	1	255.99609375	False
14:02:59.291	5	1	255.99609375	False
14:02:59.311	5	1	255.99609375	False
14:02:59.331	5	1	255.99609375	False
14:02:59.351	5	1	255.99609375	False
14:02:59.371	5	1	255.99609375	False
14:02:59.391	5	1	255.99609375	False
14:02:59.411	5	1	255.99609375	False
14:02:59.431	5	1	255.99609375	False
14:02:59.451	5	1	255.99609375	False
14:02:59.471	5	1	255.99609375	False
14:02:59.491	5	1	255.99609375	False
14:02:59.511	5	1	255.99609375	False
14:02:59.531	5	1	255.99609375	False
14:02:59.551	5	1	255.99609375	False
14:02:59.571	5	1	255.99609375	False
14:02:59.591	5	1	255.99609375	False
14:02:59.611	5	1	255.99609375	False
14:02:59.631	5	1	255.99609375	False
14:02:59.651	5	1	255.99609375	False
14:02:59.671	5	1	255.99609375	False
14:02:59.691	5	1	255.99609375	False
14:02:59.711	5	1	255.99609375	False
14:02:59.731	5	1	255.99609375	False
14:02:59.751	5	1	255.99609375	False
14:02:59.771	5	1	12.09765625	True
14:02:59.791	5	1	12.09765625	True
14:02:59.811	5	1	12.09765625	True
14:02:59.831	5	1	12.09765625	True
14:02:59.851	5	1	12.09765625	True
14:02:59.871	5	1	12.0859375	False
14:02:59.891	5	1	12.09765625	False
14:02:59.911	5	1	12.09765625	False
14:02:59.931	5	1	12.09375	False
14:02:59.951	5	1	12.0859375	False
14:02:59.971	5	1	12.10546875	False
14:02:59.991	5	1	12.0859375	True
14:03:00.011	5	1	12.08203125	False
14:03:00.031	5	1	12.09375	True
14:03:00.051	5	1	12.0859375	False
14:03:00.071	5	1	12.0859375	False
14:03:00.091	5	1	12.09375	False
14:03:00.111	5	1	12.09375	True
14:03:00.131	5	1	12.09765625	False
14:03:00.151	5	1	12.09765625	False
14:03:00.171	5	1	12.09375	True
14:03:00.191	5	1	12.09375	True
14:03:00.211	5	1	12.09765625	True
14:03:00.231	5	1	12.09375	True
14:03:00.251	5	1	12.09375	True
14:03:00.271	5	1	12.09375	True
14:03:00.291	5	1	12.10546875	True
14:03:00.311	5	1	12.09765625	True
14:03:00.331	5	1	12.09765625	True
14:03:00.351	3	0.32	12.10546875	True
14:03:00.371	3	0.32	12.10546875	True
14:03:00.391	3	0.32	12.10546875	True
14:03:00.411	3	0.32	12.09765625	True
14:03:00.431	3	0.32	12.09765625	True
14:03:00.451	3	0.32	12.09765625	True
14:03:00.471	3	0.32	12.09765625	True
14:03:00.491	3	0.32	12.09765625	True
14:03:00.511	3	0.32	12.09765625	True
14:03:00.531	3	0.32	12.09375	True
14:03:00.551	3	1	255.99609375	False
14:03:00.571	3	1	255.99609375	False
14:03:00.591	3	1	255.99609375	False
14:03:00.611	3	1	255.99609375	False
14:03:00.631	3	1	255.99609375	False
14:03:00.651	3	1	255.99609375	False
14:03:00.671	3	1	255.99609375	False
14:03:00.691	3	1	255.99609375	False
14:03:00.711	3	1	255.99609375	False
14:03:00.731	3	1	255.99609375	False
14:03:00.751	3	1	255.99609375	False
14:03:00.771	3	1	255.99609375	False
14:03:00.791	3	1	255.99609375	False
14:03:00.811	3	1	255.99609375	False
14:03:00.831	3	1	255.99609375	False
14:03:00.851	3	1	255.99609375	False
14:03:00.871	3	1	255.99609375	False
14:03:00.891	3	1	255.99609375	False
14:03:00.911	3	1	255.99609375	False
14:03:00.931	3	1	255.99609375	False
14:03:00.951	3	1	255.99609375	False
14:03:00.971	3	1	255.99609375	False
14:03:00.991	3	1	255.99609375	False
14:03:01.011	3	1	255.99609375	False
14:03:01.031	3	1	255.99609375	False
14:03:01.051	3	1	255.99609375	False
14:03:01.071	3	1	255.99609375	False
14:03:01.091	3	1	255.99609375	False
14:03:01.111	3	1	255.99609375	False
14:03:01.131	3	1	255.99609375	False
14:03:01.151	3	1	255.99609375	False
14:03:01.171	3	1	255.99609375	False
14:03:01.191	3	1	255.99609375	False
14:03:01.211	3	1	255.99609375	False
14:03:01.231	3	1	255.99609375	False
14:03:01.251	3	1	255.99609375	False
14:03:01.271	3	1	255.99609375	False
14:03:01.291	3	1	255.99609375	False
14:03:01.311	3	1	255.99609375	False
14:03:01.331	3	1	255.99609375	False
14:03:01.351	3	1	255.99609375	False
14:03:01.371	3	1	255.99609375	False
14:03:01.391	3	1	255.99609375	False
14:03:01.411	3	1	255.99609375	False
14:03:01.431	3	1	255.99609375	False
14:03:01.451	3	1	255.99609375	False
14:03:01.471	3	1	255.99609375	False
14:03:01.491	3	1	255.99609375	False
14:03:01.511	3	1	255.99609375	False
14:03:01.531	3	1	255.99609375	False
14:03:01.551	3	1	255.99609375	False
14:03:01.571	3	1	255.99609375	False
14:03:01.591	3	1	255.99609375	False
14:03:01.611	3	1	255.99609375	False
14:03:01.631	3	1	255.99609375	False
14:03:01.651	3	1	255.99609375	False
14:03:01.671	3	1	255.99609375	False
14:03:01.691	3	1	255.99609375	False
14:03:01.711	3	1	255.99609375	False
14:03:01.731	3	1	255.99609375	False
14:03:01.751	3	1	255.99609375	False
14:03:01.771	3	1	255.99609375	False
14:03:01.791	3	1	255.99609375	False
14:03:01.811	3	1	255.99609375	False
14:03:01.831	3	1	255.99609375	False
14:03:01.851	3	1	255.99609375	False
14:03:01.871	3	1	255.99609375	False
14:03:01.891	3	1	255.99609375	False
14:03:01.911	3	1	255.99609375	False
14:03:01.931	3	1	255.99609375	False
14:03:01.951	3	1	255.99609375	False
14:03:01.971	3	1	255.99609375	False
14:03:01.991	3	1	255.99609375	False
14:03:02.011	3	1	255.99609375	False
14:03:02.031	3	1	255.99609375	False
14:03:02.051	3	1	255.99609375	False
14:03:02.071	3	1	255.99609375	False
14:03:02.091	3	1	255.99609375	False
14:03:02.111	3	1	255.99609375	False
14:03:02.131	3	1	255.99609375	False
14:03:02.151	3	1	255.99609375	False
14:03:02.171	3	1	255.99609375	False
14:03:02.191	3	1	255.99609375	False
14:03:02.211	3	1	255.99609375	False
14:03:02.231	3	1	255.99609375	False
14:03:02.251	3	1	255.99609375	False
14:03:02.271	3	1	255.99609375	False
14:03:02.291	3	1	255.99609375	False
14:03:02.311	3	1	255.99609375	False
14:03:02.331	3	1	255.99609375	False
14:03:02.351	3	1	255.99609375	False
14:03:02.371	3	1	255.99609375	False
14:03:02.391	3	1	255.99609375	False
14:03:02.411	3	1	255.99609375	False
14:03:02.431	3	1	255.99609375	False
14:03:02.451	3	1	255.99609375	False
14:03:02.471	3	1	255.99609375	False
14:03:02.491	3	1	255.99609375	False
14:03:02.511	3	1	255.99609375	False
14:03:02.531	3	1	255.99609375	False
14:03:02.551	3	1	255.99609375	False
14:03:02.571	3	1	255.99609375	False
14:03:02.591	3	1	255.99609375	False
14:03:02.611	3	1	255.99609375	False
14:03:02.631	3	1	255.99609375	False
14:03:02.651	3	1	255.99609375	False
14:03:02.671	3	1	255.99609375	False
14:03:02.691	3	1	255.99609375	False
14:03:02.711	3	1	255.99609375	False
14:03:02.731	3	1	255.99609375	False
14:03:02.751	3	1	255.99609375	False
14:03:02.771	3	1	255.99609375	False
14:03:02.791	3	1	255.99609375	False
14:03:02.811	3	1	12.09765625	True
14:03:02.831	3	1	12.09765625	True
14:03:02.851	3	1	12.09765625	True
14:03:02.871	3	1	12.09765625	True
14:03:02.891	3	1	12.09765625	True
14:03:02.911	3	1	12.09375	False
14:03:02.931	3	1	12.0859375	False
14:03:02.951	3	1	12.09765625	False
14:03:02.971	3	1	12.09375	False
14:03:02.991	3	1	12.0859375	False
14:03:03.011	3	1	12.0859375	False
14:03:03.031	3	1	12.09375	False
14:03:03.051	3	1	12.09375	False
14:03:03.071	3	1	12.0859375	False
14:03:03.091	3	1	12.0859375	False
14:03:03.111	3	1	12.09765625	False
14:03:03.131	3	1	12.09375	False
14:03:03.151	3	1	12.09375	False
14:03:03.171	3	1	12.09375	True
14:03:03.191	3	1	12.09375	False
14:03:03.211	3	1	12.08203125	False
14:03:03.231	3	1	12.09375	True
14:03:03.251	3	1	12.09375	True
14:03:03.271	3	1	12.0859375	True
14:03:03.291	3	1	12.09765625	True
14:03:03.311	3	1	12.10546875	True
14:03:03.331	3	1	12.11328125	True
14:03:03.351	3	1	12.10546875	True
14:03:03.371	3	1	12.09765625	True
14:03:03.391	3	1	12.09765625	True
14:03:03.411	3	0.32	12.09765625	True
14:03:03.431	3	0.32	12.11328125	True
14:03:03.451	3	0.32	12.10546875	True
14:03:03.471	3	0.32	12.09765625	True
14:03:03.491	3	0.32	12.10546875	True
14:03:03.511	3	0.32	12.10546875	True
14:03:03.531	3	0.32	12.08203125	True
14:03:03.551	3	0.32	12.0859375	True
14:03:03.571	3	0.32	12.09765625	True
14:03:03.591	3	0.32	12.09765625	True
14:03:03.611	3	0.32	12.0859375	True
14:03:03.631	3	0.32	12.09765625	True
14:03:03.651	3	0.32	12.0859375	True
14:03:03.671	3	1	255.99609375	False
14:03:03.691	3	1	255.99609375	False
14:03:03.711	3	1	255.99609375	False
14:03:03.731	3	1	255.99609375	False
14:03:03.751	3	1	255.99609375	False
14:03:03.771	3	1	255.99609375	False
14:03:03.791	3	1	255.99609375	False
14:03:03.811	3	1	255.99609375	False
14:03:03.831	3	1	255.99609375	False
14:03:03.851	3	1	255.99609375	False
14:03:03.871	3	1	255.99609375	False
14:03:03.891	3	1	255.99609375	False
14:03:03.911	3	1	255.99609375	False
14:03:03.931	3	1	255.99609375	False
14:03:03.951	3	1	255.99609375	False
14:03:03.971	3	1	255.99609375	False
14:03:03.991	3	1	255.99609375	False
14:03:04.011	3	1	255.99609375	False
14:03:04.031	3	1	255.99609375	False
14:03:04.051	3	1	255.99609375	False
14:03:04.071	3	1	255.99609375	False
14:03:04.091	3	1	255.99609375	False
14:03:04.111	3	1	255.99609375	False
14:03:04.131	3	1	255.99609375	False
14:03:04.151	3	1	255.99609375	False
14:03:04.171	3	1	255.99609375	False
14:03:04.191	3	1	255.99609375	False
14:03:04.211	3	1	255.99609375	False
14:03:04.231	3	1	255.99609375	False
14:03:04.251	3	1	255.99609375	False
14:03:04.271	3	1	255.99609375	False
14:03:04.291	3	1	255.99609375	False
14:03:04.311	3	1	255.99609375	False
14:03:04.331	3	1	255.99609375	False
14:03:04.351	3	1	255.99609375	False
14:03:04.371	3	1	255.99609375	False
14:03:04.391	3	1	255.99609375	False
14:03:04.411	3	1	255.99609375	False
14:03:04.431	3	1	255.99609375	False
14:03:04.451	3	1	255.99609375	False
14:03:04.471	3	1	255.99609375	False
14:03:04.491	3	1	255.99609375	False
14:03:04.511	3	1	255.99609375	False
14:03:04.531	3	1	255.99609375	False
14:03:04.551	3	1	255.99609375	False
14:03:04.571	3	1	255.99609375	False
14:03:04.591	3	1	255.99609375	False
14:03:04.611	3	1	255.99609375	False
14:03:04.631	3	1	255.99609375	False
14:03:04.651	3	1	255.99609375	False
14:03:04.671	3	1	255.99609375	False
14:03:04.691	3	1	255.99609375	False
14:03:04.711	3	1	255.99609375	False
14:03:04.731	3	1	255.99609375	False
14:03:04.751	3	1	255.99609375	False
14:03:04.771	3	1	255.99609375	False
14:03:04.791	3	1	255.99609375	False
14:03:04.811	3	1	255.99609375	False
14:03:04.831	3	1	255.99609375	False
14:03:04.851	3	1	255.99609375	False
14:03:04.871	3	1	255.99609375	False
14:03:04.891	3	1	255.99609375	False
14:03:04.911	3	1	255.99609375	False
14:03:04.931	3	1	255.99609375	False
14:03:04.951	3	1	255.99609375	False
14:03:04.971	3	1	255.99609375	False
14:03:04.991	3	1	255.99609375	False
14:03:05.011	3	1	255.99609375	False
14:03:05.031	3	1	255.99609375	False
14:03:05.051	3	1	255.99609375	False
14:03:05.071	3	1	255.99609375	False
14:03:05.091	3	1	255.99609375	False
14:03:05.111	3	1	255.99609375	False
14:03:05.131	3	1	255.99609375	False
14:03:05.151	3	1	255.99609375	False
14:03:05.171	3	1	255.99609375	False
14:03:05.191	3	1	255.99609375	False
14:03:05.211	3	1	255.99609375	False
14:03:05.231	3	1	255.99609375	False
14:03:05.251	3	1	255.99609375	False
14:03:05.271	3	1	255.99609375	False
14:03:05.291	3	1	255.99609375	False
14:03:05.311	3	1	255.99609375	False
14:03:05.331	3	1	255.99609375	False
14:03:05.351	3	1	255.99609375	False
14:03:05.371	3	1	255.99609375	False
14:03:05.391	3	1	255.99609375	False
14:03:05.411	3	1	255.99609375	False
14:03:05.431	3	1	255.99609375	False
14:03:05.451	3	1	255.99609375	False
14:03:05.471	3	1	255.99609375	False
14:03:05.491	3	1	255.99609375	False
14:03:05.511	3	1	255.99609375	False
14:03:05.531	3	1	255.99609375	False
14:03:05.551	3	1	255.99609375	False
14:03:05.571	3	1	255.99609375	False
14:03:05.591	3	1	255.99609375	False
14:03:05.611	3	1	255.99609375	False
14:03:05.631	3	1	255.99609375	False
14:03:05.651	3	1	255.99609375	False
14:03:05.671	3	1	255.99609375	False
14:03:05.691	3	1	255.99609375	False
14:03:05.711	3	1	255.99609375	False
14:03:05.731	3	1	255.99609375	False
14:03:05.751	3	1	255.99609375	False
14:03:05.771	3	1	255.99609375	False
14:03:05.791	3	1	255.99609375	False
14:03:05.811	3	1	255.99609375	False
14:03:05.831	3	1	255.99609375	False
14:03:05.851	3	1	255.99609375	False
14:03:05.871	3	1	12.09375	True
14:03:05.891	3	1	12.09375	True
14:03:05.911	3	1	12.09375	True
14:03:05.931	3	1	12.09375	True
14:03:05.951	3	1	12.09375	True
14:03:05.971	3	1	12.09765625	False
14:03:05.991	3	1	12.09375	False
14:03:06.011	3	1	12.10546875	False
14:03:06.031	3	1	12.10546875	False
14:03:06.051	3	1	12.10546875	False
14:03:06.071	3	1	12.09765625	False
14:03:06.091	3	1	12.09765625	False
14:03:06.111	3	1	12.10546875	False
14:03:06.131	3	1	12.09765625	False
14:03:06.151	3	1	12.09765625	False
14:03:06.171	3	1	12.09765625	False
14:03:06.191	3	1	12.09765625	False
14:03:06.211	3	1	12.10546875	True
14:03:06.231	3	1	12.09765625	True
14:03:06.251	3	1	12.09765625	False
14:03:06.271	3	1	12.10546875	False
14:03:06.291	3	1	12.10546875	False
14:03:06.311	3	1	12.10546875	False
14:03:06.331	3	1	12.09765625	False
14:03:06.351	3	1	12.09765625	False
14:03:06.371	3	1	12.10546875	False
14:03:06.391	3	1	12.10546875	True
14:03:06.411	3	1	12.11328125	False
14:03:06.431	3	1	12.11328125	False
14:03:06.451	3	1	12.11328125	False
14:03:06.471	3	1	12.09765625	True
14:03:06.491	3	1	12.09765625	False
14:03:06.511	3	1	12.11328125	False
14:03:06.531	3	1	12.09375	False
14:03:06.551	3	1	12.10546875	False
14:03:06.571	3	1	12.09375	False
14:03:06.591	3	1	12.09765625	False
14:03:06.611	3	1	12.09765625	False
14:03:06.631	3	1	12.10546875	True
14:03:06.651	3	1	12.10546875	True
14:03:06.671	3	1	12.09765625	True
14:03:06.691	3	1	12.11328125	True
14:03:06.711	3	1	12.0859375	True
14:03:06.731	4.5	0.28	12.09765625	True
14:03:06.751	4.5	0.28	12.09375	True
14:03:06.771	4.5	0.28	12.09375	True
14:03:06.791	4.5	0.28	12.09765625	True
14:03:06.811	4.5	0.28	12.09375	True
14:03:06.831	4.5	0.28	12.09375	True
14:03:06.851	4.5	0.28	12.09765625	True
14:03:06.871	4.5	0.28	12.09765625	True
14:03:06.891	4.5	0.28	12.09765625	True
14:03:06.911	4.5	0.28	12.09375	True
14:03:06.931	4.5	0.28	12.09375	True
14:03:06.951	4.5	0.28	12.10546875	True
14:03:06.971	4.5	0.28	12.09765625	True
14:03:06.991	4.5	0.28	12.09765625	True
14:03:07.011	4.5	0.28	12.10546875	True
