My team’s current robot requires the use of linear actuators. Looking at the documentation, the java doc has a separate class specifically servos. However, we found that when we set it to Servos, nothing would happen, thus we tried setting them as usual talons, and they functioned correctly, with -1.0 being fully retracted and 1.0 being fully extended.
The problem that I’m currently having is that the servos themselves won’t start whenever I press the button that it is assigned too.
Here is the OI.java class, with the commands in question being
c5.whenPressed(new pushGearOut());
and
c7.whenPressed(new pushGearIn());
package org.usfirst.frc.team3205.robot;
import org.usfirst.frc.team3205.robot.commands.cameraOneInit;
import org.usfirst.frc.team3205.robot.commands.cameraTwoInit;
import org.usfirst.frc.team3205.robot.commands.climber;
import org.usfirst.frc.team3205.robot.commands.climberReset;
import org.usfirst.frc.team3205.robot.commands.driveBaseSwitchDirections;
import org.usfirst.frc.team3205.robot.commands.dumpFlapClose;
import org.usfirst.frc.team3205.robot.commands.dumpFlapOpen;
import org.usfirst.frc.team3205.robot.commands.hopperUnCoil;
import org.usfirst.frc.team3205.robot.commands.intakeFlapClose;
import org.usfirst.frc.team3205.robot.commands.intakeFlapOpen;
import org.usfirst.frc.team3205.robot.commands.hopperCoil;
import org.usfirst.frc.team3205.robot.commands.pushGearIn;
import org.usfirst.frc.team3205.robot.commands.pushGearOut;
import org.usfirst.frc.team3205.robot.commands.visionSwitchCameras;
import edu.wpi.first.wpilibj.buttons.Button;
import edu.wpi.first.wpilibj.buttons.JoystickButton;
//import org.usfirst.frc.team3205.robot.commands.ExampleCommand;
* This class is the glue that binds the controls on the physical operator
* interface to the commands and command groups that allow control of the robot.
public class OI {
//// CREATING BUTTONS
// One type of button is a joystick button which is any button on a
//// joystick.
// You create one by telling it which joystick it's on and which button
// number it is.
// Joystick stick = new Joystick(port);
// Button button = new JoystickButton(stick, buttonNumber);
// There are a few additional built in buttons you can use. Additionally,
// by subclassing Button you can create custom triggers and bind those to
// commands the same as any other Button.
//// TRIGGERING COMMANDS WITH BUTTONS
// Once you have a button, it's trivial to bind it to a button in one of
// three ways:
// Start the command when the button is pressed and let it run the command
// until it is finished as determined by it's isFinished method.
// button.whenPressed(new ExampleCommand());
// Run the command while the button is being held down and interrupt it once
// the button is released.
// button.whileHeld(new ExampleCommand());
// Start the command when the button is released and let it run the command
// button.whenReleased(new ExampleCommand());
public static Joystick right = new Joystick(0);
Button r1 = new JoystickButton(right, 1);
Button r2 = new JoystickButton(right, 2);
Button r3 = new JoystickButton(right, 3);
Button r4 = new JoystickButton(right, 4);
Button r5 = new JoystickButton(right, 5);
Button r6 = new JoystickButton(right, 6);
Button r7 = new JoystickButton(right, 7);
Button r8 = new JoystickButton(right, 8);
Button r9 = new JoystickButton(right, 9);
Button r10 = new JoystickButton(right, 10);
Button r11 = new JoystickButton(right, 11);
public static Joystick left = new Joystick(1);
Button l1 = new JoystickButton(left, 1);
Button l2 = new JoystickButton(left, 2);
Button l3 = new JoystickButton(left, 3);
Button l4 = new JoystickButton(left, 4);
Button l5 = new JoystickButton(left, 5);
Button l6 = new JoystickButton(left, 6);
Button l7 = new JoystickButton(left, 7);
Button l8 = new JoystickButton(left, 8);
Button l9 = new JoystickButton(left, 9);
Button l10 = new JoystickButton(left, 10);
Button l11 = new JoystickButton(left, 11);
public static Joystick controller = new Joystick(2);
Button c1 = new JoystickButton(controller, 1);
Button c2 = new JoystickButton(controller, 2);
Button c3 = new JoystickButton(controller, 3);
Button c4 = new JoystickButton(controller, 4);
Button c5 = new JoystickButton(controller, 5);
