Set a trigger to Curvature Drive Quick turn button (Java)
Hi, new to programming and working on creating a curvature drive system. I have the basic parameters and everything working I just dont like where i currently have the quick turn button set (x button) I want to set the quick turn button to the right trigger but the right trigger is an axis and the curvature drive method requires a boolean to be returned. How would I go about doing this, if anyone has example code or can find some it would be greatly appreciated.
You can make the trigger as a button like this. Use the driverstation to figure out which axis the left/right trigger are bound to:
public class XBoxTrigger extends Button {
    Joystick joystick;
    int axis;
    public XBoxTrigger(Joystick joystick, int axis) {
        this.joystick = joystick;
        this.axis = axis;
    public double getTriggerValue() {
        return joystick.getRawAxis(axis);
    @Override
    public boolean get() {
        return joystick.getRawAxis(axis) > 0.15;
ok, so how would i place that into a curvature drive, and would that go into the OI?
This is my current curvature drive code:
drive.curvatureDrive(move, turn, Robot.oi.stick.getRawButton(RobotMap.joystickPort_QuickTurn));
Your OI would probably look like this:
    Joystick xBoxController = new Joystick(RobotMap.xBoxController);
    public Button xBoxLeftTrigger, xBoxRightTrigger;
    public OI() {
        xBoxLeftTrigger = new XBoxTrigger(xBoxController, 2);
        xBoxRightTrigger = new XBoxTrigger(xBoxController, 3);
And your function call would look like this:
drive.curvatureDrive(move, turn, Robot.oi.xBoxRightTrigger.get());
Edit: If you want it as a toggle, you would need to do something like this:
boolean toggle;
if(Robot.oi.xBoxRightTrigger.get()) {
   toggle = !toggle;
drive.curvatureDrive(move, turn, toggle);
The toggle boolean would have to be initialized in the class and not as a part of the loop/function that contains drive.curvatureDrive().
Thank you so much
