Scoring Program
Attached is team 369’s scoring program for this years game. If you find any bugs or mistakes in it, please let me know and I will fix them.
369-FRC05-Scoring.zip (10.4 KB)
I’ve Checked it out and its a really Nice Job. I have not seen any problems with it. If i do ill let you know.
The program looks very good!
Isn’t there two hanging goals for each side at the start, one in each corner?
Also, add a checkbox for ‘All three bots back into the start area.’ for +10 pts.
Sean
I like how it works. Congrats on that. But there are some issues with the scoring.
THe one I’ve most noticed is that I’ve had is the score turning to zero when it should still count points for each click for that one.
There were a couple other small glitches that I’ve forgotten since I stopped playing but it is nevertheless a neat little scorer for being so quick.
For better example, click only the underneath boxes and they make connection and also click the tops one color and the bottoms another. And then switch. You’ll see what I mean.
Nice job on the program but I got a “Illegal Program Operation” when I clicked on the upper left top goal 65,536 times.
If you only click the underneath boxes they will connect because if theres no tetras on top stacked the whole goal takes the color of the top tetra contained.
If there are no TETRAS STACKED on the GOAL, the color of the highest TETRA CONTAINED in a goal will determine which alliance OWNS the GOAL.
the lower box can be a different color because it only represents the color of the CONTAINED tetra
I just updated my original post with a newer version of the program with more autonomous modes and a few bug fixes
I was under the impression that a team will always get the points of the stacked tetras no matter who owns the goal. You program gives all the points to the team who owns the goal. Which one of us is correct?
Found a problem. It’s not a really big problem, but I noticed more than 40 of each tetra may be placed. So placing a cap on it could be useful. I know it’s picky and probably won’t matter. Great job nonetheless.
Yes, it appears that even if you do not own the goal, you still get points:
If you click on the check box for one of the options on the far right (for example “RED AUTONOMOUS: a VISION TETRA is STACKED on a GOAL located on the side of the field. OTHER SIDE”) and then after it is grayed out click on it again, it activates the option on the left.
Yeah, your right I just went through all the rules again. I’ll fix it. Thanks
sounds interesting. Too bad I missed one of the test versions, hope you have it posted up again soon.
Use search next time… there’s already a scoring thread…
http://www.chiefdelphi.com/forums/showthread.php?p=315659
OK, I posted it back up, hopefully without any bugs this time
