Hello, our team is new to swerve drive and followed 0 to autonomous. We updated the software to the most recent version and this is the error we got. could someone please explain what this means and how to fix it?
Task :compileJava FAILED
SwerveSubsystem.java:59: error: cannot access Sendable
gyro.reset();
class file for edu.wpi.first.util.sendable.Sendable not found
1 error
Please pleasepleasePLEASE dont use google drive (or dropbox, or onedrive, etc) for hosting your source code… it WILL burn you at some point. Instead, you should use one of the near-infinite free git providers (github.com, gitlab.com, bitbucket.com, etc).
That said, since the google drive file viewer on my phone doesn’t show line numbers, it’ll take me a bit to parse through this. If someone else beats me to it, that’s perfectly fine as well.
The 0-Autonomous code may be problematic to implement. Like you, we ran into many errors and mistakes in the code they had published. We struggled trying to get it to work for weeks. I suggest using 364’s swerve code GitHub - Team364/BaseFalconSwerve or 3512’s https://github.com/frc3512/SwerveBot-2022depending depending on if you have falcons or neos.
