Hi,
My team and I are using RPI to do vision processing. We write the code in python, and we recently found out that whenever we connect the RPI to a power source, we have to press the “run” button in the web browser in order for the RPI to run it’s code. Does anyone know if there’s any way to make the code run automatically whenever the RPI is plugged to a power source, without having to press run?
Are you using the WPILibPi image? If so, if you’re using the web dashboard to upload the code, it should set it up to run it on boot automatically (see The Raspberry PI — FIRST Robotics Competition documentation)
We are using the WPILibPi image, and we are using the web dashboard to upload the code, but for some reason the problem still occurs…
Maybe post/link to your Python program? While it should auto-restart if it exits, it’s possible it’s indeed running on boot and hanging due to when it starts? Some other things to check:
- After booting, ssh in and run
ps -a
to see ifpython3 uploaded.py
is running. - Check the contents of /home/pi/runCamera and see if it has a line to run python
Sorry for taking so long to answer. This is still in progress, and for the meantime it just finds the target’s corners. I’ll be happy to hear any suggestion you have. Anyway, this is the code:
import json
import sys
from cscore import CameraServer, VideoSource, UsbCamera, MjpegServer
from networktables import NetworkTablesInstance
import cv2 as cv
import numpy as np
import math as m
team = 1690
server = True
lower_green = np.array([20, 30, 30])
upper_green = np.array([100, 255, 255])
output_frame = np.zeros(shape=(320, 240, 3), dtype=np.uint8)
def get_intersection(line1, line2):
a1 = line1[1] / line1[0]
a2 = line2[1] / line2[0]
b1 = line1[3] - (a1 * line1[2])
b2 = line2[3] - (a2 * line2[2])
x = (b2 - b1) / (a1 - a2)
y = a2 * x + b2
return (x, y)
configFile = "/boot/frc.json"
cameraConfigs = []
switchedCameraConfigs = []
cameras = []
class CameraConfig:
pass
def parseError(str):
"""Report parse error."""
print("config error in '" + configFile + "': " + str, file=sys.stderr)
def readCameraConfig(config):
"""Read single camera configuration."""
cam = CameraConfig()
# name
try:
cam.name = config["name"]
except KeyError:
parseError("could not read camera name")
return False
# path
try:
cam.path = config["path"]
except KeyError:
parseError("camera '{}': could not read path".format(cam.name))
return False
# stream properties
cam.streamConfig = config.get("stream")
cam.config = config
cameraConfigs.append(cam)
return True
def readSwitchedCameraConfig(config):
"""Read single switched camera configuration."""
# name
try:
except KeyError:
parseError("could not read switched camera name")
return False
# path
try:
cam.key = config["key"]
except KeyError:
parseError("switched camera '{}': could not read key".format(cam.name))
return False
switchedCameraConfigs.append(cam)
return True
def readConfig():
"""Read configuration file."""
global team
global server
# parse file
try:
with open(configFile, "rt", encoding="utf-8") as f:
j = json.load(f)
except OSError as err:
print("could not open '{}': {}".format(configFile, err),
file=sys.stderr)
return False
# top level must be an object
if not isinstance(j, dict):
parseError("must be JSON object")
return False
# team number
try:
team = j["team"]
except KeyError:
parseError("could not read team number")
return False
# ntmode (optional)
if "ntmode" in j:
str = j["ntmode"]
if str.lower() == "client":
server = False
elif str.lower() == "server":
server = True
else:
parseError("could not understand ntmode value '{}'".format(str))
# cameras
try:
cameras = j["cameras"]
except KeyError:
parseError("could not read cameras")
return False
for camera in cameras:
if not readCameraConfig(camera):
return False
# switched cameras
if "switched cameras" in j:
for camera in j["switched cameras"]:
if not readSwitchedCameraConfig(camera):
return False
return True
def startCamera(config):
"""Start running the camera."""
