Setting motor speed
How do you set a reduced power/speed to a motor or do you set a variable to the joystick.
If it’s based on a joystick axis, then just multiply the axis output by the percentage maximum power you want before you send it to the motor, e.g., (axis 1 * .7 = 70% power)
Mark how can I do that. Thank you for your help
Here’s an example: http://www.team358.org/files/programming/ControlSystem2015-2019/labview/index.php#JoystickMaxThrottle
The right half is a simple throttle limit.
Thanks Mark