14:03:07.031	4.5	1	255.99609375	False
14:03:07.051	4.5	1	255.99609375	False
14:03:07.071	4.5	1	255.99609375	False
14:03:07.091	4.5	1	255.99609375	False
14:03:07.111	4.5	1	255.99609375	False
14:03:07.131	4.5	1	255.99609375	False
14:03:07.151	4.5	1	255.99609375	False
14:03:07.171	4.5	1	255.99609375	False
14:03:07.191	4.5	1	255.99609375	False
14:03:07.211	4.5	1	255.99609375	False
14:03:07.231	4.5	1	255.99609375	False
14:03:07.251	4.5	1	255.99609375	False
14:03:07.271	4.5	1	255.99609375	False
14:03:07.291	4.5	1	255.99609375	False
14:03:07.311	4.5	1	255.99609375	False
14:03:07.331	4.5	1	255.99609375	False
14:03:07.351	4.5	1	255.99609375	False
14:03:07.371	4.5	1	255.99609375	False
14:03:07.391	4.5	1	255.99609375	False
14:03:07.411	4.5	1	255.99609375	False
14:03:07.431	4.5	1	255.99609375	False
14:03:07.451	4.5	1	255.99609375	False
14:03:07.471	4.5	1	255.99609375	False
14:03:07.491	4.5	1	255.99609375	False
14:03:07.511	4.5	1	255.99609375	False
14:03:07.531	4.5	1	255.99609375	False
14:03:07.551	4.5	1	255.99609375	False
14:03:07.571	4.5	1	255.99609375	False
14:03:07.591	4.5	1	255.99609375	False
14:03:07.611	4.5	1	255.99609375	False
14:03:07.631	4.5	1	255.99609375	False
14:03:07.651	4.5	1	255.99609375	False
14:03:07.671	4.5	1	255.99609375	False
14:03:07.691	4.5	1	255.99609375	False
14:03:07.711	4.5	1	255.99609375	False
14:03:07.731	4.5	1	255.99609375	False
14:03:07.751	4.5	1	255.99609375	False
14:03:07.771	4.5	1	255.99609375	False
14:03:07.791	4.5	1	255.99609375	False
14:03:07.811	4.5	1	255.99609375	False
14:03:07.831	4.5	1	255.99609375	False
14:03:07.851	4.5	1	255.99609375	False
14:03:07.871	4.5	1	255.99609375	False
14:03:07.891	4.5	1	255.99609375	False
14:03:07.911	4.5	1.04	255.99609375	False
14:03:07.931	4.5	1.04	255.99609375	False
14:03:07.951	4.5	1.04	255.99609375	False
14:03:07.971	4.5	1.04	255.99609375	False
14:03:07.991	4.5	1.04	255.99609375	False
14:03:08.011	4.5	1.04	255.99609375	False
14:03:08.031	4.5	1.04	255.99609375	False
14:03:08.051	4.5	1.04	255.99609375	False
14:03:08.071	4.5	1.04	255.99609375	False
14:03:08.091	4.5	1.04	255.99609375	False
14:03:08.111	4.5	1.04	255.99609375	False
14:03:08.131	4.5	1.04	255.99609375	False
14:03:08.151	4.5	1.04	255.99609375	False
14:03:08.171	4.5	1.04	255.99609375	False
14:03:08.191	4.5	1.04	255.99609375	False
14:03:08.211	4.5	1.04	255.99609375	False
14:03:08.231	4.5	1.04	255.99609375	False
14:03:08.251	4.5	1.04	255.99609375	False
14:03:08.271	4.5	1.04	255.99609375	False
14:03:08.291	4.5	1.04	255.99609375	False
14:03:08.311	4.5	1.04	255.99609375	False
14:03:08.331	4.5	1.04	255.99609375	False
14:03:08.351	4.5	1.04	255.99609375	False
14:03:08.371	4.5	1.04	255.99609375	False
14:03:08.391	4.5	1.04	255.99609375	False
14:03:08.411	4.5	1	255.99609375	False
14:03:08.431	4.5	1	255.99609375	False
14:03:08.451	4.5	1	255.99609375	False
14:03:08.471	4.5	1	255.99609375	False
14:03:08.491	4.5	1	255.99609375	False
14:03:08.511	4.5	1	255.99609375	False
14:03:08.531	4.5	1	255.99609375	False
14:03:08.551	4.5	1	255.99609375	False
14:03:08.571	4.5	1	255.99609375	False
14:03:08.591	4.5	1	255.99609375	False
14:03:08.611	4.5	1	255.99609375	False
14:03:08.631	4.5	1	255.99609375	False
14:03:08.651	4.5	1	255.99609375	False
14:03:08.671	4.5	1	255.99609375	False
14:03:08.691	4.5	1	255.99609375	False
14:03:08.711	4.5	1	255.99609375	False
14:03:08.731	4.5	1	255.99609375	False
14:03:08.751	4.5	1	255.99609375	False
14:03:08.771	4.5	1	255.99609375	False
14:03:08.791	4.5	1	255.99609375	False
14:03:08.811	4.5	1	255.99609375	False
14:03:08.831	4.5	1	255.99609375	False
14:03:08.851	4.5	1	255.99609375	False
14:03:08.871	4.5	1	255.99609375	False
14:03:08.891	4.5	1	255.99609375	False
14:03:08.911	4.5	1	12.09765625	True
14:03:08.931	4.5	1	12.09765625	True
14:03:08.951	4.5	1	12.09765625	True
14:03:08.971	4.5	1	12.09765625	True
14:03:08.991	4.5	1	12.09765625	True
14:03:09.011	4.5	1	12.09765625	True
14:03:09.031	4.5	1	12.09765625	True
14:03:09.051	4.5	1	12.09765625	True
14:03:09.071	4.5	1	12.09765625	True
14:03:09.091	4.5	1	12.09765625	False
14:03:09.111	4.5	1	12.09375	False
14:03:09.131	4.5	1	12.09375	False
14:03:09.151	4.5	1	12.09765625	False
14:03:09.171	4.5	1	12.09375	True
14:03:09.191	4.5	1	12.09375	True
14:03:09.211	4.5	0.36	12.09375	False
14:03:09.231	4.5	0.36	12.09375	True
14:03:09.251	4.5	0.36	12.0859375	True
14:03:09.271	4.5	0.36	12.09765625	True
14:03:09.291	4.5	0.36	12.0859375	True
14:03:09.311	4.5	0.36	12.09765625	True
14:03:09.331	4.5	0.36	12.10546875	True
14:03:09.351	4.5	0.36	12.09375	True
14:03:09.371	4.5	0.36	12.09765625	True
14:03:09.391	4.5	0.36	12.09765625	True
14:03:09.411	4.5	0.36	12.09765625	True
14:03:09.431	4.5	0.36	12.11328125	True
14:03:09.451	4.5	0.36	12.10546875	True
14:03:09.471	4.5	0.36	12.09765625	True
14:03:09.491	4.5	0.36	12.09765625	True
14:03:09.511	4.5	0.36	12.09375	True
14:03:09.531	4.5	1.08	255.99609375	False
14:03:09.551	4.5	1.08	255.99609375	False
14:03:09.571	4.5	1.08	255.99609375	False
14:03:09.591	4.5	1.08	255.99609375	False
14:03:09.611	4.5	1.08	255.99609375	False
14:03:09.631	4.5	1.08	255.99609375	False
14:03:09.651	4.5	1.08	255.99609375	False
14:03:09.671	4.5	1.08	255.99609375	False
14:03:09.691	4.5	1.08	255.99609375	False
14:03:09.711	4.5	1.08	255.99609375	False
14:03:09.731	4.5	1.08	255.99609375	False
14:03:09.751	4.5	1.08	255.99609375	False
14:03:09.771	4.5	1.08	255.99609375	False
14:03:09.791	4.5	1.08	255.99609375	False
14:03:09.811	4.5	1.08	255.99609375	False
14:03:09.831	4.5	1.08	255.99609375	False
14:03:09.851	4.5	1.08	255.99609375	False
14:03:09.871	4.5	1.08	255.99609375	False
14:03:09.891	4.5	1.08	255.99609375	False
14:03:09.911	4.5	1.08	255.99609375	False
14:03:09.931	4.5	1	255.99609375	False
14:03:09.951	4.5	1	255.99609375	False
14:03:09.971	4.5	1	255.99609375	False
14:03:09.991	4.5	1	255.99609375	False
14:03:10.011	4.5	1	255.99609375	False
14:03:10.031	4.5	1	255.99609375	False
14:03:10.051	4.5	1	255.99609375	False
14:03:10.071	4.5	1	255.99609375	False
14:03:10.091	4.5	1	255.99609375	False
14:03:10.111	4.5	1	255.99609375	False
14:03:10.131	4.5	1	255.99609375	False
14:03:10.151	4.5	1	255.99609375	False
14:03:10.171	4.5	1	255.99609375	False
14:03:10.191	4.5	1	255.99609375	False
14:03:10.211	4.5	1	255.99609375	False
14:03:10.231	4.5	1	255.99609375	False
14:03:10.251	4.5	1	255.99609375	False
14:03:10.271	4.5	1	255.99609375	False
14:03:10.291	4.5	1	255.99609375	False
14:03:10.311	4.5	1	255.99609375	False
14:03:10.331	4.5	1	255.99609375	False
14:03:10.351	4.5	1	255.99609375	False
14:03:10.371	4.5	1	255.99609375	False
14:03:10.391	4.5	1	255.99609375	False
14:03:10.411	4.5	1	255.99609375	False
14:03:10.431	4.5	1	255.99609375	False
14:03:10.451	4.5	1	255.99609375	False
14:03:10.471	4.5	1	255.99609375	False
14:03:10.491	4.5	1	255.99609375	False
14:03:10.511	4.5	1	255.99609375	False
14:03:10.531	4.5	1	255.99609375	False
14:03:10.551	4.5	1	255.99609375	False
14:03:10.571	4.5	1	255.99609375	False
14:03:10.591	4.5	1	255.99609375	False
14:03:10.611	4.5	1	255.99609375	False
14:03:10.631	4.5	1	255.99609375	False
14:03:10.651	4.5	1	255.99609375	False
14:03:10.671	4.5	1	255.99609375	False
14:03:10.691	4.5	1	255.99609375	False
14:03:10.711	4.5	1	255.99609375	False
14:03:10.731	4.5	1	255.99609375	False
14:03:10.751	4.5	1	255.99609375	False
14:03:10.771	4.5	1	255.99609375	False
14:03:10.791	4.5	1	255.99609375	False
14:03:10.811	4.5	1	255.99609375	False
14:03:10.831	4.5	1	255.99609375	False
14:03:10.851	4.5	1	255.99609375	False
14:03:10.871	4.5	1	255.99609375	False
14:03:10.891	4.5	1	255.99609375	False
14:03:10.911	4.5	1	255.99609375	False
14:03:10.931	4.5	1	255.99609375	False
14:03:10.951	4.5	1	255.99609375	False
14:03:10.971	4.5	1	255.99609375	False
14:03:10.991	4.5	1	255.99609375	False
14:03:11.011	4.5	1	255.99609375	False
14:03:11.031	4.5	1	255.99609375	False
14:03:11.051	4.5	1	255.99609375	False
14:03:11.071	4.5	1	255.99609375	False
14:03:11.091	4.5	1	255.99609375	False
14:03:11.111	4.5	1	255.99609375	False
14:03:11.131	4.5	1	255.99609375	False
14:03:11.151	4.5	1	255.99609375	False
14:03:11.171	4.5	1	255.99609375	False
14:03:11.191	4.5	1	255.99609375	False
14:03:11.211	4.5	1	255.99609375	False
14:03:11.231	4.5	1	255.99609375	False
14:03:11.251	4.5	1	255.99609375	False
14:03:11.271	4.5	1	255.99609375	False
14:03:11.291	4.5	1	255.99609375	False
14:03:11.311	4.5	1	255.99609375	False
14:03:11.331	4.5	1	255.99609375	False
14:03:11.351	4.5	1	255.99609375	False
14:03:11.371	4.5	1	255.99609375	False
14:03:11.391	4.5	1	255.99609375	False
14:03:11.411	4.5	1	255.99609375	False
14:03:11.431	4.5	1	255.99609375	False
14:03:11.451	4.5	1	255.99609375	False
14:03:11.471	4.5	1	255.99609375	False
14:03:11.491	4.5	1	255.99609375	False
14:03:11.511	4.5	1	255.99609375	False
14:03:11.531	4.5	1	255.99609375	False
14:03:11.551	4.5	1	255.99609375	False
14:03:11.571	4.5	1	255.99609375	False
14:03:11.591	4.5	1	255.99609375	False
14:03:11.611	4.5	1	255.99609375	False
14:03:11.631	4.5	1	255.99609375	False
14:03:11.651	4.5	1	255.99609375	False
14:03:11.671	4.5	1	255.99609375	False
14:03:11.691	4.5	1	255.99609375	False
14:03:11.711	4.5	1	255.99609375	False
14:03:11.731	4.5	1	255.99609375	False
14:03:11.751	4.5	1	255.99609375	False
14:03:11.771	4.5	1	255.99609375	False
14:03:11.791	4.5	1	255.99609375	False
14:03:11.811	4.5	1	255.99609375	False
14:03:11.831	4.5	1	255.99609375	False
14:03:11.851	4.5	1	255.99609375	False
14:03:11.871	4.5	1	255.99609375	False
14:03:11.891	4.5	1	255.99609375	False
14:03:11.911	4.5	1	255.99609375	False
14:03:11.931	4.5	1	255.99609375	False
14:03:11.951	4.5	0.32	12.09765625	True
14:03:11.971	4.5	0.32	12.09765625	True
14:03:11.991	4.5	0.32	12.09765625	True
14:03:12.011	4.5	0.32	12.09765625	True
14:03:12.031	4.5	0.32	12.09765625	True
14:03:12.051	4.5	0.32	12.09765625	True
14:03:12.071	4.5	0.32	12.09765625	True
14:03:12.091	4.5	0.32	12.09765625	True
14:03:12.111	4.5	0.32	12.09375	False
14:03:12.131	4.5	0.32	12.10546875	False
14:03:12.151	4.5	0.32	12.11328125	False
14:03:12.171	4.5	0.32	12.09375	False
14:03:12.191	4.5	0.32	12.09375	False
14:03:12.211	4.5	0.32	12.09375	False
14:03:12.231	4.5	0.32	12.09375	False
14:03:12.251	4.5	0.32	12.09375	False
14:03:12.271	4.5	0.32	12.09765625	False
14:03:12.291	4.5	0.32	12.08203125	True
14:03:12.311	4.5	0.32	12.09765625	False
14:03:12.331	4.5	0.32	12.09765625	True
14:03:12.351	4.5	0.32	12.09375	False
14:03:12.371	4.5	0.32	12.09375	False
14:03:12.391	4.5	0.32	12.10546875	False
14:03:12.411	4.5	0.32	12.09765625	False
14:03:12.431	4.5	0.32	12.10546875	False
14:03:12.451	4.5	0.32	12.09765625	False
14:03:12.471	4.5	0.32	12.09375	True
14:03:12.491	4.5	0.32	12.10546875	True
14:03:12.511	4.5	0.32	12.09765625	True
14:03:12.531	4.5	0.32	12.09765625	True
14:03:12.551	4.5	0.32	12.09765625	True
14:03:12.571	4.5	0.32	12.09375	True
14:03:12.591	4.5	0.32	12.10546875	True
14:03:12.611	4.5	0.32	12.11328125	True
14:03:12.631	4.5	0.32	12.10546875	True
14:03:12.651	4.5	0.32	12.09375	True
14:03:12.671	4.5	0.32	12.0859375	True
14:03:12.691	4.5	0.32	12.09375	True
14:03:12.711	4.5	0.32	12.09375	True
14:03:12.731	4.5	0.32	12.09765625	True
14:03:12.751	4.5	0.32	12.08203125	True
14:03:12.771	4.5	0.32	12.09765625	True
14:03:12.791	4.5	0.32	12.0859375	True
14:03:12.811	4.5	0.32	12.09765625	True
14:03:12.831	3.5	1.12	255.99609375	False
14:03:12.851	3.5	1.12	255.99609375	False
14:03:12.871	3.5	1.12	255.99609375	False
14:03:12.891	3.5	1.12	255.99609375	False
14:03:12.911	3.5	1.12	255.99609375	False
14:03:12.931	3.5	1.12	255.99609375	False
14:03:12.951	3.5	1.12	255.99609375	False
14:03:12.971	3.5	1.12	255.99609375	False
14:03:12.991	3.5	1.12	255.99609375	False
14:03:13.011	3.5	1	255.99609375	False
14:03:13.031	3.5	1	255.99609375	False
14:03:13.051	3.5	1	255.99609375	False
14:03:13.071	3.5	1	255.99609375	False
14:03:13.091	3.5	1	255.99609375	False
14:03:13.111	3.5	1	255.99609375	False
14:03:13.131	3.5	1	255.99609375	False
14:03:13.151	3.5	1	255.99609375	False
14:03:13.171	3.5	1	255.99609375	False
14:03:13.191	3.5	1	255.99609375	False
14:03:13.211	3.5	1	255.99609375	False
14:03:13.231	3.5	1	255.99609375	False
14:03:13.251	3.5	1	255.99609375	False
14:03:13.271	3.5	1	255.99609375	False
14:03:13.291	3.5	1	255.99609375	False
14:03:13.311	3.5	1	255.99609375	False
14:03:13.331	3.5	1	255.99609375	False
14:03:13.351	3.5	1	255.99609375	False
14:03:13.371	3.5	1	255.99609375	False
14:03:13.391	3.5	1	255.99609375	False
14:03:13.411	3.5	1	255.99609375	False
14:03:13.431	3.5	1	255.99609375	False
14:03:13.451	3.5	1	255.99609375	False
14:03:13.471	3.5	1	255.99609375	False
14:03:13.491	3.5	1	255.99609375	False
14:03:13.511	3.5	1	255.99609375	False
14:03:13.531	3.5	1	255.99609375	False
14:03:13.551	3.5	1	255.99609375	False
14:03:13.571	3.5	1	255.99609375	False
14:03:13.591	3.5	1	255.99609375	False
14:03:13.611	3.5	1	255.99609375	False
14:03:13.631	3.5	1	255.99609375	False
14:03:13.651	3.5	1	255.99609375	False
14:03:13.671	3.5	1	255.99609375	False
14:03:13.691	3.5	1	255.99609375	False
14:03:13.711	3.5	1	255.99609375	False
14:03:13.731	3.5	1	255.99609375	False
14:03:13.751	3.5	1	255.99609375	False
14:03:13.771	3.5	1	255.99609375	False
14:03:13.791	3.5	1	255.99609375	False
14:03:13.811	3.5	1	255.99609375	False
14:03:13.831	3.5	1	255.99609375	False
14:03:13.851	3.5	1	255.99609375	False
14:03:13.871	3.5	1	255.99609375	False
14:03:13.891	3.5	1	255.99609375	False
14:03:13.911	3.5	1	255.99609375	False
14:03:13.931	3.5	1	255.99609375	False
14:03:13.951	3.5	1	255.99609375	False
14:03:13.971	3.5	1	255.99609375	False
14:03:13.991	3.5	1	255.99609375	False
14:03:14.011	3.5	1.08	255.99609375	False
14:03:14.031	3.5	1.08	255.99609375	False
14:03:14.051	3.5	1.08	255.99609375	False
14:03:14.071	3.5	1.08	255.99609375	False
14:03:14.091	3.5	1.08	255.99609375	False
14:03:14.111	3.5	1.08	255.99609375	False
14:03:14.131	3.5	1.08	255.99609375	False
14:03:14.151	3.5	1.08	255.99609375	False
14:03:14.171	3.5	1.08	255.99609375	False