print("Starting camera '{}' on {}".format(config.name, config.path))
inst = CameraServer.getInstance()
camera = UsbCamera(config.name, config.path)
server = inst.startAutomaticCapture(camera=camera, return_server=True)
camera_data_file = open('camera_data', 'r')
try:
camera_data = json.load(camera_data_file)
config.config["brightness"] = camera_data["brightness"]
config.config["contrast"] = camera_data["contrast"]
config.config["saturation"] = camera_data["saturation"]
config.config["red_balance"] = camera_data["red_balance"]
config.config["blue_balance"] = camera_data["blue_balance"]
min_h = camera_data["min_h"]
min_s = camera_data["min_s"]
min_v = camera_data["min_v"]
max_h = camera_data["max_h"]
max_s = camera_data["max_s"]
max_v = camera_data["max_v"]
global lower_green
global upper_green
lower_green = np.array([min_h, min_s, min_v])
upper_green = np.array([max_h, max_s, max_v])
except:
print("Failed to read from json")
camera_data = {}
camera_data["brightness"] = 25
camera_data["contrast"] = 75
camera_data["saturation"] = 30
camera_data["red_balance"] = 1200
camera_data["blue_balance"] = 1500
camera_data["min_h"] = 30
camera_data["min_s"] = 100
camera_data["min_v"] = 30
camera_data["max_h"] = 90
camera_data["max_s"] = 255
camera_data["max_v"] = 255
camera_data_json = json.dumps(camera_data)
camera_data_file.write(camera_data_json)
camera_data_file.close()
camera.setConfigJson(json.dumps(config.config))
camera.setConnectionStrategy(VideoSource.ConnectionStrategy.kKeepOpen)
if config.streamConfig is not None:
server.setConfigJson(json.dumps(config.streamConfig))
return camera
def reset_network_tables():
cam_params_table.putNumber("Brightness", -1)
cam_params_table.putNumber("Contrast", -1)
cam_params_table.putNumber("Saturation", -1)
cam_params_table.putNumber("RedBalance", -1)
cam_params_table.putNumber("BlueBalance", -1)
thresholds_table.putNumber("MinHue", -1)
thresholds_table.putNumber("MinSaturation", -1)
thresholds_table.putNumber("MinValue", -1)
thresholds_table.putNumber("MaxHue", -1)
thresholds_table.putNumber("MaxSaturation", -1)
thresholds_table.putNumber("MaxValue", -1)
camera_config_table.putBoolean("NewData", False)
camera_config_table.putBoolean("SaveParams", False)
video_settings_table.putString("ImageType", "Raw")
video_settings_table.putBoolean("Corners", False)
video_settings_table.putBoolean("Contour", False)
print("Network Table Reset.")
if __name__ == "__main__":
if len(sys.argv) >= 2:
configFile = sys.argv[1]
# read configuration
if not readConfig():
sys.exit(1)
# start NetworkTables
ntinst = NetworkTablesInstance.getDefault()
if server:
print("Setting up NetworkTables server")
ntinst.startServer()
else:
print("Setting up NetworkTables client for team {}".format(team))
ntinst.startClientTeam(team)
ntinst.startDSClient()
camera_config_table = NetworkTables.getTable('CameraConfig')
thresholds_table = camera_config_table.getSubTable("Thresholds")
cam_params_table = camera_config_table.getSubTable("CamParams")
video_settings_table = camera_config_table.getSubTable("VideoSettings")
# start cameras
for config in cameraConfigs:
cameras.append(startCamera(config))
with open('/boot/frc.json') as f:
config = json.load(f)
camera = config['cameras'][0]
width = camera['width']
height = camera['height']
input_stream = inst.getVideo()
output_stream = inst.putVideo('Processed', width, height)
img = np.zeros(shape=(width, height, 3), dtype=np.uint8)
frame = np.zeros(shape=(width, height, 3), dtype=np.uint8)
hsv = np.zeros(shape=(width, height, 3), dtype=np.uint8)
mask = np.zeros(shape=(width, height, 3), dtype=np.uint8)
properties_list = ["contrast", "saturation", "red_balance", "blue_balance"]
properties_indexes = {
"contrast": 0,
"saturation": 0,
"red_balance": 0,
"blue_balance": 0,
for i, dict in enumerate(cameraConfigs[0].config["properties"]):
for cam_property in properties_list:
if cam_property == dict["name"]:
properties_indexes[cam_property] = i
camera_config_table.putBoolean("DashboardReady", False)
cycle_counter = 1
while True:
camera_config_table.putNumber("CycleCounter", cycle_counter)
cycle_counter += 1
if camera_config_table.getBoolean("DashboardReady", False):
reset_network_tables() # set all to -1
cameraConfigs[0].config["brightness"])
# cam_params_table.putNumber(
# "Contrast", cameraConfigs[0].config["properties"][properties_indexes["contrast"]]["value"])
cameraConfigs[0].config["contrast"])
# "Saturation", cameraConfigs[0].config["properties"][properties_indexes["saturation"]]["value"])
cameraConfigs[0].config["saturation"])
# "RedBalance", cameraConfigs[0].config["properties"][properties_indexes["red_balance"]]["value"])
cameraConfigs[0].config["red_balance"])
