SET command duration?
I assume that the SETxxx(n,n) command when invoked in a function and the function returns, that SETxxx maintains the desired state/action after the return and during interrupts etc until the SETxxx is next invoked or a reset occurs. Correct?
SetXXX is a command instructing WPILIb to alter a default setting.
SetPWM(1,X) // Change PWM 1 from Default “127” to a X
SetGyroDeadBand(1 , X) // Change the Default Dead for Gyro 1 to X
SetUserDisplay ( X ) ; // Change the Default OI Display from 0 to X
Once a Set command is executed, it normally doesn’t need to be resent unless
you need to modify the parameter. If X changes for any reason you need to recall
the set command.
Example:
// This will run a Victor connected to PWM 1 at full speed (255) forever
Autonomous ( ) {
SetPWM( 1, 255 ) ;
// This will run a Victor connected to PWM 1 at full speed (255) for 1 second (1000ms) then stop (127).
Autonomous ( ) {
SetPWM( 1, 255 );
Wait(1000);
SetPWM( 1, 127 );
Adam:
TNX for the prompt reply.