14:03:14.191	3.5	1.08	255.99609375	False
14:03:14.211	3.5	1.08	255.99609375	False
14:03:14.231	3.5	1.08	255.99609375	False
14:03:14.251	3.5	1.08	255.99609375	False
14:03:14.271	3.5	1.08	255.99609375	False
14:03:14.291	3.5	1.08	255.99609375	False
14:03:14.311	3.5	1.08	255.99609375	False
14:03:14.331	3.5	1.08	255.99609375	False
14:03:14.351	3.5	1.08	255.99609375	False
14:03:14.371	3.5	1.08	255.99609375	False
14:03:14.391	3.5	1.08	255.99609375	False
14:03:14.411	3.5	1.08	255.99609375	False
14:03:14.431	3.5	1.08	255.99609375	False
14:03:14.451	3.5	1.08	255.99609375	False
14:03:14.471	3.5	1.08	255.99609375	False
14:03:14.491	3.5	1.08	255.99609375	False
14:03:14.511	3.5	1.08	255.99609375	False
14:03:14.531	3.5	1	255.99609375	False
14:03:14.551	3.5	1	255.99609375	False
14:03:14.571	3.5	1	255.99609375	False
14:03:14.591	3.5	1	255.99609375	False
14:03:14.611	3.5	1	255.99609375	False
14:03:14.631	3.5	1	255.99609375	False
14:03:14.651	3.5	1	255.99609375	False
14:03:14.671	3.5	1	255.99609375	False
14:03:14.691	3.5	1	255.99609375	False
14:03:14.711	3.5	1	255.99609375	False
14:03:14.731	3.5	1	255.99609375	False
14:03:14.751	3.5	1	255.99609375	False
14:03:14.771	3.5	1	255.99609375	False
14:03:14.791	3.5	1	255.99609375	False
14:03:14.811	3.5	1	255.99609375	False
14:03:14.831	3.5	1	255.99609375	False
14:03:14.851	3.5	1	255.99609375	False
14:03:14.871	3.5	1	255.99609375	False
14:03:14.891	3.5	1	255.99609375	False
14:03:14.911	3.5	1	255.99609375	False
14:03:14.931	3.5	1	255.99609375	False
14:03:14.951	3.5	1	255.99609375	False
14:03:14.971	3.5	1	255.99609375	False
14:03:14.991	3.5	1	255.99609375	False
14:03:15.011	3.5	1	255.99609375	False
14:03:15.031	3.5	0.24	12.09375	True
14:03:15.051	3.5	0.24	12.09375	True
14:03:15.071	3.5	0.24	12.09375	True
14:03:15.091	3.5	0.24	12.09375	True
14:03:15.111	3.5	0.24	12.09375	True
14:03:15.131	3.5	0.24	12.09375	True
14:03:15.151	3.5	0.24	12.09375	True
14:03:15.171	3.5	0.24	12.09765625	False
14:03:15.191	3.5	0.24	12.10546875	False
14:03:15.211	3.5	0.24	12.09765625	False
14:03:15.231	3.5	0.24	12.09375	False
14:03:15.251	3.5	0.24	12.10546875	False
14:03:15.271	3.5	0.24	12.09375	False
14:03:15.291	3.5	0.24	12.09765625	True
14:03:15.311	3.5	0.24	12.09765625	True
14:03:15.331	3.5	0.24	12.09765625	False
14:03:15.351	3.5	0.24	12.09375	True
14:03:15.371	3.5	0.24	12.09375	False
14:03:15.391	3.5	0.24	12.10546875	False
14:03:15.411	3.5	0.24	12.09375	False
14:03:15.431	3.5	0.24	12.09375	True
14:03:15.451	3.5	0.24	12.09765625	False
14:03:15.471	3.5	0.24	12.0859375	False
14:03:15.491	3.5	0.24	12.0859375	True
14:03:15.511	3.5	0.24	12.10546875	True
14:03:15.531	3.5	0.24	12.0859375	True
14:03:15.551	3.5	0.24	12.09375	True
14:03:15.571	3.5	0.24	12.09375	True
14:03:15.591	3.5	0.24	12.10546875	True
14:03:15.611	3.5	0.24	12.09375	True
14:03:15.631	3.5	0.24	12.0859375	True
14:03:15.651	3.5	0.24	12.09375	True
14:03:15.671	3.5	0.24	12.09765625	True
14:03:15.691	3.5	0.24	12.09765625	True
14:03:15.711	3.5	0.24	12.10546875	True
14:03:15.731	3.5	0.24	12.10546875	True
14:03:15.751	3.5	0.24	12.09765625	True
14:03:15.771	3.5	0.24	12.09765625	True
14:03:15.791	3	1.12	255.99609375	False
14:03:15.811	3	1.12	255.99609375	False
14:03:15.831	3	1.12	255.99609375	False
14:03:15.851	3	1.12	255.99609375	False
14:03:15.871	3	1.12	255.99609375	False
14:03:15.891	3	1.12	255.99609375	False
14:03:15.911	3	1.12	255.99609375	False
14:03:15.931	3	1.12	255.99609375	False
14:03:15.951	3	1.12	255.99609375	False
14:03:15.971	3	1.12	255.99609375	False
14:03:15.991	3	1.12	255.99609375	False
14:03:16.011	3	1.12	255.99609375	False
14:03:16.031	3	1.04	255.99609375	False
14:03:16.051	3	1.04	255.99609375	False
14:03:16.071	3	1.04	255.99609375	False
14:03:16.091	3	1.04	255.99609375	False
14:03:16.111	3	1.04	255.99609375	False
14:03:16.131	3	1.04	255.99609375	False
14:03:16.151	3	1.04	255.99609375	False
14:03:16.171	3	1.04	255.99609375	False
14:03:16.191	3	1.04	255.99609375	False
14:03:16.211	3	1.04	255.99609375	False
14:03:16.231	3	1.04	255.99609375	False
14:03:16.251	3	1.04	255.99609375	False
14:03:16.271	3	1.04	255.99609375	False
14:03:16.291	3	1.04	255.99609375	False
14:03:16.311	3	1.04	255.99609375	False
14:03:16.331	3	1.04	255.99609375	False
14:03:16.351	3	1.04	255.99609375	False
14:03:16.371	3	1.04	255.99609375	False
14:03:16.391	3	1.04	255.99609375	False
14:03:16.411	3	1.04	255.99609375	False
14:03:16.431	3	1.04	255.99609375	False
14:03:16.451	3	1.04	255.99609375	False
14:03:16.471	3	1.04	255.99609375	False
14:03:16.491	3	1.04	255.99609375	False
14:03:16.511	3	1.04	255.99609375	False
14:03:16.531	3	1.04	255.99609375	False
14:03:16.551	3	1.04	255.99609375	False
14:03:16.571	3	1.04	255.99609375	False
14:03:16.591	3	1.04	255.99609375	False
14:03:16.611	3	1.04	255.99609375	False
14:03:16.631	3	1.04	255.99609375	False
14:03:16.651	3	1.04	255.99609375	False
14:03:16.671	3	1.04	255.99609375	False
14:03:16.691	3	1.04	255.99609375	False
14:03:16.711	3	1.04	255.99609375	False
14:03:16.731	3	1.04	255.99609375	False
14:03:16.751	3	1.04	255.99609375	False
14:03:16.771	3	1.04	255.99609375	False
14:03:16.791	3	1.04	255.99609375	False
14:03:16.811	3	1.04	255.99609375	False
14:03:16.831	3	1.04	255.99609375	False
14:03:16.851	3	1.04	255.99609375	False
14:03:16.871	3	1.04	255.99609375	False
14:03:16.891	3	1.04	255.99609375	False
14:03:16.911	3	1.04	255.99609375	False
14:03:16.931	3	1.04	255.99609375	False
14:03:16.951	3	1.04	255.99609375	False
14:03:16.971	3	1.04	255.99609375	False
14:03:16.991	3	1.04	255.99609375	False
14:03:17.011	3	1.04	255.99609375	False
14:03:17.031	3	1.04	255.99609375	False
14:03:17.051	3	1	255.99609375	False
14:03:17.071	3	1	255.99609375	False
14:03:17.091	3	1	255.99609375	False
14:03:17.111	3	1	255.99609375	False
14:03:17.131	3	1	255.99609375	False
14:03:17.151	3	1	255.99609375	False
14:03:17.171	3	1	255.99609375	False
14:03:17.191	3	1	255.99609375	False
14:03:17.211	3	1	255.99609375	False
14:03:17.231	3	1	255.99609375	False
14:03:17.251	3	1	255.99609375	False
14:03:17.271	3	1	255.99609375	False
14:03:17.291	3	1	255.99609375	False
14:03:17.311	3	1	255.99609375	False
14:03:17.331	3	1	255.99609375	False
14:03:17.351	3	1	255.99609375	False
14:03:17.371	3	1	255.99609375	False
14:03:17.391	3	1	255.99609375	False
14:03:17.411	3	1	255.99609375	False
14:03:17.431	3	1	255.99609375	False
14:03:17.451	3	1	255.99609375	False
14:03:17.471	3	1	255.99609375	False
14:03:17.491	3	1	255.99609375	False
14:03:17.511	3	1	255.99609375	False
14:03:17.531	3	1	255.99609375	False
14:03:17.551	3	1	255.99609375	False
14:03:17.571	3	1	255.99609375	False
14:03:17.591	3	1	255.99609375	False
14:03:17.611	3	1	255.99609375	False
14:03:17.631	3	1	255.99609375	False
14:03:17.651	3	1	255.99609375	False
14:03:17.671	3	1	255.99609375	False
14:03:17.691	3	1	255.99609375	False
14:03:17.711	3	1	255.99609375	False
14:03:17.731	3	1	255.99609375	False
14:03:17.751	3	1	255.99609375	False
14:03:17.771	3	1	255.99609375	False
14:03:17.791	3	1	255.99609375	False
14:03:17.811	3	1	255.99609375	False
14:03:17.831	3	1	255.99609375	False
14:03:17.851	3	1	255.99609375	False
14:03:17.871	3	1	255.99609375	False
14:03:17.891	3	1	255.99609375	False
14:03:17.911	3	1	255.99609375	False
14:03:17.931	3	1	255.99609375	False
14:03:17.951	3	1	255.99609375	False
14:03:17.971	3	1	255.99609375	False
14:03:17.991	3	1	255.99609375	False
14:03:18.011	3	1	255.99609375	False
14:03:18.031	3	1	255.99609375	False
14:03:18.051	3	1	255.99609375	False
14:03:18.071	3	0.16	12.10546875	True
14:03:18.091	3	0.16	12.10546875	True
14:03:18.111	3	0.16	12.10546875	True
14:03:18.131	3	0.16	12.10546875	True
14:03:18.151	3	0.16	12.09375	False
14:03:18.171	3	0.16	12.09375	False
14:03:18.191	3	0.16	12.09765625	False
14:03:18.211	3	0.16	12.09375	False
14:03:18.231	3	0.16	12.0859375	True
14:03:18.251	3	0.16	12.08203125	False
14:03:18.271	3	0.16	12.09375	False
14:03:18.291	3	0.16	12.09765625	True
14:03:18.311	3	0.16	12.0859375	False
14:03:18.331	3	0.16	12.08203125	False
14:03:18.351	3	0.16	12.09765625	False
14:03:18.371	3	0.16	12.0859375	False
14:03:18.391	3	0.16	12.09765625	True
14:03:18.411	3	0.16	12.09765625	True
14:03:18.431	3	0.16	12.09375	True
14:03:18.451	3	0.16	12.09765625	True
14:03:18.471	3	0.16	12.09375	True
14:03:18.491	3	0.16	12.09765625	True
14:03:18.511	3	0.16	12.10546875	True
14:03:18.531	3	0.16	12.09765625	True
14:03:18.551	3	0.16	12.09375	True
14:03:18.571	3	0.16	12.10546875	True
14:03:18.591	3	0.16	12.10546875	True
14:03:18.611	3	0.16	12.10546875	True
14:03:18.631	3	0.16	12.10546875	True
14:03:18.651	3	0.16	12.11328125	True
14:03:18.671	3	0.16	12.10546875	True
14:03:18.691	3	0.16	12.09765625	True
14:03:18.711	3	0.16	12.10546875	True
14:03:18.731	3	0.16	12.11328125	True
14:03:18.751	3	0.16	12.10546875	True
14:03:18.771	3	0.16	12.10546875	True
14:03:18.791	3	1.08	255.99609375	False
14:03:18.811	3	1.08	255.99609375	False
14:03:18.831	3	1.08	255.99609375	False
14:03:18.851	3	1.08	255.99609375	False
14:03:18.871	3	1.08	255.99609375	False
14:03:18.891	3	1.08	255.99609375	False
14:03:18.911	3	1.08	255.99609375	False
14:03:18.931	3	1.08	255.99609375	False
14:03:18.951	3	1.08	255.99609375	False
14:03:18.971	3	1.08	255.99609375	False
14:03:18.991	3	1.08	255.99609375	False
14:03:19.011	3	1.08	255.99609375	False
14:03:19.031	3	1.08	255.99609375	False
14:03:19.051	3	1.08	255.99609375	False
14:03:19.071	3	1.08	255.99609375	False
14:03:19.091	3	1	255.99609375	False
14:03:19.111	3	1	255.99609375	False
14:03:19.131	3	1	255.99609375	False
14:03:19.151	3	1	255.99609375	False
14:03:19.171	3	1	255.99609375	False
14:03:19.191	3	1	255.99609375	False
14:03:19.211	3	1	255.99609375	False
14:03:19.231	3	1	255.99609375	False
14:03:19.251	3	1	255.99609375	False
14:03:19.271	3	1	255.99609375	False
14:03:19.291	3	1	255.99609375	False
14:03:19.311	3	1	255.99609375	False
14:03:19.331	3	1	255.99609375	False
14:03:19.351	3	1	255.99609375	False
14:03:19.371	3	1	255.99609375	False
14:03:19.391	3	1	255.99609375	False
14:03:19.411	3	1	255.99609375	False
14:03:19.431	3	1	255.99609375	False
14:03:19.451	3	1	255.99609375	False
14:03:19.471	3	1	255.99609375	False
14:03:19.491	3	1	255.99609375	False
14:03:19.511	3	1	255.99609375	False
14:03:19.531	3	1	255.99609375	False
14:03:19.551	3	1	255.99609375	False
14:03:19.571	3	1	255.99609375	False
14:03:19.591	3	1	255.99609375	False
14:03:19.611	3	1	255.99609375	False
14:03:19.631	3	1	255.99609375	False
14:03:19.651	3	1	255.99609375	False
14:03:19.671	3	1	255.99609375	False
14:03:19.691	3	1	255.99609375	False
14:03:19.711	3	1	255.99609375	False
14:03:19.731	3	1	255.99609375	False
14:03:19.751	3	1	255.99609375	False
14:03:19.771	3	1	255.99609375	False
14:03:19.791	3	1	255.99609375	False
14:03:19.811	3	1	255.99609375	False
14:03:19.831	3	1	255.99609375	False
14:03:19.851	3	1	255.99609375	False
14:03:19.871	3	1	255.99609375	False
14:03:19.891	3	1	255.99609375	False
14:03:19.911	3	1	255.99609375	False
14:03:19.931	3	1	255.99609375	False
14:03:19.951	3	1	255.99609375	False
14:03:19.971	3	1	255.99609375	False
14:03:19.991	3	1	255.99609375	False
14:03:20.011	3	1	255.99609375	False
14:03:20.031	3	1	255.99609375	False
14:03:20.051	3	1	255.99609375	False
14:03:20.071	3	1	255.99609375	False
14:03:20.091	3	1	255.99609375	False
14:03:20.111	3	1	255.99609375	False
14:03:20.131	3	1	255.99609375	False
14:03:20.151	3	1	255.99609375	False
14:03:20.171	3	1	255.99609375	False
14:03:20.191	3	1	255.99609375	False
14:03:20.211	3	1	255.99609375	False
14:03:20.231	3	1	255.99609375	False
14:03:20.251	3	1	255.99609375	False
14:03:20.271	3	1	255.99609375	False
14:03:20.291	3	1	255.99609375	False
14:03:20.311	3	1	255.99609375	False
14:03:20.331	3	1	255.99609375	False
14:03:20.351	3	1	255.99609375	False
14:03:20.371	3	1	255.99609375	False
14:03:20.391	3	1	255.99609375	False
14:03:20.411	3	1	255.99609375	False
14:03:20.431	3	1	255.99609375	False
14:03:20.451	3	1	255.99609375	False
14:03:20.471	3	1	255.99609375	False
14:03:20.491	3	1	255.99609375	False
14:03:20.511	3	1	255.99609375	False
14:03:20.531	3	1	255.99609375	False
14:03:20.551	3	1	255.99609375	False
14:03:20.571	3	1	255.99609375	False
14:03:20.591	3	1.04	255.99609375	False
14:03:20.611	3	1.04	255.99609375	False
14:03:20.631	3	1.04	255.99609375	False
14:03:20.651	3	1.04	255.99609375	False
14:03:20.671	3	1.04	255.99609375	False
14:03:20.691	3	1.04	255.99609375	False
14:03:20.711	3	1.04	255.99609375	False
14:03:20.731	3	1.04	255.99609375	False
14:03:20.751	3	1.04	255.99609375	False
14:03:20.771	3	1.04	255.99609375	False
14:03:20.791	3	1.04	255.99609375	False
14:03:20.811	3	1.04	255.99609375	False
14:03:20.831	3	1.04	255.99609375	False
14:03:20.851	3	1.04	255.99609375	False
14:03:20.871	3	1.04	255.99609375	False
14:03:20.891	3	1.04	255.99609375	False
14:03:20.911	3	1.04	255.99609375	False
14:03:20.931	3	1.04	255.99609375	False
14:03:20.951	3	1.04	255.99609375	False
14:03:20.971	3	1.04	255.99609375	False
14:03:20.991	3	1.04	255.99609375	False
14:03:21.011	3	1.04	255.99609375	False
14:03:21.031	3	1.04	255.99609375	False
14:03:21.051	3	1.04	255.99609375	False
14:03:21.071	3	1.04	255.99609375	False
14:03:21.091	3	0.32	12.09765625	True
14:03:21.111	3	0.32	12.09765625	True
14:03:21.131	3	0.32	12.09765625	True
14:03:21.151	3	0.32	12.09765625	True
14:03:21.171	3	0.32	12.09765625	True
14:03:21.191	3	0.32	12.09765625	True
14:03:21.211	3	0.32	12.09765625	True
14:03:21.231	3	0.32	12.09765625	True
14:03:21.251	3	0.32	12.09765625	True
14:03:21.271	3	0.32	12.10546875	False
14:03:21.291	3	0.32	12.09765625	False
14:03:21.311	3	0.32	12.10546875	False
14:03:21.331	3	0.32	12.09375	False
14:03:21.351	3	0.32	12.10546875	False
14:03:21.371	3	0.32	12.0859375	False
14:03:21.391	3	0.32	12.09375	False
14:03:21.411	3	0.32	12.09765625	True
14:03:21.431	3	0.32	12.10546875	False
14:03:21.451	3	0.32	12.11328125	True
14:03:21.471	3	0.32	12.09375	True
14:03:21.491	3	0.32	12.11328125	True
14:03:21.511	3	0.32	12.10546875	True