# "BlueBalance", cameraConfigs[0].config["properties"][properties_indexes["blue_balance"]]["value"])
cameraConfigs[0].config["blue_balance"])
thresholds_table.putNumber("MinHue", lower_green[0])
thresholds_table.putNumber("MinSaturation", lower_green[1])
thresholds_table.putNumber("MinValue", lower_green[2])
thresholds_table.putNumber("MaxHue", upper_green[0])
thresholds_table.putNumber("MaxSaturation", upper_green[1])
thresholds_table.putNumber("MaxValue", upper_green[2])
print("Updated Network Tables")
frame_shape = (frame.shape[1], frame.shape[0])
found_targets = False
largest_target_area = 0
hsv = cv.cvtColor(frame, cv.COLOR_BGR2HSV)
mask = cv.inRange(hsv, lower_green, upper_green)
mask = cv.erode(mask, erode_element)
mask = cv.dilate(mask, erode_element)
if video_settings_table.getString("ImageType", "Raw") == "Mask":
output_frame = mask
else:
output_frame = frame
_, contours, _ = cv.findContours(mask, cv.RETR_TREE,
cv.CHAIN_APPROX_NONE)
for cnt in contours:
area = cv.contourArea(cnt)
hull = cv.convexHull(cnt)
hull_area = cv.contourArea(hull)
if hull_area > min_size:
solidity = float(area) / hull_area
# test 2, 3 - min size and the filled area is in this ratio from the convex hull
if 0.12 < solidity < 0.4:
poly_apx = np.squeeze(
cv.approxPolyDP(hull, 0.03 * cv.arcLength(hull, True),
True))
if (len(poly_apx) == 4
): # test 4 - the approx polygon has 4 lines
poly_apx = orderPolygon(poly_apx)
top_line = cv.norm(poly_apx[0] - poly_apx[3])
bot_line = cv.norm(poly_apx[1] - poly_apx[2])
if top_line / bot_line > 1.15: # test 5 - the top line is longer
found_targets = True
if area > largest_target_area: # keep the largest
largest_target_area = area
t_corners = np.squeeze(poly_apx)
target_cnt = np.flip(np.squeeze(cnt), 0)
else:
print("* poly with not 4 lines")
if found_targets:
if video_settings_table.getBoolean("Contour", False):
cv.drawContours(output_frame, [target_cnt], -1, (0, 0, 255), 2)
if video_settings_table.getBoolean("Corners", False):
for j, pnt in enumerate(t_corners):
cv.circle(output_frame, (int(pnt[0]), int(pnt[1])), 7,
(255, 0, 255 * (j == 0)), 2)
if (camera_config_table.getBoolean("NewData", False)):
brightness = cam_params_table.getNumber("Brightness", 0)
cameraConfigs[0].config['brightness'] = brightness
contrast = cam_params_table.getNumber("Contrast", 0)
properties_indexes["contrast"]]["value"] = contrast
saturation = cam_params_table.getNumber("Saturation", 0)
properties_indexes["saturation"]]["value"] = saturation
red_balance = cam_params_table.getNumber("RedBalance", 0)
properties_indexes["red_balance"]]["value"] = red_balance
blue_balance = cam_params_table.getNumber("BlueBalance", 0)
properties_indexes["blue_balance"]]["value"] = blue_balance
cameras[0].setConfigJson(json.dumps(cameraConfigs[0].config))
min_h = thresholds_table.getNumber("MinHue", lower_green[0])
min_s = thresholds_table.getNumber("MinSaturation", lower_green[1])
min_v = thresholds_table.getNumber("MinValue", lower_green[2])
max_h = thresholds_table.getNumber("MaxHue", upper_green[0])
max_s = thresholds_table.getNumber("MaxSaturation", upper_green[1])
max_v = thresholds_table.getNumber("MaxValue", upper_green[2])
if (camera_config_table.getBoolean("SaveParams", False)):
try:
with open('camera_data', "w+") as f:
camera_data = {}
camera_data["brightness"] = brightness
camera_data["contrast"] = contrast
camera_data["saturation"] = saturation
camera_data["red_balance"] = red_balance
camera_data["blue_balance"] = blue_balance
camera_data["min_h"] = min_h
camera_data["min_s"] = min_s
camera_data["min_v"] = min_v
camera_data["max_h"] = max_h
camera_data["max_s"] = max_s
camera_data["max_v"] = max_v
f.write(camera_data_json)
except:
print("Can't save parameters while in Read-Only")
output_stream.putFrame(output_frame)
Can you answer my other two questions (ps -a output and /home/pi/runCamera content)?
Thank you for your response. I don’t know how to connect with ssh, so I’m waiting for a mentor to help me with it. He will arrive tomorrow, and then I’ll be able to answer your questions.
I checked what you suggested and I saw that uploaded.py was running and that /home/pi/runCamera has a line to run python. We tried to reboot the raspberry after turning on everything else, and it turns out that the problem was that the raspberry tried to connect to the network tables before it existed. This probably happend because the raspberry is connected to a switch which connects to the router. Also, we are using our own dashboard to read values sent by the raspberry from the network tables, and so when the values didn’t update, we thought the problem was that the code wasn’t running.
Anyways, thank you for the help.
