Sending video from coprocessor to Dashboard
Currently, we have the Microsoft LifeCam plugged into a Kangaroo that is running the LabVIEW vision example. Is there any way to then send the video back to the dashboard so the drivers can see the stream too?
Thanks!
The robot code does this using the Camera Background Loop VI. You can place it on your coprocessor if you like. But if you run more than one of these, they are using the same port and will make a mess.
Greg McKaskle
Awesome! We will give it a try! We are only using the single camera, so we shouldn’t have a problem using the same port. I will remove the vision code from the robot program and just use the coprocessor loop.
Thanks!
