Setting default tile size for shuffleboard in code
Hi all. We’ve been using shuffleboard this year for calibration purposes, but instead of manually positioning objects and saving a layout we’ve been defining the layout in code so we get the same dashboard on every computer. To accommodate different resolutions (since you can’t scroll in shuffleboard) we’ve changed the default tile size in the application. We haven’t seen a way to change this in code though, meaning we’d have to manually change the value every time we open shuffleboard. Is there any way to set tab preferences in code? Or, is there another way to resize shuffleboard programatically? Thanks in advance!
you can set the position in code, maybe looking at the API could yield some results in terms of scaling. Maybe @Oblarg could say if his annotations have this feature.
The Shuffleboard API does not currently support changing global or tab-specific properties
