The Links Of The Image That Descrype The Problem, Please See It To Understand My Problem
http://us.f1f.yahoofs.com/bc/41b6caa7_7b34/bc/Mail+Attachments/Robot_Design.bmp?bfkCRMCBi9_9zDpQ
Hello,
I’m not in FIRST competition, And I’m new in robotics, So please be patient with
me, and use a simple words, cause my English is not so good, Thanks.
The Problem:
I’m building my graduate project it’s a rover robot that move on 6 wheels as
shown on the above figure, this figure is a basic design for my BlackBot,
as you can see, Wheels number 1,2 and 3 are connected together with Track-1,
while Wheels number 4,5 and 6 are connected together with Track-2,
Each wheels from 6 wheels are connected to its servo motors, So we have 6
Servo here,
Now assume that we want to compact the design of this robot, can we
connect the servo number 1,2 and 3 together in parallel connection, Called Con-1
And connect servo number 4,5 and 6 together in parallel connection, Called Con-2
I think its ok, if we connect the first 3 servo together in parallel so the volt
is constant but the current will distributed on each servo,
For example: if we connect the 3 servo in parallel, and apply 5 volt and 300 mA
to this connection, So each servo will take 5 volt and 100 mA, Cause volt is
constant and the current is variable.
The question is:- Is there a way (Circuit) That deliver to each servo a 5 volt and 300 mA.
If you see the above figure I supposed that I have an 2 amplification circuit that will
amplification the power and signal that came from the main board and distribute
it to each servo, so each servo take 5 volt and 300 mA,
Please if any body understand what I’m talking about, and have the answer, please help me out here,
Thanks In Advanced For Whatever Help…