14:03:21.531	3	0.32	12.09765625	True
14:03:21.551	3	0.32	12.09765625	True
14:03:21.571	3	0.32	12.10546875	True
14:03:21.591	3	0.32	12.09375	True
14:03:21.611	3	0.32	12.10546875	True
14:03:21.631	3	0.32	12.0859375	True
14:03:21.651	3	0.32	12.0859375	True
14:03:21.671	3	0.32	12.09765625	True
14:03:21.691	3	0.32	12.09375	True
14:03:21.711	3	0.32	12.09765625	True
14:03:21.731	3	0.32	12.09765625	True
14:03:21.751	3	1.08	255.99609375	False
14:03:21.771	3	1.08	255.99609375	False
14:03:21.791	3	1.08	255.99609375	False
14:03:21.811	3	1.08	255.99609375	False
14:03:21.831	3	1.08	255.99609375	False
14:03:21.851	3	1.08	255.99609375	False
14:03:21.871	3	1.08	255.99609375	False
14:03:21.891	3	1.08	255.99609375	False
14:03:21.911	3	1.08	255.99609375	False
14:03:21.931	3	1.08	255.99609375	False
14:03:21.951	3	1.08	255.99609375	False
14:03:21.971	3	1.08	255.99609375	False
14:03:21.991	3	1.08	255.99609375	False
14:03:22.011	3	1.08	255.99609375	False
14:03:22.031	3	1.08	255.99609375	False
14:03:22.051	3	1.08	255.99609375	False
14:03:22.071	3	1.08	255.99609375	False
14:03:22.091	3	1.08	255.99609375	False
14:03:22.111	3	1.08	255.99609375	False
14:03:22.131	3	1.08	255.99609375	False
14:03:22.151	3	1.08	255.99609375	False
14:03:22.171	3	1.08	255.99609375	False
14:03:22.191	3	1.08	255.99609375	False
14:03:22.211	3	1.08	255.99609375	False
14:03:22.231	3	1.08	255.99609375	False
14:03:22.251	3	1.08	255.99609375	False
14:03:22.271	3	1.08	255.99609375	False
14:03:22.291	3	1.08	255.99609375	False
14:03:22.311	3	1.08	255.99609375	False
14:03:22.331	3	1.08	255.99609375	False
14:03:22.351	3	1.08	255.99609375	False
14:03:22.371	3	1.08	255.99609375	False
14:03:22.391	3	1.08	255.99609375	False
14:03:22.411	3	1.08	255.99609375	False
14:03:22.431	3	1.08	255.99609375	False
14:03:22.451	3	1.08	255.99609375	False
14:03:22.471	3	1.08	255.99609375	False
14:03:22.491	3	1.08	255.99609375	False
14:03:22.511	3	1.08	255.99609375	False
14:03:22.531	3	1.08	255.99609375	False
14:03:22.551	3	1.08	255.99609375	False
14:03:22.571	3	1.08	255.99609375	False
14:03:22.591	3	1.08	255.99609375	False
14:03:22.611	3	1	255.99609375	False
14:03:22.631	3	1	255.99609375	False
14:03:22.651	3	1	255.99609375	False
14:03:22.671	3	1	255.99609375	False
14:03:22.691	3	1	255.99609375	False
14:03:22.711	3	1	255.99609375	False
14:03:22.731	3	1	255.99609375	False
14:03:22.751	3	1	255.99609375	False
14:03:22.771	3	1	255.99609375	False
14:03:22.791	3	1	255.99609375	False
14:03:22.811	3	1	255.99609375	False
14:03:22.831	3	1	255.99609375	False
14:03:22.851	3	1	255.99609375	False
14:03:22.871	3	1	255.99609375	False
14:03:22.891	3	1	255.99609375	False
14:03:22.911	3	1	255.99609375	False
14:03:22.931	3	1	255.99609375	False
14:03:22.951	3	1	255.99609375	False
14:03:22.971	3	1	255.99609375	False
14:03:22.991	3	1	255.99609375	False
14:03:23.011	3	1	255.99609375	False
14:03:23.031	3	1	255.99609375	False
14:03:23.051	3	1	255.99609375	False
14:03:23.071	3	1	255.99609375	False
14:03:23.091	3	1	255.99609375	False
14:03:23.111	3	1	255.99609375	False
14:03:23.131	3	1	255.99609375	False
14:03:23.151	3	1	255.99609375	False
14:03:23.171	3	1	255.99609375	False
14:03:23.191	3	1	255.99609375	False
14:03:23.211	3	1	255.99609375	False
14:03:23.231	3	1	255.99609375	False
14:03:23.251	3	1	255.99609375	False
14:03:23.271	3	1	255.99609375	False
14:03:23.291	3	1	255.99609375	False
14:03:23.311	3	1	255.99609375	False
14:03:23.331	3	1	255.99609375	False
14:03:23.351	3	1	255.99609375	False
14:03:23.371	3	1	255.99609375	False
14:03:23.391	3	1	255.99609375	False
14:03:23.411	3	1	255.99609375	False
14:03:23.431	3	1	255.99609375	False
14:03:23.451	3	1	255.99609375	False
14:03:23.471	3	1	255.99609375	False
14:03:23.491	3	1	255.99609375	False
14:03:23.511	3	1	255.99609375	False
14:03:23.531	3	1	255.99609375	False
14:03:23.551	3	1	255.99609375	False
14:03:23.571	3	1	255.99609375	False
14:03:23.591	3	1	255.99609375	False
14:03:23.611	3	1	255.99609375	False
14:03:23.631	3	1	255.99609375	False
14:03:23.651	3	1	255.99609375	False
14:03:23.671	3	1	255.99609375	False
14:03:23.691	3	1	255.99609375	False
14:03:23.711	3	1	255.99609375	False
14:03:23.731	3	1	255.99609375	False
14:03:23.751	3	1	255.99609375	False
14:03:23.771	3	1	255.99609375	False
14:03:23.791	3	1	255.99609375	False
14:03:23.811	3	1	255.99609375	False
14:03:23.831	3	1	255.99609375	False
14:03:23.851	3	1	255.99609375	False
14:03:23.871	3	1	255.99609375	False
14:03:23.891	3	1	255.99609375	False
14:03:23.911	3	1	255.99609375	False
14:03:23.931	3	1	255.99609375	False
14:03:23.951	3	1	255.99609375	False
14:03:23.971	3	1	255.99609375	False
14:03:23.991	3	1	255.99609375	False
14:03:24.011	3	1	255.99609375	False
14:03:24.031	3	1	255.99609375	False
14:03:24.051	3	1	255.99609375	False
14:03:24.071	3	1	255.99609375	False
14:03:24.091	3	1	255.99609375	False
14:03:24.111	3	1	12.09375	True
14:03:24.131	3	1	12.09375	True
14:03:24.151	3	1	12.09375	True
14:03:24.171	3	1	12.09375	True
14:03:24.191	3	1	12.09375	True
14:03:24.211	3	1	12.09375	True
14:03:24.231	3	1	12.09375	True
14:03:24.251	3	1	12.09375	True
14:03:24.271	3	1	12.09375	True
14:03:24.291	3	1	12.09375	True
14:03:24.311	3	1	12.09375	True
14:03:24.331	3	1	12.09375	True
14:03:24.351	3	1	12.09375	True
14:03:24.371	3	1	12.09375	True
14:03:24.391	3	1	12.10546875	False
14:03:24.411	3	1	12.11328125	False
14:03:24.431	3	1	12.09765625	False
14:03:24.451	3	1	12.09765625	True
14:03:24.471	3	1	12.0859375	True
14:03:24.491	3	1	12.0859375	False
14:03:24.511	3	1	12.08203125	True
14:03:24.531	3	1	12.09765625	True
14:03:24.551	3	1	12.09375	True
14:03:24.571	3	1	12.09765625	True
14:03:24.591	3	1	12.09765625	True
14:03:24.611	3	1	12.09765625	True
14:03:24.631	3	1	12.11328125	True
14:03:24.651	3	1	12.09765625	True
14:03:24.671	3	0.68	12.09375	True
14:03:24.691	3	0.68	12.11328125	True
14:03:24.711	3	1	255.99609375	False
14:03:24.731	3	1	255.99609375	False
14:03:24.751	3	1	255.99609375	False
14:03:24.771	3	1	255.99609375	False
14:03:24.791	3	1	255.99609375	False
14:03:24.811	3	1	255.99609375	False
14:03:24.831	3	1	255.99609375	False
14:03:24.851	3	1	255.99609375	False
14:03:24.871	3	1	255.99609375	False
14:03:24.891	3	1	255.99609375	False
14:03:24.911	3	1	255.99609375	False
14:03:24.931	3	1	255.99609375	False
14:03:24.951	3	1	255.99609375	False
14:03:24.971	3	1	255.99609375	False
14:03:24.991	3	1	255.99609375	False
14:03:25.011	3	1	255.99609375	False
14:03:25.031	3	1	255.99609375	False
14:03:25.051	3	1	255.99609375	False
14:03:25.071	3	1	255.99609375	False
14:03:25.091	3	1	255.99609375	False
14:03:25.111	3	1	255.99609375	False
14:03:25.131	3	1	255.99609375	False
14:03:25.151	3	1	255.99609375	False
14:03:25.171	3	1	255.99609375	False
14:03:25.191	3	1	255.99609375	False
14:03:25.211	3	1	255.99609375	False
14:03:25.231	3	1	255.99609375	False
14:03:25.251	3	1	255.99609375	False
14:03:25.271	3	1	255.99609375	False
14:03:25.291	3	1	255.99609375	False
14:03:25.311	3	1	255.99609375	False
14:03:25.331	3	1	255.99609375	False
14:03:25.351	3	1	255.99609375	False
14:03:25.371	3	1	255.99609375	False
14:03:25.391	3	1	255.99609375	False
14:03:25.411	3	1	255.99609375	False
14:03:25.431	3	1	255.99609375	False
14:03:25.451	3	1	255.99609375	False
14:03:25.471	3	1	255.99609375	False
14:03:25.491	3	1	255.99609375	False
14:03:25.511	3	1	255.99609375	False
14:03:25.531	3	1	255.99609375	False
14:03:25.551	3	1	255.99609375	False
14:03:25.571	3	1	255.99609375	False
14:03:25.591	3	1	255.99609375	False
14:03:25.611	3	1	255.99609375	False
14:03:25.631	3	1	255.99609375	False
14:03:25.651	3	1.04	255.99609375	False
14:03:25.671	3	1.04	255.99609375	False
14:03:25.691	3	1.04	255.99609375	False
14:03:25.711	3	1.04	255.99609375	False
14:03:25.731	3	1.04	255.99609375	False
14:03:25.751	3	1.04	255.99609375	False
14:03:25.771	3	1.04	255.99609375	False
14:03:25.791	3	1.04	255.99609375	False
14:03:25.811	3	1.04	255.99609375	False
14:03:25.831	3	1.04	255.99609375	False
14:03:25.851	3	1.04	255.99609375	False
14:03:25.871	3	1.04	255.99609375	False
14:03:25.891	3	1.04	255.99609375	False
14:03:25.911	3	1.04	255.99609375	False
14:03:25.931	3	1.04	255.99609375	False
14:03:25.951	3	1.04	255.99609375	False
14:03:25.971	3	1.04	255.99609375	False
14:03:25.991	3	1.04	255.99609375	False
14:03:26.011	3	1.04	255.99609375	False
14:03:26.031	3	1.04	255.99609375	False
14:03:26.051	3	1.04	255.99609375	False
14:03:26.071	3	1.04	255.99609375	False
14:03:26.091	3	1.04	255.99609375	False
14:03:26.111	3	1.04	255.99609375	False
14:03:26.131	3	1.04	255.99609375	False
14:03:26.151	3	1	255.99609375	False
14:03:26.171	3	1	255.99609375	False
14:03:26.191	3	1	255.99609375	False
14:03:26.211	3	1	255.99609375	False
14:03:26.231	3	1	255.99609375	False
14:03:26.251	3	1	255.99609375	False
14:03:26.271	3	1	255.99609375	False
14:03:26.291	3	1	255.99609375	False
14:03:26.311	3	1	255.99609375	False
14:03:26.331	3	1	255.99609375	False
14:03:26.351	3	1	255.99609375	False
14:03:26.371	3	1	255.99609375	False
14:03:26.391	3	1	255.99609375	False
14:03:26.411	3	1	255.99609375	False
14:03:26.431	3	1	255.99609375	False
14:03:26.451	3	1	255.99609375	False
14:03:26.471	3	1	255.99609375	False
14:03:26.491	3	1	255.99609375	False
14:03:26.511	3	1	255.99609375	False
14:03:26.531	3	1	255.99609375	False
14:03:26.551	3	1	255.99609375	False
14:03:26.571	3	1	255.99609375	False
14:03:26.591	3	1	255.99609375	False
14:03:26.611	3	1	255.99609375	False
14:03:26.631	3	1	255.99609375	False
14:03:26.651	3	1	255.99609375	False
14:03:26.671	3	1	255.99609375	False
14:03:26.691	3	1	255.99609375	False
14:03:26.711	3	1	255.99609375	False
14:03:26.731	3	1	255.99609375	False
14:03:26.751	3	1	255.99609375	False
14:03:26.771	3	1	255.99609375	False
14:03:26.791	3	1	255.99609375	False
14:03:26.811	3	1	255.99609375	False
14:03:26.831	3	1	255.99609375	False
14:03:26.851	3	1	255.99609375	False
14:03:26.871	3	1	255.99609375	False
14:03:26.891	3	1	255.99609375	False
14:03:26.911	3	1	255.99609375	False
14:03:26.931	3	1	255.99609375	False
14:03:26.951	3	1	255.99609375	False
14:03:26.971	3	1	255.99609375	False
14:03:26.991	3	1	255.99609375	False
14:03:27.011	3	1	255.99609375	False
14:03:27.031	3	1	255.99609375	False
14:03:27.051	3	1	255.99609375	False
14:03:27.071	3	1	255.99609375	False
14:03:27.091	3	1	255.99609375	False
14:03:27.111	3	1	255.99609375	False
14:03:27.131	3	1	255.99609375	False
14:03:27.151	3	1	255.99609375	False
14:03:27.171	3	1	12.10546875	True
14:03:27.191	3	1	12.10546875	True
14:03:27.211	3	1	12.10546875	True
14:03:27.231	3	1	12.10546875	True
14:03:27.251	3	1	12.10546875	True
14:03:27.271	3	1	12.10546875	True
14:03:27.291	3	1	12.10546875	True
14:03:27.311	3	1	12.10546875	True
14:03:27.331	3	1	12.10546875	True
14:03:27.351	3	1	12.0859375	False
14:03:27.371	3	1	12.09375	False
14:03:27.391	3	1	12.0859375	False
14:03:27.411	3	1	12.09375	True
14:03:27.431	3	1	12.09375	True
14:03:27.451	3	1	12.09375	False
14:03:27.471	3	1	12.0859375	False
14:03:27.491	3	1	12.0859375	False
14:03:27.511	3	1	12.09375	False
14:03:27.531	3	1	12.0859375	True
14:03:27.551	3	1	12.0859375	False
14:03:27.571	3	1	12.09375	False
14:03:27.591	3	1	12.09765625	False
14:03:27.611	3	1	12.10546875	False
14:03:27.631	3	1	12.09375	False
14:03:27.651	3	1	12.0859375	False
14:03:27.671	3	1	12.0859375	False
14:03:27.691	3	1	12.09375	False
14:03:27.711	3	1	12.0859375	True
14:03:27.731	3	1	12.09765625	False
14:03:27.751	3	1	12.09765625	False
14:03:27.771	3	1	12.09765625	False
14:03:27.791	3	1	12.09765625	False
14:03:27.811	3	1	12.10546875	True
14:03:27.831	3	1	12.08203125	False
14:03:27.851	3	1	12.0859375	True
14:03:27.871	3	1	12.09375	True
14:03:27.891	3	1	12.09765625	True
14:03:27.911	3	1	12.09375	True
14:03:27.931	3	1	12.09375	True
14:03:27.951	3	1	12.09375	True
14:03:27.971	3	1	12.09375	True
14:03:27.991	3	1	12.10546875	True
14:03:28.011	3	1	12.09375	True
14:03:28.031	3	1	12.10546875	True
14:03:28.051	3.5	0.48	12.09765625	True
14:03:28.071	3.5	0.48	12.10546875	True
14:03:28.091	3.5	0.48	12.0859375	True
14:03:28.111	3.5	0.48	12.10546875	True
14:03:28.131	3.5	1	255.99609375	False
14:03:28.151	3.5	1	255.99609375	False
14:03:28.171	3.5	1	255.99609375	False
14:03:28.191	3.5	1	255.99609375	False
14:03:28.211	3.5	1	255.99609375	False
14:03:28.231	3.5	1	255.99609375	False
14:03:28.251	3.5	1	255.99609375	False
14:03:28.271	3.5	1	255.99609375	False
14:03:28.291	3.5	1	255.99609375	False
14:03:28.311	3.5	1	255.99609375	False
14:03:28.331	3.5	1	255.99609375	False
14:03:28.351	3.5	1	255.99609375	False
14:03:28.371	3.5	1	255.99609375	False
14:03:28.391	3.5	1	255.99609375	False
14:03:28.411	3.5	1	255.99609375	False
14:03:28.431	3.5	1	255.99609375	False
14:03:28.451	3.5	1	255.99609375	False
14:03:28.471	3.5	1	255.99609375	False
14:03:28.491	3.5	1	255.99609375	False
14:03:28.511	3.5	1	255.99609375	False
14:03:28.531	3.5	1	255.99609375	False
14:03:28.551	3.5	1	255.99609375	False
14:03:28.571	3.5	1	255.99609375	False
14:03:28.591	3.5	1	255.99609375	False
14:03:28.611	3.5	1	255.99609375	False
14:03:28.631	3.5	1	255.99609375	False
14:03:28.651	3.5	1	255.99609375	False
14:03:28.671	3.5	1	255.99609375	False
14:03:28.691	3.5	1	255.99609375	False
14:03:28.711	3.5	1	255.99609375	False
14:03:28.731	3.5	1	255.99609375	False
14:03:28.751	3.5	1	255.99609375	False
14:03:28.771	3.5	1	255.99609375	False
14:03:28.791	3.5	1	255.99609375	False
14:03:28.811	3.5	1	255.99609375	False
14:03:28.831	3.5	1	255.99609375	False
14:03:28.851	3.5	1	255.99609375	False
14:03:28.871	3.5	1	255.99609375	False
14:03:28.891	3.5	1	255.99609375	False
14:03:28.911	3.5	1	255.99609375	False
14:03:28.931	3.5	1	255.99609375	False
14:03:28.951	3.5	1	255.99609375	False
14:03:28.971	3.5	1	255.99609375	False
14:03:28.991	3.5	1	255.99609375	False
14:03:29.011	3.5	1	255.99609375	False
14:03:29.031	3.5	1	255.99609375	False
14:03:29.051	3.5	1	255.99609375	False
14:03:29.071	3.5	1	255.99609375	False
14:03:29.091	3.5	1	255.99609375	False
14:03:29.111	3.5	1	255.99609375	False
