SD read/write numbers
Where is the SD read functions? I can’t find them in the menu structure.
Where did my life go wrong?
SD and NT VIs were merged. If you wire a variable starting with /, it is an absolute path. If it doesn’t, /SmartDashboard/ is prepended. So the palettes only contain the NT version, but the SD VIs will continue to work if you have them in some legacy code.
Greg McKaskle
