xyyuii
February 15, 2022, 9:29pm
Hello, so I’m testing this system with a turret from another robot, to where when it reaches the max angle of the turret, it goes all the way around to the min angle, and when it’s done with that it goes back to tracking the target. However, for some reason, when it goes to turn to the max angle, it doesn’t go all the way and just stops midway for some reason. Could someone take a look at it and see if I’m just missing something? I’ve checked the PIDs, and they’re all working fine, and the setAngle and set methods are working fine too.
public void trackTarget(double measure) {
// set(aimingPID.calculate(measure, 0));
if (getPosition() >= MAX_ANG || !maxchanging)
maxchanging = true;
setAngle(-30);
if (getPosition() <= -30) {
maxchanging = false;
else if (getPosition() <= MIN_ANG || !minchanging)
minchanging = true;
setAngle(253);
if (getPosition() >= 253) {
minchanging = false;
if (!maxchanging && !minchanging)
setAngle(getPosition() - measure);
Seeing the rest of your code would help a lot in debugging it.
One thing I will mention is that you can set the minimum and maximum encoder counts in your motor controller configuration, and it will automatically behave like you want it to.
example using TalonFX:
turretMotor.configForwardSoftLimitThreshold(7000);
turretMotor.configReverseSoftLimitThreshold(-7000);
turretMotor.configForwardSoftLimitEnable(true);
turretMotor.configReverseSoftLimitEnable(true);
xyyuii
February 17, 2022, 10:58pm
3
Here’s the entirety of the Turret.java code:
package frc.robot.subsystems;
import java.util.Map;
import com.revrobotics.CANEncoder;
import com.revrobotics.CANPIDController;
import com.revrobotics.CANSparkMax;
import com.revrobotics.CANSparkMaxLowLevel.MotorType;
import com.revrobotics.ControlType;
import com.revrobotics.CANSparkMax.IdleMode;
import edu.wpi.first.networktables.NetworkTableEntry;
import edu.wpi.first.wpilibj.Notifier;
import edu.wpi.first.wpilibj.controller.PIDController;
import edu.wpi.first.wpilibj.controller.ProfiledPIDController;
import edu.wpi.first.wpilibj.shuffleboard.BuiltInWidgets;
import edu.wpi.first.wpilibj.shuffleboard.Shuffleboard;
import edu.wpi.first.wpilibj.trajectory.TrapezoidProfile.Constraints;
import edu.wpi.first.wpilibj2.command.SubsystemBase;
* Class encapsulating turret function.
public class Turret extends SubsystemBase {
// device initialization
private final CANSparkMax turretMotor = new CANSparkMax(23, MotorType.kBrushless);
private final CANEncoder turretEncoder = turretMotor.getEncoder();
private final ProfiledPIDController aimingPID = new ProfiledPIDController(/*0.021*/ 0.035, 0.0, 0.0, new Constraints(MAX_VELOCITY, MAX_ACCELERATION));
private final ProfiledPIDController anglePID = new ProfiledPIDController(0.03, 0.0, 0.0046, new Constraints());
//0.1, 0.15
// constants
private static final double MAX_VELOCITY = 1.5; // rpm
private static final double MAX_ACCELERATION = 0.75; // rpm / sec
private static final double GEAR_RATIO = 40.0 * (120.0 / 16.0); // angular velocity will be divided by this amount
private static final double ENCODER_TO_DEGREES = 360.0 / GEAR_RATIO; // degrees
private static final double RAMP_RATE = 0.5; // seconds
private static final double MAX_ANG = 255;
private static final double MIN_ANG = -32;
private double reduction = 1.0;
private boolean MANUAL = false;
private static boolean maxchanging = false;
private static boolean minchanging = false;
* Constructs new Turret object and configures devices.
public Turret() {
resetEncoders();
setRampRate();
turretMotor.setIdleMode(IdleMode.kBrake);
Notifier shuffle = new Notifier(() -> updateShuffleboard());
shuffle.startPeriodic(0.1);
SmartDashboard.putNumber("Set T Angle P", anglePID.getP());
SmartDashboard.putNumber("Set T Angle I", anglePID.getI());
SmartDashboard.putNumber("Set T Angle D", anglePID.getD());
SmartDashboard.putNumber("Set T Angle", 0.0);
* Runs every loop.
@Override
public void periodic() {
* Writes values to Shuffleboard.
private void updateShuffleboard() {
SmartDashboard.putNumber("Turret pos (deg)", getPosition());
//SmartDashboard.putNumber("Turret temp", turretMotor.getMotorTemperature());
//SmartDashboard.putNumber("Turret raw vel", turretEncoder.getVelocity());
public void setPIDs(double kP, double kI, double kD) {
anglePID.setPID(kP, kI, kD);
* Sets turret motor to given percentage [-1.0, 1.0].
public void set(double percent) {
turretMotor.set(percent * reduction);
* Turns turret to angle in degrees.
public void setAngle(double angle) {
set(anglePID.calculate(getPosition(), angle));
maxchanging = true;
setAngle(-30);
minchanging = true;
setAngle(253);
* Configures motor ramp rates.
public void setRampRate() {
turretMotor.setClosedLoopRampRate(0);
turretMotor.setOpenLoopRampRate(RAMP_RATE);
public void setReduction(double reduction) {
this.reduction = reduction;
* Resets turret encoder value to 0.
public void resetEncoders() {
turretEncoder.setPosition(0);
* Returns turret encoder position in degrees.
public double getPosition() {
return turretEncoder.getPosition() * ENCODER_TO_DEGREES;
* Returns turret encoder velocity in degrees per second.
public double getVelocity() {
return turretEncoder.getVelocity() * ENCODER_TO_DEGREES / 60.0;
* Returns max position of turret in degrees.
public double getMaxPosition() {
return MAX_ANG;
* Returns min position of turret in degrees.
public double getMinPosition() {
return MIN_ANG;
public boolean getManual() {
return MANUAL;
public void setManual(boolean manual) {
MANUAL = manual;
public void toggleManual() {
MANUAL = !MANUAL;
* Returns turret motor temperature in Celsius.
public double getTemp() {
return turretMotor.getMotorTemperature();
February 17, 2023, 10:58pm
4
