yes, we’ve tried it before and it didn’t work and for measure, we’re using limelight for the vision on our turret, so you’re basically putting in the angle the limelight detects in the measure parameter
this is the command that actually uses the trackTarget() method
package frc.robot.commands.turret;
import edu.wpi.first.wpilibj2.command.CommandBase;
import frc.robot.subsystems.Limelight;
import frc.robot.subsystems.Turret;
* Turns turret to keep vision target centered.
public class AutoAim extends CommandBase {
private final Turret turret;
private final Limelight limelight;
* Constructs new AutoAim command to turn turret to keep vision target centered.
* @param turret - Turret subsystem to use.
* @param limelight - Limelight subsystem to use.
public AutoAim(Turret turret, Limelight limelight) {
addRequirements(turret);
this.turret = turret;
this.limelight = limelight;
@Override
public void initialize() {
limelight.trackTarget();
@Override
public void execute() {
turret.trackTarget(limelight.getHorizontalAngle());
@Override
public boolean isFinished() {
return Math.abs(limelight.getHorizontalAngle()) < 0.5;
@Override
public void end(boolean interrupted) {
turret.set(0);
this is where the command is used/binded in the robot controller, (its under the new bindings method)
package frc.robot;
import java.io.IOException;
import edu.wpi.first.wpilibj.GenericHID.Hand;
import edu.wpi.first.wpilibj.GenericHID.RumbleType;
import edu.wpi.first.wpilibj.geometry.Pose2d;
import edu.wpi.first.wpilibj.smartdashboard.SendableChooser;
import edu.wpi.first.wpilibj2.command.Command;
import edu.wpi.first.wpilibj2.command.InstantCommand;
import edu.wpi.first.wpilibj2.command.RunCommand;
import frc.robot.commands.climb.FireBrake;
import frc.robot.commands.climb.ManualClimb;
import frc.robot.commands.drive.CenterBall;
import frc.robot.commands.drive.DriveCenterPort;
import frc.robot.commands.drive.FollowTrajectory;
import frc.robot.commands.auto.LTrenchSixBall;
import frc.robot.commands.auto.MTrenchSixBall;
import frc.robot.commands.auto.TrenchEightBall;
import frc.robot.commands.auto.WheelEightBall;
import frc.robot.commands.auto.WheelFiveBall;
import frc.robot.commands.hood.LowerHood;
import frc.robot.commands.hood.RaiseHood;
import frc.robot.commands.hood.ToggleHood;
import frc.robot.commands.intake.LowerIntake;
import frc.robot.commands.intake.RaiseIntake;
import frc.robot.commands.intake.SpinIndexer;
import frc.robot.commands.intake.SpinJustIntake;
import frc.robot.commands.intake.ToggleIntake;
import frc.robot.commands.magazine.AutoMagazine;
import frc.robot.commands.magazine.RunMagazine;
import frc.robot.commands.shooter.AutoFire;
import frc.robot.commands.shooter.AutoFireQuantity;
import frc.robot.commands.shooter.InMotionFire;
import frc.robot.commands.shooter.SpinShooter;
import frc.robot.commands.test.MotorTest;
import frc.robot.commands.turret.AutoAim;
import frc.robot.commands.turret.ManualTurret;
import frc.robot.commands.turret.TurretToAngle;
import frc.robot.commands.turret.ZeroTurret;
import frc.robot.subsystems.Climber;
import frc.robot.subsystems.Drivetrain;
import frc.robot.subsystems.Hood;
import frc.robot.subsystems.Intake;
import frc.robot.subsystems.IntakeCamera;
import frc.robot.subsystems.Magazine;
import frc.robot.subsystems.Shooter;
import frc.robot.utils.ButtonBox;
import frc.robot.utils.CspController;
import frc.robot.utils.CspSequentialCommandGroup;
import frc.robot.utils.KillAll;
import frc.robot.utils.TempManager;
import frc.robot.utils.Waypoints;
import frc.robot.utils.BrownoutProtection;
import frc.robot.utils.WaypointsList;
import frc.robot.utils.CspController.Scaling;
* Class containing setup for robot.
public class RobotContainer {
// subsystem initialization
private final Drivetrain drivetrain = new Drivetrain();
private final Magazine magazine = new Magazine();
private final Shooter shooter = new Shooter();
private final Turret turret = new Turret();
private final Climber climber = new Climber();
private final IntakeCamera camera = new IntakeCamera();
private final Intake intake = new Intake();
private final Hood hood = new Hood();
private final Limelight limelight = new Limelight();
private final TempManager tempManager = new TempManager(climber, drivetrain, intake, magazine, shooter, turret);
private final BrownoutProtection bop = new BrownoutProtection(drivetrain, intake, magazine, shooter, turret);
// controller initialization
private final CspController pilot = new CspController(0);
private final CspController copilot = new CspController(1);
//private final ButtonBox buttonBox = new ButtonBox(2);
// EMERGENCY POWER!!!!!!
