Scores for Kettering Preseason events
Does anyone happen to have the final scores for the matches at the two Kettering preseason events? If not I will go through the live stream and find them, but I figured I’d check first.
If you do it on your own can you post them here please
Edit: i’m going through them myself right now and will post once I’m done, however it appears either final scores or breakdowns are not correct because they do not add up properly.
Just went through it - the numbers under each breakdown are the added up auto/tele/end scores because there seemed to be discrepancies in that - two in the PM session didn’t have the scores posted.