14:03:29.131	3.5	1	255.99609375	False
14:03:29.151	3.5	1	255.99609375	False
14:03:29.171	3.5	1	255.99609375	False
14:03:29.191	3.5	1.04	255.99609375	False
14:03:29.211	3.5	1.04	255.99609375	False
14:03:29.231	3.5	1.04	255.99609375	False
14:03:29.251	3.5	1.04	255.99609375	False
14:03:29.271	3.5	1.04	255.99609375	False
14:03:29.291	3.5	1.04	255.99609375	False
14:03:29.311	3.5	1.04	255.99609375	False
14:03:29.331	3.5	1.04	255.99609375	False
14:03:29.351	3.5	1.04	255.99609375	False
14:03:29.371	3.5	1.04	255.99609375	False
14:03:29.391	3.5	1.04	255.99609375	False
14:03:29.411	3.5	1.04	255.99609375	False
14:03:29.431	3.5	1.04	255.99609375	False
14:03:29.451	3.5	1.04	255.99609375	False
14:03:29.471	3.5	1.04	255.99609375	False
14:03:29.491	3.5	1.04	255.99609375	False
14:03:29.511	3.5	1.04	255.99609375	False
14:03:29.531	3.5	1.04	255.99609375	False
14:03:29.551	3.5	1.04	255.99609375	False
14:03:29.571	3.5	1.04	255.99609375	False
14:03:29.591	3.5	1.04	255.99609375	False
14:03:29.611	3.5	1.04	255.99609375	False
14:03:29.631	3.5	1.04	255.99609375	False
14:03:29.651	3.5	1.04	255.99609375	False
14:03:29.671	3.5	1.04	255.99609375	False
14:03:29.691	3.5	1	255.99609375	False
14:03:29.711	3.5	1	255.99609375	False
14:03:29.731	3.5	1	255.99609375	False
14:03:29.751	3.5	1	255.99609375	False
14:03:29.771	3.5	1	255.99609375	False
14:03:29.791	3.5	1	255.99609375	False
14:03:29.811	3.5	1	255.99609375	False
14:03:29.831	3.5	1	255.99609375	False
14:03:29.851	3.5	1	255.99609375	False
14:03:29.871	3.5	1	255.99609375	False
14:03:29.891	3.5	1	255.99609375	False
14:03:29.911	3.5	1	255.99609375	False
14:03:29.931	3.5	1	255.99609375	False
14:03:29.951	3.5	1	255.99609375	False
14:03:29.971	3.5	1	255.99609375	False
14:03:29.991	3.5	1	255.99609375	False
14:03:30.011	3.5	1	255.99609375	False
14:03:30.031	3.5	1	255.99609375	False
14:03:30.051	3.5	1	255.99609375	False
14:03:30.071	3.5	1	255.99609375	False
14:03:30.091	3.5	1	255.99609375	False
14:03:30.111	3.5	1	255.99609375	False
14:03:30.131	3.5	1	255.99609375	False
14:03:30.151	3.5	1	255.99609375	False
14:03:30.171	3.5	1	255.99609375	False
14:03:30.191	3.5	1	12.10546875	True
14:03:30.211	3.5	1	12.10546875	True
14:03:30.231	3.5	1	12.10546875	True
14:03:30.251	3.5	1	12.10546875	True
14:03:30.271	3.5	1	12.10546875	True
14:03:30.291	3.5	1	12.10546875	True
14:03:30.311	3.5	1	12.10546875	True
14:03:30.331	3.5	1	12.10546875	True
14:03:30.351	3.5	1	12.10546875	True
14:03:30.371	3.5	1	12.0859375	False
14:03:30.391	3.5	1	12.09765625	False
14:03:30.411	3.5	1	12.0859375	False
14:03:30.431	3.5	1	12.08203125	True
14:03:30.451	3.5	1	12.0859375	False
14:03:30.471	3.5	1	12.09375	False
14:03:30.491	3.5	1	12.09375	False
14:03:30.511	3.5	1	12.0859375	False
14:03:30.531	3.5	1	12.08203125	False
14:03:30.551	3.5	1	12.0859375	False
14:03:30.571	3.5	1	12.09375	True
14:03:30.591	3.5	1	12.09375	False
14:03:30.611	3.5	1	12.09375	False
14:03:30.631	3.5	1	12.09765625	False
14:03:30.651	3.5	1	12.09375	False
14:03:30.671	3.5	1	12.0859375	False
14:03:30.691	3.5	1	12.09375	False
14:03:30.711	3.5	1	12.09375	False
14:03:30.731	3.5	1	12.0859375	True
14:03:30.751	3.5	1	12.09375	False
14:03:30.771	3.5	1	12.08203125	False
14:03:30.791	3.5	1	12.09375	False
14:03:30.811	3.5	1	12.08203125	True
14:03:30.831	3.5	1	12.08203125	False
14:03:30.851	3.5	1	12.09375	False
14:03:30.871	3.5	1	12.09375	False
14:03:30.891	3.5	1	12.0859375	False
14:03:30.911	3.5	1	12.09375	False
14:03:30.931	3.5	1	12.08203125	True
14:03:30.951	3.5	1	12.08203125	False
14:03:30.971	3.5	1	12.08203125	False
14:03:30.991	3.5	1	12.07421875	False
14:03:31.011	3.5	1	12.09375	False
14:03:31.031	3.5	1	12.09375	False
14:03:31.051	3.5	1	12.08203125	False
14:03:31.071	3.5	1	12.08203125	False
14:03:31.091	3.5	1	12.08203125	False
14:03:31.111	3.5	1	12.08203125	False
14:03:31.131	3.5	1	12.0859375	True
14:03:31.151	3.5	1	12.09375	False
14:03:31.171	3.5	1	12.09375	False
14:03:31.191	3.5	1	12.08203125	False
14:03:31.211	3.5	1	12.0859375	False
14:03:31.231	3.5	1	12.0859375	True
14:03:31.251	3.5	1	12.09375	False
14:03:31.271	3.5	1	12.0859375	False
14:03:31.291	3.5	1	12.0859375	False
14:03:31.311	3.5	1	12.0859375	True
14:03:31.331	3.5	1	12.09375	False
14:03:31.351	3.5	1	12.0859375	False
14:03:31.371	3.5	1	12.09375	True
14:03:31.391	3.5	1	12.09375	False
14:03:31.411	3.5	1	12.09375	False
14:03:31.431	3.5	1	12.09765625	False
14:03:31.451	3.5	1	12.07421875	False
14:03:31.471	3.5	1	12.09375	False
14:03:31.491	3.5	1	12.08203125	False
14:03:31.511	3.5	1	12.09765625	False
14:03:31.531	3.5	1	12.0859375	True
14:03:31.551	3.5	1	12.09765625	False
14:03:31.571	3.5	1	12.0859375	False
14:03:31.591	3.5	1	12.09375	False
14:03:31.611	3.5	1	12.09375	False
14:03:31.631	3.5	1	12.08203125	True
14:03:31.651	3.5	1	12.09375	True
14:03:31.671	3.5	1	12.11328125	True
14:03:31.691	3.5	1	12.09375	True
14:03:31.711	3.5	1	12.09765625	True
14:03:31.731	3.5	1	12.09765625	True
14:03:31.751	3.5	1	12.09765625	True
14:03:31.771	3.5	1	12.10546875	True
14:03:31.791	3.5	1	12.10546875	True
14:03:31.811	5.5	0.44	12.10546875	True
14:03:31.831	5.5	0.44	12.09375	True
14:03:31.851	5.5	0.44	12.09765625	True
14:03:31.871	5.5	0.44	12.09375	True
14:03:31.891	5.5	0.44	12.09375	True
14:03:31.911	5.5	0.44	12.0859375	True
14:03:31.931	5.5	1	255.99609375	False
14:03:31.951	5.5	1	255.99609375	False
14:03:31.971	5.5	1	255.99609375	False
14:03:31.991	5.5	1	255.99609375	False
14:03:32.011	5.5	1	255.99609375	False
14:03:32.031	5.5	1	255.99609375	False
14:03:32.051	5.5	1	255.99609375	False
14:03:32.071	5.5	1	255.99609375	False
14:03:32.091	5.5	1	255.99609375	False
14:03:32.111	5.5	1	255.99609375	False
14:03:32.131	5.5	1	255.99609375	False
14:03:32.151	5.5	1	255.99609375	False
14:03:32.171	5.5	1	255.99609375	False
14:03:32.191	5.5	1	255.99609375	False
14:03:32.211	5.5	1	255.99609375	False
14:03:32.231	5.5	1	255.99609375	False
14:03:32.251	5.5	1	255.99609375	False
14:03:32.271	5.5	1	255.99609375	False
14:03:32.291	5.5	1	255.99609375	False
14:03:32.311	5.5	1	255.99609375	False
14:03:32.331	5.5	1	255.99609375	False
14:03:32.351	5.5	1	255.99609375	False
14:03:32.371	5.5	1	255.99609375	False
14:03:32.391	5.5	1	255.99609375	False
14:03:32.411	5.5	1	255.99609375	False
14:03:32.431	5.5	1	255.99609375	False
14:03:32.451	5.5	1	255.99609375	False
14:03:32.471	5.5	1	255.99609375	False
14:03:32.491	5.5	1	255.99609375	False
14:03:32.511	5.5	1	255.99609375	False
14:03:32.531	5.5	1	255.99609375	False
14:03:32.551	5.5	1	255.99609375	False
14:03:32.571	5.5	1	255.99609375	False
14:03:32.591	5.5	1	255.99609375	False
14:03:32.611	5.5	1	255.99609375	False
14:03:32.631	5.5	1	255.99609375	False
14:03:32.651	5.5	1	255.99609375	False
14:03:32.671	5.5	1	255.99609375	False
14:03:32.691	5.5	1	255.99609375	False
14:03:32.711	5.5	1	255.99609375	False
14:03:32.731	5.5	1	255.99609375	False
14:03:32.751	5.5	1	255.99609375	False
14:03:32.771	5.5	1	255.99609375	False
14:03:32.791	5.5	1	255.99609375	False
14:03:32.811	5.5	1	255.99609375	False
14:03:32.831	5.5	1	255.99609375	False
14:03:32.851	5.5	1	255.99609375	False
14:03:32.871	5.5	1	255.99609375	False
14:03:32.891	5.5	1	255.99609375	False
14:03:32.911	5.5	1	255.99609375	False
14:03:32.931	5.5	1	255.99609375	False
14:03:32.951	5.5	1	255.99609375	False
14:03:32.971	5.5	1	255.99609375	False
14:03:32.991	5.5	1	255.99609375	False
14:03:33.011	5.5	1	255.99609375	False
14:03:33.031	5.5	1	255.99609375	False
14:03:33.051	5.5	1	255.99609375	False
14:03:33.071	5.5	1	255.99609375	False
14:03:33.091	5.5	1	255.99609375	False
14:03:33.111	5.5	1	255.99609375	False
14:03:33.131	5.5	1	255.99609375	False
14:03:33.151	5.5	1	255.99609375	False
14:03:33.171	5.5	1	255.99609375	False
14:03:33.191	5.5	1	255.99609375	False
14:03:33.211	5.5	1	255.99609375	False
14:03:33.231	5.5	1	12.0859375	True
14:03:33.251	5.5	1	12.0859375	True
14:03:33.271	5.5	1	12.0859375	True
14:03:33.291	5.5	1	12.0859375	True
14:03:33.311	5.5	1	12.0859375	True
14:03:33.331	5.5	1	12.0859375	True
14:03:33.351	5.5	1	12.0859375	True
14:03:33.371	5.5	1	12.0859375	True
14:03:33.391	5.5	1	12.0859375	True
14:03:33.411	5.5	1	12.0859375	True
14:03:33.431	5.5	1	12.0859375	True
14:03:33.451	5.5	1	12.0859375	True
14:03:33.471	5.5	1	12.0859375	True
14:03:33.491	5.5	1	12.0859375	True
14:03:33.511	5.5	1	12.09765625	False
14:03:33.531	5.5	1	12.09765625	False
14:03:33.551	5.5	1	12.09375	False
14:03:33.571	5.5	1	12.0859375	False
14:03:33.591	5.5	1	12.10546875	False
14:03:33.611	5.5	1	12.09765625	False
14:03:33.631	5.5	1	12.09765625	False
14:03:33.651	5.5	1	12.11328125	True
14:03:33.671	5.5	1	12.09765625	False
14:03:33.691	5.5	1	12.10546875	False
14:03:33.711	5.5	1	12.09375	False
14:03:33.731	5.5	1	12.09765625	False
14:03:33.751	5.5	1	12.09765625	False
14:03:33.771	5.5	1	12.0859375	False
14:03:33.791	5.5	1	12.09765625	False
14:03:33.811	5.5	1	12.09375	False
14:03:33.831	5.5	1	12.0859375	False
14:03:33.851	5.5	1	12.09375	True
14:03:33.871	5.5	1	12.09765625	False
14:03:33.891	5.5	1	12.0859375	False
14:03:33.911	5.5	1	12.09375	False
14:03:33.931	5.5	1	12.09375	False
14:03:33.951	5.5	1	12.09765625	False
14:03:33.971	5.5	1	12.09765625	False
14:03:33.991	5.5	1	12.09765625	True
14:03:34.011	5.5	1	12.09375	True
14:03:34.031	5.5	1	12.09375	True
14:03:34.051	5.5	1	12.09375	True
14:03:34.071	5.5	1	12.09375	True
14:03:34.091	5.5	0.6	12.09375	True
14:03:34.111	5.5	0.6	12.09765625	True
14:03:34.131	5.5	0.6	12.10546875	True
14:03:34.151	5.5	0.6	12.0859375	True
14:03:34.171	5.5	0.6	12.0859375	True
14:03:34.191	5.5	0.6	12.09375	True
14:03:34.211	5.5	0.6	12.09765625	True
14:03:34.231	5.5	0.6	12.09765625	True
14:03:34.251	5.5	0.6	12.08203125	True
14:03:34.271	5.5	1	255.99609375	False
14:03:34.291	5.5	1	255.99609375	False
14:03:34.311	5.5	1	255.99609375	False
14:03:34.331	5.5	1	255.99609375	False
14:03:34.351	5.5	1	255.99609375	False
14:03:34.371	5.5	1	255.99609375	False
14:03:34.391	5.5	1	255.99609375	False
14:03:34.411	5.5	1	255.99609375	False
14:03:34.431	5.5	1	255.99609375	False
14:03:34.451	5.5	1	255.99609375	False
14:03:34.471	5.5	1	255.99609375	False
14:03:34.491	5.5	1	255.99609375	False
14:03:34.511	5.5	1	255.99609375	False
14:03:34.531	5.5	1	255.99609375	False
14:03:34.551	5.5	1	255.99609375	False
14:03:34.571	5.5	1	255.99609375	False
14:03:34.591	5.5	1	255.99609375	False
14:03:34.611	5.5	1	255.99609375	False
14:03:34.631	5.5	1	255.99609375	False
14:03:34.651	5.5	1	255.99609375	False
14:03:34.671	5.5	1	255.99609375	False
14:03:34.691	5.5	1	255.99609375	False
14:03:34.711	5.5	1	255.99609375	False
14:03:34.731	5.5	1	255.99609375	False
14:03:34.751	5.5	1	255.99609375	False
14:03:34.771	5.5	1	255.99609375	False
14:03:34.791	5.5	1	255.99609375	False
14:03:34.811	5.5	1	255.99609375	False
14:03:34.831	5.5	1	255.99609375	False
14:03:34.851	5.5	1	255.99609375	False
14:03:34.871	5.5	1	255.99609375	False
14:03:34.891	5.5	1	255.99609375	False
14:03:34.911	5.5	1	255.99609375	False
14:03:34.931	5.5	1	255.99609375	False
14:03:34.951	5.5	1	255.99609375	False
14:03:34.971	5.5	1	255.99609375	False
14:03:34.991	5.5	1	255.99609375	False
14:03:35.011	5.5	1	255.99609375	False
14:03:35.031	5.5	1	255.99609375	False
14:03:35.051	5.5	1	255.99609375	False
14:03:35.071	5.5	1	255.99609375	False
14:03:35.091	5.5	1	255.99609375	False
14:03:35.111	5.5	1	255.99609375	False
14:03:35.131	5.5	1	255.99609375	False
14:03:35.151	5.5	1	255.99609375	False
14:03:35.171	5.5	1	255.99609375	False
14:03:35.191	5.5	1	255.99609375	False
14:03:35.211	5.5	1	255.99609375	False
14:03:35.231	5.5	1	255.99609375	False
14:03:35.251	5.5	1	255.99609375	False
14:03:35.271	5.5	1	255.99609375	False
14:03:35.291	5.5	1.04	255.99609375	False
14:03:35.311	5.5	1.04	255.99609375	False
14:03:35.331	5.5	1.04	255.99609375	False
14:03:35.351	5.5	1.04	255.99609375	False
14:03:35.371	5.5	1.04	255.99609375	False
14:03:35.391	5.5	1.04	255.99609375	False
14:03:35.411	5.5	1.04	255.99609375	False
14:03:35.431	5.5	1.04	255.99609375	False
14:03:35.451	5.5	1.04	255.99609375	False
14:03:35.471	5.5	1.04	255.99609375	False
14:03:35.491	5.5	1.04	255.99609375	False
14:03:35.511	5.5	1.04	255.99609375	False
14:03:35.531	5.5	1.04	255.99609375	False
14:03:35.551	5.5	1.04	255.99609375	False
14:03:35.571	5.5	1.04	255.99609375	False
14:03:35.591	5.5	1.04	255.99609375	False
14:03:35.611	5.5	1.04	255.99609375	False
14:03:35.631	5.5	1.04	255.99609375	False
14:03:35.651	5.5	1.04	255.99609375	False
14:03:35.671	5.5	1.04	255.99609375	False
14:03:35.691	5.5	1.04	255.99609375	False
14:03:35.711	5.5	1.04	255.99609375	False
14:03:35.731	5.5	1.04	255.99609375	False
14:03:35.751	5.5	1.04	255.99609375	False
14:03:35.771	5.5	1.04	255.99609375	False
14:03:35.791	5.5	1	255.99609375	False
14:03:35.811	5.5	1	255.99609375	False
14:03:35.831	5.5	1	255.99609375	False
14:03:35.851	5.5	1	255.99609375	False
14:03:35.871	5.5	1	255.99609375	False
14:03:35.891	5.5	1	255.99609375	False
14:03:35.911	5.5	1	255.99609375	False
14:03:35.931	5.5	1	255.99609375	False
14:03:35.951	5.5	1	255.99609375	False
14:03:35.971	5.5	1	255.99609375	False
14:03:35.991	5.5	1	255.99609375	False
14:03:36.011	5.5	1	255.99609375	False
14:03:36.031	5.5	1	255.99609375	False
14:03:36.051	5.5	1	255.99609375	False
14:03:36.071	5.5	1	255.99609375	False
14:03:36.091	5.5	1	255.99609375	False
14:03:36.111	5.5	1	255.99609375	False
14:03:36.131	5.5	1	255.99609375	False
14:03:36.151	5.5	1	255.99609375	False
14:03:36.171	5.5	1	255.99609375	False
14:03:36.191	5.5	1	255.99609375	False
14:03:36.211	5.5	1	255.99609375	False
14:03:36.231	5.5	1	255.99609375	False
14:03:36.251	5.5	1	255.99609375	False
14:03:36.271	5.5	1	255.99609375	False
14:03:36.291	5.5	1	12.09765625	True
14:03:36.311	5.5	1	12.09765625	True
14:03:36.331	5.5	1	12.09765625	True
14:03:36.351	5.5	1	12.09765625	True
14:03:36.371	5.5	1	12.09765625	True
14:03:36.391	5.5	1	12.09765625	True
14:03:36.411	5.5	1	12.09765625	True
14:03:36.431	5.5	1	12.09765625	True
14:03:36.451	5.5	1	12.09375	False
14:03:36.471	5.5	1	12.09765625	False
