I have shown the line in red below that gives us the following error in NetBeans:
unreported exception edu.wpi.first.wpilibj.camera.AxisCameraException; must be caught or declared to be thrown
The code works and runs on CRIO with the test file image.
Any help would be appreciated.
package edu.wpi.first.wpilibj.templates;
import edu.wpi.first.wpilibj.SimpleRobot;
import edu.wpi.first.wpilibj.Timer;
import edu.wpi.first.wpilibj.camera.AxisCamera;
import edu.wpi.first.wpilibj.image.BinaryImage;
import edu.wpi.first.wpilibj.image.ColorImage;
import edu.wpi.first.wpilibj.image.CriteriaCollection;
import edu.wpi.first.wpilibj.image.NIVision.MeasurementType;
import edu.wpi.first.wpilibj.image.NIVisionException;
import edu.wpi.first.wpilibj.image.ParticleAnalysisReport;
import edu.wpi.first.wpilibj.image.RGBImage;
* Sample program to use NIVision to find rectangles in the scene that are illuminated
* by a red ring light (similar to the model from FIRSTChoice). The camera sensitivity
* is set very low so as to only show light sources and remove any distracting parts
* of the image.
* The CriteriaCollection is the set of criteria that is used to filter the set of
* rectangles that are detected. In this example we're looking for rectangles with
* a minimum width of 30 pixels and maximum of 400 pixels. Similar for height (see
* the addCriteria() methods below.
* The algorithm first does a color threshold operation that only takes objects in the
* scene that have a significant red color component. Then removes small objects that
* might be caused by red reflection scattered from other parts of the scene. Then
* a convex hull operation fills all the rectangle outlines (even the partially occluded
* ones). Finally a particle filter looks for all the shapes that meet the requirements
* specified in the criteria collection.
* Look in the VisionImages directory inside the project that is created for the sample
* images as well as the NI Vision Assistant file that contains the vision command
* chain (open it with the Vision Assistant)
public class CameraTest extends SimpleRobot {
AxisCamera camera; // the axis camera object (connected to the switch)
CriteriaCollection cc; // the criteria for doing the particle filter operation
public void robotInit() {
camera = AxisCamera.getInstance("10.20.13.11"); // get an instance ofthe camera
cc = new CriteriaCollection(); // create the criteria for the particle filter
cc.addCriteria(MeasurementType.IMAQ_MT_BOUNDING_RECT_WIDTH, 30, 400, false);
cc.addCriteria(MeasurementType.IMAQ_MT_BOUNDING_RECT_HEIGHT, 40, 400, false);
public void autonomous() {
while (isAutonomous() && isEnabled()) {
try {
* Do the image capture with the camera and apply the algorithm described above. This
* sample will either get images from the camera or from an image file stored in the top
* level directory in the flash memory on the cRIO. The file name in this case is "10ft2.jpg"
ColorImage image = camera.getImage(); // comment if using stored images
//ColorImage image; // next 2 lines read image from flash on cRIO
//image = new RGBImage("/10ft2.jpg");
BinaryImage thresholdImage = image.thresholdRGB(25, 255, 0, 45, 0, 47); // keep only red objects
BinaryImage bigObjectsImage = thresholdImage.removeSmallObjects(false, 2); // remove small artifacts
BinaryImage convexHullImage = bigObjectsImage.convexHull(false); // fill in occluded rectangles
BinaryImage filteredImage = convexHullImage.particleFilter(cc); // find filled in rectangles
ParticleAnalysisReport] reports = filteredImage.getOrderedParticleAnalysisReports(); // get list of results
for (int i = 0; i < reports.length; i++) { // print results
ParticleAnalysisReport r = reports*;
System.out.println("Particle: " + i + ": Center of mass x: " + r.center_mass_x);
System.out.println(filteredImage.getNumberParticles() + " " + Timer.getFPGATimestamp());
* all images in Java must be freed after they are used since they are allocated out
* of C data structures. Not calling free() will cause the memory to accumulate over
* each pass of this loop.
filteredImage.free();
convexHullImage.free();
bigObjectsImage.free();
thresholdImage.free();
image.free();
// } catch (AxisCameraException ex) { // this is needed if the camera.getImage() is called
// ex.printStackTrace();
} catch (NIVisionException ex) {
* This function is called once each time the robot enters operator control.
public void operatorControl() {
while (isOperatorControl() && isEnabled()) {
Timer.delay(1);
