Servo Specs
Dose anyone know where I can find the specs for the Servo’s that were provided in the kit??
This is the Hitec HS-322 Deluxe Servo with the Hitec/JR/Z Connector.
FEATURES: Three pole motor.
One resin bushing.
INCLUDES: One Hitec Deluxe Servo with the Hitec/JR/Z Connector with, four 2mm x
15mm phillips head mounting screws, four rubber grommets, four
eyelets, one star shaped, one arm, and two arm straight servo horns
SPECS: Wire color codes: Black-Ground, Red-Power, Yellow-Signal
Operating speed: 0.19 sec @ 60 degrees at 4.8V
Torque: 39oz/in (2.8kg cm)
Weight: 1.51oz (43g)
Length: 1.57" (40mm)
Width: 0.78" (20mm)
Height: 1.43" (36.5mm)
Wire length: 12" (305mm) approximate
JXS 7/12/02
ir/kh
