Run Virtual cRIO
Hi,
I hope this is not a “stupid” question,:)but;
what would happen if one tried to run the cRIO image on a virtual machine (e.g. VMWare)? Would it even work?
Just curious.:o
-Masoug
Not easily, since I don’t think VMWare supports real-time OS’s.
Also, the cRIO is 2 processors: a 400MHz PowerPC CPU (what your code runs on), and an FPGA processor to interface with the modules. Your average emulator won’t do that.
If you’re looking for a way to test code without a cRIO, I think a special version of WPILib designed to run on a regular computer would work. The hardest part would probably be implementing the DS to robot comms protocol. A GUI robot control panel that allows you to set all the sensors and read all the outputs would be nice (labview comes to mind)
Well i guess then we are stuck with the cRIO…
Anyway THANKS for the responses!
-Masoug
Here’s what I would do:
Go into each top-level WPIlib VI, move the inputs and outputs far to the outside if possible, and wrap a Conditional Disable Structure around them, case on OS (VxWorks vs WIN) and put simulator code in the WIN case. If WIN, you can have a big global variables file for each type of IO (relay, PWM, DIO, Joystick, etc.) and do stuff. For the Comm loop, you could read a joystick and set the appropriate joystick data, as it is set in the existing comm code (except with USB joysticks on your computer instead). You could also throw in a Wait On Occurrence to the DS Occurrence (what gets passed into Start Comm) so the Robot Mode VI dosen’t timeout (and a wait in there too so it runs at the normal speed or so)
Well if your using C++ you could always use the wpi test harness. http://firstforge.wpi.edu/sf/projects/wpilib_test_harness