14:03:36.491	5.5	1	12.10546875	False
14:03:36.511	5.5	1	12.09765625	True
14:03:36.531	5.5	1	12.10546875	False
14:03:36.551	5.5	1	12.10546875	False
14:03:36.571	5.5	1	12.09765625	False
14:03:36.591	5.5	1	12.10546875	False
14:03:36.611	5.5	1	12.09765625	False
14:03:36.631	5.5	1	12.09765625	False
14:03:36.651	5.5	1	12.09375	False
14:03:36.671	5.5	1	12.09765625	False
14:03:36.691	5.5	1	12.09765625	False
14:03:36.711	5.5	1	12.09375	True
14:03:36.731	5.5	1	12.10546875	False
14:03:36.751	5.5	1	12.09765625	True
14:03:36.771	5.5	1	12.09375	True
14:03:36.791	5.5	1	12.09375	True
14:03:36.811	5.5	1	12.09375	True
14:03:36.831	5.5	1	12.09375	True
14:03:36.851	5.5	0.4	12.09765625	True
14:03:36.871	5.5	0.4	12.09375	True
14:03:36.891	5.5	0.4	12.11328125	True
14:03:36.911	5.5	0.4	12.08203125	True
14:03:36.931	5.5	0.4	12.0859375	True
14:03:36.951	5.5	0.4	12.10546875	True
14:03:36.971	5.5	0.4	12.09765625	True
14:03:36.991	5.5	0.4	12.10546875	True
14:03:37.011	5.5	0.4	12.11328125	True
14:03:37.031	5.5	0.4	12.09765625	True
14:03:37.051	5.5	1	255.99609375	False
14:03:37.071	5.5	1	255.99609375	False
14:03:37.091	5.5	1	255.99609375	False
14:03:37.111	5.5	1	255.99609375	False
14:03:37.131	5.5	1	255.99609375	False
14:03:37.151	5.5	1	255.99609375	False
14:03:37.171	5.5	1	255.99609375	False
14:03:37.191	5.5	1	255.99609375	False
14:03:37.211	5.5	1	255.99609375	False
14:03:37.231	5.5	1	255.99609375	False
14:03:37.251	5.5	1	255.99609375	False
14:03:37.271	5.5	1	255.99609375	False
14:03:37.291	5.5	1	255.99609375	False
14:03:37.311	5.5	1	255.99609375	False
14:03:37.331	5.5	1	255.99609375	False
14:03:37.351	5.5	1	255.99609375	False
14:03:37.371	5.5	1	255.99609375	False
14:03:37.391	5.5	1	255.99609375	False
14:03:37.411	5.5	1	255.99609375	False
14:03:37.431	5.5	1	255.99609375	False
14:03:37.451	5.5	1	255.99609375	False
14:03:37.471	5.5	1	255.99609375	False
14:03:37.491	5.5	1	255.99609375	False
14:03:37.511	5.5	1	255.99609375	False
14:03:37.531	5.5	1	255.99609375	False
14:03:37.551	5.5	1	255.99609375	False
14:03:37.571	5.5	1	255.99609375	False
14:03:37.591	5.5	1	255.99609375	False
14:03:37.611	5.5	1	255.99609375	False
14:03:37.631	5.5	1	255.99609375	False
14:03:37.651	5.5	1	255.99609375	False
14:03:37.671	5.5	1	255.99609375	False
14:03:37.691	5.5	1	255.99609375	False
14:03:37.711	5.5	1	255.99609375	False
14:03:37.731	5.5	1	255.99609375	False
14:03:37.751	5.5	1	255.99609375	False
14:03:37.771	5.5	1	255.99609375	False
14:03:37.791	5.5	1	255.99609375	False
14:03:37.811	5.5	1	255.99609375	False
14:03:37.831	5.5	1	255.99609375	False
14:03:37.851	5.5	1	255.99609375	False
14:03:37.871	5.5	1	255.99609375	False
14:03:37.891	5.5	1	255.99609375	False
14:03:37.911	5.5	1	255.99609375	False
14:03:37.931	5.5	1	255.99609375	False
14:03:37.951	5.5	1	255.99609375	False
14:03:37.971	5.5	1	255.99609375	False
14:03:37.991	5.5	1	255.99609375	False
14:03:38.011	5.5	1	255.99609375	False
14:03:38.031	5.5	1	255.99609375	False
14:03:38.051	5.5	1	255.99609375	False
14:03:38.071	5.5	1	255.99609375	False
14:03:38.091	5.5	1	255.99609375	False
14:03:38.111	5.5	1	255.99609375	False
14:03:38.131	5.5	1	255.99609375	False
14:03:38.151	5.5	1	255.99609375	False
14:03:38.171	5.5	1	255.99609375	False
14:03:38.191	5.5	1	255.99609375	False
14:03:38.211	5.5	1	255.99609375	False
14:03:38.231	5.5	1	255.99609375	False
14:03:38.251	5.5	1	255.99609375	False
14:03:38.271	5.5	1	255.99609375	False
14:03:38.291	5.5	1	255.99609375	False
14:03:38.311	5.5	1	255.99609375	False
14:03:38.331	5.5	1	255.99609375	False
14:03:38.351	5.5	1	255.99609375	False
14:03:38.371	5.5	1	255.99609375	False
14:03:38.391	5.5	1	255.99609375	False
14:03:38.411	5.5	1	255.99609375	False
14:03:38.431	5.5	1	255.99609375	False
14:03:38.451	5.5	1	255.99609375	False
14:03:38.471	5.5	1	255.99609375	False
14:03:38.491	5.5	1	255.99609375	False
14:03:38.511	5.5	1	255.99609375	False
14:03:38.531	5.5	1	255.99609375	False
14:03:38.551	5.5	1	255.99609375	False
14:03:38.571	5.5	1	255.99609375	False
14:03:38.591	5.5	1	255.99609375	False
14:03:38.611	5.5	1	255.99609375	False
14:03:38.631	5.5	1	255.99609375	False
14:03:38.651	5.5	1	255.99609375	False
14:03:38.671	5.5	1	255.99609375	False
14:03:38.691	5.5	1	255.99609375	False
14:03:38.711	5.5	1	255.99609375	False
14:03:38.731	5.5	1	255.99609375	False
14:03:38.751	5.5	1	255.99609375	False
14:03:38.771	5.5	1	255.99609375	False
14:03:38.791	5.5	1	255.99609375	False
14:03:38.811	5.5	1	255.99609375	False
14:03:38.831	5.5	1	255.99609375	False
14:03:38.851	5.5	1	255.99609375	False
14:03:38.871	5.5	1	255.99609375	False
14:03:38.891	5.5	1	255.99609375	False
14:03:38.911	5.5	1	255.99609375	False
14:03:38.931	5.5	1	255.99609375	False
14:03:38.951	5.5	1	255.99609375	False
14:03:38.971	5.5	1	255.99609375	False
14:03:38.991	5.5	1	255.99609375	False
14:03:39.011	5.5	1	255.99609375	False
14:03:39.031	5.5	1	255.99609375	False
14:03:39.051	5.5	1	255.99609375	False
14:03:39.071	5.5	1	255.99609375	False
14:03:39.091	5.5	1	255.99609375	False
14:03:39.111	5.5	1	255.99609375	False
14:03:39.131	5.5	1	255.99609375	False
14:03:39.151	5.5	1	255.99609375	False
14:03:39.171	5.5	1	255.99609375	False
14:03:39.191	5.5	1	255.99609375	False
14:03:39.211	5.5	1	255.99609375	False
14:03:39.231	5.5	1	255.99609375	False
14:03:39.251	5.5	1	255.99609375	False
14:03:39.271	5.5	1	255.99609375	False
14:03:39.291	5.5	1	255.99609375	False
14:03:39.311	5.5	1	12.10546875	True
14:03:39.331	5.5	1	12.10546875	True
14:03:39.351	5.5	1	12.10546875	True
14:03:39.371	5.5	1	12.10546875	True
14:03:39.391	5.5	1	12.10546875	True
14:03:39.411	5.5	1	12.0859375	False
14:03:39.431	5.5	1	12.09375	False
14:03:39.451	5.5	1	12.09375	False
14:03:39.471	5.5	1	12.09375	False
14:03:39.491	5.5	1	12.09375	False
14:03:39.511	5.5	1	12.0859375	True
14:03:39.531	5.5	1	12.09375	False
14:03:39.551	5.5	1	12.09765625	False
14:03:39.571	5.5	1	12.08203125	False
14:03:39.591	5.5	1	12.09375	False
14:03:39.611	5.5	1	12.0859375	False
14:03:39.631	5.5	1	12.09375	False
14:03:39.651	5.5	1	12.0859375	True
14:03:39.671	5.5	1	12.09375	False
14:03:39.691	5.5	1	12.09375	False
14:03:39.711	5.5	1	12.09375	True
14:03:39.731	5.5	1	12.0859375	False
14:03:39.751	5.5	1	12.09765625	False
14:03:39.771	5.5	1	12.0859375	False
14:03:39.791	5.5	1	12.08203125	False
14:03:39.811	5.5	1	12.09765625	False
14:03:39.831	5.5	1	12.0859375	False
14:03:39.851	5.5	1	12.0859375	False
14:03:39.871	5.5	1	12.09765625	False
14:03:39.891	5.5	1	12.09375	True
14:03:39.911	5.5	1	12.09765625	False
14:03:39.931	5.5	1	12.09375	True
14:03:39.951	5.5	1	12.0859375	True
14:03:39.971	5.5	1	12.10546875	True
14:03:39.991	5.5	1	12.09375	True
14:03:40.011	5.5	1	12.09765625	True
14:03:40.031	5.5	1	12.09375	True
14:03:40.051	5.5	1	12.09765625	True
14:03:40.071	4	0.32	12.0859375	True
14:03:40.091	4	0.32	12.09375	True
14:03:40.111	4	0.32	12.09765625	True
14:03:40.131	4	0.32	12.10546875	True
14:03:40.151	4	0.32	12.09375	True
14:03:40.171	4	0.32	12.09765625	True
14:03:40.191	4	0.32	12.10546875	True
14:03:40.211	4	0.32	12.09765625	True
14:03:40.231	4	0.32	12.09375	True
14:03:40.251	4	0.32	12.09765625	True
14:03:40.271	4	0.32	12.10546875	True
14:03:40.291	4	0.32	12.09375	True
14:03:40.311	4	0.32	12.11328125	True
14:03:40.331	3.5	1	255.99609375	False
14:03:40.351	3.5	1	255.99609375	False
14:03:40.371	3.5	1	255.99609375	False
14:03:40.391	3.5	1	255.99609375	False
14:03:40.411	3.5	1	255.99609375	False
14:03:40.431	3.5	1	255.99609375	False
14:03:40.451	3.5	1	255.99609375	False
14:03:40.471	3.5	1	255.99609375	False
14:03:40.491	3.5	1	255.99609375	False
14:03:40.511	3.5	1	255.99609375	False
14:03:40.531	3.5	1	255.99609375	False
14:03:40.551	3.5	1	255.99609375	False
14:03:40.571	3.5	1	255.99609375	False
14:03:40.591	3.5	1	255.99609375	False
14:03:40.611	3.5	1	255.99609375	False
14:03:40.631	3.5	1	255.99609375	False
14:03:40.651	3.5	1	255.99609375	False
14:03:40.671	3.5	1	255.99609375	False
14:03:40.691	3.5	1	255.99609375	False
14:03:40.711	3.5	1	255.99609375	False
14:03:40.731	3.5	1	255.99609375	False
14:03:40.751	3.5	1	255.99609375	False
14:03:40.771	3.5	1	255.99609375	False
14:03:40.791	3.5	1	255.99609375	False
14:03:40.811	3.5	1	255.99609375	False
14:03:40.831	3.5	1	255.99609375	False
14:03:40.851	3.5	1	255.99609375	False
14:03:40.871	3.5	1	255.99609375	False
14:03:40.891	3.5	1	255.99609375	False
14:03:40.911	3.5	1	255.99609375	False
14:03:40.931	3.5	1	255.99609375	False
14:03:40.951	3.5	1	255.99609375	False
14:03:40.971	3.5	1	255.99609375	False
14:03:40.991	3.5	1	255.99609375	False
14:03:41.011	3.5	1	255.99609375	False
14:03:41.031	3.5	1	255.99609375	False
14:03:41.051	3.5	1	255.99609375	False
14:03:41.071	3.5	1	255.99609375	False
14:03:41.091	3.5	1	255.99609375	False
14:03:41.111	3.5	1	255.99609375	False
14:03:41.131	3.5	1	255.99609375	False
14:03:41.151	3.5	1	255.99609375	False
14:03:41.171	3.5	1	255.99609375	False
14:03:41.191	3.5	1	255.99609375	False
14:03:41.211	3.5	1	255.99609375	False
14:03:41.231	3.5	1	255.99609375	False
14:03:41.251	3.5	1	255.99609375	False
14:03:41.271	3.5	1	255.99609375	False
14:03:41.291	3.5	1	255.99609375	False
14:03:41.311	3.5	1	255.99609375	False
14:03:41.331	3.5	1	255.99609375	False
14:03:41.351	3.5	1	255.99609375	False
14:03:41.371	3.5	1	255.99609375	False
14:03:41.391	3.5	1	255.99609375	False
14:03:41.411	3.5	1	255.99609375	False
14:03:41.431	3.5	1	255.99609375	False
14:03:41.451	3.5	1	255.99609375	False
14:03:41.471	3.5	1	255.99609375	False
14:03:41.491	3.5	1	255.99609375	False
14:03:41.511	3.5	1	255.99609375	False
14:03:41.531	3.5	1	255.99609375	False
14:03:41.551	3.5	1	255.99609375	False
14:03:41.571	3.5	1	255.99609375	False
14:03:41.591	3.5	1	255.99609375	False
14:03:41.611	3.5	1	255.99609375	False
14:03:41.631	3.5	1	255.99609375	False
14:03:41.651	3.5	1	255.99609375	False
14:03:41.671	3.5	1	255.99609375	False
14:03:41.691	3.5	1	255.99609375	False
14:03:41.711	3.5	1	255.99609375	False
14:03:41.731	3.5	1	255.99609375	False
14:03:41.751	3.5	1	255.99609375	False
14:03:41.771	3.5	1	255.99609375	False
14:03:41.791	3.5	1	255.99609375	False
14:03:41.811	3.5	1	255.99609375	False
14:03:41.831	3.5	1	255.99609375	False
14:03:41.851	3.5	1	255.99609375	False
14:03:41.871	3.5	1.04	255.99609375	False
14:03:41.891	3.5	1.04	255.99609375	False
14:03:41.911	3.5	1.04	255.99609375	False
14:03:41.931	3.5	1.04	255.99609375	False
14:03:41.951	3.5	1.04	255.99609375	False
14:03:41.971	3.5	1.04	255.99609375	False
14:03:41.991	3.5	1.04	255.99609375	False
14:03:42.011	3.5	1.04	255.99609375	False
14:03:42.031	3.5	1.04	255.99609375	False
14:03:42.051	3.5	1.04	255.99609375	False
14:03:42.071	3.5	1.04	255.99609375	False
14:03:42.091	3.5	1.04	255.99609375	False
14:03:42.111	3.5	1.04	255.99609375	False
14:03:42.131	3.5	1.04	255.99609375	False
14:03:42.151	3.5	1.04	255.99609375	False
14:03:42.171	3.5	1.04	255.99609375	False
14:03:42.191	3.5	1.04	255.99609375	False
14:03:42.211	3.5	1.04	255.99609375	False
14:03:42.231	3.5	1.04	255.99609375	False
14:03:42.251	3.5	1.04	255.99609375	False
14:03:42.271	3.5	1.04	255.99609375	False
14:03:42.291	3.5	1.04	255.99609375	False
14:03:42.311	3.5	1.04	255.99609375	False
14:03:42.331	3.5	1.04	255.99609375	False
14:03:42.351	3.5	1.04	255.99609375	False
14:03:42.371	3.5	1.04	12.0859375	True
14:03:42.391	3.5	1.04	12.0859375	True
14:03:42.411	3.5	1.04	12.0859375	True
14:03:42.431	3.5	1.04	12.0859375	True
14:03:42.451	3.5	1.04	12.0859375	True
14:03:42.471	3.5	1.04	12.0859375	True
14:03:42.491	3.5	1.04	12.09375	False
14:03:42.511	3.5	1.04	12.09375	False
14:03:42.531	3.5	1.04	12.08203125	False
14:03:42.551	3.5	1.04	12.08203125	False
14:03:42.571	3.5	1.04	12.08203125	False
14:03:42.591	3.5	1.04	12.09375	False
14:03:42.611	3.5	1.04	12.0859375	False
14:03:42.631	3.5	1.04	12.09375	True
14:03:42.651	3.5	1.04	12.09375	True
14:03:42.671	3.5	1.04	12.09375	False
14:03:42.691	3.5	1.04	12.09765625	False
14:03:42.711	3.5	1.04	12.09375	False
14:03:42.731	3.5	1.04	12.08203125	False
14:03:42.751	3.5	1.04	12.09375	True
14:03:42.771	3.5	1.04	12.09765625	False
14:03:42.791	3.5	1.04	12.09375	False
14:03:42.811	3.5	1.04	12.09375	False
14:03:42.831	3.5	1.04	12.10546875	True
14:03:42.851	3.5	1.04	12.09765625	False
14:03:42.871	3.5	1.04	12.09765625	False
14:03:42.891	3.5	1.04	12.09375	False
14:03:42.911	3.5	1.04	12.09375	False
14:03:42.931	3.5	1.04	12.09765625	True
14:03:42.951	3.5	1.04	12.09765625	False
14:03:42.971	3.5	1.04	12.09765625	False
14:03:42.991	3.5	1.04	12.09765625	True
14:03:43.011	3.5	1.04	12.09765625	True
14:03:43.031	3.5	1.04	12.09765625	True
14:03:43.051	3.5	0.32	12.11328125	True
14:03:43.071	3.5	0.32	12.10546875	True
14:03:43.091	3.5	0.32	12.09765625	True
14:03:43.111	3.5	0.32	12.09765625	True
14:03:43.131	3.5	0.32	12.11328125	True
14:03:43.151	3.5	0.32	12.09765625	True
14:03:43.171	3.5	0.32	12.09765625	True
14:03:43.191	3.5	0.32	12.09375	True
14:03:43.211	3.5	0.32	12.09375	True
14:03:43.231	3.5	0.32	12.09375	True
14:03:43.251	3.5	0.32	12.09375	True
14:03:43.271	3.5	0.32	12.0859375	True
14:03:43.291	3.5	0.32	12.09765625	True
14:03:43.311	3.5	0.32	12.09375	True
14:03:43.331	3	1	255.99609375	False
14:03:43.351	3	1	255.99609375	False
14:03:43.371	3	1	255.99609375	False
14:03:43.391	3	1	255.99609375	False
14:03:43.411	3	1	255.99609375	False
14:03:43.431	3	1	255.99609375	False
14:03:43.451	3	1	255.99609375	False
14:03:43.471	3	1	255.99609375	False
14:03:43.491	3	1	255.99609375	False
14:03:43.511	3	1	255.99609375	False
14:03:43.531	3	1	255.99609375	False
14:03:43.551	3	1	255.99609375	False
14:03:43.571	3	1	255.99609375	False
14:03:43.591	3	1	255.99609375	False
14:03:43.611	3	1	255.99609375	False
14:03:43.631	3	1	255.99609375	False
14:03:43.651	3	1	255.99609375	False
14:03:43.671	3	1	255.99609375	False
14:03:43.691	3	1	255.99609375	False
14:03:43.711	3	1	255.99609375	False
14:03:43.731	3	1	255.99609375	False
14:03:43.751	3	1	255.99609375	False
14:03:43.771	3	1	255.99609375	False
14:03:43.791	3	1	255.99609375	False
