I hate to start a thread like this but with Champs just a couple days away Im hoping to get some input. We are looking to put 2 pneumatic solenoids in series, the second to be a pass through/ vent to atmosphere to effectively put a cylinder in neutral. The only rule that could possibly effect this is the following:
R78]
The outputs from multiple valves may not be plumbed together into the same input on a pneumatic cylinder.
My thinking is that there is only one solenoid output going into one input which satisfies the requirment. This rule is clearly to limit flow rate which we are not altering in any way.
Could I get some feedback preferably from inspector type people?
I think your proposal follows both the spirit and the letter of the rules. Unless otherwise directed by a Lead Robot Inspector, I would accept it without hesitation.
Our entire catapult system is reliant upon running solenoid valves in series. We’ve never had any trouble with inspectors; we just need to show them that each port on our cylinders is connected to only one valve.
Couldn’t you achieve the same result by pressurizing both sides of the cylinder equally? Only problem I can see is that it would be a bit less air-efficient.
EDIT: Never-mind, I just remembered how physics work…
