Do we get 10 points for an alliance robot hudling a trackball?
I never really understood it, is it (2 poitns for the ball crossing, 6 bonous poitns, and then another 2 for the robot crossing)
Thanks
it is 8 points for the ball being hurdled… and 2 points for the robots crossing your alliance’s finish line
on your alliances finish line, you can get 10. on your opponents’ finish line, you get a total of 8 points.
To be clear, you don’t get 10 points for hurdling. You get 8 points per hurdle, and then once you cross the finish line you get 2 points. They are two separate acts, and not mutually associated.
Um, the only points you get on the opponent’s line are the 4 points you get during HYBRID. No Hurdle points on the opponent’s side.
you dont get any points for hurdling over your opponent’s overpass
Or crossing their finish line.
Summary: 8 points for a hurdle (own line), two for a robot (own line), two for a ball under the overpass (own line, must not be in contact), 12 if the ball is anywhere on the overpass at the end of the match.
