servo problem
can some one tell me, do i have to put 0 to 180 on servo angle or 0 to -1
i try everything to programmed function and everything but still not working can someone help me…
0 to 180 and make sure you have a jumper on the two pin connector next to the pmw of your choice.
i tried 0 to 180 still doesent work
Do you have a jumper installed?
yeah i did
Your code should look something like this.
yes i do have same one…
Could you post your code?
You aren’t trying to lift a 10 pound weight with that servo, are you ?
no i m not lifting anything
Do you have a cheap digital voltmeter handy?
Does putting the Driver Station into Test Mode, and using the Dashboard Test tab, let you move the servo?
here is a code
yeah i do y
right now your two positions are using double numeric values when i believe they should be just numeric values. (Changes the orange numbers to blue numbers)
can you tell me how to change it and is my code is fine…
Your code looks fine. To change if from a orange 0, to a blue zero, simply just type 0 then (enter) it should change to blue, at least that is all i have to do.
i pressed enter didnt change it to blue
Alright then go to the numeric palette and select the numeric constant. (the blue one)
nvm i changed it