14:03:43.811	3	1	255.99609375	False
14:03:43.831	3	1	255.99609375	False
14:03:43.851	3	1	255.99609375	False
14:03:43.871	3	1	255.99609375	False
14:03:43.891	3	1	255.99609375	False
14:03:43.911	3	1	255.99609375	False
14:03:43.931	3	1	255.99609375	False
14:03:43.951	3	1	255.99609375	False
14:03:43.971	3	1	255.99609375	False
14:03:43.991	3	1	255.99609375	False
14:03:44.011	3	1	255.99609375	False
14:03:44.031	3	1	255.99609375	False
14:03:44.051	3	1	255.99609375	False
14:03:44.071	3	1	255.99609375	False
14:03:44.091	3	1	255.99609375	False
14:03:44.111	3	1	255.99609375	False
14:03:44.131	3	1	255.99609375	False
14:03:44.151	3	1	255.99609375	False
14:03:44.171	3	1	255.99609375	False
14:03:44.191	3	1	255.99609375	False
14:03:44.211	3	1	255.99609375	False
14:03:44.231	3	1	255.99609375	False
14:03:44.251	3	1	255.99609375	False
14:03:44.271	3	1	255.99609375	False
14:03:44.291	3	1	255.99609375	False
14:03:44.311	3	1	255.99609375	False
14:03:44.331	3	1	255.99609375	False
14:03:44.351	3	1	255.99609375	False
14:03:44.371	3	1	255.99609375	False
14:03:44.391	3	1.04	255.99609375	False
14:03:44.411	3	1.04	255.99609375	False
14:03:44.431	3	1.04	255.99609375	False
14:03:44.451	3	1.04	255.99609375	False
14:03:44.471	3	1.04	255.99609375	False
14:03:44.491	3	1.04	255.99609375	False
14:03:44.511	3	1.04	255.99609375	False
14:03:44.531	3	1.04	255.99609375	False
14:03:44.551	3	1.04	255.99609375	False
14:03:44.571	3	1.04	255.99609375	False
14:03:44.591	3	1.04	255.99609375	False
14:03:44.611	3	1.04	255.99609375	False
14:03:44.631	3	1.04	255.99609375	False
14:03:44.651	3	1.04	255.99609375	False
14:03:44.671	3	1.04	255.99609375	False
14:03:44.691	3	1.04	255.99609375	False
14:03:44.711	3	1.04	255.99609375	False
14:03:44.731	3	1.04	255.99609375	False
14:03:44.751	3	1.04	255.99609375	False
14:03:44.771	3	1.04	255.99609375	False
14:03:44.791	3	1.04	255.99609375	False
14:03:44.811	3	1.04	255.99609375	False
14:03:44.831	3	1.04	255.99609375	False
14:03:44.851	3	1.04	255.99609375	False
14:03:44.871	3	1.04	255.99609375	False
14:03:44.891	3	1	255.99609375	False
14:03:44.911	3	1	255.99609375	False
14:03:44.931	3	1	255.99609375	False
14:03:44.951	3	1	255.99609375	False
14:03:44.971	3	1	255.99609375	False
14:03:44.991	3	1	255.99609375	False
14:03:45.011	3	1	255.99609375	False
14:03:45.031	3	1	255.99609375	False
14:03:45.051	3	1	255.99609375	False
14:03:45.071	3	1	255.99609375	False
14:03:45.091	3	1	255.99609375	False
14:03:45.111	3	1	255.99609375	False
14:03:45.131	3	1	255.99609375	False
14:03:45.151	3	1	255.99609375	False
14:03:45.171	3	1	255.99609375	False
14:03:45.191	3	1	255.99609375	False
14:03:45.211	3	1	255.99609375	False
14:03:45.231	3	1	255.99609375	False
14:03:45.251	3	1	255.99609375	False
14:03:45.271	3	1	255.99609375	False
14:03:45.291	3	1	255.99609375	False
14:03:45.311	3	1	255.99609375	False
14:03:45.331	3	1	255.99609375	False
14:03:45.351	3	1	255.99609375	False
14:03:45.371	3	1	255.99609375	False
14:03:45.391	3	1	12.09765625	True
14:03:45.411	3	1	12.09765625	True
14:03:45.431	3	1	12.09765625	True
14:03:45.451	3	1	12.09765625	True
14:03:45.471	3	1	12.09765625	True
14:03:45.491	3	1	12.09765625	True
14:03:45.511	3	1	12.09765625	False
14:03:45.531	3	1	12.10546875	False
14:03:45.551	3	1	12.09765625	False
14:03:45.571	3	1	12.10546875	False
14:03:45.591	3	1	12.10546875	False
14:03:45.611	3	1	12.10546875	False
14:03:45.631	3	1	12.09375	False
14:03:45.651	3	1	12.10546875	False
14:03:45.671	3	1	12.10546875	True
14:03:45.691	3	1	12.09375	False
14:03:45.711	3	1	12.09765625	False
14:03:45.731	3	1	12.10546875	True
14:03:45.751	3	1	12.09765625	False
14:03:45.771	3	1	12.10546875	False
14:03:45.791	3	1	12.09375	False
14:03:45.811	3	1	12.09375	False
14:03:45.831	3	1	12.09765625	False
14:03:45.851	3	1	12.09765625	False
14:03:45.871	3	1	12.09765625	True
14:03:45.891	3	1	12.0859375	False
14:03:45.911	3	1	12.09375	False
14:03:45.931	3	1	12.09375	False
14:03:45.951	3	1	12.09375	False
14:03:45.971	3	1	12.09765625	False
14:03:45.991	3	1	12.10546875	False
14:03:46.011	3	1	12.09765625	True
14:03:46.031	3	1	12.11328125	True
14:03:46.051	3	0.32	12.09765625	True
14:03:46.071	3	0.32	12.09375	True
14:03:46.091	3	0.32	12.09375	True
14:03:46.111	3	0.32	12.09375	True
14:03:46.131	3	0.32	12.09375	True
14:03:46.151	3	0.32	12.0859375	True
14:03:46.171	3	0.32	12.09375	True
14:03:46.191	3	0.32	12.09765625	True
14:03:46.211	3	0.32	12.0859375	True
14:03:46.231	3	0.32	12.0859375	True
14:03:46.251	3	0.32	12.09375	True
14:03:46.271	3	0.32	12.09765625	True
14:03:46.291	3	0.32	12.0859375	True
14:03:46.311	3	0.32	12.09765625	True
14:03:46.331	3	0.32	12.09765625	True
14:03:46.351	3	0.32	12.09765625	True
14:03:46.371	3	0.32	12.09765625	True
14:03:46.391	3.5	1	255.99609375	False
14:03:46.411	3.5	1	255.99609375	False
14:03:46.431	3.5	1	255.99609375	False
14:03:46.451	3.5	1	255.99609375	False
14:03:46.471	3.5	1	255.99609375	False
14:03:46.491	3.5	1	255.99609375	False
14:03:46.511	3.5	1	255.99609375	False
14:03:46.531	3.5	1	255.99609375	False
14:03:46.551	3.5	1	255.99609375	False
14:03:46.571	3.5	1	255.99609375	False
14:03:46.591	3.5	1	255.99609375	False
14:03:46.611	3.5	1	255.99609375	False
14:03:46.631	3.5	1	255.99609375	False
14:03:46.651	3.5	1	255.99609375	False
14:03:46.671	3.5	1	255.99609375	False
14:03:46.691	3.5	1	255.99609375	False
14:03:46.711	3.5	1	255.99609375	False
14:03:46.731	3.5	1	255.99609375	False
14:03:46.751	3.5	1	255.99609375	False
14:03:46.771	3.5	1	255.99609375	False
14:03:46.791	3.5	1	255.99609375	False
14:03:46.811	3.5	1	255.99609375	False
14:03:46.831	3.5	1	255.99609375	False
14:03:46.851	3.5	1	255.99609375	False
14:03:46.871	3.5	1	255.99609375	False
14:03:46.891	3.5	1	255.99609375	False
14:03:46.911	3.5	1	255.99609375	False
14:03:46.931	3.5	1	255.99609375	False
14:03:46.951	3.5	1	255.99609375	False
14:03:46.971	3.5	1	255.99609375	False
14:03:46.991	3.5	1	255.99609375	False
14:03:47.011	3.5	1	255.99609375	False
14:03:47.031	3.5	1	255.99609375	False
14:03:47.051	3.5	1	255.99609375	False
14:03:47.071	3.5	1	255.99609375	False
14:03:47.091	3.5	1	255.99609375	False
14:03:47.111	3.5	1	255.99609375	False
14:03:47.131	3.5	1	255.99609375	False
14:03:47.151	3.5	1	255.99609375	False
14:03:47.171	3.5	1	255.99609375	False
14:03:47.191	3.5	1	255.99609375	False
14:03:47.211	3.5	1	255.99609375	False
14:03:47.231	3.5	1	255.99609375	False
14:03:47.251	3.5	1	255.99609375	False
14:03:47.271	3.5	1	255.99609375	False
14:03:47.291	3.5	1	255.99609375	False
14:03:47.311	3.5	1	255.99609375	False
14:03:47.331	3.5	1	255.99609375	False
14:03:47.351	3.5	1	255.99609375	False
14:03:47.371	3.5	1	255.99609375	False
14:03:47.391	3.5	1	255.99609375	False
14:03:47.411	3.5	1	255.99609375	False
14:03:47.431	3.5	1	255.99609375	False
14:03:47.451	3.5	1	255.99609375	False
14:03:47.471	3.5	1	255.99609375	False
14:03:47.491	3.5	1	255.99609375	False
14:03:47.511	3.5	1	255.99609375	False
14:03:47.531	3.5	1	255.99609375	False
14:03:47.551	3.5	1	255.99609375	False
14:03:47.571	3.5	1	255.99609375	False
14:03:47.591	3.5	1	255.99609375	False
14:03:47.611	3.5	1	255.99609375	False
14:03:47.631	3.5	1	255.99609375	False
14:03:47.651	3.5	1	255.99609375	False
14:03:47.671	3.5	1	255.99609375	False
14:03:47.691	3.5	1	255.99609375	False
14:03:47.711	3.5	1	255.99609375	False
14:03:47.731	3.5	1	255.99609375	False
14:03:47.751	3.5	1	255.99609375	False
14:03:47.771	3.5	1	255.99609375	False
14:03:47.791	3.5	1	255.99609375	False
14:03:47.811	3.5	1	255.99609375	False
14:03:47.831	3.5	1	255.99609375	False
14:03:47.851	3.5	1	255.99609375	False
14:03:47.871	3.5	1	255.99609375	False
14:03:47.891	3.5	1	255.99609375	False
14:03:47.911	3.5	1	255.99609375	False
14:03:47.931	3.5	1	255.99609375	False
14:03:47.951	3.5	1	255.99609375	False
14:03:47.971	3.5	1	255.99609375	False
14:03:47.991	3.5	1	255.99609375	False
14:03:48.011	3.5	1	255.99609375	False
14:03:48.031	3.5	1	255.99609375	False
14:03:48.051	3.5	1	255.99609375	False
14:03:48.071	3.5	1	255.99609375	False
14:03:48.091	3.5	1	255.99609375	False
14:03:48.111	3.5	1	255.99609375	False
14:03:48.131	3.5	1	255.99609375	False
14:03:48.151	3.5	1	255.99609375	False
14:03:48.171	3.5	1	255.99609375	False
14:03:48.191	3.5	1	255.99609375	False
14:03:48.211	3.5	1	255.99609375	False
14:03:48.231	3.5	1	255.99609375	False
14:03:48.251	3.5	1	255.99609375	False
14:03:48.271	3.5	1	255.99609375	False
14:03:48.291	3.5	1	255.99609375	False
14:03:48.311	3.5	1	255.99609375	False
14:03:48.331	3.5	1	255.99609375	False
14:03:48.351	3.5	1	255.99609375	False
14:03:48.371	3.5	1	255.99609375	False
14:03:48.391	3.5	1	255.99609375	False
14:03:48.411	3.5	1	255.99609375	False
14:03:48.431	3.5	1	255.99609375	False
14:03:48.451	3.5	1	12.09765625	True
14:03:48.471	3.5	1	12.09765625	True
14:03:48.491	3.5	1	12.09765625	True
14:03:48.511	3.5	1	12.09765625	True
14:03:48.531	3.5	1	12.09765625	True
14:03:48.551	3.5	1	12.09765625	True
14:03:48.571	3.5	1	12.09765625	True
14:03:48.591	3.5	1	12.09375	False
14:03:48.611	3.5	1	12.09375	False
14:03:48.631	3.5	1	12.08203125	False
14:03:48.651	3.5	1	12.0859375	True
14:03:48.671	3.5	1	12.0859375	False
14:03:48.691	3.5	1	12.09765625	False
14:03:48.711	3.5	0.36	12.09765625	True
14:03:48.731	3.5	0.36	12.09765625	False
14:03:48.751	3.5	0.36	12.0859375	True
14:03:48.771	3.5	0.36	12.09375	False
14:03:48.791	3.5	0.36	12.09375	True
14:03:48.811	3.5	0.36	12.09375	False
14:03:48.831	3.5	0.36	12.09375	False
14:03:48.851	3.5	0.36	12.09375	True
14:03:48.871	3.5	0.36	12.09375	False
14:03:48.891	3.5	0.36	12.08203125	True
14:03:48.911	3.5	0.36	12.09375	False
14:03:48.931	3.5	0.36	12.08203125	False
14:03:48.951	3.5	0.36	12.0859375	True
14:03:48.971	3.5	0.36	12.10546875	False
14:03:48.991	3.5	0.36	12.09375	False
14:03:49.011	3.5	0.36	12.0859375	False
14:03:49.031	3.5	0.36	12.0859375	True
14:03:49.051	3.5	0.36	12.0859375	False
14:03:49.071	3.5	0.36	12.09375	False
14:03:49.091	3.5	0.36	12.08203125	False
14:03:49.111	3.5	0.36	12.09375	False
14:03:49.131	3.5	0.36	12.09375	False
14:03:49.151	3.5	0.36	12.09375	False
14:03:49.171	3.5	0.36	12.09375	False
14:03:49.191	3.5	0.36	12.09765625	True
14:03:49.211	3.5	0.36	12.09375	False
14:03:49.231	3.5	0.36	12.0859375	True
14:03:49.251	3.5	0.36	12.09765625	True
14:03:49.271	3.5	0.36	12.0859375	True
14:03:49.291	3.5	0.36	12.09765625	True
14:03:49.311	3.5	0.36	12.09375	True
14:03:49.331	3.5	0.36	12.08203125	True
14:03:49.351	3.5	0.36	12.10546875	True
14:03:49.371	3.5	0.36	12.09375	True
14:03:49.391	3.5	0.36	12.09765625	True
14:03:49.411	3.5	0.36	12.09765625	True
14:03:49.431	3.5	0.36	12.09765625	True
14:03:49.451	3.5	0.36	12.09375	True
14:03:49.471	3.5	0.36	12.09765625	True
14:03:49.491	3.5	0.36	12.0859375	True
14:03:49.511	3.5	0.36	12.09375	True
14:03:49.531	3.5	0.36	12.09375	True
14:03:49.551	3.5	1.08	255.99609375	False
14:03:49.571	3.5	1	255.99609375	False
14:03:49.591	3.5	1	255.99609375	False
14:03:49.611	3.5	1	255.99609375	False
14:03:49.631	3.5	1	255.99609375	False
14:03:49.651	3.5	1	255.99609375	False
14:03:49.671	3.5	1	255.99609375	False
14:03:49.691	3.5	1	255.99609375	False
14:03:49.711	3.5	1	255.99609375	False
14:03:49.731	3.5	1	255.99609375	False
14:03:49.751	3.5	1	255.99609375	False
14:03:49.771	3.5	1	255.99609375	False
14:03:49.791	3.5	1	255.99609375	False
14:03:49.811	3.5	1	255.99609375	False
14:03:49.831	3.5	1	255.99609375	False
14:03:49.851	3.5	1	255.99609375	False
14:03:49.871	3.5	1	255.99609375	False
14:03:49.891	3.5	1	255.99609375	False
14:03:49.911	3.5	1	255.99609375	False
14:03:49.931	3.5	1	255.99609375	False
14:03:49.951	3.5	1	255.99609375	False
14:03:49.971	3.5	1	255.99609375	False
14:03:49.991	3.5	1	255.99609375	False
14:03:50.011	3.5	1	255.99609375	False
14:03:50.031	3.5	1	255.99609375	False
14:03:50.051	3.5	1	255.99609375	False
14:03:50.071	3.5	1	255.99609375	False
14:03:50.091	3.5	1	255.99609375	False
14:03:50.111	3.5	1	255.99609375	False
14:03:50.131	3.5	1	255.99609375	False
14:03:50.151	3.5	1	255.99609375	False
14:03:50.171	3.5	1	255.99609375	False
14:03:50.191	3.5	1	255.99609375	False
14:03:50.211	3.5	1	255.99609375	False
14:03:50.231	3.5	1	255.99609375	False
14:03:50.251	3.5	1	255.99609375	False
14:03:50.271	3.5	1	255.99609375	False
14:03:50.291	3.5	1	255.99609375	False
14:03:50.311	3.5	1	255.99609375	False
14:03:50.331	3.5	1	255.99609375	False
14:03:50.351	3.5	1	255.99609375	False
14:03:50.371	3.5	1	255.99609375	False
14:03:50.391	3.5	1	255.99609375	False
14:03:50.411	3.5	1	255.99609375	False
14:03:50.431	3.5	1	255.99609375	False
14:03:50.451	3.5	1	255.99609375	False
14:03:50.471	3.5	1	255.99609375	False
14:03:50.491	3.5	1	255.99609375	False
14:03:50.511	3.5	1	255.99609375	False
14:03:50.531	3.5	1	255.99609375	False
14:03:50.551	3.5	1	255.99609375	False
14:03:50.571	3.5	1	255.99609375	False
14:03:50.591	3.5	1	255.99609375	False
14:03:50.611	3.5	1	255.99609375	False
14:03:50.631	3.5	1	255.99609375	False
14:03:50.651	3.5	1	255.99609375	False
14:03:50.671	3.5	1	255.99609375	False
14:03:50.691	3.5	1	255.99609375	False
14:03:50.711	3.5	1	255.99609375	False
14:03:50.731	3.5	1	255.99609375	False
14:03:50.751	3.5	1	255.99609375	False
14:03:50.771	3.5	1	255.99609375	False
14:03:50.791	3.5	1	255.99609375	False
14:03:50.811	3.5	1	255.99609375	False
14:03:50.831	3.5	1	255.99609375	False
14:03:50.851	3.5	1	255.99609375	False
14:03:50.871	3.5	1	255.99609375	False
14:03:50.891	3.5	1	255.99609375	False
14:03:50.911	3.5	1	255.99609375	False
14:03:50.931	3.5	1	255.99609375	False
14:03:50.951	3.5	1	255.99609375	False
14:03:50.971	3.5	1	255.99609375	False
14:03:50.991	3.5	0.92	12.09765625	True
14:03:51.011	3.5	0.92	12.09765625	True
14:03:51.031	3.5	0.92	12.09765625	True
14:03:51.051	3.5	0.92	12.09765625	True
14:03:51.071	3.5	0.92	12.09765625	True
14:03:51.091	3.5	0.92	12.09765625	True
14:03:51.111	3.5	0.92	12.09765625	True
14:03:51.131	3.5	0.92	12.09765625	True
14:03:51.151	3.5	0.92	12.09765625	True
14:03:51.171	3.5	0.92	12.09765625	True
14:03:51.191	3.5	0.92	12.09765625	True
