Servo Motors
Anyone have the torque ratings for the servos provided in the kit?
42 inch-oz, although it has been said in the past that servo manufactures inflate their specs by 2x.
Edit: this is the stall torque, and it is also from memory.
Is this the stall torque?
What the heck are you doing with servos that you have to worry about their stall torque?
Isn’t it obvious? :slight_smile:
Trying to replace a heavy motor with two servos, to perform a light-load task… :smiley:
if u are talking about the Hitec HS-300 servos, the torque is 42 inches per oz at 4.8v and 49 inches per oz at 6v. u can also goto the Hitec site which is www.hitecrcd.com . if u think that it is of any use.
Mike O’Brien
Team 384