// auto chooser initialization
private final SendableChooser<CspSequentialCommandGroup> autoChooser = new SendableChooser<CspSequentialCommandGroup>();
// state variables
private Pose2d initialPose = new Pose2d();
public TempManager getTempManager() {
return tempManager;
public BrownoutProtection getBrownoutProtection() {
return bop;
* Initializes robot subsystems, controllers, commands, and chooser.
* @throws IOException
public RobotContainer() throws IOException {
setDefaultCommands();
configureButtonBindings();
putChooser();
* Resets variables and sensors for each subsystem.
public void resetSubsystems() {
drivetrain.reset(initialPose);
turret.resetEncoders();
* Sets the default command for each subsystem, if applicable.
private void setDefaultCommands() {
drivetrain.setDefaultCommand(new RunCommand(
() -> drivetrain.arcade(pilot.getY(Hand.kLeft, Scaling.SQUARED), pilot.getX(Hand.kRight, Scaling.LINEAR), pilot.getBumper(Hand.kLeft)),
drivetrain));
turret.setDefaultCommand(new RunCommand(() -> turret.set(0.0), turret));;
//shooter.setDefaultCommand(new SpinShooter(shooter, 2500.0));
* Binds commands to buttons on controllers.
private void configureButtonBindings() {
newBindings();
//oldBindings();
pilot.getStartButtonObj().whenPressed(new KillAll());
copilotBindings();
copilot.getStartButtonObj().whenPressed(new KillAll());
buttonboxBindings();
putDashboardButtons();
private void copilotBindings() {
copilot.getAButtonObj().whenPressed(new InstantCommand(() -> climber.engagePneuBrake(true), climber));
copilot.getAButtonObj().whenReleased(new InstantCommand(() -> climber.engagePneuBrake(false), climber));
copilot.getXButtonObj().whileHeld(new RunMagazine(magazine, 1.0));
copilot.getXButtonObj().whenReleased(new RunMagazine(magazine, 0.0));
copilot.getYButtonObj().whenPressed(new FireBrake(climber));
copilot.getRtButtonObj().whileActiveContinuous(new AutoMagazine(magazine, intake, true, true));
copilot.getLtButtonObj().whileActiveContinuous(new AutoMagazine(magazine, intake, false, true));
copilot.getDpadLeftButtonObj().whileHeld(new ManualTurret(turret, 0.2));
copilot.getDpadLeftButtonObj().whenReleased(new ManualTurret(turret, 0));
copilot.getDpadRightButtonObj().whileHeld(new ManualTurret(turret, -0.2));
copilot.getDpadRightButtonObj().whenReleased(new ManualTurret(turret, 0));
copilot.getRbButtonObj().whileHeld(new ManualClimb(climber, -0.9));
copilot.getRbButtonObj().whenReleased(new ManualClimb(climber, 0));
copilot.getLbButtonObj().whileHeld(new ManualClimb(climber, 0.6));
copilot.getLbButtonObj().whenReleased(new ManualClimb(climber, 0));
copilot.getBackButtonObj().whenPressed(new ZeroTurret(turret));
private void newBindings() {
pilot.getRtButtonObj().whileActiveContinuous(new AutoMagazine(magazine, intake, true, true)).whenInactive(new AutoMagazine(magazine, intake, true, false));
pilot.getLtButtonObj().whileActiveContinuous(new AutoMagazine(magazine, intake, false, true)).whenInactive(new AutoMagazine(magazine, intake, false, false));
pilot.getRbButtonObj().whileHeld(new CenterBall(drivetrain, camera, () -> pilot.getY(Hand.kLeft)));
pilot.getDpadUpButtonObj().whenPressed(new ManualClimb(climber, -0.9)).whenReleased(new ManualClimb(climber, 0));
pilot.getDpadDownButtonObj().whileHeld(new ManualClimb(climber, 0.6)).whenReleased(new ManualClimb(climber, 0));
pilot.getDpadLeftButtonObj().whileHeld(new ManualTurret(turret, 0.2)).whenReleased(new ManualTurret(turret, 0));
pilot.getDpadRightButtonObj().whileHeld(new ManualTurret(turret, -0.2)).whenReleased(new ManualTurret(turret, 0));
pilot.getLsButtonObj().whenPressed(new LowerIntake(intake));
pilot.getRsButtonObj().whenPressed(new RaiseIntake(intake));
pilot.getYButtonObj().whileHeld(new AutoFire(drivetrain, shooter, magazine, intake, limelight, turret, hood, true));
pilot.getYButtonObj().whenReleased(new AutoFire(drivetrain, shooter, magazine, intake, limelight, turret, hood, false));
// pilot.getXButtonObj().whileHeld(new RunMagazine(magazine, -0.9));
// pilot.getXButtonObj().whenReleased(new RunMagazine(magazine, 0));
