Hello, we just finished flashing and configuring a OM5P-AN router, and we are able to successfully deploy code by connecting the router to our RIO via tether, but we aren’t able to interface with it to set static IP’s. We need to do this because we are using opencv & python for vision processing which require static IP’s. Does anyone know how to access the interface? Thanks a lot!
The radio already has been given a static IP of 10.2.19.1 by the configuration utility.
This year the radio firmware does not include a web server, so you can’t browse to it and change settings.
Ok thank you, so the only thing else we are confused with is setting static IP’s for things like the raspberry pi?
You have to set it as a static IP on the raspberry PI itself.
https://www.modmypi.com/blog/how-to-give-your-raspberry-pi-a-static-ip-address-update
