searching only searches body
When you “search entire posts” it only searches the body, not the title of the posts as well. It would seem that to search the entire post, it would need to search the title as well.
I suppose thats worded wrong, then. I’ll look into it, but I’m guessing that you can search either the body or the title, and not both.
If this is the case, it may not be easily fixed. As nice as the feature would be, I don’t have the time or patience right now to search through (and potentially break) 2500+ lines of code.
I definetly don’t want you to potentially break the code at this point in the season. I was think more that if it wasn’t an easy fix, you could report it to the vbulletin developers.
http://www.vbulletin.com/forum/showthread.php?postid=616996#post616996
If you’d like to follow the play-by-play.
By the response I’ve gotten, it looks like it’s just worded strange.
You can search either post OR title, but not both. [without a hack]
Well, I just did my search again, and it did find what I was searching for when it was only in the title. I’m not sure if I skipped over it before, or whether it’s changed since then.
Sorry for the false alarm