14:03:51.211	3.5	0.92	12.09765625	True
14:03:51.231	3.5	0.92	12.09765625	True
14:03:51.251	3.5	0.92	12.09765625	True
14:03:51.271	3.5	0.92	12.09765625	True
14:03:51.291	3.5	0.92	12.09765625	True
14:03:51.311	3.5	0.92	12.09765625	True
14:03:51.331	3.5	0.92	12.09765625	True
14:03:51.351	3.5	0.92	12.09765625	True
14:03:51.371	3.5	0.92	12.09765625	True
14:03:51.391	3.5	0.92	12.09765625	True
14:03:51.411	3.5	0.92	12.09765625	True
14:03:51.431	3.5	0.92	12.09765625	True
14:03:51.451	3.5	0.92	12.09765625	False
14:03:51.471	3.5	0.92	12.10546875	False
14:03:51.491	3.5	0.92	12.09375	False
14:03:51.511	3.5	0.92	12.09375	False
14:03:51.531	3.5	0.92	12.09765625	True
14:03:51.551	3.5	0.92	12.09375	False
14:03:51.571	3.5	0.92	12.09765625	False
14:03:51.591	3.5	0.92	12.09375	False
14:03:51.611	3.5	0.92	12.09375	True
14:03:51.631	3.5	0.92	12.08203125	False
14:03:51.651	3.5	0.92	12.09375	False
14:03:51.671	3.5	0.92	12.09765625	False
14:03:51.691	3.5	0.92	12.09765625	False
14:03:51.711	3.5	0.92	12.10546875	False
14:03:51.731	3.5	0.92	12.09765625	False
14:03:51.751	3.5	0.92	12.09375	True
14:03:51.771	3.5	0.92	12.09375	False
14:03:51.791	3.5	0.92	12.09765625	False
14:03:51.811	3.5	0.92	12.10546875	False
14:03:51.831	3.5	0.92	12.0859375	True
14:03:51.851	3.5	0.92	12.0859375	False
14:03:51.871	3.5	0.92	12.09375	False
14:03:51.891	3.5	0.92	12.09375	False
14:03:51.911	3.5	0.92	12.0859375	False
14:03:51.931	3.5	0.92	12.07421875	True
14:03:51.951	3.5	0.92	12.09765625	True
14:03:51.971	3.5	0.92	12.09375	True
14:03:51.991	3.5	0.92	12.09765625	True
14:03:52.011	3.5	0.92	12.09765625	True
14:03:52.031	3.5	0.12	12.09375	True
14:03:52.051	3.5	0.12	12.0859375	True
14:03:52.071	3.5	0.12	12.0859375	True
14:03:52.091	3.5	0.12	12.09375	True
14:03:52.111	3.5	0.12	12.09375	True
14:03:52.131	3.5	1	255.99609375	False
14:03:52.151	3.5	1	255.99609375	False
14:03:52.171	3.5	1	255.99609375	False
14:03:52.191	3.5	1	255.99609375	False
14:03:52.211	3.5	1	255.99609375	False
14:03:52.231	3.5	1	255.99609375	False
14:03:52.251	3.5	1	255.99609375	False
14:03:52.271	3.5	1	255.99609375	False
14:03:52.291	3.5	1	255.99609375	False
14:03:52.311	3.5	1	255.99609375	False
14:03:52.331	3.5	1	255.99609375	False
14:03:52.351	3.5	1	255.99609375	False
14:03:52.371	3.5	1	255.99609375	False
14:03:52.391	3.5	1	255.99609375	False
14:03:52.411	3.5	1	255.99609375	False
14:03:52.431	3.5	1	255.99609375	False
14:03:52.451	3.5	1	255.99609375	False
14:03:52.471	3.5	1	255.99609375	False
14:03:52.491	3.5	1	255.99609375	False
14:03:52.511	3.5	1	255.99609375	False
14:03:52.531	3.5	1	255.99609375	False
14:03:52.551	3.5	1	255.99609375	False
14:03:52.571	3.5	1	255.99609375	False
14:03:52.591	3.5	1	255.99609375	False
14:03:52.611	3.5	1	255.99609375	False
14:03:52.631	3.5	1	255.99609375	False
14:03:52.651	3.5	1	255.99609375	False
14:03:52.671	3.5	1	255.99609375	False
14:03:52.691	3.5	1	255.99609375	False
14:03:52.711	3.5	1	255.99609375	False
14:03:52.731	3.5	1	255.99609375	False
14:03:52.751	3.5	1	255.99609375	False
14:03:52.771	3.5	1	255.99609375	False
14:03:52.791	3.5	1	255.99609375	False
14:03:52.811	3.5	1	255.99609375	False
14:03:52.831	3.5	1	255.99609375	False
14:03:52.851	3.5	1	255.99609375	False
14:03:52.871	3.5	1	255.99609375	False
14:03:52.891	3.5	1	255.99609375	False
14:03:52.911	3.5	1	255.99609375	False
14:03:52.931	3.5	1	255.99609375	False
14:03:52.951	3.5	1	255.99609375	False
14:03:52.971	3.5	1	255.99609375	False
14:03:52.991	3.5	1	255.99609375	False
14:03:53.011	3.5	1	255.99609375	False
14:03:53.031	3.5	1	255.99609375	False
14:03:53.051	3.5	1	255.99609375	False
14:03:53.071	3.5	1	255.99609375	False
14:03:53.091	3.5	1	255.99609375	False
14:03:53.111	3.5	1	255.99609375	False
14:03:53.131	3.5	1	255.99609375	False
14:03:53.151	3.5	1	255.99609375	False
14:03:53.171	3.5	1	255.99609375	False
14:03:53.191	3.5	1	255.99609375	False
14:03:53.211	3.5	1	255.99609375	False
14:03:53.231	3.5	1	255.99609375	False
14:03:53.251	3.5	1	255.99609375	False
14:03:53.271	3.5	1	255.99609375	False
14:03:53.291	3.5	1	255.99609375	False
14:03:53.311	3.5	1	255.99609375	False
14:03:53.331	3.5	1	255.99609375	False
14:03:53.351	3.5	1	255.99609375	False
14:03:53.371	3.5	1	255.99609375	False
14:03:53.391	3.5	1	255.99609375	False
14:03:53.411	3.5	1	255.99609375	False
14:03:53.431	3.5	1	255.99609375	False
14:03:53.451	3.5	1	255.99609375	False
14:03:53.471	3.5	1	255.99609375	False
14:03:53.491	3.5	1	255.99609375	False
14:03:53.511	3.5	1	255.99609375	False
14:03:53.531	3.5	1	255.99609375	False
14:03:53.551	3.5	1	255.99609375	False
14:03:53.571	3.5	1	255.99609375	False
14:03:53.591	3.5	1	255.99609375	False
14:03:53.611	3.5	1	255.99609375	False
14:03:53.631	3.5	1	255.99609375	False
14:03:53.651	3.5	1	255.99609375	False
14:03:53.671	3.5	1	255.99609375	False
14:03:53.691	3.5	1	255.99609375	False
14:03:53.711	3.5	1	255.99609375	False
14:03:53.731	3.5	1	255.99609375	False
14:03:53.751	3.5	1	255.99609375	False
14:03:53.771	3.5	1	255.99609375	False
14:03:53.791	3.5	1	255.99609375	False
14:03:53.811	3.5	1	255.99609375	False
14:03:53.831	3.5	1	255.99609375	False
14:03:53.851	3.5	1	255.99609375	False
14:03:53.871	3.5	1	255.99609375	False
14:03:53.891	3.5	1	255.99609375	False
14:03:53.911	3.5	1	255.99609375	False
14:03:53.931	3.5	1	255.99609375	False
14:03:53.951	3.5	1	255.99609375	False
14:03:53.971	3.5	1	255.99609375	False
14:03:53.991	3.5	1	255.99609375	False
14:03:54.011	3.5	1	255.99609375	False
14:03:54.031	3.5	1	255.99609375	False
14:03:54.051	3.5	1	255.99609375	False
14:03:54.071	3.5	1	255.99609375	False
14:03:54.091	3.5	1	255.99609375	False
14:03:54.111	3.5	1	255.99609375	False
14:03:54.131	3.5	1	255.99609375	False
14:03:54.151	3.5	1	255.99609375	False
14:03:54.171	3.5	1	255.99609375	False
14:03:54.191	3.5	1	255.99609375	False
14:03:54.211	3.5	1	255.99609375	False
14:03:54.231	3.5	1	255.99609375	False
14:03:54.251	3.5	1	255.99609375	False
14:03:54.271	3.5	1	255.99609375	False
14:03:54.291	3.5	1	255.99609375	False
14:03:54.311	3.5	1	255.99609375	False
14:03:54.331	3.5	1	255.99609375	False
14:03:54.351	3.5	1	255.99609375	False
14:03:54.371	3.5	1	255.99609375	False
14:03:54.391	3.5	1	255.99609375	False
14:03:54.411	3.5	1	255.99609375	False
14:03:54.431	3.5	1	255.99609375	False
14:03:54.451	3.5	1	255.99609375	False
14:03:54.471	3.5	1	255.99609375	False
14:03:54.491	3.5	1	255.99609375	False
14:03:54.511	3.5	1	255.99609375	False
14:03:54.531	3.5	1	255.99609375	False
14:03:54.551	3.5	1	255.99609375	False
14:03:54.571	3.5	1	255.99609375	False
14:03:54.591	3.5	1	255.99609375	False
14:03:54.611	3.5	1	255.99609375	False
14:03:54.631	3.5	1	255.99609375	False
14:03:54.651	3.5	1	255.99609375	False
14:03:54.671	3.5	1	255.99609375	False
14:03:54.691	3.5	1	255.99609375	False
14:03:54.711	3.5	1	255.99609375	False
14:03:54.731	3.5	1	255.99609375	False
14:03:54.751	3.5	1	255.99609375	False
14:03:54.771	3.5	1	255.99609375	False
14:03:54.791	3.5	1	255.99609375	False
14:03:54.811	3.5	1	255.99609375	False
14:03:54.831	3.5	1	255.99609375	False
14:03:54.851	3.5	1	255.99609375	False
14:03:54.871	3.5	1	255.99609375	False
14:03:54.891	3.5	1	255.99609375	False
14:03:54.911	3.5	1	255.99609375	False
14:03:54.931	3.5	1	255.99609375	False
14:03:54.951	3.5	1	255.99609375	False
14:03:54.971	3.5	1	255.99609375	False
14:03:54.991	3.5	1	255.99609375	False
14:03:55.011	3.5	1	255.99609375	False
14:03:55.031	3.5	1	255.99609375	False
14:03:55.051	3.5	1	255.99609375	False
14:03:55.071	3.5	1	255.99609375	False
14:03:55.091	3.5	1	255.99609375	False
14:03:55.111	3.5	1	255.99609375	False
14:03:55.131	3.5	1	255.99609375	False
14:03:55.151	3.5	1	255.99609375	False
14:03:55.171	3.5	1	255.99609375	False
14:03:55.191	3.5	1	255.99609375	False
14:03:55.211	3.5	1	255.99609375	False
14:03:55.231	3.5	1	255.99609375	False
14:03:55.251	3.5	1	255.99609375	False
14:03:55.271	3.5	1	255.99609375	False
14:03:55.291	3.5	1	255.99609375	False
14:03:55.311	3.5	1	255.99609375	False
14:03:55.331	3.5	1	255.99609375	False
14:03:55.351	3.5	1	255.99609375	False
14:03:55.371	3.5	1	255.99609375	False
14:03:55.391	3.5	1	255.99609375	False
14:03:55.411	3.5	1	255.99609375	False
14:03:55.431	3.5	1	255.99609375	False
14:03:55.451	3.5	1	255.99609375	False
14:03:55.471	3.5	1	255.99609375	False
14:03:55.491	3.5	1	255.99609375	False
14:03:55.511	3.5	1	255.99609375	False
14:03:55.531	3.5	1	255.99609375	False
14:03:55.551	3.5	1	255.99609375	False
14:03:55.571	3.5	1	255.99609375	False
14:03:55.591	3.5	1	255.99609375	False
14:03:55.611	3.5	1	255.99609375	False
14:03:55.631	3.5	1	255.99609375	False
14:03:55.651	3.5	1	255.99609375	False
14:03:55.671	3.5	1	255.99609375	False
14:03:55.691	3.5	1	255.99609375	False
14:03:55.711	3.5	1	255.99609375	False
14:03:55.731	3.5	1	255.99609375	False
14:03:55.751	3.5	1	255.99609375	False
14:03:55.771	3.5	1	255.99609375	False
14:03:55.791	3.5	1	255.99609375	False
14:03:55.811	3.5	1	255.99609375	False
14:03:55.831	3.5	1	255.99609375	False
14:03:55.851	3.5	1	255.99609375	False
14:03:55.871	3.5	1	255.99609375	False
14:03:55.891	3.5	1	255.99609375	False
14:03:55.911	3.5	1	255.99609375	False
14:03:55.931	3.5	1	255.99609375	False
14:03:55.951	3.5	1	255.99609375	False
14:03:55.971	3.5	1	255.99609375	False
14:03:55.991	3.5	1	255.99609375	False
14:03:56.011	3.5	1	255.99609375	False
14:03:56.031	3.5	1	255.99609375	False
14:03:56.051	3.5	1	255.99609375	False
14:03:56.071	3.5	1	255.99609375	False
14:03:56.091	3.5	1	255.99609375	False
14:03:56.111	3.5	1	255.99609375	False
14:03:56.131	3.5	1	255.99609375	False
14:03:56.151	3.5	1	255.99609375	False
14:03:56.171	3.5	1	255.99609375	False
That’s a log of when the robot was connected at 2.4Ghz, but we found an USB adapter that supports 5Ghz band and started trying to use it. Yesterday we only got a connection once and after that it could not even get a connection started at all. Today, for no apparent reason, it was able to connect no problem and avoid receiving any interference. Which is strange because the school techie came in today and re-enabled the nearest router to us after turning it off yesterday. The schools Wi-Fi is also in the 5Ghz band so a problem with interference could still happen. Biggest of all we also tried the same setup last year and it did not solve the problem. For now we’ll call the problem solved and thank you for your time.
Update: Long story short, we didn’t setup a second router. We tried a USB Wi-Fi adapter to go 5Ghz, and it did clean up the signal somewhat. Later the school techie rebuilt an old laptop for us to use that is much more powerful than our previous laptop and supports 5Ghz my default. New problem that has evolved through the last week is that RoboRIO and the router refuse to communicate with each other.
Are you using the same RoboRio as last year? Have you tried a different location (you don’t need the whole robot)?
Same RoboRIO as last year, which is currently our only one. When connected to the router via Wi-Fi, the DS can ping the router but not the RoboRIO. However, when the laptop is tethered either with USB or Ethernet it can communicate just fine, and we can ping both 172.22.11.1 and roboRIO-6188-FRC.local and get responses. Far as I can tell everything is set DHCP and to obtain address automatically. I don’t believe we are having packet loss issue anymore, as we have had the DS and robot communicate once or twice out of way too many tries and it wasn’t showing packet loss anymore.
At our next opportunity I guess our next action would be to take RoboRIO and the router out of the robot and try to truly isolate them and see if they play nice with each other then.
Keep posting update on here… I have the same issues going on. If i figure i tout ill post my resolution.
On your laptop, see how many other WiFi systems are in the vicinity. If there are a lot, you will have more competition for the spectrum.
Try taking your RoboRio, radio and laptop to somewhere where there are few or no other WiFi networks. If the link quality improves, you are having too much competition for the radio spectrum from the systems at your workshop. If the link quality does not improve, you may have some bad setting or bad hardware. Try other laptops and borrow a radio from another team.
Update: Things are getting stranger. We were able to get a wifi connection to start and hold after tethering the robot with a USB cable and then unplugging the cable. Haven’t been able to make it happen again though.
Interference doesn’t look like a culprit as almost all other networks in range are 2.4Ghz and we are using 5Ghz. The couple 5Ghz networks in range are not nearly as strong as ours. We have also tried other laptops with different versions of Windows to try driving it as well.
We’ve re-imaged RoboRIO and the router but it looks like they still won’t communicate with each other.
We had this issue with version 17.3 of the radio configuration utility. Rolling back to 17.2 fixed the issue for us.
Same here, but only when using last year’s radio model. The new model works fine for us with the 17.3 update.
Today it crossed my mind to check the Event viewer to see if it was spitting out any errors. I was right.
The description for Event ID 100 from source niZeroconfService cannot be found. Either the component that raises this event is not installed on your local computer or the installation is corrupted. You can install or repair the component on the local computer.
If the event originated on another computer, the display information had to be saved with the event.
The following information was included with the event:
AppendDNSNameString: Illegal empty label in name “.lan”
The specified resource type cannot be found in the image file*
So, is this an mDNS issue then? We’ve already uninstalled it and reinstalled it with the update suite.
If you think its a mDNS issue you can try and install iTunes, that fixes most mDNS issues.
