My team is having trouble with setting up our d-link for home use.
The radio seems to work on a robot programmed for recycle rush. However when we switch it over to a aerial assist bot we can not even get communications with the router.
Does anyone know how to fix?
P.s. How does one reset router set up for competion to home use?
You may not to be able to connect for a few reasons.
Assuming you are still using a cRIO on your 2014 robot, you will need to change the protocol on the Driver Station under settings to 09’-14’ DS & FMS
Your bridge may still be in competiton mode. If you have not re-congfigured it since your last competiton (including off season events) you need to switch the switch on the back of the bridge to “AP” and re-configure it using the bridge re-configuring tool.
