I have a wrapper Command that reads a .csv file that translates the data as points to generate points for my trajectory following. The issue seems to be that when I do this, I am only able to run a single path. Attempting to run multiple paths in succession fails where only the first path runs and the second path doesn’t seem to run. I believe it has to do with the wrapper Command scheduling a ramsete Command directly instead of feeding it in a parallel/sequential command group. Is there a betterway of doing this?:
ParallelCommandGroup:
public class TestSequentialForward extends SequentialCommandGroup {
public TestSequentialForward(DriveTrain driveTrain) {
ArrayList<Pose2d> pathA = new ArrayList<>();
pathA.add(new Pose2d(0,0,new Rotation2d()));
pathA.add(new Pose2d(Units.feetToMeters(2), Units.feetToMeters(0),new Rotation2d()));
ArrayList<Pose2d> pathB = new ArrayList<>();
pathB.add(new Pose2d(Units.feetToMeters(2),0, new Rotation2d()));
pathB.add(new Pose2d(Units.feetToMeters(4), Units.feetToMeters(0),new Rotation2d()));
addCommands(new ResetOdometry(driveTrain),
new TestPath(driveTrain, pathA, false),
new TestPath(driveTrain, pathB, false));
TestPath (Note that this is a test wrapper that doesn’t read a .csv file, but the concept is the same):
public class TestPath extends CommandBase {
@SuppressWarnings({"PMD.UnusedPrivateField", "PMD.SingularField"})
private final DriveTrain m_driveTrain;
private Trajectory trajectory;
private static double m_period = 0.02;
private Notifier m_notifier;
private ArrayList<Pose2d> m_path;
private boolean m_isInverted;
VitruvianRamseteCommand followTrajectory;
* Creates a new ExampleCommand.
* @param driveTrain The subsystem used by this command.
public TestPath(DriveTrain driveTrain, ArrayList<Pose2d> path, boolean isInverted) {
m_driveTrain = driveTrain;
m_path = path;
m_isInverted = isInverted;
// Use addRequirements() here to declare subsystem dependencies.
addRequirements(m_driveTrain);
// Called when the command is initially scheduled.
@Override
public void initialize() {
var trajectoryConstraints = new DifferentialDriveKinematicsConstraint(m_driveTrain.getDriveTrainKinematics(),
3);
var trajectoryConfig = new TrajectoryConfig(Units.feetToMeters(4), Units.feetToMeters(2));
trajectoryConfig.setReversed(m_isInverted);
trajectory = TrajectoryGenerator.generateTrajectory(m_path, trajectoryConfig);
followTrajectory = new VitruvianRamseteCommand(
trajectory,
m_driveTrain::getRobotPose,
new RamseteController(),
m_driveTrain.getFeedforward(),
m_driveTrain::getSpeeds,
m_driveTrain.getLeftPIDController(),
m_driveTrain.getRightPIDController(),
m_driveTrain::setVoltageOutput,
m_driveTrain,
m_path,
trajectoryConfig
CommandScheduler.getInstance().schedule(followTrajectory);
// Called once the command ends or is interrupted.
@Override
public void end(boolean interrupted) {
// Returns true when the command should end.
@Override
public boolean isFinished() {
return false;
VitruvianRamseteCommand:
public class VitruvianRamseteCommand extends RamseteCommand {
Trajectory m_trajectory;
TrajectoryConfig m_config;
Supplier<Pose2d> m_pose;
double autoDuration, autoStartTime;
public VitruvianRamseteCommand(Trajectory trajectory, Supplier<Pose2d> pose, RamseteController controller, SimpleMotorFeedforward feedforward, DifferentialDriveKinematics kinematics, Supplier<DifferentialDriveWheelSpeeds> wheelSpeeds, PIDController leftController, PIDController rightController, BiConsumer<Double, Double> outputVolts, DriveTrain driveTrain, ArrayList<Pose2d> path, TrajectoryConfig config) {
super(trajectory, pose, controller, feedforward, kinematics, wheelSpeeds, leftController, rightController, outputVolts, driveTrain);
m_pose = pose;
m_trajectory = trajectory;
m_path = path;
m_config = config;
@Override
super.initialize();
autoStartTime = Timer.getFPGATimestamp();
double distance = 0;
for (int i = 0; i < m_path.size() - 1; i++) {
var pointA = m_path.get(i);
var pointB = m_path.get(i + 1);
double deltaX = pointB.getTranslation().getX() - pointA.getTranslation().getX();
double deltaY = pointB.getTranslation().getY() - pointA.getTranslation().getY();
double deltaDistance = Math.sqrt(Math.pow(deltaX, 2) + Math.pow(deltaY, 2));
distance += deltaDistance;
autoDuration = (distance / m_config.getMaxVelocity()) + 2;
@Override
double deltaX = Units.metersToFeet(Math.abs(m_pose.get().getTranslation().getX() - m_path.get(m_path.size() - 1).getTranslation().getX()));
double deltaY = Units.metersToFeet(Math.abs(m_pose.get().getTranslation().getY() - m_path.get(m_path.size() - 1).getTranslation().getY()));
double deltaRot = Math.abs(m_pose.get().getRotation().getDegrees() - m_path.get(m_path.size() - 1).getRotation().getDegrees());
boolean isFinished = ((deltaX < 0.25) && (deltaY < 0.25) && (deltaRot < 2)) || (Timer.getFPGATimestamp() > (autoDuration + autoStartTime));
return isFinished;
