Screw Size
Does anyone have the screw sizes for the components in the electrical board?
These would include the Power Distribution Board, Digital IO Board, CRIO, Jaguars, Victors, and Spikes.
Thanks.
Power terminals
Main Breaker: Terminal Supply CB3-SM-120 (pdf), 1/4-28 UNF studs, qty 2
Power Distribution Board: Andymark am-0865 (link): M6x1 studs, qty 2
Jaguar MDL-BDC24 (pdf): 6-32 UNC screw terminals, qty 4
Victor 884 (link): 6-32 UNC screw terminals, qty 4
Mounting hardware
Power Distribution Board: Andymark am-0865 (pdf): hole dia .257", qty 4
Digital Sidecar: Andymark am-0866 (pdf), hole dia .173", qty 2
cRIO-FRC (pdf): M4x0.7x16 flat head machine screws, qty 2
cRIO-FRC II (pdf): M4x0.7x25 flat head machine screws, qty 2
24V Power Converter: Current Logic 360-CPR (pdf), hole dia 7 mm, qty 2
Jaguar MDL-BDC24 (pdf): hole dia .175", qty 2
Victor 884 (pdf): hole dia .135", qty 2
Spike Relay Module (pdf): hole for #8 screw, qty 2
Diagnostic Signal Light: Rockwell Automation 855PB-B12ME522 (pdf): mounts into hole dia 22.5 mm
