Running PhotonVision on a windows 10 computer
I am trying to get PhotonVision to run on a windows 10 machine just to run a few tests. Running into these errors:
I’ve already installed Bonjour and JDK 11.
Anyone run into something similar?
What to you see when you type java -version in the command prompt? It should report the java jdk version you are running.
Mine looks like this:
C:\Users\acast>java -version
openjdk version “11.0.21” 2023-10-17
OpenJDK Runtime Environment Temurin-11.0.21+9 (build 11.0.21+9)
OpenJDK 64-Bit Server VM Temurin-11.0.21+9 (build 11.0.21+9, mixed mode)
similar but not the same.
Did you get some sort of “refused to connect” message when you tried connecting to localhost:5800 in your browser?
I found the problem. I downloaded the x86 JDK instead of the x64. Working now.
Thanks for the clues.
