Safety Glasses Preference Survey
Hello, we are students from the Industrial Design Department at National Cheng Kung University from Taiwan. Thank you for participating in this questionnaire! The main purpose of this survey is to understand your assessment of the importance of various factors related to safety eyewear and to gauge your level of satisfaction. Your responses are crucial to our research. The information you provide will be used solely for the purpose of this survey and will not be used for any other purposes. It will also be kept anonymous, so please feel free to answer.
We sincerely appreciate your assistance and supporthttps://docs.google.com/forms/d/1Zj2Aap0O1-nFaI1teDjzso2Irt2L9E3TbCSVGAoJ2F4/edithttps://docs.google.com/forms/d/1Zj2Aap0O1-nFaI1teDjzso2Irt2L9E3TbCSVGAoJ2F4/edit
It won’t take you more than 5 minutes to answer the survey🥺
And thanks for all the respondents​:pray:t3::pray:t3::pray:t3:
Also, if you have any questions about the survey,
You can leave your comments here, thanks :pray:t3:
good luck students!
Thanks a lot :pleading_face:
Looking forward to more people to answer :pray:t3:
I wear glasses, so generally most safety glasses I’ve used (even the over glasses ones) aren’t particularly comfortable or helpful (tend to try to fall off, keep getting in the way) Covid era masking rules make it even worse.
A better pair (I should get some prescription safety glasses) would probably get me in the shop more lol.
Thanks for your reply!! We’ll take it into consideration of our design​:pleading_face::pray:t3:
Hi, happy to fill out the survey. There is a small mistake in one of the instructions:
Satisfaction with various aspects (1 for very satisfied, 2 for dissatisfied, 3 for neutral, 4 for satisfied, 5 for very satisfied
Should be
Satisfaction with various aspects (1 for very dissatisfied, 2 for dissatisfied, 3 for neutral, 4 for satisfied, 5 for very satisfied
Cheers,
-Scott
Got it!!We will modify it right now🙏🏼Thanks!
Go go go🚀
I am so grateful :pleading_face::pray:t3::face_holding_back_tears:
I’d love to help here, but I wear prescription safety glasses exclusively. No separate sideshields… You might want to include that as one of your options, or at least be aware that’s not being captured.
Got it! I added a new option in the survey. Thanks a lot🙏🏼
Go go go​:rocket::pray:t3:
I wear bifocal safety goggles.
Maybe one more option… REAL prescription safety glasses. :wink: I’m of the opinion that side shields are mostly useless, but then I use mine professionally.
Here’s the pair of prescription safety glasses that were at arms reach… Prescription lenses, integral side shielding built into the unit, no separate parts.
FYI, prescription safety glasses CAN be cheap, as long as you -don’t- get all the fancy options like coatings, self-darkening, and progressive lenses. Under $100 should be easily do able.
For folks that wear prescription glasses, I can’t reccommend enough getting proper prescription safety glasses. You will be saying “Why the heck didn’t I do this before?!?!?!?” Far, far, far better than those goofy overglasses!
Got it. We are going to design safety “glasses” actually, thanks for your reply🙏🏼
Can’t answer the survey… you need “none of the above” on a lot of the questions!
Ok. We’ll consider about it! Thanks
Go go go​:rocket::rocket::rocket:
