I seems like we’ve been playing Q&A tag with team 948 all season long!
I know you have seen all these already, and it was 948 who posed some of these questions, but here some of the Q&As that have been asked regarding these rules.
Q183:
Q. Rule G18-1 says that forcing the opposing ALLIANCE into a penalty is “not in the spirit of FRC and [is] not allowed” whereas G30 dictates: “regardless of who initiates the contact, a ROBOT may not contact an opponent ROBOT touching the carpet in its LOADING ZONE." Which rule will predominate?
A. If the Team is employing a strategy that tries to take advantage of [G30], [G18-1] takes precedence.
Q255:
Q. If our robot is in our protected loading zone and an opposing robot places itself directly in front of us such that we cannot leave the protected area without intentially striking the other robot (causing a penality), which robot is penalized?
A. The purpose of this forum is to answer specific questions about specific Rules. We cannot comment absolutely on hypothetical situations. With that said, if a ROBOT is perceived as trying to leave a protected area to play the game, this will not be considered a violation of [G18-1]. Conversely, if a ROBOT repeatedly rams an opponent ROBOT, drawing penalties on that ROBOT, even though there’s a clear egress from the area, that would be considered a violation of [G18-1].
Q256:
Q. If we are actively shooting full-court shots from our protected loading zone and another robot attempts to defend against us and we push the other robot away to create space to shoot either with our robot’s body or an extension, which robot will be penalized?
A. The purpose of this forum is to answer specific questions about specific Rules. We cannot comment absolutely on hypothetical situations. If contact in a protected area is made as an attempt to play the game, it will not be a violation of [G18-1]. Conversely, if a ROBOT repeatedly rams an opponent ROBOT, drawing penalties on that ROBOT, even though there’s a clear egress from the area, that would be considered a violation of [G18-1].
Q347:
Q. With reference to Q255: “With that said, if a ROBOT is perceived as trying to leave a protected area to play the game, this will not be considered a violation of [G18-1].” In this case, can you confirm that the opposing alliance will still be penalized per [G30]?
A. The purpose of this forum is to answer specific questions about specific rules. We cannot comment absolutely on hypothetical situations. Generally, if [G18-1] is not violated during a violation of another Game Rule (e.g. [G30]), the violation of that Game Rule (i.e. [G30]) will be enforced.
Q348:
Q. With reference to Q256: “If contact in a protected area is made as an attempt to play the game, it will not be a violation of [G18-1].” Where a referee has determined that contact to create space to shoot satisfies the above condition, will the opposing alliance be penalized per [G30]?
I have my interpretation, but I am also not the ref who will be calling our matches, so YMMV:
If there is contact while you are protected, a penalty will be called one way or the other no matter what (either from G18-1 or G30). There should be no unpenalized contact - so someone will be getting points every time a protected robot and an opponent touch.
If your robot was “perceived as trying to leave a protected area to play the game” or the contact was otherwise “made as an attempt to play the game” the penalty will go against your opponent. This is where the ambiguity lies. Is pushing an opponent away to clear space for your full court shot “an attempt to play the game?” I’d like to say so…but again YMMV.
If the same situation happens over and over again, the penalties should be assessed the same way… over and over again. I don’t see anything in the rules or Q&A which say “for the first X incidents it will be called one way, then automatically after that, it will be called differently.” If you legitimately try and push an opponent back to clear space 30 times a match, and it’s called a penalty on the opponent the first time, I would expect it to be called that way the 2nd-30th time as well.