Button c6 = new JoystickButton(controller, 6);
Button c7 = new JoystickButton(controller, 7);
Button c8 = new JoystickButton(controller, 8);
Button c9 = new JoystickButton(controller, 9);
Button c10 = new JoystickButton(controller, 10);
Button c11 = new JoystickButton(controller, 11);
Button c12 = new JoystickButton(controller, 12);
public static Joystick xbox = new Joystick(2);
Button x1 = new JoystickButton(xbox, 1);
Button x2 = new JoystickButton(xbox, 2);
Button x3 = new JoystickButton(xbox, 3);
Button x4 = new JoystickButton(xbox, 4);
Button x5 = new JoystickButton(xbox, 5);
Button x6 = new JoystickButton(xbox, 6);
Button x7 = new JoystickButton(xbox, 7);
Button x8 = new JoystickButton(xbox, 8);
Button x9 = new JoystickButton(xbox, 9);
Button x10 = new JoystickButton(xbox, 10);
public OI(){
//c6.whileHeld(new dumpFlapOpen());
//c8.whileHeld(new dumpFlapClose());
c9.whileHeld(new intakeFlapOpen());
c10.whileHeld(new intakeFlapClose());
// c5.whenActive(new pushGearOut());
// c7.whenActive(new pushGearIn());
// c5.toggleWhenPressed(new pushGearOut());
// c7.toggleWhenPressed(new pushGearIn());
// c5.whileHeld(new pushGearOut());
// c7.whileHeld(new pushGearIn());
c4.whileHeld(new hopperCoil());
c3.whileHeld(new hopperUnCoil());
c1.whileHeld(new climber());
c2.whileHeld(new climberReset());
c11.toggleWhenPressed(new cameraOneInit());
c12.toggleWhenPressed(new cameraTwoInit());
r1.toggleWhenPressed(new driveBaseSwitchDirections());
l1.toggleWhenPressed(new visionSwitchCameras());
//r1.whenPressed(new visionSwitchCameras());
// l1.whenPressed(new visionSwitchCameras());
//r1.whenActive(new visionSwitchCameras());
Here is the gear subsystem:
package org.usfirst.frc.team3205.robot.subsystems;
import org.usfirst.frc.team3205.robot.RobotMap;
import edu.wpi.first.wpilibj.DigitalInput;
import edu.wpi.first.wpilibj.Servo;
import edu.wpi.first.wpilibj.Talon;
import edu.wpi.first.wpilibj.command.Subsystem;
public class Gear extends Subsystem {
// Put methods for controlling this subsystem
// here. Call these from Commands.
private DigitalInput gearIn;
private Talon gearOut;
//private Servo gearOut;
public Gear(){
gearIn = new DigitalInput(RobotMap.IS_GEAR_IN);
//gearOut = new Servo(RobotMap.PUSH_EM_OUT);
gearOut = new Talon(RobotMap.PUSH_EM_OUT);
// when the limit switch is pressed pull down the limit switch
public void initDefaultCommand() {
// Set the default command for a subsystem here.
//setDefaultCommand(new MySpecialCommand());
setDefaultCommand(new pushGearOut());
public boolean isGearIn(){
return gearIn.get();
public void pushOut(){ // this actually pulls in the gear
gearOut.set(0.8);
//gearOut.setAngle(45);
public void retract(){ // this actually puts out the gear
gearOut.set(-1.0);
//gearOut.setAngle(10);
// public double getAngle(){
// //return gearOut.getAngle();
public void updateSmartDashboard(){
SmartDashboard.putBoolean("Is Gear in", isGearIn());
And here are the pushGearOut() and pushGearIn() commands:
package org.usfirst.frc.team3205.robot.commands;
import org.usfirst.frc.team3205.robot.Robot;
import edu.wpi.first.wpilibj.command.Command;
public class pushGearOut extends Command {
public pushGearOut() {
// Use requires() here to declare subsystem dependencies
// eg. requires(chassis);
requires(Robot.gear);
// Called just before this Command runs the first time
protected void initialize() {
System.out.println(";alksdfja;lskjfl;aksdfj");
Robot.gear.pushOut();
// Called repeatedly when this Command is scheduled to run
protected void execute() {
//Robot.gear.pushOut();
// Make this return true when this Command no longer needs to run execute()
protected boolean isFinished() {
return true;
// Called once after isFinished returns true
protected void end() {
// Called when another command which requires one or more of the same
// subsystems is scheduled to run
protected void interrupted() {
public class pushGearIn extends Command {
public pushGearIn() {
System.out.println("why isnt this working");
// System.out.println(OI.c5.get());
Robot.gear.retract();
//Robot.gear.retract();
return true;
I know the servo works as it can run when a limit switch is triggered which I set to, however whenever I try executing the command through buttons nothing appears to happen.
Any help is appreciated.
