Hey all, I was just wondering about experiences that other teams have had regarding scissor lifts??
All comments welcome, I’m just trying to explore all of the possibilities!!
Put it this way, I doubt anyone has ever built a Second scissor lift:)
Seriously though they rarely work very well, they all seem to wobble a lot when they get very high.
No experience, except that I spend a lot of time on man-rated industrial scissor lifts.
If stability is important, scissor lifts of more than one stage should be rated as do not use. I walk from one end of a lift to the other, it sways a bit.
If simplicity is important, scissor lifts in general should be rated as do not use. (See: elevator system, pneumatic lift)
If you can’t do much precision work… See the bold text above.
If you are seriously considering doing a scissor lift system, you should do the math. I’ve heard of engineers getting scared of that math. You need to account for all the stages, the stability, and the precision needed. It’s not easy.
Very well put. Scissor lifts are just way more complex than they need to be for FRC application. Most of the Ri3D teams chose to use elevators for a reason. They are simple, can be light weight, and effective.
No. Absolutely not. But I am sure we will see a few teams using them.
We used a scissor lift once on 842 back in Ultimate Ascent. We used it to bring Frisbee to our shooting mechanism because we somehow forgot about gravity. I don’t think you could pay us enough to make another scissor lift. Despite it being very small and simple, it was very inconsistent, never landed right, jammed regularly and overall wasted dozens of hours due to having to adjust it. Even if you can get one working quickly compared to an elevator, the time spent fixing and adjusting it is not worth it at all.
At the start of each season, I remind the team of our two absolute rules (born from very bad experiences):
My FTC team came to me with a design that included a scissor lift. I asked if that was the best design the could come up with. They said it was. I said you need to try harder! The have a much better design now!
There are only two rules when designing on our team:
I haven’t had any experience with scissorlifts, but our mentors must have a really good reason for not wanting to ever have one.
I have one rule that applies to FTC more than FRC and it is as follows:
Unless you have to raise an object more than 20ft in the air. A scissor lift is not the answer.
(Bascially unless we play a game like 2011 (bowled over) again you shouldn’t need to use a scissor lift.)
Bowled Over was 2011-12. I’ll agree that it was probably the only time I’ve ever seen a scissor lift that was actually effective. Seeing teams shoot those crate 20-30 feet up with elastic powered scissor lifts was both really cool and really scary.
If you want to be successful this year at competitions, a scissor lift is almost certainly not the way to go. Build a nice elevator or something. You only actually need one stage this year.
Out of curiostity, what’s if it’s single stage? I.E. Two bars that cross with a joint in the middle.
Assume that it’s milled accurately and not made on a drill press.
We used a scissor lift in 2013 to score the colored discs while our robot was on the pyramid. We needed a compact mechanism to lift a few frisbees a few feet, and I thought it worked great for us.
Obviously this is very different than lifting totes;however, I think they can work well in specific applications, and to automatically rule them out is a mistake.
Ours are:
We did both in our first year and haven’t done either since.
I understand why casters and agree.
but whyscisser lifts
Nothing wrong with scissor lifts!
Why and how? This seems to be a very contradictory veiwpoint here, and I’d like to hear your thoughts. What is your experience?
We built one in 2003 stack attack and it stacked bins very nicely. The scissors lift only had to go 2 bins high max.
We built one in our rookie year (1996), we never even thought to replicate that experience since. I use a scissor type man lift here at work on a regular basis. In order for it to work well, a rigid precision frame and bearings in the joints are essential. The problem with most is the non-precision with which they are built. This leads to instability while moving and therefore intermittent loads that exceed the ability of the drive to overcome.
We have a do not use list too…
No casters/shopping cart wheels for obvious reasons.
No omni wheels on ramps.
Anything else that does not fit the game.
Two more things that make scissor lifts hard:
One or both of the bottom sections has to slide across the bottom surface as it extends upward. Getting that to work smoothly with low friction and without wobbling around is tricky.
Powering a scissor lift without hydraulics is hard if you’re lifting a decent amount of weight. When it’s fully retracted, you have to supply a lot of force to get it started, because the initial angle is unfavorable. Certainly it can be done with motors, but I think it’s a lot trickier than powering an elevator or an arm.