pilot.getXButtonObj().whenPressed(new TurretToAngle(turret, 30));
pilot.getBButtonObj().whenPressed(new AutoAim(turret, limelight));
private void oldBindings() {
// pilot.getRbButtonObj().whileHeld(new ManualClimb(climber, -0.9));
// pilot.getRbButtonObj().whenReleased(new ManualClimb(climber, 0));
pilot.getLbButtonObj().whileHeld(new RunCommand(() -> intake.spinIntake(1.0), intake));
pilot.getLbButtonObj().whenReleased(new RunCommand(() -> intake.spinIntake(0.0), intake));
pilot.getLtButtonObj().whileActiveContinuous(new ToggleHood(hood));
pilot.getLbButtonObj().whenPressed(new ToggleIntake(intake));
pilot.getDpadDownButtonObj().whenPressed(new LowerIntake(intake));
pilot.getDpadUpButtonObj().whenPressed(new RaiseIntake(intake));
pilot.getBButtonObj().whileHeld(new AutoMagazine(magazine, intake, true, true));
pilot.getBButtonObj().whenReleased(new AutoMagazine(magazine, intake, true, false));
pilot.getAButtonObj().whileHeld(new AutoMagazine(magazine, intake, false, true));
pilot.getAButtonObj().whenReleased(new AutoMagazine(magazine, intake, false, false));
private void putDashboardButtons() {
SmartDashboard.putData("Set Shooter PIDs", new RunCommand(() -> shooter.setPIDs(
SmartDashboard.getNumber("Set S P", 0.0),
SmartDashboard.getNumber("Set S I", 0.0),
SmartDashboard.getNumber("Set S D", 0.0)), shooter));
SmartDashboard.putData("Set Shooter Velocity", new RunCommand(() -> shooter.setVelocity(SmartDashboard.getNumber("Set S Velocity", 0.0)), shooter));
SmartDashboard.putData("Set Turret Angle PIDs", new InstantCommand(() -> turret.setPIDs(
SmartDashboard.getNumber("Set T Angle P", 0.0),
SmartDashboard.getNumber("Set T Angle I", 0.0),
SmartDashboard.getNumber("Set T Angle D", 0.0)), turret));
SmartDashboard.putData("Set Turret Angle", new TurretToAngle(turret, SmartDashboard.getNumber("Set T Angle", 0.0)));
SmartDashboard.putData("Rezero Turret", new ZeroTurret(turret));
SmartDashboard.putData("Rezero Odometry", new InstantCommand(() -> drivetrain.reset(initialPose), drivetrain));
private void buttonboxBindings() {
// buttonBox.getButton2Obj().whenPressed(new InstantCommand(() -> climber.engagePneuBrake(false), climber));
// buttonBox.getButton1Obj().whileHeld(new ManualClimb(climber, -0.9))
// .whenReleased(new ManualClimb(climber, 0.0));
// buttonBox.getButton3Obj().whileHeld(new ManualClimb(climber, 0.6))
// buttonBox.getButton4Obj().whenPressed(new RunMagazine(magazine, 0.625))
// .whenReleased(new RunMagazine(magazine, 0.0));
// buttonBox.getButton5Obj().whenPressed(new SpinShooter(shooter, 3500.0))
// .whenReleased(new SpinShooter(shooter, 2000.0));
// buttonBox.getButton6Obj().whenPressed(new TurretToAngle(turret, 0.0));
// buttonBox.getButton7Obj().whenPressed(new TurretToAngle(turret, 180.0));
// buttonBox.getButton8Obj().whileHeld(new RunCommand(() -> {
// intake.spin(0.0, 0.0);
// magazine.set(0.0);
// climber.set(0.0);
// turret.set(0.0);
// shooter.set(0.0);
// }, intake, magazine, climber, turret, shooter));
* Configures and places auto chooser on dashboard.
private void putChooser() throws IOException {
autoChooser.addOption("Do Nothing", null);
autoChooser.addOption("Left Trench 6-Ball (M)", new MTrenchSixBall(drivetrain, turret, shooter, magazine, intake, limelight));
autoChooser.addOption("Left Trench 6-Ball (L)", new LTrenchSixBall(drivetrain, shooter, intake, magazine, limelight, turret));
//autoChooser.addOption("Left Trench 8-Ball", new TrenchEightBall(drivetrain, turret, shooter, magazine, intake, limelight));
autoChooser.addOption("Wheel 5-Ball", new WheelFiveBall(drivetrain, magazine, intake, shooter, limelight, turret));
SmartDashboard.putData("Auto Chooser", autoChooser);
* Returns the currently selected command from the auto chooser and gets its initial pose.
public Command getAutoCommand() {
Command autoCommand = autoChooser.getSelected();
if (autoCommand != null) {
initialPose = autoChooser.getSelected().getInitialPose();
} else {
return autoCommand;
public Command getTestCommand() {
return new MotorTest(shooter, intake, magazine, turret);
